Device Discovery - Third Party VIN Driver
Discovering devices using VIN drivers can be done using the Cvb::DeviceFactory::Discover.
The exact details of what each device reports depends on the exact implementation of the VIN driver in question. For more details, refer to the driver documentation.
auto discoveredDevices = Cvb::DeviceFactory::Discover(Cvb::DiscoverFlags::IgnoreTLs); // (1)
auto chosenDiscoveryInformation = discoveredDevices[0]; // (2)
auto device = Cvb::DeviceFactory::Open<Cvb::VinDevice>(chosenDiscoveryInformation->AccessToken(), Cvb::AcquisitionStack::PreferVin); // (3)
// Configure device
// Start acquisition and streaming
using (var discoveredDevices = DeviceFactory.Discover(DiscoverFlags.IgnoreTLs)) // (1)
var chosenDiscoveryInformation = discoveredDevices[0]; // (2)
using (var device = (VinDevice)DeviceFactory.Open(chosenDiscoveryInformation, AcquisitionStack.PreferVin)) // (3)
// Configure device
discoveredDevices = cvb.DeviceFactory.discover_from_root(cvb.DiscoverFlags.IgnoreTLs) # (1)
chosenDiscoveryInformation = discoveredDevices[0] # (2)
with cvb.DeviceFactory.open(chosenDiscoveryInformation.access_token, cvb.AcquisitionStack.PreferVin) as device: # (3)
# Configure device
# Start acquisition and streaming
  1. Discover all VIN devices. By default all devices are discovered so by using the Cvb::DiscoverFlags::IgnoreTLs flag, the GenTL devices are excluded.
  2. Filter the found discovery information to select the correct one. As the reported data depends on the VIN driver in question, the first is selected for simplicity.
  3. Open the device as a Cvb::VinDevice using Cvb::AcquisitionStack::PreferVin.
