RTPStreaming/Cvb++/CppRTPStreaming
This example program is located in your CVB installation under %CVB%Tutorial/RTPStreaming/Cvb++/CppRTPStreaming.
DeviceSimulator.cpp:
#include "DeviceSimulator.hpp"
#include <cvb/block.hpp>
#include <cvb/global.hpp>
// helper method to create test pattern images
static std::vector<std::shared_ptr<Cvb::Image>> CreateImages(size_t count) {
std::vector<std::shared_ptr<Cvb::Image>> images;
images.reserve(count);
std::generate_n(std::back_inserter(images), count, [count, i = 0]() mutable {
Cvb::PfncFormat::RGB8);
Cvb::VisitAs<uint8_t>(
[i, count](auto red, auto green, auto blue) {
for (int y = 0; y < red.Height(); ++y)
for (int x = 0; x < red.Width(); ++x) {
red(x, y) = static_cast<uint8_t>(i + x + y);
green(x, y) = static_cast<uint8_t>((count - 1 - i) + x + y);
blue(x, y) = static_cast<uint8_t>(i + x + y + 128);
image->Plane(0), image->Plane(1), image->Plane(2));
++i;
return image;
return images;
DeviceSimulator::DeviceSimulator(size_t numImages) {
_images = CreateImages(numImages);
std::shared_ptr<Cvb::Image> DeviceSimulator::GetNextImage() {
const std::shared_ptr<Cvb::Image> img = _images[_currentImageIndex];
if (++_currentImageIndex >= _images.size())
_currentImageIndex = 0;
return img;
static std::unique_ptr< Image > FromPixelFormat(const Cvb::Size2D< int > &size, Cvb::PfncFormat format)
DeviceSimulator.hpp:
#include <vector>
// Simple helper class to 'simulate' a camera.
class DeviceSimulator {
DeviceSimulator(size_t numImages);
std::shared_ptr<Cvb::Image> GetNextImage();
private:
std::vector<std::shared_ptr<Cvb::Image>> _images;
int _currentImageIndex = 0;
// Example for RTP streaming.
#include <chrono>
#include <exception>
#include <fstream>
#include <future>
#include <string>
#include <vector>
#include <cvb/rtpstreaming/rtpstreaming.hpp>
#include <cvb/rtpstreaming/stream.hpp>
#include <cvb/rtpstreaming/stream_config.hpp>
// flag to cancel the streaming
std::atomic<bool> cancelFlag(false);
// Waits for 'Enter' key to be pressed
void CheckForCancel() {
std::cin.get();
cancelFlag.store(true);
// create stream configuration
auto config = Cvb::RTPStreaming::StreamConfig::Create();
config->SetDstAddr("127.0.0.1");
config->SetDstPort(6005);
// load preconfigured h264 configuration
auto codecFile =
Cvb::String(CVB_LIT("tutorial\\RTPStreaming\\Images\\h264.json"));
std::ifstream codecFileStream(codecFile);
if (!codecFileStream)
throw std::runtime_error("h264.json file not found");
std::stringstream buffer;
buffer << codecFileStream.rdbuf();
config->SetupCodecFromJSON(buffer.str());
// write sdp file for ffplay
auto sdp = config->ReadSessionDescriptionProtocol();
std::ofstream sdpFile("h264.sdp");
sdpFile << sdp;
sdpFile.close();
std::cout << "Wrote h264.sdp file to the current working directory"
<< std::endl;
// create stream with config
auto stream = Cvb::RTPStreaming::Stream::Create(*config);
// create test images (4 seconds with the preconfigured 25 fps)
auto deviceSim = DeviceSimulator(100);
std::cout.clear();
std::cout << "Stream successfully set up. You should now start ffplay to "
"receive the stream images."
<< std::endl;
std::cout << "ffplay should be started via the command line like this: "
<< std::endl;
std::cout << "ffplay -protocol_whitelist rtp,file,udp -i h264.sdp"
<< std::endl;
std::cout << "Press 'Enter' once ffplay is running to continue"
<< std::endl;
// wait for user input
std::cin.get();
std::cout << "Streaming images... press 'Enter' to stop streaming"
<< std::endl;
std::thread cancelThread(CheckForCancel);
// stream the images
auto streamTask = std::async(std::launch::async, [&]() {
while (!cancelFlag.load()) {
auto start = std::chrono::high_resolution_clock::now();
stream->PushImage(*deviceSim.GetNextImage());
auto end = std::chrono::high_resolution_clock::now();
// calculate frame delay
// stream is preconfigured via the json file with 25 fps (which
// corresponds to a period of 40ms) additionally, subtract measured
// encoding length
std::this_thread::sleep_for(std::chrono::milliseconds(40) -
(end - start));
// Wait for 'Enter' to be pressed to cancel
cancelThread.join();
// Wait for the asynchronous task to finish
streamTask.wait();
std::string msg = e.what();
if (msg.find("avutil") != std::string::npos)
std::cout << "FFmpeg not found. Make sure you have installed FFmpeg and "
"added it to your PATH environment variable. Error message: "
<< msg << std::endl;
std::cout << msg << std::endl;
static std::unique_ptr< Stream > Create(const StreamConfig &streamConfig)
