To build modern and responsive graphical user interfaces (GUIs) for CVB applications using CVB.NET, the Windows Presentation Foundation (WPF) framework provides a flexible and powerful foundation.
Prerequisites
Before starting, ensure that you have installed the necessary prerequisites listed in the CVB.NET Getting Started Guide.
Creating the application
Using Visual Studio, create a new application using the WPF Application project template.
Next, add a reference to the following two dlls, located in your CVB installation directory under %CVB%\Lib\net:
- Stemmer.Cvb.dll
- Stemmer.Cvb.Wpf.dll
Using the Display Control
CVB.NET provides a native WPF Display Control, found in the Stemmer.Cvb.Wpf namespace. To use this control in xaml code, you will need to add a xaml using: xmlns:cvb="http://www.commonvisionblox.com/wpf"
<Window x:Class="WpfExample.MainWindow"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:local="clr-namespace:WpfExample"
mc:Ignorable="d"
Title="MainWindow" Height="450" Width="800">
<Grid>
<cvb:Display x:Name="myDisplay"/>
</Grid>
</Window>
You can then assign an image to the display in the code-behind (MainWindow.xaml.cs) of the xaml file:
using System.Windows;
namespace WpfExample
public partial class MainWindow : Window
public MainWindow()
InitializeComponent();
myDisplay.Image =
Image.
FromFile(
"C:\\path\\to\\your\\image.bmp");
Using the Display Control with MVVM
WPF is able to strongly leverage the Model-View-ViewModel (MVVM) design approach, which helps to seperate UI- and business logic. MVVM also makes it easy to communicate data changes to the UI to automatically redraw it. For that, Bindings and the INotifyPropertyChanged interface are used. In this example the CVB Display uses a Binding to connect its Image property to the DisplayImage property of the MainViewModel.
mc:Ignorable="d"
<Window.DataContext>
<local:MainViewModel/>
</Window.DataContext>
<Grid>
<cvb:Display Image="{Binding DisplayImage}"/>
</Grid>
</Window>
You then create a ViewModel for the View which acts as a bridge between your UI and business logic.
using System.ComponentModel;
using System.Runtime.CompilerServices;
internal class MainViewModel : INotifyPropertyChanged
#region INotifyPropertyChanged Implementation
public event PropertyChangedEventHandler PropertyChanged;
protected void NotifyOfPropertyChange([CallerMemberName] string propertyName = "")
PropertyChanged?.Invoke(this, new PropertyChangedEventArgs(propertyName));
#endregion INotifyPropertyChanged Implementation
public Image DisplayImage
get => _displayImage;
set
if (_displayImage != value)
_displayImage = value;
NotifyOfPropertyChange();
private Image _displayImage;
public MainViewModel()
DisplayImage = Image.
FromFile(
Example Programs
Your CVB installation includes several example programs demonstrating the integration of CVB.NET with WPF. They are located under %CVB%\Tutorial. Look for examples that contain .xaml files.
