Acquisition and Streaming - Single Stream
using namespace Cvb;
auto devices = DeviceFactory::Discover(DiscoverFlags::IgnoreVins); // (1)
auto device = DeviceFactory::Open<GenICamDevice>(devices[0].AccessToken(),
AcquisitionStack::GenTL); // (2)
auto stream = device->Stream<ImageStream>(); // default: index = 0 (3)
stream->Start(); // (4)
while(true)
ImagePtr image;
WaitStatus status;
std::tie(image, status, nodeMaps) = stream->Wait(); // (5)
//Process image
stream->Abort(); // (6)
void Start() override
WaitStatus
using (var devices = DeviceFactory.Discover(DiscoverFlags.IgnoreVins)) // (1)
using (var device = (GenICamDevice)DeviceFactory.Open(devices[0], AcquisitionStack.GenTL)) // (2)
var stream = device.GetStream<ImageStream>(0); // (3)
stream.Start(); // (4)
while(true) {
WaitStatus status;
using (var image = stream.Wait(out status)) // (5)
//Process image
stream.Abort(); // (6)
devices = cvb.DeviceFactory.discover_from_root(cvb.DiscoverFlags.IgnoreVins) # (1)
with cvb.DeviceFactory.open(devices[0].access_token, cvb.AcquisitionStack.GenTL) as device: # (2)
stream = device.stream(cvb.ImageStream) # default: index = 0 (3)
stream.start() # (4)
while True:
image, status, node_maps = stream.wait() # (5)
# Process image
stream.abort() # (6)
  1. All devices are discovered across all interfaces and transport layers except for the legacy VIN transport layers.
  2. The first discovered device is opened using the GenTL acquisition stack and internally allocated buffers.
  3. A data stream is instantiated with index zero (default; when working with devices with more than one stream, the stream index could be passed as parameter).
  4. The stream acquisition is simplified to the combined start, which advises the driver to start the acquisition engine and stream control mechanism automatically. A user does not have to call these separate streaming components separately unless they want to. By default, infinite acquisition is started. After starting the stream, the stream engine and control are running in the background until the stream is stopped, sending a continuous flow of images or composites.
  5. Each image will need to be proactively waited for by means of a call to wait on the stream. The returned tuple consists of three components: the actual image, a status code and a nodemap enumerator.
  6. The abort operation immediately stops the ongoing stream.
