Some devices may be able to provide multiple pieces of data in a single data streams. For example, there could be a camera that sends two pieces of data, one being a color image and the seconds some metadata such as timestamp and location. As these two pieces of information are different but related (unlike a camera sending two data streams), these will be presented as a single Cvb::Composite object.
while(true)
std::tie(composite, status, nodeMaps) = stream->Wait();
for (int i = 0; i < composite->ItemCount(); i++)
auto component = composite->ItemAt(i);
if (auto image = get_if<ImagePtr>(&component))
else if (auto pointCloud = get_if<PointCloudPtr>(&component))
stream->Abort();
while(true) {
foreach (var part in composite)
if (part.GetType() == typeof(
Image)) {
stream.Abort();
static Image FromHandle(IntPtr nativeHandle)
static PointCloud FromHandle(IntPtr handle, ShareObject doShare)
cvbbool_t ShareObject(OBJ Object)
while True:
with composite:
for part in composite:
stream.abort()
Note: In this example, we treat each component as potentially being a different type on each frame. In reality, for a specific camera model, the component type at each index should not change type (i.e. item 1 is always the image, item 2 is the metadata, etc).
- The device and stream are opened as normal. To ensure that all components can be received, the stream must be of type
Cvb::CompositeStream.
- The composite is read from the stream in the same manner as a normal image.
- Each component of a
Cvb::Composite has a specified type, Cvb::Image, Cvb::PointCloud, etc. The type of the component is checked to determine how to process it.
