GEVServer/Cvb++/CLIGevServerSpeedtest
This example program is located in your CVB installation under %CVB%Tutorial/GEVServer/Cvb++/CLIGevServerSpeedtest.
CLI11.hpp:
// CLI11: Version 2.5.0
// Originally designed by Henry Schreiner
// https://github.com/CLIUtils/CLI11
// This is a standalone header file generated by MakeSingleHeader.py in
// CLI11/scripts from: v2.5.0
// CLI11 2.5.0 Copyright (c) 2017-2025 University of Cincinnati, developed by
// Henry Schreiner under NSF AWARD 1414736. All rights reserved.
// Redistribution and use in source and binary forms of CLI11, with or without
// modification, are permitted provided that the following conditions are met:
// 1. Redistributions of source code must retain the above copyright notice,
// this
// list of conditions and the following disclaimer.
// 2. Redistributions in binary form must reproduce the above copyright notice,
// this list of conditions and the following disclaimer in the documentation
// and/or other materials provided with the distribution.
// 3. Neither the name of the copyright holder nor the names of its contributors
// may be used to endorse or promote products derived from this software
// without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
// AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
// ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
// LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
// CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
// CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
// ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
// POSSIBILITY OF SUCH DAMAGE.
#pragma once
// Standard combined includes:
#include <algorithm>
#include <array>
#include <cctype>
#include <clocale>
#include <cmath>
#include <cstdint>
#include <cstdlib>
#include <cstring>
#include <cwchar>
#include <exception>
#include <fstream>
#include <functional>
#include <iomanip>
#include <iterator>
#include <limits>
#include <locale>
#include <map>
#include <memory>
#include <numeric>
#include <set>
#include <sstream>
#include <stdexcept>
#include <string>
#include <tuple>
#include <type_traits>
#include <utility>
#include <vector>
#define CLI11_VERSION_MAJOR 2
#define CLI11_VERSION_MINOR 5
#define CLI11_VERSION_PATCH 0
#define CLI11_VERSION "2.5.0"
// The following version macro is very similar to the one in pybind11
#if !(defined(_MSC_VER) && __cplusplus == 199711L) && !defined(__INTEL_COMPILER)
#if __cplusplus >= 201402L
#define CLI11_CPP14
#if __cplusplus >= 201703L
#define CLI11_CPP17
#if __cplusplus > 201703L
#define CLI11_CPP20
#if __cplusplus > 202002L
#define CLI11_CPP23
#if __cplusplus > 202302L
#define CLI11_CPP26
#endif
#endif
#endif
#endif
#endif
#elif defined(_MSC_VER) && __cplusplus == 199711L
// MSVC sets _MSVC_LANG rather than __cplusplus (supposedly until the standard
// was fully implemented) Unless you use the /Zc:__cplusplus flag on Visual
// Studio 2017 15.7 Preview 3 or newer
#if _MSVC_LANG >= 201402L
#define CLI11_CPP14
#if _MSVC_LANG > 201402L && _MSC_VER >= 1910
#define CLI11_CPP17
#if _MSVC_LANG > 201703L && _MSC_VER >= 1910
#define CLI11_CPP20
#if _MSVC_LANG > 202002L && _MSC_VER >= 1922
#define CLI11_CPP23
#endif
#endif
#endif
#endif
#endif
#if defined(CLI11_CPP14)
#define CLI11_DEPRECATED(reason) [[deprecated(reason)]]
#define CLI11_DEPRECATED(reason) __declspec(deprecated(reason))
#else
#define CLI11_DEPRECATED(reason) __attribute__((deprecated(reason)))
#endif
// GCC < 10 doesn't ignore this in unevaluated contexts
#if !defined(CLI11_CPP17) || \
(defined(__GNUC__) && !defined(__llvm__) && !defined(__INTEL_COMPILER) && \
__GNUC__ < 10 && __GNUC__ > 4)
#define CLI11_NODISCARD
#else
#define CLI11_NODISCARD [[nodiscard]]
#endif
#ifndef CLI11_USE_STATIC_RTTI
#if (defined(_HAS_STATIC_RTTI) && _HAS_STATIC_RTTI)
#define CLI11_USE_STATIC_RTTI 1
#elif defined(__cpp_rtti)
#if (defined(_CPPRTTI) && _CPPRTTI == 0)
#else
#define CLI11_USE_STATIC_RTTI 0
#endif
#elif (defined(__GCC_RTTI) && __GXX_RTTI)
#else
#endif
#endif
#if defined CLI11_CPP17 && defined __has_include && \
!defined CLI11_HAS_FILESYSTEM
#if __has_include(<filesystem>)
// Filesystem cannot be used if targeting macOS < 10.15
#if defined __MAC_OS_X_VERSION_MIN_REQUIRED && \
__MAC_OS_X_VERSION_MIN_REQUIRED < 101500
#define CLI11_HAS_FILESYSTEM 0
#elif defined(__wasi__)
// As of wasi-sdk-14, filesystem is not implemented
#else
#include <filesystem>
#if defined __cpp_lib_filesystem && __cpp_lib_filesystem >= 201703
#if defined _GLIBCXX_RELEASE && _GLIBCXX_RELEASE >= 9
#define CLI11_HAS_FILESYSTEM 1
#elif defined(__GLIBCXX__)
// if we are using gcc and Version <9 default to no filesystem
#else
#endif
#else
#endif
#endif
#endif
#endif
#if !defined(CLI11_CPP26) && !defined(CLI11_HAS_CODECVT)
#if defined(__GNUC__) && !defined(__llvm__) && !defined(__INTEL_COMPILER) && \
__GNUC__ < 5
#define CLI11_HAS_CODECVT 0
#else
#define CLI11_HAS_CODECVT 1
#include <codecvt>
#endif
#else
#if defined(CLI11_HAS_CODECVT)
#if CLI11_HAS_CODECVT > 0
#include <codecvt>
#endif
#else
#endif
#endif
#if defined(__GNUC__) // GCC or clang
#define CLI11_DIAGNOSTIC_PUSH _Pragma("GCC diagnostic push")
#define CLI11_DIAGNOSTIC_POP _Pragma("GCC diagnostic pop")
#define CLI11_DIAGNOSTIC_IGNORE_DEPRECATED \
_Pragma("GCC diagnostic ignored \"-Wdeprecated-declarations\"")
#define CLI11_DIAGNOSTIC_PUSH __pragma(warning(push))
#define CLI11_DIAGNOSTIC_POP __pragma(warning(pop))
#define CLI11_DIAGNOSTIC_IGNORE_DEPRECATED __pragma(warning(disable : 4996))
#else
#endif
#ifdef CLI11_COMPILE
#define CLI11_INLINE
#else
#define CLI11_INLINE inline
#endif
#if defined CLI11_HAS_FILESYSTEM && CLI11_HAS_FILESYSTEM > 0
#include <filesystem> // NOLINT(build/include)
#else
#include <sys/stat.h>
#include <sys/types.h>
#endif
#ifdef CLI11_CPP17
#include <string_view>
#endif // CLI11_CPP17
#include <string_view> // NOLINT(build/include)
#endif // CLI11_HAS_FILESYSTEM
#if defined(_WIN32)
#if !(defined(_AMD64_) || defined(_X86_) || defined(_ARM_))
#if defined(__amd64__) || defined(__amd64) || defined(__x86_64__) || \
defined(__x86_64) || defined(_M_X64) || defined(_M_AMD64)
#define _AMD64_
#elif defined(i386) || defined(__i386) || defined(__i386__) || \
defined(__i386__) || defined(_M_IX86)
#define _X86_
#elif defined(__arm__) || defined(_M_ARM) || defined(_M_ARMT)
#define _ARM_
#elif defined(__aarch64__) || defined(_M_ARM64)
#define _ARM64_
#elif defined(_M_ARM64EC)
#define _ARM64EC_
#endif
#endif
// first
#ifndef NOMINMAX
// if NOMINMAX is already defined we don't want to mess with that either way
#define NOMINMAX
#include <windef.h>
#undef NOMINMAX
#else
#include <windef.h>
#endif
// second
#include <winbase.h>
// third
#include <processthreadsapi.h>
#include <shellapi.h>
#endif
namespace CLI {
CLI11_INLINE std::string narrow(const std::wstring &str);
CLI11_INLINE std::string narrow(const wchar_t *str);
CLI11_INLINE std::string narrow(const wchar_t *str, std::size_t size);
CLI11_INLINE std::wstring widen(const std::string &str);
CLI11_INLINE std::wstring widen(const char *str);
CLI11_INLINE std::wstring widen(const char *str, std::size_t size);
#ifdef CLI11_CPP17
CLI11_INLINE std::string narrow(std::wstring_view str);
CLI11_INLINE std::wstring widen(std::string_view str);
CLI11_INLINE std::filesystem::path to_path(std::string_view str);
namespace detail {
#if !CLI11_HAS_CODECVT
CLI11_INLINE void set_unicode_locale() {
static const std::array<const char *, 3> unicode_locales{
{"C.UTF-8", "en_US.UTF-8", ".UTF-8"}};
for (const auto &locale_name : unicode_locales) {
if (std::setlocale(LC_ALL, locale_name) != nullptr) {
throw std::runtime_error("CLI::narrow: could not set locale to C.UTF-8");
template <typename F> struct scope_guard_t {
F closure;
explicit scope_guard_t(F closure_) : closure(closure_) {}
~scope_guard_t() { closure(); }
CLI11_NODISCARD CLI11_INLINE scope_guard_t<F> scope_guard(F &&closure) {
return scope_guard_t<F>{std::forward<F>(closure)};
#endif // !CLI11_HAS_CODECVT
CLI11_INLINE std::string narrow_impl(const wchar_t *str, std::size_t str_size) {
#ifdef _WIN32
return std::wstring_convert<std::codecvt_utf8_utf16<wchar_t>>().to_bytes(
str, str + str_size);
#else
return std::wstring_convert<std::codecvt_utf8<wchar_t>>().to_bytes(
#endif // _WIN32
#else // CLI11_HAS_CODECVT
(void)str_size;
std::mbstate_t state = std::mbstate_t();
const wchar_t *it = str;
std::string old_locale = std::setlocale(LC_ALL, nullptr);
auto sg = scope_guard([&] { std::setlocale(LC_ALL, old_locale.c_str()); });
set_unicode_locale();
std::size_t new_size = std::wcsrtombs(nullptr, &it, 0, &state);
if (new_size == static_cast<std::size_t>(-1)) {
"CLI::narrow: conversion error in std::wcsrtombs at offset " +
std::to_string(it - str));
std::string result(new_size, '\0');
std::wcsrtombs(const_cast<char *>(result.data()), &str, new_size, &state);
return result;
#endif // CLI11_HAS_CODECVT
CLI11_INLINE std::wstring widen_impl(const char *str, std::size_t str_size) {
#ifdef _WIN32
return std::wstring_convert<std::codecvt_utf8_utf16<wchar_t>>().from_bytes(
#else
return std::wstring_convert<std::codecvt_utf8<wchar_t>>().from_bytes(
#endif // _WIN32
(void)str_size;
const char *it = str;
std::size_t new_size = std::mbsrtowcs(nullptr, &it, 0, &state);
"CLI::widen: conversion error in std::mbsrtowcs at offset " +
std::wstring result(new_size, L'\0');
std::mbsrtowcs(const_cast<wchar_t *>(result.data()), &str, new_size, &state);
return result;
} // namespace detail
CLI11_INLINE std::string narrow(const wchar_t *str, std::size_t str_size) {
return detail::narrow_impl(str, str_size);
CLI11_INLINE std::string narrow(const std::wstring &str) {
return detail::narrow_impl(str.data(), str.size());
// Flawfinder: ignore
CLI11_INLINE std::string narrow(const wchar_t *str) {
return detail::narrow_impl(str, std::wcslen(str));
CLI11_INLINE std::wstring widen(const char *str, std::size_t str_size) {
return detail::widen_impl(str, str_size);
CLI11_INLINE std::wstring widen(const std::string &str) {
return detail::widen_impl(str.data(), str.size());
CLI11_INLINE std::wstring widen(const char *str) {
return detail::widen_impl(str, std::strlen(str));
#ifdef CLI11_CPP17
CLI11_INLINE std::string narrow(std::wstring_view str) {
CLI11_INLINE std::wstring widen(std::string_view str) {
CLI11_INLINE std::filesystem::path to_path(std::string_view str) {
return std::filesystem::path{
#ifdef _WIN32
widen(str)
#else
str
#endif // _WIN32
namespace detail {
#ifdef _WIN32
CLI11_INLINE std::vector<std::string> compute_win32_argv();
#endif
namespace detail {
#ifdef _WIN32
CLI11_INLINE std::vector<std::string> compute_win32_argv() {
std::vector<std::string> result;
int argc = 0;
auto deleter = [](wchar_t **ptr) { LocalFree(ptr); };
// NOLINTBEGIN(*-avoid-c-arrays)
auto wargv = std::unique_ptr<wchar_t *[], decltype(deleter)>(
CommandLineToArgvW(GetCommandLineW(), &argc), deleter);
// NOLINTEND(*-avoid-c-arrays)
if (wargv == nullptr) {
throw std::runtime_error("CommandLineToArgvW failed with code " +
std::to_string(GetLastError()));
result.reserve(static_cast<size_t>(argc));
for (size_t i = 0; i < static_cast<size_t>(argc); ++i) {
result.push_back(narrow(wargv[i]));
return result;
#endif
namespace enums {
template <typename T,
typename = typename std::enable_if<std::is_enum<T>::value>::type>
std::ostream &operator<<(std::ostream &in, const T &item) {
// make sure this is out of the detail namespace otherwise it won't be found
// when needed
return in << static_cast<typename std::underlying_type<T>::type>(item);
} // namespace enums
using enums::operator<<;
namespace detail {
constexpr int expected_max_vector_size{1 << 29};
// Based on http://stackoverflow.com/questions/236129/split-a-string-in-c
CLI11_INLINE std::vector<std::string> split(const std::string &s, char delim);
template <typename T> std::string join(const T &v, std::string delim = ",") {
std::ostringstream s;
auto beg = std::begin(v);
auto end = std::end(v);
if (beg != end)
s << *beg++;
while (beg != end) {
s << delim << *beg++;
auto rval = s.str();
if (!rval.empty() && delim.size() == 1 && rval.back() == delim[0]) {
// remove trailing delimiter if the last entry was empty
rval.pop_back();
return rval;
template <typename T, typename Callable,
!std::is_constructible<std::string, Callable>::value>::type>
std::string join(const T &v, Callable func, std::string delim = ",") {
auto loc = s.tellp();
auto nloc = s.tellp();
if (nloc > loc) {
s << delim;
loc = nloc;
s << func(*beg++);
return s.str();
template <typename T> std::string rjoin(const T &v, std::string delim = ",") {
for (std::size_t start = 0; start < v.size(); start++) {
if (start > 0)
s << delim;
s << v[v.size() - start - 1];
return s.str();
// Based roughly on
// http://stackoverflow.com/questions/25829143/c-trim-whitespace-from-a-string
CLI11_INLINE std::string &ltrim(std::string &str);
CLI11_INLINE std::string &ltrim(std::string &str, const std::string &filter);
CLI11_INLINE std::string &rtrim(std::string &str);
CLI11_INLINE std::string &rtrim(std::string &str, const std::string &filter);
inline std::string &trim(std::string &str) { return ltrim(rtrim(str)); }
inline std::string &trim(std::string &str, const std::string filter) {
return ltrim(rtrim(str, filter), filter);
inline std::string trim_copy(const std::string &str) {
std::string s = str;
return trim(s);
CLI11_INLINE std::string &remove_quotes(std::string &str);
CLI11_INLINE void remove_quotes(std::vector<std::string> &args);
CLI11_INLINE std::string fix_newlines(const std::string &leader,
std::string input);
inline std::string trim_copy(const std::string &str,
const std::string &filter) {
return trim(s, filter);
CLI11_INLINE std::ostream &
format_aliases(std::ostream &out, const std::vector<std::string> &aliases,
std::size_t wid);
template <typename T> bool valid_first_char(T c) {
return ((c != '-') &&
(static_cast<unsigned char>(c) > 33)); // space and '!' not allowed
template <typename T> bool valid_later_char(T c) {
// = and : are value separators, { has special meaning for option defaults,
// and control codes other than tab would just be annoying to deal with in
// many places allowing space here has too much potential for inadvertent
// entry errors and bugs
return ((c != '=') && (c != ':') && (c != '{') &&
((static_cast<unsigned char>(c) > 32) || c == '\t'));
CLI11_INLINE bool valid_name_string(const std::string &str);
inline bool valid_alias_name_string(const std::string &str) {
static const std::string badChars(std::string("\n") + '\0');
return (str.find_first_of(badChars) == std::string::npos);
inline bool is_separator(const std::string &str) {
static const std::string sep("%%");
return (str.empty() || str == sep);
inline bool isalpha(const std::string &str) {
return std::all_of(str.begin(), str.end(),
[](char c) { return std::isalpha(c, std::locale()); });
inline std::string to_lower(std::string str) {
std::transform(std::begin(str), std::end(str), std::begin(str),
[](const std::string::value_type &x) {
return std::tolower(x, std::locale());
return str;
inline std::string remove_underscore(std::string str) {
str.erase(std::remove(std::begin(str), std::end(str), '_'), std::end(str));
return str;
CLI11_INLINE std::string find_and_replace(std::string str, std::string from,
std::string to);
inline bool has_default_flag_values(const std::string &flags) {
return (flags.find_first_of("{!") != std::string::npos);
CLI11_INLINE void remove_default_flag_values(std::string &flags);
CLI11_INLINE std::ptrdiff_t find_member(std::string name,
const std::vector<std::string> names,
bool ignore_case = false,
bool ignore_underscore = false);
template <typename Callable>
inline std::string find_and_modify(std::string str, std::string trigger,
Callable modify) {
std::size_t start_pos = 0;
while ((start_pos = str.find(trigger, start_pos)) != std::string::npos) {
start_pos = modify(str, start_pos);
return str;
CLI11_INLINE std::size_t close_sequence(const std::string &str,
std::size_t start, char closure_char);
CLI11_INLINE std::vector<std::string> split_up(std::string str,
char delimiter = '\0');
CLI11_INLINE std::string get_environment_value(const std::string &env_name);
CLI11_INLINE std::size_t escape_detect(std::string &str, std::size_t offset);
CLI11_INLINE bool has_escapable_character(const std::string &str);
CLI11_INLINE std::string add_escaped_characters(const std::string &str);
CLI11_INLINE std::string remove_escaped_characters(const std::string &str);
binary_escape_string(const std::string &string_to_escape);
CLI11_INLINE bool is_binary_escaped_string(const std::string &escaped_string);
extract_binary_string(const std::string &escaped_string);
CLI11_INLINE bool process_quoted_string(std::string &str,
char string_char = '\"',
char literal_char = '\'');
CLI11_INLINE std::ostream &streamOutAsParagraph(
std::ostream &out, const std::string &text, std::size_t paragraphWidth,
const std::string &linePrefix = "", bool skipPrefixOnFirstLine = false);
namespace detail {
CLI11_INLINE std::vector<std::string> split(const std::string &s, char delim) {
std::vector<std::string> elems;
// Check to see if empty string, give consistent result
if (s.empty()) {
elems.emplace_back();
} else {
std::stringstream ss;
ss.str(s);
std::string item;
while (std::getline(ss, item, delim)) {
elems.push_back(item);
return elems;
CLI11_INLINE std::string &ltrim(std::string &str) {
auto it = std::find_if(str.begin(), str.end(), [](char ch) {
return !std::isspace<char>(ch, std::locale());
str.erase(str.begin(), it);
return str;
CLI11_INLINE std::string &ltrim(std::string &str, const std::string &filter) {
auto it = std::find_if(str.begin(), str.end(), [&filter](char ch) {
return filter.find(ch) == std::string::npos;
return str;
CLI11_INLINE std::string &rtrim(std::string &str) {
auto it = std::find_if(str.rbegin(), str.rend(), [](char ch) {
str.erase(it.base(), str.end());
return str;
CLI11_INLINE std::string &rtrim(std::string &str, const std::string &filter) {
auto it = std::find_if(str.rbegin(), str.rend(), [&filter](char ch) {
return str;
CLI11_INLINE std::string &remove_quotes(std::string &str) {
if (str.length() > 1 &&
(str.front() == '"' || str.front() == '\'' || str.front() == '`')) {
if (str.front() == str.back()) {
str.pop_back();
str.erase(str.begin(), str.begin() + 1);
return str;
CLI11_INLINE std::string &remove_outer(std::string &str, char key) {
if (str.length() > 1 && (str.front() == key)) {
str.pop_back();
return str;
std::string input) {
std::string::size_type n = 0;
while (n != std::string::npos && n < input.size()) {
n = input.find('\n', n);
if (n != std::string::npos) {
input = input.substr(0, n + 1) + leader + input.substr(n + 1);
n += leader.size();
return input;
std::size_t wid) {
if (!aliases.empty()) {
out << std::setw(static_cast<int>(wid)) << " aliases: ";
bool front = true;
for (const auto &alias : aliases) {
if (!front) {
out << ", ";
} else {
front = false;
out << detail::fix_newlines(" ", alias);
out << "\n";
return out;
CLI11_INLINE bool valid_name_string(const std::string &str) {
if (str.empty() || !valid_first_char(str[0])) {
return false;
auto e = str.end();
for (auto c = str.begin() + 1; c != e; ++c)
if (!valid_later_char(*c))
return false;
return true;
std::string to) {
while ((start_pos = str.find(from, start_pos)) != std::string::npos) {
str.replace(start_pos, from.length(), to);
start_pos += to.length();
return str;
CLI11_INLINE void remove_default_flag_values(std::string &flags) {
auto loc = flags.find_first_of('{', 2);
while (loc != std::string::npos) {
auto finish = flags.find_first_of("},", loc + 1);
if ((finish != std::string::npos) && (flags[finish] == '}')) {
flags.erase(flags.begin() + static_cast<std::ptrdiff_t>(loc),
flags.begin() + static_cast<std::ptrdiff_t>(finish) + 1);
loc = flags.find_first_of('{', loc + 1);
flags.erase(std::remove(flags.begin(), flags.end(), '!'), flags.end());
bool ignore_case,
bool ignore_underscore) {
auto it = std::end(names);
if (ignore_case) {
if (ignore_underscore) {
name = detail::to_lower(detail::remove_underscore(name));
it = std::find_if(
std::begin(names), std::end(names), [&name](std::string local_name) {
return detail::to_lower(detail::remove_underscore(local_name)) ==
name;
} else {
name = detail::to_lower(name);
it = std::find_if(std::begin(names), std::end(names),
return detail::to_lower(local_name) == name;
} else if (ignore_underscore) {
name = detail::remove_underscore(name);
return detail::remove_underscore(local_name) == name;
} else {
it = std::find(std::begin(names), std::end(names), name);
return (it != std::end(names)) ? (it - std::begin(names)) : (-1);
static const std::string escapedChars("\b\t\n\f\r\"\\");
static const std::string escapedCharsCode("btnfr\"\\");
static const std::string bracketChars{"\"'`[(<{"};
static const std::string matchBracketChars("\"'`])>}");
CLI11_INLINE bool has_escapable_character(const std::string &str) {
return (str.find_first_of(escapedChars) != std::string::npos);
CLI11_INLINE std::string add_escaped_characters(const std::string &str) {
std::string out;
out.reserve(str.size() + 4);
for (char s : str) {
auto sloc = escapedChars.find_first_of(s);
if (sloc != std::string::npos) {
out.push_back('\\');
out.push_back(escapedCharsCode[sloc]);
} else {
out.push_back(s);
return out;
CLI11_INLINE std::uint32_t hexConvert(char hc) {
int hcode{0};
if (hc >= '0' && hc <= '9') {
hcode = (hc - '0');
} else if (hc >= 'A' && hc <= 'F') {
hcode = (hc - 'A' + 10);
} else if (hc >= 'a' && hc <= 'f') {
hcode = (hc - 'a' + 10);
} else {
hcode = -1;
return static_cast<uint32_t>(hcode);
CLI11_INLINE char make_char(std::uint32_t code) {
return static_cast<char>(static_cast<unsigned char>(code));
CLI11_INLINE void append_codepoint(std::string &str, std::uint32_t code) {
if (code < 0x80) { // ascii code equivalent
str.push_back(static_cast<char>(code));
} else if (code < 0x800) { // \u0080 to \u07FF
// 110yyyyx 10xxxxxx; 0x3f == 0b0011'1111
str.push_back(make_char(0xC0 | code >> 6));
str.push_back(make_char(0x80 | (code & 0x3F)));
} else if (code < 0x10000) { // U+0800...U+FFFF
if (0xD800 <= code && code <= 0xDFFF) {
throw std::invalid_argument("[0xD800, 0xDFFF] are not valid UTF-8.");
// 1110yyyy 10yxxxxx 10xxxxxx
str.push_back(make_char(0xE0 | code >> 12));
str.push_back(make_char(0x80 | (code >> 6 & 0x3F)));
} else if (code < 0x110000) { // U+010000 ... U+10FFFF
// 11110yyy 10yyxxxx 10xxxxxx 10xxxxxx
str.push_back(make_char(0xF0 | code >> 18));
str.push_back(make_char(0x80 | (code >> 12 & 0x3F)));
CLI11_INLINE std::string remove_escaped_characters(const std::string &str) {
std::string out;
out.reserve(str.size());
for (auto loc = str.begin(); loc < str.end(); ++loc) {
if (*loc == '\\') {
if (str.end() - loc < 2) {
throw std::invalid_argument("invalid escape sequence " + str);
auto ecloc = escapedCharsCode.find_first_of(*(loc + 1));
if (ecloc != std::string::npos) {
out.push_back(escapedChars[ecloc]);
++loc;
} else if (*(loc + 1) == 'u') {
// must have 4 hex characters
if (str.end() - loc < 6) {
"unicode sequence must have 4 hex codes " + str);
std::uint32_t code{0};
std::uint32_t mplier{16 * 16 * 16};
for (int ii = 2; ii < 6; ++ii) {
std::uint32_t res = hexConvert(*(loc + ii));
if (res > 0x0F) {
code += res * mplier;
mplier = mplier / 16;
append_codepoint(out, code);
loc += 5;
} else if (*(loc + 1) == 'U') {
// must have 8 hex characters
if (str.end() - loc < 10) {
"unicode sequence must have 8 hex codes " + str);
std::uint32_t mplier{16 * 16 * 16 * 16 * 16 * 16 * 16};
for (int ii = 2; ii < 10; ++ii) {
if (res > 0x0F) {
loc += 9;
} else if (*(loc + 1) == '0') {
out.push_back('\0');
++loc;
} else {
std::string("unrecognized escape sequence \\") + *(loc + 1) +
" in " + str);
} else {
out.push_back(*loc);
return out;
CLI11_INLINE std::size_t close_string_quote(const std::string &str,
std::size_t start,
char closure_char) {
std::size_t loc{0};
for (loc = start + 1; loc < str.size(); ++loc) {
if (str[loc] == closure_char) {
if (str[loc] == '\\') {
// skip the next character for escaped sequences
++loc;
return loc;
CLI11_INLINE std::size_t close_literal_quote(const std::string &str,
std::size_t start,
auto loc = str.find_first_of(closure_char, start + 1);
return (loc != std::string::npos ? loc : str.size());
std::size_t start, char closure_char) {
auto bracket_loc = matchBracketChars.find(closure_char);
switch (bracket_loc) {
case 0:
return close_string_quote(str, start, closure_char);
case 1:
case 2:
case std::string::npos:
return close_literal_quote(str, start, closure_char);
std::string closures(1, closure_char);
auto loc = start + 1;
while (loc < str.size()) {
if (str[loc] == closures.back()) {
closures.pop_back();
if (closures.empty()) {
return loc;
bracket_loc = bracketChars.find(str[loc]);
if (bracket_loc != std::string::npos) {
case 0:
loc = close_string_quote(str, loc, str[loc]);
case 1:
case 2:
loc = close_literal_quote(str, loc, str[loc]);
closures.push_back(matchBracketChars[bracket_loc]);
++loc;
if (loc > str.size()) {
loc = str.size();
return loc;
char delimiter) {
auto find_ws = [delimiter](char ch) {
return (delimiter == '\0') ? std::isspace<char>(ch, std::locale())
: (ch == delimiter);
trim(str);
std::vector<std::string> output;
while (!str.empty()) {
if (bracketChars.find_first_of(str[0]) != std::string::npos) {
auto bracketLoc = bracketChars.find_first_of(str[0]);
auto end = close_sequence(str, 0, matchBracketChars[bracketLoc]);
if (end >= str.size()) {
output.push_back(std::move(str));
str.clear();
} else {
output.push_back(str.substr(0, end + 1));
if (end + 2 < str.size()) {
str = str.substr(end + 2);
} else {
str.clear();
} else {
auto it = std::find_if(std::begin(str), std::end(str), find_ws);
if (it != std::end(str)) {
std::string value = std::string(str.begin(), it);
output.push_back(value);
str = std::string(it + 1, str.end());
} else {
output.push_back(str);
str.clear();
trim(str);
return output;
CLI11_INLINE std::size_t escape_detect(std::string &str, std::size_t offset) {
auto next = str[offset + 1];
if ((next == '\"') || (next == '\'') || (next == '`')) {
auto astart = str.find_last_of("-/ \"\'`", offset - 1);
if (astart != std::string::npos) {
if (str[astart] == ((str[offset] == '=') ? '-' : '/'))
str[offset] =
' '; // interpret this as a space so the split_up works properly
return offset + 1;
binary_escape_string(const std::string &string_to_escape) {
// s is our escaped output string
std::string escaped_string{};
// loop through all characters
for (char c : string_to_escape) {
// check if a given character is printable
// the cast is necessary to avoid undefined behaviour
if (isprint(static_cast<unsigned char>(c)) == 0) {
std::stringstream stream;
// if the character is not printable
// we'll convert it to a hex string using a stringstream
// note that since char is signed we have to cast it to unsigned first
stream << std::hex
<< static_cast<unsigned int>(static_cast<unsigned char>(c));
std::string code = stream.str();
escaped_string +=
std::string("\\x") + (code.size() < 2 ? "0" : "") + code;
} else if (c == 'x' || c == 'X') {
// need to check for inadvertent binary sequences
if (!escaped_string.empty() && escaped_string.back() == '\\') {
escaped_string += std::string("\\x") + (c == 'x' ? "78" : "58");
} else {
escaped_string.push_back(c);
} else {
if (escaped_string != string_to_escape) {
auto sqLoc = escaped_string.find('\'');
while (sqLoc != std::string::npos) {
escaped_string[sqLoc] = '\\';
escaped_string.insert(sqLoc + 1, "x27");
escaped_string.insert(0, "'B\"(");
escaped_string.push_back(')');
escaped_string.push_back('"');
escaped_string.push_back('\'');
return escaped_string;
CLI11_INLINE bool is_binary_escaped_string(const std::string &escaped_string) {
size_t ssize = escaped_string.size();
if (escaped_string.compare(0, 3, "B\"(") == 0 &&
escaped_string.compare(ssize - 2, 2, ")\"") == 0) {
return true;
return (escaped_string.compare(0, 4, "'B\"(") == 0 &&
escaped_string.compare(ssize - 3, 3, ")\"'") == 0);
extract_binary_string(const std::string &escaped_string) {
std::size_t start{0};
std::size_t tail{0};
start = 3;
tail = 2;
} else if (escaped_string.compare(0, 4, "'B\"(") == 0 &&
escaped_string.compare(ssize - 3, 3, ")\"'") == 0) {
start = 4;
tail = 3;
if (start == 0) {
std::string outstring;
outstring.reserve(ssize - start - tail);
std::size_t loc = start;
while (loc < ssize - tail) {
// ssize-2 to skip )" at the end
if (escaped_string[loc] == '\\' &&
(escaped_string[loc + 1] == 'x' || escaped_string[loc + 1] == 'X')) {
auto c1 = escaped_string[loc + 2];
auto c2 = escaped_string[loc + 3];
std::uint32_t res1 = hexConvert(c1);
std::uint32_t res2 = hexConvert(c2);
if (res1 <= 0x0F && res2 <= 0x0F) {
loc += 4;
outstring.push_back(static_cast<char>(res1 * 16 + res2));
continue;
outstring.push_back(escaped_string[loc]);
++loc;
return outstring;
CLI11_INLINE void remove_quotes(std::vector<std::string> &args) {
for (auto &arg : args) {
if (arg.front() == '\"' && arg.back() == '\"') {
remove_quotes(arg);
// only remove escaped for string arguments not literal strings
arg = remove_escaped_characters(arg);
} else {
remove_quotes(arg);
CLI11_INLINE void handle_secondary_array(std::string &str) {
if (str.size() >= 2 && str.front() == '[' && str.back() == ']') {
// handle some special array processing for arguments if it might be
// interpreted as a secondary array
std::string tstr{"[["};
for (std::size_t ii = 1; ii < str.size(); ++ii) {
tstr.push_back(str[ii]);
str = std::move(tstr);
CLI11_INLINE bool process_quoted_string(std::string &str, char string_char,
char literal_char) {
if (str.size() <= 1) {
return false;
if (detail::is_binary_escaped_string(str)) {
str = detail::extract_binary_string(str);
handle_secondary_array(str);
return true;
if (str.front() == string_char && str.back() == string_char) {
detail::remove_outer(str, string_char);
if (str.find_first_of('\\') != std::string::npos) {
str = detail::remove_escaped_characters(str);
return true;
if ((str.front() == literal_char || str.front() == '`') &&
str.back() == str.front()) {
detail::remove_outer(str, str.front());
return true;
return false;
std::string get_environment_value(const std::string &env_name) {
char *buffer = nullptr;
std::string ename_string;
#ifdef _MSC_VER
// Windows version
std::size_t sz = 0;
if (_dupenv_s(&buffer, &sz, env_name.c_str()) == 0 && buffer != nullptr) {
ename_string = std::string(buffer);
free(buffer);
#else
// This also works on Windows, but gives a warning
buffer = std::getenv(env_name.c_str());
if (buffer != nullptr) {
#endif
return ename_string;
CLI11_INLINE std::ostream &streamOutAsParagraph(std::ostream &out,
const std::string &linePrefix,
bool skipPrefixOnFirstLine) {
if (!skipPrefixOnFirstLine)
out << linePrefix; // First line prefix
std::istringstream lss(text);
std::string line = "";
while (std::getline(lss, line)) {
std::istringstream iss(line);
std::string word = "";
std::size_t charsWritten = 0;
while (iss >> word) {
if (word.length() + charsWritten > paragraphWidth) {
out << '\n' << linePrefix;
charsWritten = 0;
out << word << " ";
charsWritten += word.length() + 1;
if (!lss.eof())
return out;
// Use one of these on all error classes.
// These are temporary and are undef'd at the end of this file.
#define CLI11_ERROR_DEF(parent, name) \
protected: \
name(std::string ename, std::string msg, int exit_code) \
: parent(std::move(ename), std::move(msg), exit_code) {} \
name(std::string ename, std::string msg, ExitCodes exit_code) \
public: \
name(std::string msg, ExitCodes exit_code) \
: parent(#name, std::move(msg), exit_code) {} \
name(std::string msg, int exit_code) \
// This is added after the one above if a class is used directly and builds its
// own message
#define CLI11_ERROR_SIMPLE(name) \
explicit name(std::string msg) : name(#name, msg, ExitCodes::name) {}
enum class ExitCodes {
Success = 0,
IncorrectConstruction = 100,
BadNameString,
OptionAlreadyAdded,
FileError,
ConversionError,
ValidationError,
RequiredError,
RequiresError,
ExcludesError,
ExtrasError,
ConfigError,
InvalidError,
HorribleError,
OptionNotFound,
ArgumentMismatch,
BaseClass = 127
// Error definitions
class Error : public std::runtime_error {
int actual_exit_code;
std::string error_name{"Error"};
CLI11_NODISCARD int get_exit_code() const { return actual_exit_code; }
CLI11_NODISCARD std::string get_name() const { return error_name; }
Error(std::string name, std::string msg,
int exit_code = static_cast<int>(ExitCodes::BaseClass))
: runtime_error(msg), actual_exit_code(exit_code),
error_name(std::move(name)) {}
Error(std::string name, std::string msg, ExitCodes exit_code)
: Error(name, msg, static_cast<int>(exit_code)) {}
// Note: Using Error::Error constructors does not work on GCC 4.7
class ConstructionError : public Error {
CLI11_ERROR_DEF(Error, ConstructionError)
class IncorrectConstruction : public ConstructionError {
CLI11_ERROR_DEF(ConstructionError, IncorrectConstruction)
CLI11_ERROR_SIMPLE(IncorrectConstruction)
static IncorrectConstruction PositionalFlag(std::string name) {
return IncorrectConstruction(name + ": Flags cannot be positional");
static IncorrectConstruction Set0Opt(std::string name) {
": Cannot set 0 expected, use a flag instead");
static IncorrectConstruction SetFlag(std::string name) {
": Cannot set an expected number for flags");
static IncorrectConstruction ChangeNotVector(std::string name) {
name + ": You can only change the expected arguments for vectors");
static IncorrectConstruction AfterMultiOpt(std::string name) {
": You can't change expected arguments after "
"you've changed the multi option policy!");
static IncorrectConstruction MissingOption(std::string name) {
return IncorrectConstruction("Option " + name + " is not defined");
static IncorrectConstruction MultiOptionPolicy(std::string name) {
name +
": multi_option_policy only works for flags and exact value options");
class BadNameString : public ConstructionError {
CLI11_ERROR_DEF(ConstructionError, BadNameString)
CLI11_ERROR_SIMPLE(BadNameString)
static BadNameString OneCharName(std::string name) {
return BadNameString("Invalid one char name: " + name);
static BadNameString MissingDash(std::string name) {
return BadNameString("Long names strings require 2 dashes " + name);
static BadNameString BadLongName(std::string name) {
return BadNameString("Bad long name: " + name);
static BadNameString BadPositionalName(std::string name) {
return BadNameString("Invalid positional Name: " + name);
static BadNameString ReservedName(std::string name) {
"Names '-','--','++' are reserved and not allowed as option names " +
name);
static BadNameString MultiPositionalNames(std::string name) {
return BadNameString("Only one positional name allowed, remove: " + name);
class OptionAlreadyAdded : public ConstructionError {
CLI11_ERROR_DEF(ConstructionError, OptionAlreadyAdded)
explicit OptionAlreadyAdded(std::string name)
: OptionAlreadyAdded(name + " is already added",
ExitCodes::OptionAlreadyAdded) {}
static OptionAlreadyAdded Requires(std::string name, std::string other) {
return {name + " requires " + other, ExitCodes::OptionAlreadyAdded};
static OptionAlreadyAdded Excludes(std::string name, std::string other) {
return {name + " excludes " + other, ExitCodes::OptionAlreadyAdded};
// Parsing errors
class ParseError : public Error {
CLI11_ERROR_DEF(Error, ParseError)
// Not really "errors"
class Success : public ParseError {
CLI11_ERROR_DEF(ParseError, Success)
Success()
: Success("Successfully completed, should be caught and quit",
ExitCodes::Success) {}
class CallForHelp : public Success {
CLI11_ERROR_DEF(Success, CallForHelp)
CallForHelp()
: CallForHelp("This should be caught in your main function, see examples",
class CallForAllHelp : public Success {
CLI11_ERROR_DEF(Success, CallForAllHelp)
CallForAllHelp()
: CallForAllHelp(
class CallForVersion : public Success {
CLI11_ERROR_DEF(Success, CallForVersion)
CallForVersion()
: CallForVersion(
class RuntimeError : public ParseError {
CLI11_ERROR_DEF(ParseError, RuntimeError)
explicit RuntimeError(int exit_code = 1)
: RuntimeError("Runtime error", exit_code) {}
class FileError : public ParseError {
CLI11_ERROR_DEF(ParseError, FileError)
CLI11_ERROR_SIMPLE(FileError)
static FileError Missing(std::string name) {
return FileError(name + " was not readable (missing?)");
class ConversionError : public ParseError {
CLI11_ERROR_DEF(ParseError, ConversionError)
CLI11_ERROR_SIMPLE(ConversionError)
ConversionError(std::string member, std::string name)
: ConversionError("The value " + member +
" is not an allowed value for " + name) {}
ConversionError(std::string name, std::vector<std::string> results)
: ConversionError("Could not convert: " + name + " = " +
detail::join(results)) {}
static ConversionError TooManyInputsFlag(std::string name) {
return ConversionError(name + ": too many inputs for a flag");
static ConversionError TrueFalse(std::string name) {
return ConversionError(name + ": Should be true/false or a number");
class ValidationError : public ParseError {
CLI11_ERROR_DEF(ParseError, ValidationError)
CLI11_ERROR_SIMPLE(ValidationError)
explicit ValidationError(std::string name, std::string msg)
: ValidationError(name + ": " + msg) {}
class RequiredError : public ParseError {
CLI11_ERROR_DEF(ParseError, RequiredError)
explicit RequiredError(std::string name)
: RequiredError(name + " is required", ExitCodes::RequiredError) {}
static RequiredError Subcommand(std::size_t min_subcom) {
if (min_subcom == 1) {
return RequiredError("A subcommand");
return {"Requires at least " + std::to_string(min_subcom) + " subcommands",
ExitCodes::RequiredError};
static RequiredError Option(std::size_t min_option, std::size_t max_option,
std::size_t used,
const std::string &option_list) {
if ((min_option == 1) && (max_option == 1) && (used == 0))
return RequiredError("Exactly 1 option from [" + option_list + "]");
if ((min_option == 1) && (max_option == 1) && (used > 1)) {
return {"Exactly 1 option from [" + option_list + "] is required but " +
std::to_string(used) + " were given",
if ((min_option == 1) && (used == 0))
return RequiredError("At least 1 option from [" + option_list + "]");
if (used < min_option) {
return {"Requires at least " + std::to_string(min_option) +
" options used but only " + std::to_string(used) +
" were given from [" + option_list + "]",
if (max_option == 1)
return {"Requires at most 1 options be given from [" + option_list + "]",
return {"Requires at most " + std::to_string(max_option) +
" options be used but " + std::to_string(used) +
class ArgumentMismatch : public ParseError {
CLI11_ERROR_DEF(ParseError, ArgumentMismatch)
CLI11_ERROR_SIMPLE(ArgumentMismatch)
ArgumentMismatch(std::string name, int expected, std::size_t received)
: ArgumentMismatch(expected > 0
? ("Expected exactly " + std::to_string(expected) +
" arguments to " + name + ", got " +
std::to_string(received))
: ("Expected at least " +
std::to_string(-expected) + " arguments to " +
name + ", got " + std::to_string(received)),
ExitCodes::ArgumentMismatch) {}
static ArgumentMismatch AtLeast(std::string name, int num,
std::size_t received) {
return ArgumentMismatch(name + ": At least " + std::to_string(num) +
" required but received " +
std::to_string(received));
static ArgumentMismatch AtMost(std::string name, int num,
return ArgumentMismatch(name + ": At Most " + std::to_string(num) +
static ArgumentMismatch TypedAtLeast(std::string name, int num,
std::string type) {
return ArgumentMismatch(name + ": " + std::to_string(num) + " required " +
type + " missing");
static ArgumentMismatch FlagOverride(std::string name) {
return ArgumentMismatch(name + " was given a disallowed flag override");
static ArgumentMismatch PartialType(std::string name, int num,
std::string type) {
return ArgumentMismatch(name + ": " + type + " only partially specified: " +
std::to_string(num) + " required for each element");
class RequiresError : public ParseError {
CLI11_ERROR_DEF(ParseError, RequiresError)
RequiresError(std::string curname, std::string subname)
: RequiresError(curname + " requires " + subname,
ExitCodes::RequiresError) {}
class ExcludesError : public ParseError {
CLI11_ERROR_DEF(ParseError, ExcludesError)
ExcludesError(std::string curname, std::string subname)
: ExcludesError(curname + " excludes " + subname,
ExitCodes::ExcludesError) {}
class ExtrasError : public ParseError {
CLI11_ERROR_DEF(ParseError, ExtrasError)
explicit ExtrasError(std::vector<std::string> args)
: ExtrasError((args.size() > 1
? "The following arguments were not expected: "
: "The following argument was not expected: ") +
detail::rjoin(args, " "),
ExitCodes::ExtrasError) {}
ExtrasError(const std::string &name, std::vector<std::string> args)
: ExtrasError(name,
(args.size() > 1
class ConfigError : public ParseError {
CLI11_ERROR_DEF(ParseError, ConfigError)
CLI11_ERROR_SIMPLE(ConfigError)
static ConfigError Extras(std::string item) {
return ConfigError("INI was not able to parse " + item);
static ConfigError NotConfigurable(std::string item) {
return ConfigError(item +
": This option is not allowed in a configuration file");
class InvalidError : public ParseError {
CLI11_ERROR_DEF(ParseError, InvalidError)
explicit InvalidError(std::string name)
: InvalidError(
name +
": Too many positional arguments with unlimited expected args",
ExitCodes::InvalidError) {}
class HorribleError : public ParseError {
CLI11_ERROR_DEF(ParseError, HorribleError)
CLI11_ERROR_SIMPLE(HorribleError)
// After parsing
class OptionNotFound : public Error {
CLI11_ERROR_DEF(Error, OptionNotFound)
explicit OptionNotFound(std::string name)
: OptionNotFound(name + " not found", ExitCodes::OptionNotFound) {}
#undef CLI11_ERROR_DEF
#undef CLI11_ERROR_SIMPLE
// Type tools
// Utilities for type enabling
namespace detail {
// Based generally on https://rmf.io/cxx11/almost-static-if
enum class enabler {};
constexpr enabler dummy = {};
template <bool B, class T = void>
using enable_if_t = typename std::enable_if<B, T>::type;
template <typename... Ts> struct make_void {
using type = void;
template <typename... Ts> using void_t = typename make_void<Ts...>::type;
template <bool B, class T, class F>
using conditional_t = typename std::conditional<B, T, F>::type;
template <typename T> struct is_bool : std::false_type {};
template <> struct is_bool<bool> : std::true_type {};
template <typename T> struct is_shared_ptr : std::false_type {};
struct is_shared_ptr<std::shared_ptr<T>> : std::true_type {};
struct is_shared_ptr<const std::shared_ptr<T>> : std::true_type {};
template <typename T> struct is_copyable_ptr {
static bool const value =
is_shared_ptr<T>::value || std::is_pointer<T>::value;
template <typename T> struct IsMemberType {
using type = T;
template <> struct IsMemberType<const char *> {
using type = std::string;
namespace adl_detail {
template <typename T, typename S = std::string> class is_lexical_castable {
template <typename TT, typename SS>
static auto test(int) -> decltype(lexical_cast(std::declval<const SS &>(),
std::declval<TT &>()),
std::true_type());
template <typename, typename> static auto test(...) -> std::false_type;
static constexpr bool value = decltype(test<T, S>(0))::value;
} // namespace adl_detail
namespace detail {
// These are utilities for IsMember and other transforming objects
template <typename T, typename Enable = void> struct element_type {
using type = T;
struct element_type<T,
typename std::enable_if<is_copyable_ptr<T>::value>::type> {
using type = typename std::pointer_traits<T>::element_type;
template <typename T> struct element_value_type {
using type = typename element_type<T>::type::value_type;
template <typename T, typename _ = void> struct pair_adaptor : std::false_type {
using value_type = typename T::value_type;
using first_type = typename std::remove_const<value_type>::type;
using second_type = typename std::remove_const<value_type>::type;
template <typename Q>
static auto first(Q &&pair_value) -> decltype(std::forward<Q>(pair_value)) {
return std::forward<Q>(pair_value);
static auto second(Q &&pair_value) -> decltype(std::forward<Q>(pair_value)) {
struct pair_adaptor<T,
conditional_t<false,
void_t<typename T::value_type::first_type,
typename T::value_type::second_type>,
void>> : std::true_type {
using first_type =
typename std::remove_const<typename value_type::first_type>::type;
using second_type =
typename std::remove_const<typename value_type::second_type>::type;
-> decltype(std::get<0>(std::forward<Q>(pair_value))) {
return std::get<0>(std::forward<Q>(pair_value));
-> decltype(std::get<1>(std::forward<Q>(pair_value))) {
return std::get<1>(std::forward<Q>(pair_value));
// Warning is suppressed due to "bug" in gcc<5.0 and gcc 7.0 with c++17 enabled
// that generates a -Wnarrowing warning in the unevaluated context even if the
// function that was using this wasn't used. The standard says narrowing in
// brace initialization shouldn't be allowed but for backwards compatibility gcc
// allows it in some contexts. It is a little fuzzy what happens in template
// constructs and I think that was something GCC took a little while to work
// out. But regardless some versions of gcc generate a warning when they
// shouldn't from the following code so that should be suppressed
#ifdef __GNUC__
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored "-Wnarrowing"
#endif
// check for constructibility from a specific type and copy assignable used in
// the parse detection
template <typename T, typename C> class is_direct_constructible {
template <typename TT, typename CC>
static auto test(int, std::true_type) -> decltype(
// NVCC warns about narrowing conversions here
#ifdef __CUDACC__
#ifdef __NVCC_DIAG_PRAGMA_SUPPORT__
#pragma nv_diag_suppress 2361
#else
#pragma diag_suppress 2361
#endif
#endif
TT{std::declval<CC>()}
#ifdef __CUDACC__
#pragma nv_diag_default 2361
#else
#pragma diag_default 2361
#endif
#endif
std::is_move_assignable<TT>());
static auto test(int, std::false_type) -> std::false_type;
static constexpr bool value = decltype(test<T, C>(
0, typename std::is_constructible<T, C>::type()))::value;
#ifdef __GNUC__
#pragma GCC diagnostic pop
#endif
// Check for output streamability
// Based on
// https://stackoverflow.com/questions/22758291/how-can-i-detect-if-a-type-can-be-streamed-to-an-stdostream
template <typename T, typename S = std::ostringstream> class is_ostreamable {
-> decltype(std::declval<SS &>() << std::declval<TT>(), std::true_type());
template <typename T, typename S = std::istringstream> class is_istreamable {
-> decltype(std::declval<SS &>() >> std::declval<TT &>(),
std::true_type());
template <typename T> class is_complex {
template <typename TT>
-> decltype(std::declval<TT>().real(), std::declval<TT>().imag(),
std::true_type());
template <typename> static auto test(...) -> std::false_type;
static constexpr bool value = decltype(test<T>(0))::value;
template <typename T, enable_if_t<is_istreamable<T>::value, detail::enabler> =
detail::dummy>
bool from_stream(const std::string &istring, T &obj) {
std::istringstream is;
is.str(istring);
is >> obj;
return !is.fail() && !is.rdbuf()->in_avail();
template <typename T, enable_if_t<!is_istreamable<T>::value, detail::enabler> =
detail::dummy>
bool from_stream(const std::string & /*istring*/, T & /*obj*/) {
return false;
// check to see if an object is a mutable container (fail by default)
struct is_mutable_container : std::false_type {};
struct is_mutable_container<
T, conditional_t<
false,
void_t<typename T::value_type, decltype(std::declval<T>().end()),
decltype(std::declval<T>().clear()),
decltype(std::declval<T>().insert(
std::declval<decltype(std::declval<T>().end())>(),
std::declval<const typename T::value_type &>()))>,
void>>
: public conditional_t<std::is_constructible<T, std::string>::value ||
std::is_constructible<T, std::wstring>::value,
std::false_type, std::true_type> {};
struct is_readable_container : std::false_type {};
struct is_readable_container<
T, conditional_t<false,
void_t<decltype(std::declval<T>().end()),
decltype(std::declval<T>().begin())>,
void>> : public std::true_type {};
// check to see if an object is a wrapper (fail by default)
template <typename T, typename _ = void> struct is_wrapper : std::false_type {};
// check if an object is a wrapper (it has a value_type defined)
struct is_wrapper<T, conditional_t<false, void_t<typename T::value_type>, void>>
// Check for tuple like types, as in classes with a tuple_size type trait
// Even though in C++26 std::complex gains a std::tuple interface, for our
// purposes we treat is as NOT a tuple
template <typename S> class is_tuple_like {
template <typename SS, enable_if_t<!is_complex<SS>::value, detail::enabler> =
detail::dummy>
// static auto test(int)
// -> decltype(std::conditional<(std::tuple_size<SS>::value > 0),
// std::true_type, std::false_type>::type());
-> decltype(std::tuple_size<typename std::decay<SS>::type>::value,
std::true_type{});
static constexpr bool value = decltype(test<S>(0))::value;
template <typename T, typename Enable = void> struct type_count_base {
static const int value{0};
struct type_count_base<
T, typename std::enable_if<!is_tuple_like<T>::value &&
!is_mutable_container<T>::value &&
!std::is_void<T>::value>::type> {
static constexpr int value{1};
T, typename std::enable_if<is_tuple_like<T>::value &&
!is_mutable_container<T>::value>::type> {
// cppcheck-suppress unusedStructMember
std::tuple_size<typename std::decay<T>::type>::value};
T, typename std::enable_if<is_mutable_container<T>::value>::type> {
static constexpr int value{type_count_base<typename T::value_type>::value};
template <typename T, enable_if_t<std::is_convertible<T, std::string>::value,
detail::enabler> = detail::dummy>
auto to_string(T &&value) -> decltype(std::forward<T>(value)) {
return std::forward<T>(value);
enable_if_t<std::is_constructible<std::string, T>::value &&
!std::is_convertible<T, std::string>::value,
std::string to_string(T &&value) {
return std::string(value); // NOLINT(google-readability-casting)
enable_if_t<!std::is_convertible<T, std::string>::value &&
!std::is_constructible<std::string, T>::value &&
is_ostreamable<T>::value,
stream << value;
return stream.str();
// additional forward declarations
template <
typename T,
!is_ostreamable<T>::value && is_tuple_like<T>::value &&
type_count_base<T>::value == 1,
inline std::string to_string(T &&value);
template <
typename T,
type_count_base<T>::value >= 2,
!is_readable_container<
typename std::remove_const<T>::type>::value &&
!is_tuple_like<T>::value,
inline std::string to_string(T &&) {
return {};
is_readable_container<T>::value,
inline std::string to_string(T &&variable) {
auto cval = variable.begin();
auto end = variable.end();
if (cval == end) {
return {"{}"};
std::vector<std::string> defaults;
while (cval != end) {
defaults.emplace_back(CLI::detail::to_string(*cval));
++cval;
return {"[" + detail::join(defaults) + "]"};
template <typename T, std::size_t I>
inline
typename std::enable_if<I == type_count_base<T>::value, std::string>::type
tuple_value_string(T && /*value*/);
inline
typename std::enable_if<(I < type_count_base<T>::value), std::string>::type
tuple_value_string(T &&value);
template <
typename T,
detail::enabler>>
inline std::string to_string(T &&value) {
return to_string(std::get<0>(value));
template <
typename T,
detail::enabler>>
auto tname = std::string(1, '[') + tuple_value_string<T, 0>(value);
tname.push_back(']');
return tname;
inline
tuple_value_string(T && /*value*/) {
return std::string{};
inline
tuple_value_string(T &&value) {
auto str = std::string{to_string(std::get<I>(value))} + ',' +
tuple_value_string<T, I + 1>(value);
if (str.back() == ',')
str.pop_back();
return str;
template <
typename T1, typename T2, typename T,
enable_if_t<std::is_same<T1, T2>::value, detail::enabler> = detail::dummy>
auto checked_to_string(T &&value)
-> decltype(to_string(std::forward<T>(value))) {
return to_string(std::forward<T>(value));
template <
enable_if_t<!std::is_same<T1, T2>::value, detail::enabler> = detail::dummy>
std::string checked_to_string(T &&) {
template <typename T, enable_if_t<std::is_arithmetic<T>::value,
std::string value_string(const T &value) {
return std::to_string(value);
enable_if_t<std::is_enum<T>::value, detail::enabler> = detail::dummy>
static_cast<typename std::underlying_type<T>::type>(value));
enable_if_t<!std::is_enum<T>::value && !std::is_arithmetic<T>::value,
auto value_string(const T &value) -> decltype(to_string(value)) {
return to_string(value);
template <typename T, typename def, typename Enable = void>
struct wrapped_type {
using type = def;
template <typename T, typename def>
struct wrapped_type<T, def,
typename std::enable_if<is_wrapper<T>::value>::type> {
using type = typename T::value_type;
template <typename T> struct subtype_count;
template <typename T> struct subtype_count_min;
template <typename T, typename Enable = void> struct type_count {
struct type_count<T,
!is_wrapper<T>::value && !is_tuple_like<T>::value &&
!is_complex<T>::value && !std::is_void<T>::value>::type> {
struct type_count<T, typename std::enable_if<is_complex<T>::value>::type> {
static constexpr int value{2};
struct type_count<
static constexpr int value{subtype_count<typename T::value_type>::value};
struct type_count<
T, typename std::enable_if<is_wrapper<T>::value && !is_complex<T>::value &&
static constexpr int value{type_count<typename T::value_type>::value};
constexpr typename std::enable_if<I == type_count_base<T>::value, int>::type
tuple_type_size() {
constexpr typename std::enable_if <
I<type_count_base<T>::value, int>::type tuple_type_size() {
return subtype_count<typename std::tuple_element<I, T>::type>::value +
tuple_type_size<T, I + 1>();
struct type_count<T, typename std::enable_if<is_tuple_like<T>::value>::type> {
static constexpr int value{tuple_type_size<T, 0>()};
template <typename T> struct subtype_count {
static constexpr int value{is_mutable_container<T>::value
? expected_max_vector_size
: type_count<T>::value};
template <typename T, typename Enable = void> struct type_count_min {
struct type_count_min<
T, typename std::enable_if<!is_mutable_container<T>::value &&
!is_wrapper<T>::value && !is_complex<T>::value &&
static constexpr int value{type_count<T>::value};
struct type_count_min<T, typename std::enable_if<is_complex<T>::value>::type> {
!is_tuple_like<T>::value>::type> {
static constexpr int value{subtype_count_min<typename T::value_type>::value};
tuple_type_size_min() {
I<type_count_base<T>::value, int>::type tuple_type_size_min() {
return subtype_count_min<typename std::tuple_element<I, T>::type>::value +
tuple_type_size_min<T, I + 1>();
static constexpr int value{tuple_type_size_min<T, 0>()};
template <typename T> struct subtype_count_min {
? ((type_count<T>::value < expected_max_vector_size)
? type_count<T>::value
: 0)
: type_count_min<T>::value};
template <typename T, typename Enable = void> struct expected_count {
struct expected_count<T,
static constexpr int value{expected_max_vector_size};
static constexpr int value{expected_count<typename T::value_type>::value};
// Enumeration of the different supported categorizations of objects
enum class object_category : int {
char_value = 1,
integral_value = 2,
unsigned_integral = 4,
enumeration = 6,
boolean_value = 8,
floating_point = 10,
number_constructible = 12,
double_constructible = 14,
integer_constructible = 16,
// string like types
string_assignable = 23,
string_constructible = 24,
wstring_assignable = 25,
wstring_constructible = 26,
other = 45,
// special wrapper or container types
wrapper_value = 50,
complex_number = 60,
tuple_value = 70,
container_value = 80,
template <typename T, typename Enable = void> struct classify_object {
static constexpr object_category value{object_category::other};
struct classify_object<
T, typename std::enable_if<std::is_integral<T>::value &&
!std::is_same<T, char>::value &&
std::is_signed<T>::value && !is_bool<T>::value &&
!std::is_enum<T>::value>::type> {
static constexpr object_category value{object_category::integral_value};
std::is_integral<T>::value && std::is_unsigned<T>::value &&
!std::is_same<T, char>::value && !is_bool<T>::value>::type> {
static constexpr object_category value{object_category::unsigned_integral};
struct classify_object<T,
typename std::enable_if<std::is_same<T, char>::value &&
static constexpr object_category value{object_category::char_value};
struct classify_object<T, typename std::enable_if<is_bool<T>::value>::type> {
static constexpr object_category value{object_category::boolean_value};
T, typename std::enable_if<std::is_floating_point<T>::value>::type> {
static constexpr object_category value{object_category::floating_point};
#if defined _MSC_VER
// in MSVC wstring should take precedence if available this isn't as useful on
// other compilers due to the broader use of utf-8 encoding
#define WIDE_STRING_CHECK \
!std::is_assignable<T &, std::wstring>::value && \
!std::is_constructible<T, std::wstring>::value
#define STRING_CHECK true
#else
#define WIDE_STRING_CHECK true
#define STRING_CHECK \
!std::is_assignable<T &, std::string>::value && \
!std::is_constructible<T, std::string>::value
#endif
!std::is_floating_point<T>::value &&
!std::is_integral<T>::value && WIDE_STRING_CHECK &&
std::is_assignable<T &, std::string>::value>::type> {
static constexpr object_category value{object_category::string_assignable};
!std::is_floating_point<T>::value && !std::is_integral<T>::value &&
(type_count<T>::value == 1) && WIDE_STRING_CHECK &&
std::is_constructible<T, std::string>::value>::type> {
static constexpr object_category value{object_category::string_constructible};
T,
STRING_CHECK && std::is_assignable<T &, std::wstring>::value>::type> {
static constexpr object_category value{object_category::wstring_assignable};
(type_count<T>::value == 1) && STRING_CHECK &&
std::is_constructible<T, std::wstring>::value>::type> {
object_category::wstring_constructible};
typename std::enable_if<std::is_enum<T>::value>::type> {
static constexpr object_category value{object_category::enumeration};
struct classify_object<T, typename std::enable_if<is_complex<T>::value>::type> {
static constexpr object_category value{object_category::complex_number};
template <typename T> struct uncommon_type {
using type = typename std::conditional<
!std::is_constructible<T, std::string>::value &&
!std::is_constructible<T, std::wstring>::value &&
!is_complex<T>::value && !is_mutable_container<T>::value &&
!std::is_enum<T>::value,
std::true_type, std::false_type>::type;
static constexpr bool value = type::value;
T, typename std::enable_if<(
!is_mutable_container<T>::value && is_wrapper<T>::value &&
!is_tuple_like<T>::value && uncommon_type<T>::value)>::type> {
static constexpr object_category value{object_category::wrapper_value};
uncommon_type<T>::value && type_count<T>::value == 1 &&
!is_wrapper<T>::value && is_direct_constructible<T, double>::value &&
is_direct_constructible<T, int>::value>::type> {
static constexpr object_category value{object_category::number_constructible};
T,
!is_wrapper<T>::value && !is_direct_constructible<T, double>::value &&
object_category::integer_constructible};
!is_direct_constructible<T, int>::value>::type> {
static constexpr object_category value{object_category::double_constructible};
((type_count<T>::value >= 2 && !is_wrapper<T>::value) ||
(uncommon_type<T>::value &&
!is_direct_constructible<T, int>::value) ||
(uncommon_type<T>::value && type_count<T>::value >= 2))>::type> {
static constexpr object_category value{object_category::tuple_value};
// the condition on this class requires it be like a tuple, but on some
// compilers (like Xcode) tuples can be constructed from just the first
// element so tuples of <string, int,int> can be constructed from a string,
// which could lead to issues so there are two variants of the condition, the
// first isolates things with a type size >=2 mainly to get tuples on Xcode
// with the exception of wrappers, the second is the main one and just
// separating out those cases that are caught by other object classifications
static constexpr object_category value{object_category::container_value};
// Type name print
enable_if_t<classify_object<T>::value == object_category::char_value,
constexpr const char *type_name() {
return "CHAR";
template <
typename T,
enable_if_t<classify_object<T>::value == object_category::integral_value ||
object_category::integer_constructible,
return "INT";
template <typename T, enable_if_t<classify_object<T>::value ==
object_category::unsigned_integral,
return "UINT";
template <
typename T,
enable_if_t<classify_object<T>::value == object_category::floating_point ||
object_category::number_constructible ||
object_category::double_constructible,
return "FLOAT";
enable_if_t<classify_object<T>::value == object_category::enumeration,
return "ENUM";
object_category::boolean_value,
return "BOOLEAN";
object_category::complex_number,
return "COMPLEX";
enable_if_t<classify_object<T>::value >=
object_category::string_assignable &&
classify_object<T>::value <= object_category::other,
return "TEXT";
object_category::tuple_value &&
std::string type_name(); // forward declaration
template <
typename T,
enable_if_t<classify_object<T>::value == object_category::container_value ||
classify_object<T>::value == object_category::wrapper_value,
inline std::string type_name() {
return type_name<
typename std::decay<typename std::tuple_element<0, T>::type>::type>();
inline
tuple_name() {
inline
tuple_name() {
auto str = std::string{type_name<typename std::decay<
typename std::tuple_element<I, T>::type>::type>()} +
',' + tuple_name<T, I + 1>();
str.pop_back();
return str;
detail::enabler>>
auto tname = std::string(1, '[') + tuple_name<T, 0>();
return tname;
template <
typename T,
detail::enabler>>
return type_name<typename T::value_type>();
// Lexical cast
template <typename T, enable_if_t<std::is_unsigned<T>::value, detail::enabler> =
detail::dummy>
bool integral_conversion(const std::string &input, T &output) noexcept {
if (input.empty() || input.front() == '-') {
return false;
char *val{nullptr};
errno = 0;
std::uint64_t output_ll = std::strtoull(input.c_str(), &val, 0);
if (errno == ERANGE) {
return false;
output = static_cast<T>(output_ll);
if (val == (input.c_str() + input.size()) &&
static_cast<std::uint64_t>(output) == output_ll) {
return true;
val = nullptr;
std::int64_t output_sll = std::strtoll(input.c_str(), &val, 0);
if (val == (input.c_str() + input.size())) {
output = (output_sll < 0) ? static_cast<T>(0) : static_cast<T>(output_sll);
return (static_cast<std::int64_t>(output) == output_sll);
// remove separators
if (input.find_first_of("_'") != std::string::npos) {
std::string nstring = input;
nstring.erase(std::remove(nstring.begin(), nstring.end(), '_'),
nstring.end());
nstring.erase(std::remove(nstring.begin(), nstring.end(), '\''),
nstring.end());
return integral_conversion(nstring, output);
if (std::isspace(static_cast<unsigned char>(input.back()))) {
return integral_conversion(trim_copy(input), output);
if (input.compare(0, 2, "0o") == 0 || input.compare(0, 2, "0O") == 0) {
val = nullptr;
errno = 0;
output_ll = std::strtoull(input.c_str() + 2, &val, 8);
return false;
return (val == (input.c_str() + input.size()) &&
static_cast<std::uint64_t>(output) == output_ll);
if (input.compare(0, 2, "0b") == 0 || input.compare(0, 2, "0B") == 0) {
// LCOV_EXCL_START
// In some new compilers including the coverage testing one binary strings
// are handled properly in strtoull automatically so this coverage is
// missing but is well tested in other compilers
val = nullptr;
errno = 0;
output_ll = std::strtoull(input.c_str() + 2, &val, 2);
return false;
// LCOV_EXCL_STOP
return false;
template <typename T, enable_if_t<std::is_signed<T>::value, detail::enabler> =
detail::dummy>
if (input.empty()) {
return false;
char *val = nullptr;
errno = 0;
std::int64_t output_ll = std::strtoll(input.c_str(), &val, 0);
return false;
static_cast<std::int64_t>(output) == output_ll) {
return true;
if (input == "true") {
// this is to deal with a few oddities with flags and wrapper int types
output = static_cast<T>(1);
return true;
// remove separators and trailing spaces
nstring.end());
nstring.end());
val = nullptr;
errno = 0;
output_ll = std::strtoll(input.c_str() + 2, &val, 8);
return false;
static_cast<std::int64_t>(output) == output_ll);
// LCOV_EXCL_START
// are handled properly in strtoll automatically so this coverage is missing
// but is well tested in other compilers
val = nullptr;
errno = 0;
output_ll = std::strtoll(input.c_str() + 2, &val, 2);
return false;
// LCOV_EXCL_STOP
return false;
inline std::int64_t to_flag_value(std::string val) noexcept {
static const std::string trueString("true");
static const std::string falseString("false");
if (val == trueString) {
return 1;
if (val == falseString) {
return -1;
val = detail::to_lower(val);
std::int64_t ret = 0;
if (val.size() == 1) {
if (val[0] >= '1' && val[0] <= '9') {
return (static_cast<std::int64_t>(val[0]) - '0');
switch (val[0]) {
case '0':
case 'f':
case 'n':
case '-':
ret = -1;
case 't':
case 'y':
case '+':
ret = 1;
errno = EINVAL;
return -1;
return ret;
if (val == trueString || val == "on" || val == "yes" || val == "enable") {
ret = 1;
} else if (val == falseString || val == "off" || val == "no" ||
val == "disable") {
ret = -1;
} else {
char *loc_ptr{nullptr};
ret = std::strtoll(val.c_str(), &loc_ptr, 0);
if (loc_ptr != (val.c_str() + val.size()) && errno == 0) {
errno = EINVAL;
return ret;
bool lexical_cast(const std::string &input, T &output) {
return integral_conversion(input, output);
if (input.size() == 1) {
output = static_cast<T>(input[0]);
return true;
errno = 0;
auto out = to_flag_value(input);
if (errno == 0) {
output = (out > 0);
} else if (errno == ERANGE) {
output = (input[0] != '-');
} else {
return false;
return true;
object_category::floating_point,
return false;
auto output_ld = std::strtold(input.c_str(), &val);
output = static_cast<T>(output_ld);
return true;
while (std::isspace(static_cast<unsigned char>(*val))) {
++val;
return true;
nstring.end());
nstring.end());
return lexical_cast(nstring, output);
return false;
using XC = typename wrapped_type<T, double>::type;
XC x{0.0}, y{0.0};
auto str1 = input;
bool worked = false;
auto nloc = str1.find_last_of("+-");
if (nloc != std::string::npos && nloc > 0) {
worked = lexical_cast(str1.substr(0, nloc), x);
str1 = str1.substr(nloc);
if (str1.back() == 'i' || str1.back() == 'j')
str1.pop_back();
worked = worked && lexical_cast(str1, y);
} else {
if (str1.back() == 'i' || str1.back() == 'j') {
str1.pop_back();
worked = lexical_cast(str1, y);
x = XC{0};
} else {
worked = lexical_cast(str1, x);
y = XC{0};
if (worked) {
output = T{x, y};
return worked;
return from_stream(input, output);
object_category::string_assignable,
output = input;
return true;
object_category::string_constructible,
output = T(input);
return true;
object_category::wstring_assignable,
output = widen(input);
return true;
object_category::wstring_constructible,
output = T{widen(input)};
return true;
typename std::underlying_type<T>::type val;
if (!integral_conversion(input, val)) {
return false;
output = static_cast<T>(val);
return true;
template <
typename T,
enable_if_t<classify_object<T>::value == object_category::wrapper_value &&
std::is_assignable<T &, typename T::value_type>::value,
typename T::value_type val;
if (lexical_cast(input, val)) {
output = val;
return true;
template <
typename T,
!std::is_assignable<T &, typename T::value_type>::value &&
std::is_assignable<T &, T>::value,
output = T{val};
return true;
object_category::number_constructible,
int val = 0;
if (integral_conversion(input, val)) {
output = T(val);
return true;
double dval = 0.0;
if (lexical_cast(input, dval)) {
output = T{dval};
return true;
int val = 0;
output = T(val);
return true;
double val = 0.0;
output = T{val};
return true;
enable_if_t<classify_object<T>::value == object_category::other &&
std::is_assignable<T &, int>::value,
int val = 0;
#ifdef _MSC_VER
#pragma warning(push)
#pragma warning(disable : 4800)
#endif
// with Atomic<XX> this could produce a warning due to the conversion but if
// atomic gets here it is an old style so will most likely still work
output = val;
#ifdef _MSC_VER
#pragma warning(pop)
#endif
return true;
// LCOV_EXCL_START
// This version of cast is only used for odd cases in an older compilers the
// fail over from_stream is tested elsewhere an not relevant for coverage here
// LCOV_EXCL_STOP
!std::is_assignable<T &, int>::value &&
!is_istreamable<T>::value &&
!adl_detail::is_lexical_castable<T>::value,
bool lexical_cast(const std::string & /*input*/, T & /*output*/) {
static_assert(!std::is_same<T, T>::value, // Can't just write false here.
"option object type must have a lexical cast overload or "
"streaming input operator(>>) defined, if it "
"is convertible from another type use the add_option<T, "
"XC>(...) with XC being the known type");
return false;
template <typename AssignTo, typename ConvertTo,
enable_if_t<std::is_same<AssignTo, ConvertTo>::value &&
(classify_object<AssignTo>::value ==
object_category::string_assignable ||
object_category::string_constructible ||
object_category::wstring_assignable ||
object_category::wstring_constructible),
bool lexical_assign(const std::string &input, AssignTo &output) {
return lexical_cast(input, output);
std::is_assignable<AssignTo &, AssignTo>::value &&
classify_object<AssignTo>::value !=
object_category::string_constructible &&
object_category::wstring_assignable &&
output = AssignTo{};
return true;
} // LCOV_EXCL_LINE
!std::is_assignable<AssignTo &, AssignTo>::value &&
typename AssignTo::value_type emptyVal{};
output = emptyVal;
return true;
std::is_assignable<AssignTo &, int>::value,
output = 0;
return true;
int val{0};
#if defined(__clang__)
/* on some older clang compilers */
#pragma clang diagnostic push
#pragma clang diagnostic ignored "-Wsign-conversion"
#endif
output = val;
#pragma clang diagnostic pop
#endif
return true;
return false;
enable_if_t<!std::is_same<AssignTo, ConvertTo>::value &&
std::is_assignable<AssignTo &, ConvertTo &>::value,
ConvertTo val{};
bool parse_result = (!input.empty()) ? lexical_cast(input, val) : true;
if (parse_result) {
output = val;
return parse_result;
!std::is_assignable<AssignTo &, ConvertTo &>::value &&
std::is_move_assignable<AssignTo>::value,
ConvertTo val{};
bool parse_result = input.empty() ? true : lexical_cast(input, val);
if (parse_result) {
output = AssignTo(
val); // use () form of constructor to allow some implicit conversions
template <
enable_if_t<classify_object<ConvertTo>::value <= object_category::other &&
classify_object<AssignTo>::value <=
bool lexical_conversion(const std::vector<std::string> &strings,
AssignTo &output) {
return lexical_assign<AssignTo, ConvertTo>(strings[0], output);
enable_if_t<(type_count<AssignTo>::value <= 2) &&
expected_count<AssignTo>::value == 1 &&
is_tuple_like<ConvertTo>::value &&
type_count_base<ConvertTo>::value == 2,
AssignTo &output) {
// the remove const is to handle pair types coming from a container
using FirstType = typename std::remove_const<
typename std::tuple_element<0, ConvertTo>::type>::type;
using SecondType = typename std::tuple_element<1, ConvertTo>::type;
FirstType v1;
SecondType v2;
bool retval = lexical_assign<FirstType, FirstType>(strings[0], v1);
retval = retval && lexical_assign<SecondType, SecondType>(
(strings.size() > 1) ? strings[1] : std::string{}, v2);
if (retval) {
output = AssignTo{v1, v2};
return retval;
template <class AssignTo, class ConvertTo,
enable_if_t<is_mutable_container<AssignTo>::value &&
is_mutable_container<ConvertTo>::value &&
type_count<ConvertTo>::value == 1,
AssignTo &output) {
output.erase(output.begin(), output.end());
if (strings.empty()) {
return true;
if (strings.size() == 1 && strings[0] == "{}") {
return true;
bool skip_remaining = false;
if (strings.size() == 2 && strings[0] == "{}" && is_separator(strings[1])) {
skip_remaining = true;
for (const auto &elem : strings) {
typename AssignTo::value_type out;
bool retval = lexical_assign<typename AssignTo::value_type,
typename ConvertTo::value_type>(elem, out);
if (!retval) {
return false;
output.insert(output.end(), std::move(out));
if (skip_remaining) {
return (!output.empty());
template <
enable_if_t<is_complex<ConvertTo>::value, detail::enabler> = detail::dummy>
AssignTo &output) {
if (strings.size() >= 2 && !strings[1].empty()) {
using XC2 = typename wrapped_type<ConvertTo, double>::type;
XC2 x{0.0}, y{0.0};
auto str1 = strings[1];
str1.pop_back();
auto worked = lexical_cast(strings[0], x) && lexical_cast(str1, y);
if (worked) {
output = ConvertTo{x, y};
return worked;
(expected_count<ConvertTo>::value == 1) &&
(type_count<ConvertTo>::value == 1),
AssignTo &output) {
bool retval = true;
output.clear();
output.reserve(strings.size());
output.emplace_back();
retval = retval && lexical_assign<typename AssignTo::value_type, ConvertTo>(
elem, output.back());
return (!output.empty()) && retval;
bool lexical_conversion(std::vector<std::string> strings, AssignTo &output);
type_count_base<ConvertTo>::value != 2 &&
((type_count<ConvertTo>::value > 2) ||
type_count_base<ConvertTo>::value)),
AssignTo &output);
enable_if_t<is_tuple_like<AssignTo>::value &&
(type_count_base<ConvertTo>::value !=
type_count<ConvertTo>::value ||
type_count<ConvertTo>::value > 2),
AssignTo &output); // forward declaration
enable_if_t<!is_tuple_like<AssignTo>::value &&
!is_mutable_container<AssignTo>::value &&
classify_object<ConvertTo>::value !=
(is_mutable_container<ConvertTo>::value ||
AssignTo &output) {
if (strings.size() > 1 || (!strings.empty() && !(strings.front().empty()))) {
ConvertTo val;
auto retval = lexical_conversion<ConvertTo, ConvertTo>(strings, val);
output = AssignTo{val};
return retval;
return true;
template <class AssignTo, class ConvertTo, std::size_t I>
inline
typename std::enable_if<(I >= type_count_base<AssignTo>::value), bool>::type
tuple_conversion(const std::vector<std::string> &, AssignTo &) {
return true;
template <class AssignTo, class ConvertTo>
inline typename std::enable_if<!is_mutable_container<ConvertTo>::value &&
bool>::type
tuple_type_conversion(std::vector<std::string> &strings, AssignTo &output) {
auto retval = lexical_assign<AssignTo, ConvertTo>(strings[0], output);
strings.erase(strings.begin());
return retval;
(type_count<ConvertTo>::value > 1) &&
type_count_min<ConvertTo>::value,
bool>::type
auto retval = lexical_conversion<AssignTo, ConvertTo>(strings, output);
strings.erase(strings.begin(),
strings.begin() + type_count<ConvertTo>::value);
return retval;
inline typename std::enable_if<is_mutable_container<ConvertTo>::value ||
type_count<ConvertTo>::value !=
bool>::type
std::size_t index{subtype_count_min<ConvertTo>::value};
const std::size_t mx_count{subtype_count<ConvertTo>::value};
const std::size_t mx{(std::min)(mx_count, strings.size() - 1)};
while (index < mx) {
if (is_separator(strings[index])) {
++index;
bool retval = lexical_conversion<AssignTo, ConvertTo>(
std::vector<std::string>(strings.begin(),
strings.begin() +
static_cast<std::ptrdiff_t>(index)),
output);
if (strings.size() > index) {
strings.begin() + static_cast<std::ptrdiff_t>(index) + 1);
} else {
strings.clear();
return retval;
inline
typename std::enable_if<(I < type_count_base<AssignTo>::value), bool>::type
tuple_conversion(std::vector<std::string> strings, AssignTo &output) {
bool retval = true;
using ConvertToElement =
typename std::conditional<is_tuple_like<ConvertTo>::value,
typename std::tuple_element<I, ConvertTo>::type,
ConvertTo>::type;
if (!strings.empty()) {
retval =
retval &&
tuple_type_conversion<typename std::tuple_element<I, AssignTo>::type,
ConvertToElement>(strings, std::get<I>(output));
retval = retval && tuple_conversion<AssignTo, ConvertTo, I + 1>(
std::move(strings), output);
return retval;
detail::enabler>>
bool lexical_conversion(std::vector<std::string> strings, AssignTo &output) {
output.clear();
while (!strings.empty()) {
typename std::remove_const<typename std::tuple_element<
0, typename ConvertTo::value_type>::type>::type v1;
typename std::tuple_element<1, typename ConvertTo::value_type>::type v2;
bool retval =
tuple_type_conversion<decltype(v1), decltype(v1)>(strings, v1);
retval = retval &&
tuple_type_conversion<decltype(v2), decltype(v2)>(strings, v2);
if (retval) {
output.insert(output.end(), typename AssignTo::value_type{v1, v2});
} else {
return false;
detail::enabler>>
AssignTo &output) {
static_assert(!is_tuple_like<ConvertTo>::value ||
type_count_base<AssignTo>::value ==
type_count_base<ConvertTo>::value,
"if the conversion type is defined as a tuple it must be the "
"same size as the type you are converting to");
return tuple_conversion<AssignTo, ConvertTo, 0>(strings, output);
detail::enabler>>
AssignTo &output) {
bool retval = true;
output.clear();
std::vector<std::string> temp;
std::size_t ii{0};
std::size_t icount{0};
std::size_t xcm{type_count<ConvertTo>::value};
auto ii_max = strings.size();
while (ii < ii_max) {
temp.push_back(strings[ii]);
++ii;
++icount;
if (icount == xcm || is_separator(temp.back()) || ii == ii_max) {
if (static_cast<int>(xcm) > type_count_min<ConvertTo>::value &&
is_separator(temp.back())) {
temp.pop_back();
typename AssignTo::value_type temp_out;
retval = retval && lexical_conversion<typename AssignTo::value_type,
temp, temp_out);
temp.clear();
if (!retval) {
return false;
output.insert(output.end(), std::move(temp_out));
icount = 0;
return retval;
template <typename AssignTo, class ConvertTo,
enable_if_t<classify_object<ConvertTo>::value ==
std::is_assignable<ConvertTo &, ConvertTo>::value,
AssignTo &output) {
if (strings.empty() || strings.front().empty()) {
output = ConvertTo{};
return true;
typename ConvertTo::value_type val;
if (lexical_conversion<typename ConvertTo::value_type,
typename ConvertTo::value_type>(strings, val)) {
output = ConvertTo{val};
return true;
return false;
!std::is_assignable<AssignTo &, ConvertTo>::value,
AssignTo &output) {
using ConvertType = typename ConvertTo::value_type;
output = ConvertType{};
return true;
ConvertType val;
output = val;
return true;
return false;
inline std::string sum_string_vector(const std::vector<std::string> &values) {
double val{0.0};
bool fail{false};
std::string output;
for (const auto &arg : values) {
double tv{0.0};
auto comp = lexical_cast(arg, tv);
if (!comp) {
errno = 0;
auto fv = detail::to_flag_value(arg);
fail = (errno != 0);
if (fail) {
tv = static_cast<double>(fv);
val += tv;
if (fail) {
output.append(arg);
} else {
std::ostringstream out;
out.precision(16);
out << val;
output = out.str();
return output;
} // namespace detail
namespace detail {
// Returns false if not a short option. Otherwise, sets opt name and rest and
// returns true
CLI11_INLINE bool split_short(const std::string &current, std::string &name,
std::string &rest);
// Returns false if not a long option. Otherwise, sets opt name and other side
// of = and returns true
CLI11_INLINE bool split_long(const std::string &current, std::string &name,
std::string &value);
// Returns false if not a windows style option. Otherwise, sets opt name and
// value and returns true
CLI11_INLINE bool split_windows_style(const std::string &current,
std::string &name, std::string &value);
// Splits a string into multiple long and short names
CLI11_INLINE std::vector<std::string> split_names(std::string current);
CLI11_INLINE std::vector<std::pair<std::string, std::string>>
get_default_flag_values(const std::string &str);
CLI11_INLINE
std::tuple<std::vector<std::string>, std::vector<std::string>, std::string>
get_names(const std::vector<std::string> &input,
bool allow_non_standard = false);
namespace detail {
std::string &rest) {
if (current.size() > 1 && current[0] == '-' && valid_first_char(current[1])) {
name = current.substr(1, 1);
rest = current.substr(2);
return true;
return false;
std::string &value) {
if (current.size() > 2 && current.compare(0, 2, "--") == 0 &&
valid_first_char(current[2])) {
auto loc = current.find_first_of('=');
if (loc != std::string::npos) {
name = current.substr(2, loc - 2);
value = current.substr(loc + 1);
} else {
name = current.substr(2);
value = "";
return true;
return false;
std::string &name, std::string &value) {
if (current.size() > 1 && current[0] == '/' && valid_first_char(current[1])) {
auto loc = current.find_first_of(':');
name = current.substr(1, loc - 1);
} else {
name = current.substr(1);
value = "";
return true;
return false;
CLI11_INLINE std::vector<std::string> split_names(std::string current) {
std::size_t val = 0;
while ((val = current.find(',')) != std::string::npos) {
output.push_back(trim_copy(current.substr(0, val)));
current = current.substr(val + 1);
output.push_back(trim_copy(current));
return output;
get_default_flag_values(const std::string &str) {
std::vector<std::string> flags = split_names(str);
flags.erase(std::remove_if(flags.begin(), flags.end(),
[](const std::string &name) {
return ((name.empty()) ||
(!(((name.find_first_of('{') !=
std::string::npos) &&
(name.back() == '}')) ||
(name[0] == '!'))));
flags.end());
std::vector<std::pair<std::string, std::string>> output;
output.reserve(flags.size());
for (auto &flag : flags) {
auto def_start = flag.find_first_of('{');
std::string defval = "false";
if ((def_start != std::string::npos) && (flag.back() == '}')) {
defval = flag.substr(def_start + 1);
defval.pop_back();
flag.erase(
def_start,
std::string::npos); // NOLINT(readability-suspicious-call-argument)
flag.erase(0, flag.find_first_not_of("-!"));
output.emplace_back(flag, defval);
return output;
CLI11_INLINE
get_names(const std::vector<std::string> &input, bool allow_non_standard) {
std::vector<std::string> short_names;
std::vector<std::string> long_names;
std::string pos_name;
for (std::string name : input) {
if (name.length() == 0) {
continue;
if (name.length() > 1 && name[0] == '-' && name[1] != '-') {
if (name.length() == 2 && valid_first_char(name[1])) {
short_names.emplace_back(1, name[1]);
} else if (name.length() > 2) {
if (allow_non_standard) {
name = name.substr(1);
if (valid_name_string(name)) {
short_names.push_back(name);
} else {
throw BadNameString::BadLongName(name);
} else {
throw BadNameString::MissingDash(name);
} else {
throw BadNameString::OneCharName(name);
} else if (name.length() > 2 && name.substr(0, 2) == "--") {
name = name.substr(2);
long_names.push_back(name);
} else {
} else if (name == "-" || name == "--" || name == "++") {
throw BadNameString::ReservedName(name);
} else {
if (!pos_name.empty()) {
throw BadNameString::MultiPositionalNames(name);
pos_name = name;
} else {
throw BadNameString::BadPositionalName(name);
return std::make_tuple(short_names, long_names, pos_name);
class App;
struct ConfigItem {
std::vector<std::string> parents{};
std::string name{};
std::vector<std::string> inputs{};
bool multiline{false};
CLI11_NODISCARD std::string fullname() const {
std::vector<std::string> tmp = parents;
tmp.emplace_back(name);
return detail::join(tmp, ".");
(void)multiline; // suppression for cppcheck false positive
class Config {
protected:
std::vector<ConfigItem> items{};
virtual std::string to_config(const App *, bool, bool, std::string) const = 0;
virtual std::vector<ConfigItem> from_config(std::istream &) const = 0;
CLI11_NODISCARD virtual std::string to_flag(const ConfigItem &item) const {
if (item.inputs.size() == 1) {
return item.inputs.at(0);
if (item.inputs.empty()) {
return "{}";
throw ConversionError::TooManyInputsFlag(item.fullname()); // LCOV_EXCL_LINE
CLI11_NODISCARD std::vector<ConfigItem>
from_file(const std::string &name) const {
std::ifstream input{name};
if (!input.good())
throw FileError::Missing(name);
return from_config(input);
virtual ~Config() = default;
class ConfigBase : public Config {
protected:
char commentChar = '#';
char arrayStart = '[';
char arrayEnd = ']';
char arraySeparator = ',';
char valueDelimiter = '=';
char stringQuote = '"';
char literalQuote = '\'';
uint8_t maximumLayers{255};
char parentSeparatorChar{'.'};
bool commentDefaultsBool = false;
bool allowMultipleDuplicateFields{false};
int16_t configIndex{-1};
std::string configSection{};
std::string to_config(const App * /*app*/, bool default_also,
bool write_description,
std::string prefix) const override;
std::vector<ConfigItem> from_config(std::istream &input) const override;
ConfigBase *comment(char cchar) {
commentChar = cchar;
return this;
ConfigBase *arrayBounds(char aStart, char aEnd) {
arrayStart = aStart;
arrayEnd = aEnd;
return this;
ConfigBase *arrayDelimiter(char aSep) {
arraySeparator = aSep;
return this;
ConfigBase *valueSeparator(char vSep) {
valueDelimiter = vSep;
return this;
ConfigBase *quoteCharacter(char qString, char literalChar) {
stringQuote = qString;
literalQuote = literalChar;
return this;
ConfigBase *maxLayers(uint8_t layers) {
maximumLayers = layers;
return this;
ConfigBase *parentSeparator(char sep) {
parentSeparatorChar = sep;
return this;
ConfigBase *commentDefaults(bool comDef = true) {
commentDefaultsBool = comDef;
return this;
std::string &sectionRef() { return configSection; }
CLI11_NODISCARD const std::string &section() const { return configSection; }
ConfigBase *section(const std::string &sectionName) {
configSection = sectionName;
return this;
int16_t &indexRef() { return configIndex; }
CLI11_NODISCARD int16_t index() const { return configIndex; }
ConfigBase *index(int16_t sectionIndex) {
configIndex = sectionIndex;
return this;
ConfigBase *allowDuplicateFields(bool value = true) {
allowMultipleDuplicateFields = value;
return this;
using ConfigTOML = ConfigBase;
class ConfigINI : public ConfigTOML {
ConfigINI() {
commentChar = ';';
arrayStart = '\0';
arrayEnd = '\0';
arraySeparator = ' ';
class Option;
class Validator {
protected:
std::function<std::string()> desc_function_{[]() { return std::string{}; }};
std::function<std::string(std::string &)> func_{
[](std::string &) { return std::string{}; }};
std::string name_{};
int application_index_ = -1;
bool active_{true};
bool non_modifying_{false};
Validator(std::string validator_desc,
std::function<std::string(std::string &)> func)
: desc_function_([validator_desc]() { return validator_desc; }),
func_(std::move(func)) {}
Validator() = default;
explicit Validator(std::string validator_desc)
: desc_function_([validator_desc]() { return validator_desc; }) {}
Validator(std::function<std::string(std::string &)> op,
std::string validator_desc, std::string validator_name = "")
func_(std::move(op)), name_(std::move(validator_name)) {}
Validator &operation(std::function<std::string(std::string &)> op) {
func_ = std::move(op);
return *this;
std::string operator()(std::string &str) const;
std::string operator()(const std::string &str) const {
std::string value = str;
return (active_) ? func_(value) : std::string{};
Validator &description(std::string validator_desc) {
desc_function_ = [validator_desc]() { return validator_desc; };
return *this;
CLI11_NODISCARD Validator description(std::string validator_desc) const;
CLI11_NODISCARD std::string get_description() const {
if (active_) {
return desc_function_();
Validator &name(std::string validator_name) {
name_ = std::move(validator_name);
return *this;
CLI11_NODISCARD Validator name(std::string validator_name) const {
Validator newval(*this);
newval.name_ = std::move(validator_name);
return newval;
CLI11_NODISCARD const std::string &get_name() const { return name_; }
Validator &active(bool active_val = true) {
active_ = active_val;
return *this;
CLI11_NODISCARD Validator active(bool active_val = true) const {
newval.active_ = active_val;
return newval;
Validator &non_modifying(bool no_modify = true) {
non_modifying_ = no_modify;
return *this;
Validator &application_index(int app_index) {
application_index_ = app_index;
return *this;
CLI11_NODISCARD Validator application_index(int app_index) const {
newval.application_index_ = app_index;
return newval;
CLI11_NODISCARD int get_application_index() const {
return application_index_;
CLI11_NODISCARD bool get_active() const { return active_; }
CLI11_NODISCARD bool get_modifying() const { return !non_modifying_; }
Validator operator&(const Validator &other) const;
Validator operator|(const Validator &other) const;
Validator operator!() const;
private:
void _merge_description(const Validator &val1, const Validator &val2,
const std::string &merger);
class CustomValidator : public Validator {
// The implementation of the built in validators is using the Validator class;
// the user is only expected to use the const (static) versions (since there's
// no setup). Therefore, this is in detail.
namespace detail {
enum class path_type { nonexistent, file, directory };
CLI11_INLINE path_type check_path(const char *file) noexcept;
class ExistingFileValidator : public Validator {
ExistingFileValidator();
class ExistingDirectoryValidator : public Validator {
ExistingDirectoryValidator();
class ExistingPathValidator : public Validator {
ExistingPathValidator();
class NonexistentPathValidator : public Validator {
NonexistentPathValidator();
class IPV4Validator : public Validator {
IPV4Validator();
class EscapedStringTransformer : public Validator {
EscapedStringTransformer();
// Static is not needed here, because global const implies static.
const detail::ExistingFileValidator ExistingFile;
const detail::ExistingDirectoryValidator ExistingDirectory;
const detail::ExistingPathValidator ExistingPath;
const detail::NonexistentPathValidator NonexistentPath;
const detail::IPV4Validator ValidIPV4;
const detail::EscapedStringTransformer EscapedString;
template <typename DesiredType> class TypeValidator : public Validator {
explicit TypeValidator(const std::string &validator_name)
: Validator(validator_name, [](std::string &input_string) {
using CLI::detail::lexical_cast;
auto val = DesiredType();
if (!lexical_cast(input_string, val)) {
return std::string("Failed parsing ") + input_string + " as a " +
detail::type_name<DesiredType>();
return std::string();
TypeValidator() : TypeValidator(detail::type_name<DesiredType>()) {}
const TypeValidator<double> Number("NUMBER");
class FileOnDefaultPath : public Validator {
explicit FileOnDefaultPath(std::string default_path,
bool enableErrorReturn = true);
class Range : public Validator {
Range(T min_val, T max_val, const std::string &validator_name = std::string{})
: Validator(validator_name) {
if (validator_name.empty()) {
std::stringstream out;
out << detail::type_name<T>() << " in [" << min_val << " - " << max_val
description(out.str());
func_ = [min_val, max_val](std::string &input) {
T val;
bool converted = lexical_cast(input, val);
if ((!converted) || (val < min_val || val > max_val)) {
out << "Value " << input << " not in range [";
out << min_val << " - " << max_val << "]";
return out.str();
explicit Range(T max_val, const std::string &validator_name = std::string{})
: Range(static_cast<T>(0), max_val, validator_name) {}
const Range NonNegativeNumber((std::numeric_limits<double>::max)(),
"NONNEGATIVE");
const Range PositiveNumber((std::numeric_limits<double>::min)(),
(std::numeric_limits<double>::max)(), "POSITIVE");
class Bound : public Validator {
template <typename T> Bound(T min_val, T max_val) {
out << detail::type_name<T>() << " bounded to [" << min_val << " - "
<< max_val << "]";
T val;
if (!converted) {
return std::string("Value ") + input + " could not be converted";
if (val < min_val)
input = detail::to_string(min_val);
else if (val > max_val)
input = detail::to_string(max_val);
explicit Bound(T max_val) : Bound(static_cast<T>(0), max_val) {}
namespace detail {
template <
typename T,
enable_if_t<is_copyable_ptr<typename std::remove_reference<T>::type>::value,
auto smart_deref(T value) -> decltype(*value) {
return *value;
enable_if_t<
!is_copyable_ptr<typename std::remove_reference<T>::type>::value,
typename std::remove_reference<T>::type &smart_deref(T &value) {
return value;
template <typename T> std::string generate_set(const T &set) {
using element_t = typename detail::element_type<T>::type;
using iteration_type_t =
typename detail::pair_adaptor<element_t>::value_type; // the type of the
// object pair
std::string out(1, '{');
out.append(detail::join(
detail::smart_deref(set),
[](const iteration_type_t &v) {
return detail::pair_adaptor<element_t>::first(v);
out.push_back('}');
return out;
std::string generate_map(const T &map, bool key_only = false) {
// object pair
detail::smart_deref(map),
[key_only](const iteration_type_t &v) {
std::string res{
detail::to_string(detail::pair_adaptor<element_t>::first(v))};
if (!key_only) {
res.append("->");
res += detail::to_string(detail::pair_adaptor<element_t>::second(v));
return res;
out.push_back('}');
return out;
template <typename C, typename V> struct has_find {
template <typename CC, typename VV>
static auto test(int) -> decltype(std::declval<CC>().find(std::declval<VV>()),
std::true_type());
static auto test(...) -> decltype(std::false_type());
static const auto value = decltype(test<C, V>(0))::value;
using type = std::integral_constant<bool, value>;
template <typename T, typename V,
enable_if_t<!has_find<T, V>::value, detail::enabler> = detail::dummy>
auto search(const T &set, const V &val)
-> std::pair<bool, decltype(std::begin(detail::smart_deref(set)))> {
auto &setref = detail::smart_deref(set);
auto it =
std::find_if(std::begin(setref), std::end(setref),
[&val](decltype(*std::begin(setref)) v) {
return (detail::pair_adaptor<element_t>::first(v) == val);
return {(it != std::end(setref)), it};
enable_if_t<has_find<T, V>::value, detail::enabler> = detail::dummy>
auto it = setref.find(val);
template <typename T, typename V>
auto search(const T &set, const V &val,
const std::function<V(V)> &filter_function)
// do the potentially faster first search
auto res = search(set, val);
if ((res.first) || (!(filter_function))) {
return res;
// if we haven't found it do the longer linear search with all the element
// translations
auto it = std::find_if(std::begin(setref), std::end(setref),
[&](decltype(*std::begin(setref)) v) {
V a{detail::pair_adaptor<element_t>::first(v)};
a = filter_function(a);
return (a == val);
// the following suggestion was made by Nikita Ofitserov(@himikof)
// done in templates to prevent compiler warnings on negation of unsigned
// numbers
inline typename std::enable_if<std::is_signed<T>::value, T>::type
overflowCheck(const T &a, const T &b) {
if ((a > 0) == (b > 0)) {
return ((std::numeric_limits<T>::max)() / (std::abs)(a) < (std::abs)(b));
return ((std::numeric_limits<T>::min)() / (std::abs)(a) > -(std::abs)(b));
inline typename std::enable_if<!std::is_signed<T>::value, T>::type
return ((std::numeric_limits<T>::max)() / a < b);
typename std::enable_if<std::is_integral<T>::value, bool>::type
checked_multiply(T &a, T b) {
if (a == 0 || b == 0 || a == 1 || b == 1) {
a *= b;
return true;
if (a == (std::numeric_limits<T>::min)() ||
b == (std::numeric_limits<T>::min)()) {
return false;
if (overflowCheck(a, b)) {
return false;
a *= b;
return true;
typename std::enable_if<std::is_floating_point<T>::value, bool>::type
T c = a * b;
if (std::isinf(c) && !std::isinf(a) && !std::isinf(b)) {
return false;
a = c;
return true;
class IsMember : public Validator {
using filter_fn_t = std::function<std::string(std::string)>;
template <typename T, typename... Args>
IsMember(std::initializer_list<T> values, Args &&...args)
: IsMember(std::vector<T>(values), std::forward<Args>(args)...) {}
explicit IsMember(T &&set) : IsMember(std::forward<T>(set), nullptr) {}
template <typename T, typename F>
explicit IsMember(T set, F filter_function) {
// Get the type of the contained item - requires a container have
// ::value_type if the type does not have first_type and second_type, these
// are both value_type
using element_t =
typename detail::element_type<T>::type; // Removes (smart) pointers if
// needed
using item_t =
typename detail::pair_adaptor<element_t>::first_type; // Is value_type
// if not a map
using local_item_t =
typename IsMemberType<item_t>::type; // This will convert bad types to
// good ones
// (const char * to std::string)
// Make a local copy of the filter function, using a std::function if not
// one already
std::function<local_item_t(local_item_t)> filter_fn = filter_function;
// This is the type name for help, it will take the current version of the
// set contents
desc_function_ = [set]() {
return detail::generate_set(detail::smart_deref(set));
// This is the function that validates
// It stores a copy of the set pointer-like, so shared_ptr will stay alive
func_ = [set, filter_fn](std::string &input) {
local_item_t b;
if (!lexical_cast(input, b)) {
throw ValidationError(input); // name is added later
if (filter_fn) {
b = filter_fn(b);
auto res = detail::search(set, b, filter_fn);
if (res.first) {
// Make sure the version in the input string is identical to the one in
// the set
if (filter_fn) {
input = detail::value_string(
detail::pair_adaptor<element_t>::first(*(res.second)));
// Return empty error string (success)
// If you reach this point, the result was not found
return input + " not in " +
IsMember(T &&set, filter_fn_t filter_fn_1, filter_fn_t filter_fn_2,
Args &&...other)
: IsMember(
[filter_fn_1, filter_fn_2](std::string a) {
return filter_fn_2(filter_fn_1(a));
other...) {}
using TransformPairs = std::vector<std::pair<std::string, T>>;
class Transformer : public Validator {
template <typename... Args>
Transformer(std::initializer_list<std::pair<std::string, std::string>> values,
Args &&...args)
: Transformer(TransformPairs<std::string>(values),
explicit Transformer(T &&mapping)
: Transformer(std::forward<T>(mapping), nullptr) {}
explicit Transformer(T mapping, F filter_function) {
static_assert(
detail::pair_adaptor<typename detail::element_type<T>::type>::value,
"mapping must produce value pairs");
using element_t =
// needed
using item_t =
// if not a map
typename IsMemberType<item_t>::type; // Will convert bad types to good
// ones
// one already
// set contents
desc_function_ = [mapping]() {
return detail::generate_map(detail::smart_deref(mapping));
func_ = [mapping, filter_fn](std::string &input) {
local_item_t b;
// there is no possible way we can match anything in the mapping if we
// can't convert so just return
if (filter_fn) {
b = filter_fn(b);
auto res = detail::search(mapping, b, filter_fn);
if (res.first) {
detail::pair_adaptor<element_t>::second(*res.second));
Transformer(T &&mapping, filter_fn_t filter_fn_1, filter_fn_t filter_fn_2,
Args &&...other)
: Transformer(
other...) {}
class CheckedTransformer : public Validator {
CheckedTransformer(
Args &&...args)
: CheckedTransformer(TransformPairs<std::string>(values),
explicit CheckedTransformer(T mapping)
: CheckedTransformer(std::move(mapping), nullptr) {}
explicit CheckedTransformer(T mapping, F filter_function) {
static_assert(
using element_t =
// needed
using item_t =
// if not a map
// ones
// object pair
// one already
auto tfunc = [mapping]() {
std::string out("value in ");
out += detail::generate_map(detail::smart_deref(mapping)) + " OR {";
out += detail::join(
detail::smart_deref(mapping),
return detail::to_string(
out.push_back('}');
return out;
desc_function_ = tfunc;
func_ = [mapping, tfunc, filter_fn](std::string &input) {
local_item_t b;
bool converted = lexical_cast(input, b);
if (converted) {
if (filter_fn) {
b = filter_fn(b);
if (res.first) {
for (const auto &v : detail::smart_deref(mapping)) {
auto output_string =
detail::value_string(detail::pair_adaptor<element_t>::second(v));
if (output_string == input) {
return "Check " + input + " " + tfunc() + " FAILED";
CheckedTransformer(T &&mapping, filter_fn_t filter_fn_1,
filter_fn_t filter_fn_2, Args &&...other)
other...) {}
inline std::string ignore_case(std::string item) {
return detail::to_lower(item);
inline std::string ignore_underscore(std::string item) {
return detail::remove_underscore(item);
inline std::string ignore_space(std::string item) {
item.erase(std::remove(std::begin(item), std::end(item), ' '),
std::end(item));
item.erase(std::remove(std::begin(item), std::end(item), '\t'),
std::end(item));
return item;
class AsNumberWithUnit : public Validator {
enum Options {
CASE_SENSITIVE = 0,
CASE_INSENSITIVE = 1,
UNIT_OPTIONAL = 0,
UNIT_REQUIRED = 2,
DEFAULT = CASE_INSENSITIVE | UNIT_OPTIONAL
template <typename Number>
explicit AsNumberWithUnit(std::map<std::string, Number> mapping,
Options opts = DEFAULT,
const std::string &unit_name = "UNIT") {
description(generate_description<Number>(unit_name, opts));
validate_mapping(mapping, opts);
// transform function
func_ = [mapping, opts](std::string &input) -> std::string {
Number num{};
detail::rtrim(input);
throw ValidationError("Input is empty");
// Find split position between number and prefix
auto unit_begin = input.end();
while (unit_begin > input.begin() &&
std::isalpha(*(unit_begin - 1), std::locale())) {
--unit_begin;
std::string unit{unit_begin, input.end()};
input.resize(
static_cast<std::size_t>(std::distance(input.begin(), unit_begin)));
detail::trim(input);
if (opts & UNIT_REQUIRED && unit.empty()) {
throw ValidationError("Missing mandatory unit");
if (opts & CASE_INSENSITIVE) {
unit = detail::to_lower(unit);
if (unit.empty()) {
if (!lexical_cast(input, num)) {
throw ValidationError(std::string("Value ") + input +
" could not be converted to " +
detail::type_name<Number>());
// No need to modify input if no unit passed
return {};
// find corresponding factor
auto it = mapping.find(unit);
if (it == mapping.end()) {
throw ValidationError(unit +
" unit not recognized. "
"Allowed values: " +
detail::generate_map(mapping, true));
if (!input.empty()) {
bool converted = lexical_cast(input, num);
if (!converted) {
// perform safe multiplication
bool ok = detail::checked_multiply(num, it->second);
if (!ok) {
detail::to_string(num) + " multiplied by " + unit +
" factor would cause number overflow. Use smaller value.");
} else {
num = static_cast<Number>(it->second);
input = detail::to_string(num);
return {};
private:
static void validate_mapping(std::map<std::string, Number> &mapping,
Options opts) {
for (auto &kv : mapping) {
if (kv.first.empty()) {
throw ValidationError("Unit must not be empty.");
if (!detail::isalpha(kv.first)) {
throw ValidationError("Unit must contain only letters.");
// make all units lowercase if CASE_INSENSITIVE
std::map<std::string, Number> lower_mapping;
auto s = detail::to_lower(kv.first);
if (lower_mapping.count(s)) {
throw ValidationError(std::string("Several matching lowercase unit "
"representations are found: ") +
s);
lower_mapping[detail::to_lower(kv.first)] = kv.second;
mapping = std::move(lower_mapping);
static std::string generate_description(const std::string &name,
Options opts) {
out << detail::type_name<Number>() << ' ';
if (opts & UNIT_REQUIRED) {
out << name;
} else {
out << '[' << name << ']';
return out.str();
inline AsNumberWithUnit::Options operator|(const AsNumberWithUnit::Options &a,
const AsNumberWithUnit::Options &b) {
return static_cast<AsNumberWithUnit::Options>(static_cast<int>(a) |
static_cast<int>(b));
class AsSizeValue : public AsNumberWithUnit {
using result_t = std::uint64_t;
explicit AsSizeValue(bool kb_is_1000);
private:
static std::map<std::string, result_t> init_mapping(bool kb_is_1000);
static std::map<std::string, result_t> get_mapping(bool kb_is_1000);
namespace detail {
CLI11_INLINE std::pair<std::string, std::string>
split_program_name(std::string commandline);
CLI11_INLINE std::string Validator::operator()(std::string &str) const {
std::string retstring;
if (active_) {
if (non_modifying_) {
retstring = func_(value);
} else {
retstring = func_(str);
return retstring;
CLI11_NODISCARD CLI11_INLINE Validator
Validator::description(std::string validator_desc) const {
newval.desc_function_ = [validator_desc]() { return validator_desc; };
return newval;
CLI11_INLINE Validator Validator::operator&(const Validator &other) const {
Validator newval;
newval._merge_description(*this, other, " AND ");
// Give references (will make a copy in lambda function)
const std::function<std::string(std::string & filename)> &f1 = func_;
const std::function<std::string(std::string & filename)> &f2 = other.func_;
newval.func_ = [f1, f2](std::string &input) {
std::string s1 = f1(input);
std::string s2 = f2(input);
if (!s1.empty() && !s2.empty())
return std::string("(") + s1 + ") AND (" + s2 + ")";
return s1 + s2;
newval.active_ = active_ && other.active_;
newval.application_index_ = application_index_;
return newval;
CLI11_INLINE Validator Validator::operator|(const Validator &other) const {
Validator newval;
newval._merge_description(*this, other, " OR ");
const std::function<std::string(std::string &)> &f1 = func_;
const std::function<std::string(std::string &)> &f2 = other.func_;
if (s1.empty() || s2.empty())
return std::string("(") + s1 + ") OR (" + s2 + ")";
return newval;
CLI11_INLINE Validator Validator::operator!() const {
Validator newval;
const std::function<std::string()> &dfunc1 = desc_function_;
newval.desc_function_ = [dfunc1]() {
auto str = dfunc1();
return (!str.empty()) ? std::string("NOT ") + str : std::string{};
const std::function<std::string(std::string & res)> &f1 = func_;
newval.func_ = [f1, dfunc1](std::string &test) -> std::string {
std::string s1 = f1(test);
if (s1.empty()) {
return std::string("check ") + dfunc1() + " succeeded improperly";
newval.active_ = active_;
return newval;
CLI11_INLINE void Validator::_merge_description(const Validator &val1,
const std::string &merger) {
const std::function<std::string()> &dfunc1 = val1.desc_function_;
const std::function<std::string()> &dfunc2 = val2.desc_function_;
desc_function_ = [=]() {
std::string f1 = dfunc1();
std::string f2 = dfunc2();
if ((f1.empty()) || (f2.empty())) {
return f1 + f2;
return std::string(1, '(') + f1 + ')' + merger + '(' + f2 + ')';
namespace detail {
#if defined CLI11_HAS_FILESYSTEM && CLI11_HAS_FILESYSTEM > 0
CLI11_INLINE path_type check_path(const char *file) noexcept {
std::error_code ec;
auto stat = std::filesystem::status(to_path(file), ec);
if (ec) {
return path_type::nonexistent;
switch (stat.type()) {
case std::filesystem::file_type::none: // LCOV_EXCL_LINE
case std::filesystem::file_type::not_found:
return path_type::nonexistent; // LCOV_EXCL_LINE
case std::filesystem::file_type::directory:
return path_type::directory;
case std::filesystem::file_type::symlink:
case std::filesystem::file_type::block:
case std::filesystem::file_type::character:
case std::filesystem::file_type::fifo:
case std::filesystem::file_type::socket:
case std::filesystem::file_type::regular:
case std::filesystem::file_type::unknown:
return path_type::file;
#else
#if defined(_MSC_VER)
struct __stat64 buffer;
if (_stat64(file, &buffer) == 0) {
return ((buffer.st_mode & S_IFDIR) != 0) ? path_type::directory
: path_type::file;
#else
struct stat buffer;
if (stat(file, &buffer) == 0) {
: path_type::file;
#endif
#endif
CLI11_INLINE ExistingFileValidator::ExistingFileValidator()
: Validator("FILE") {
func_ = [](std::string &filename) {
auto path_result = check_path(filename.c_str());
if (path_result == path_type::nonexistent) {
return "File does not exist: " + filename;
if (path_result == path_type::directory) {
return "File is actually a directory: " + filename;
CLI11_INLINE ExistingDirectoryValidator::ExistingDirectoryValidator()
: Validator("DIR") {
return "Directory does not exist: " + filename;
if (path_result == path_type::file) {
return "Directory is actually a file: " + filename;
CLI11_INLINE ExistingPathValidator::ExistingPathValidator()
: Validator("PATH(existing)") {
return "Path does not exist: " + filename;
CLI11_INLINE NonexistentPathValidator::NonexistentPathValidator()
: Validator("PATH(non-existing)") {
if (path_result != path_type::nonexistent) {
return "Path already exists: " + filename;
CLI11_INLINE IPV4Validator::IPV4Validator() : Validator("IPV4") {
func_ = [](std::string &ip_addr) {
auto result = CLI::detail::split(ip_addr, '.');
if (result.size() != 4) {
return std::string("Invalid IPV4 address must have four parts (") +
ip_addr + ')';
int num = 0;
for (const auto &var : result) {
bool retval = lexical_cast(var, num);
if (!retval) {
return std::string("Failed parsing number (") + var + ')';
if (num < 0 || num > 255) {
return std::string("Each IP number must be between 0 and 255 ") + var;
CLI11_INLINE EscapedStringTransformer::EscapedStringTransformer() {
func_ = [](std::string &str) {
if (str.size() > 1 &&
(str.front() == '\"' || str.front() == '\'' || str.front() == '`') &&
str.front() == str.back()) {
process_quoted_string(str);
} else if (str.find_first_of('\\') != std::string::npos) {
if (detail::is_binary_escaped_string(str)) {
str = detail::extract_binary_string(str);
} else {
str = remove_escaped_characters(str);
} catch (const std::invalid_argument &ia) {
return std::string(ia.what());
CLI11_INLINE FileOnDefaultPath::FileOnDefaultPath(std::string default_path,
bool enableErrorReturn)
func_ = [default_path, enableErrorReturn](std::string &filename) {
auto path_result = detail::check_path(filename.c_str());
if (path_result == detail::path_type::nonexistent) {
std::string test_file_path = default_path;
if (default_path.back() != '/' && default_path.back() != '\\') {
// Add folder separator
test_file_path += '/';
test_file_path.append(filename);
path_result = detail::check_path(test_file_path.c_str());
if (path_result == detail::path_type::file) {
filename = test_file_path;
} else {
if (enableErrorReturn) {
CLI11_INLINE AsSizeValue::AsSizeValue(bool kb_is_1000)
: AsNumberWithUnit(get_mapping(kb_is_1000)) {
if (kb_is_1000) {
description("SIZE [b, kb(=1000b), kib(=1024b), ...]");
} else {
description("SIZE [b, kb(=1024b), ...]");
CLI11_INLINE std::map<std::string, AsSizeValue::result_t>
AsSizeValue::init_mapping(bool kb_is_1000) {
std::map<std::string, result_t> m;
result_t k_factor = kb_is_1000 ? 1000 : 1024;
result_t ki_factor = 1024;
result_t k = 1;
result_t ki = 1;
m["b"] = 1;
for (std::string p : {"k", "m", "g", "t", "p", "e"}) {
k *= k_factor;
ki *= ki_factor;
m[p] = k;
m[p + "b"] = k;
m[p + "i"] = ki;
m[p + "ib"] = ki;
return m;
AsSizeValue::get_mapping(bool kb_is_1000) {
if (kb_is_1000) {
static auto m = init_mapping(true);
return m;
static auto m = init_mapping(false);
return m;
namespace detail {
split_program_name(std::string commandline) {
// try to determine the programName
std::pair<std::string, std::string> vals;
trim(commandline);
auto esp = commandline.find_first_of(' ', 1);
while (detail::check_path(commandline.substr(0, esp).c_str()) !=
path_type::file) {
esp = commandline.find_first_of(' ', esp + 1);
if (esp == std::string::npos) {
// if we have reached the end and haven't found a valid file just assume
// the first argument is the program name
if (commandline[0] == '"' || commandline[0] == '\'' ||
commandline[0] == '`') {
bool embeddedQuote = false;
auto keyChar = commandline[0];
auto end = commandline.find_first_of(keyChar, 1);
while ((end != std::string::npos) &&
(commandline[end - 1] == '\\')) { // deal with escaped quotes
end = commandline.find_first_of(keyChar, end + 1);
embeddedQuote = true;
if (end != std::string::npos) {
vals.first = commandline.substr(1, end - 1);
esp = end + 1;
if (embeddedQuote) {
vals.first =
find_and_replace(vals.first, std::string("\\") + keyChar,
std::string(1, keyChar));
} else {
} else {
if (vals.first.empty()) {
vals.first = commandline.substr(0, esp);
rtrim(vals.first);
// strip the program name
vals.second = (esp < commandline.length() - 1) ? commandline.substr(esp + 1)
: std::string{};
ltrim(vals.second);
return vals;
class Option;
class App;
enum class AppFormatMode {
Normal,
All,
Sub,
class FormatterBase {
protected:
std::size_t column_width_{30};
std::size_t right_column_width_{65};
std::size_t description_paragraph_width_{80};
std::size_t footer_paragraph_width_{80};
std::map<std::string, std::string> labels_{};
FormatterBase() = default;
FormatterBase(const FormatterBase &) = default;
FormatterBase(FormatterBase &&) = default;
FormatterBase &operator=(const FormatterBase &) = default;
FormatterBase &operator=(FormatterBase &&) = default;
virtual ~FormatterBase() noexcept {} // NOLINT(modernize-use-equals-default)
virtual std::string make_help(const App *, std::string,
AppFormatMode) const = 0;
void label(std::string key, std::string val) { labels_[key] = val; }
void column_width(std::size_t val) { column_width_ = val; }
void right_column_width(std::size_t val) { right_column_width_ = val; }
void description_paragraph_width(std::size_t val) {
description_paragraph_width_ = val;
void footer_paragraph_width(std::size_t val) {
footer_paragraph_width_ = val;
CLI11_NODISCARD std::string get_label(std::string key) const {
if (labels_.find(key) == labels_.end())
return key;
return labels_.at(key);
CLI11_NODISCARD std::size_t get_column_width() const { return column_width_; }
CLI11_NODISCARD std::size_t get_right_column_width() const {
return right_column_width_;
CLI11_NODISCARD std::size_t get_description_paragraph_width() const {
return description_paragraph_width_;
CLI11_NODISCARD std::size_t get_footer_paragraph_width() const {
return footer_paragraph_width_;
class FormatterLambda final : public FormatterBase {
using funct_t =
std::function<std::string(const App *, std::string, AppFormatMode)>;
funct_t lambda_;
explicit FormatterLambda(funct_t funct) : lambda_(std::move(funct)) {}
~FormatterLambda() noexcept override {
std::string make_help(const App *app, std::string name,
AppFormatMode mode) const override {
return lambda_(app, name, mode);
class Formatter : public FormatterBase {
Formatter() = default;
Formatter(const Formatter &) = default;
Formatter(Formatter &&) = default;
Formatter &operator=(const Formatter &) = default;
Formatter &operator=(Formatter &&) = default;
make_group(std::string group, bool is_positional,
std::vector<const Option *> opts) const;
virtual std::string make_positionals(const App *app) const;
std::string make_groups(const App *app, AppFormatMode mode) const;
virtual std::string make_subcommands(const App *app,
virtual std::string make_subcommand(const App *sub) const;
virtual std::string make_expanded(const App *sub, AppFormatMode mode) const;
virtual std::string make_footer(const App *app) const;
virtual std::string make_description(const App *app) const;
virtual std::string make_usage(const App *app, std::string name) const;
std::string make_help(const App *app, std::string,
AppFormatMode mode) const override;
virtual std::string make_option(const Option *, bool) const;
virtual std::string make_option_name(const Option *, bool) const;
virtual std::string make_option_opts(const Option *) const;
virtual std::string make_option_desc(const Option *) const;
virtual std::string make_option_usage(const Option *opt) const;
using results_t = std::vector<std::string>;
using callback_t = std::function<bool(const results_t &)>;
class Option;
class App;
using Option_p = std::unique_ptr<Option>;
enum class MultiOptionPolicy : char {
Throw,
TakeLast,
TakeFirst,
Join,
TakeAll,
Sum,
Reverse,
template <typename CRTP> class OptionBase {
friend App;
protected:
std::string group_ = std::string("OPTIONS");
bool required_{false};
bool ignore_case_{false};
bool ignore_underscore_{false};
bool configurable_{true};
bool disable_flag_override_{false};
char delimiter_{'\0'};
bool always_capture_default_{false};
MultiOptionPolicy multi_option_policy_{MultiOptionPolicy::Throw};
template <typename T> void copy_to(T *other) const;
// setters
CRTP *group(const std::string &name) {
if (!detail::valid_alias_name_string(name)) {
throw IncorrectConstruction(
"Group names may not contain newlines or null characters");
group_ = name;
return static_cast<CRTP *>(this);
CRTP *required(bool value = true) {
required_ = value;
CRTP *mandatory(bool value = true) { return required(value); }
CRTP *always_capture_default(bool value = true) {
always_capture_default_ = value;
// Getters
CLI11_NODISCARD const std::string &get_group() const { return group_; }
CLI11_NODISCARD bool get_required() const { return required_; }
CLI11_NODISCARD bool get_ignore_case() const { return ignore_case_; }
CLI11_NODISCARD bool get_ignore_underscore() const {
return ignore_underscore_;
CLI11_NODISCARD bool get_configurable() const { return configurable_; }
CLI11_NODISCARD bool get_disable_flag_override() const {
return disable_flag_override_;
CLI11_NODISCARD char get_delimiter() const { return delimiter_; }
CLI11_NODISCARD bool get_always_capture_default() const {
return always_capture_default_;
CLI11_NODISCARD MultiOptionPolicy get_multi_option_policy() const {
return multi_option_policy_;
// Shortcuts for multi option policy
CRTP *take_last() {
auto *self = static_cast<CRTP *>(this);
self->multi_option_policy(MultiOptionPolicy::TakeLast);
return self;
CRTP *take_first() {
self->multi_option_policy(MultiOptionPolicy::TakeFirst);
return self;
CRTP *take_all() {
auto self = static_cast<CRTP *>(this);
self->multi_option_policy(MultiOptionPolicy::TakeAll);
return self;
CRTP *join() {
self->multi_option_policy(MultiOptionPolicy::Join);
return self;
CRTP *join(char delim) {
self->delimiter_ = delim;
return self;
CRTP *configurable(bool value = true) {
configurable_ = value;
CRTP *delimiter(char value = '\0') {
delimiter_ = value;
class OptionDefaults : public OptionBase<OptionDefaults> {
OptionDefaults() = default;
// Methods here need a different implementation if they are Option vs.
// OptionDefault
OptionDefaults *
multi_option_policy(MultiOptionPolicy value = MultiOptionPolicy::Throw) {
multi_option_policy_ = value;
return this;
OptionDefaults *ignore_case(bool value = true) {
ignore_case_ = value;
return this;
OptionDefaults *ignore_underscore(bool value = true) {
ignore_underscore_ = value;
return this;
OptionDefaults *disable_flag_override(bool value = true) {
disable_flag_override_ = value;
return this;
OptionDefaults *delimiter(char value = '\0') {
delimiter_ = value;
return this;
class Option : public OptionBase<Option> {
friend App;
protected:
std::vector<std::string> snames_{};
std::vector<std::string> lnames_{};
std::vector<std::pair<std::string, std::string>> default_flag_values_{};
std::vector<std::string> fnames_{};
std::string pname_{};
std::string envname_{};
std::string description_{};
std::string default_str_{};
std::string option_text_{};
std::function<std::string()> type_name_{[]() { return std::string(); }};
std::function<std::string()> default_function_{};
int type_size_max_{1};
int type_size_min_{1};
int expected_min_{1};
int expected_max_{1};
std::vector<Validator> validators_{};
std::set<Option *> needs_{};
std::set<Option *> excludes_{};
App *parent_{nullptr};
callback_t callback_{};
results_t results_{};
results_t proc_results_{};
enum class option_state : char {
parsing = 0,
validated = 2,
reduced = 4,
callback_run = 6,
option_state current_option_state_{option_state::parsing};
bool allow_extra_args_{false};
bool flag_like_{false};
bool run_callback_for_default_{false};
bool inject_separator_{false};
bool trigger_on_result_{false};
bool force_callback_{false};
Option(std::string option_name, std::string option_description,
callback_t callback, App *parent, bool allow_non_standard = false)
: description_(std::move(option_description)), parent_(parent),
callback_(std::move(callback)) {
std::tie(snames_, lnames_, pname_) =
detail::get_names(detail::split_names(option_name), allow_non_standard);
Option(const Option &) = delete;
Option &operator=(const Option &) = delete;
CLI11_NODISCARD std::size_t count() const { return results_.size(); }
CLI11_NODISCARD bool empty() const { return results_.empty(); }
explicit operator bool() const { return !empty() || force_callback_; }
void clear() {
results_.clear();
current_option_state_ = option_state::parsing;
Option *expected(int value);
Option *expected(int value_min, int value_max);
Option *allow_extra_args(bool value = true) {
allow_extra_args_ = value;
return this;
CLI11_NODISCARD bool get_allow_extra_args() const {
return allow_extra_args_;
Option *trigger_on_parse(bool value = true) {
trigger_on_result_ = value;
return this;
CLI11_NODISCARD bool get_trigger_on_parse() const {
return trigger_on_result_;
Option *force_callback(bool value = true) {
force_callback_ = value;
return this;
CLI11_NODISCARD bool get_force_callback() const { return force_callback_; }
Option *run_callback_for_default(bool value = true) {
run_callback_for_default_ = value;
return this;
CLI11_NODISCARD bool get_run_callback_for_default() const {
return run_callback_for_default_;
Option *check(Validator validator, const std::string &validator_name = "");
Option *check(std::function<std::string(const std::string &)> Validator,
std::string Validator_description = "",
std::string Validator_name = "");
Option *transform(Validator Validator,
const std::string &Validator_name = "");
Option *transform(const std::function<std::string(std::string)> &func,
std::string transform_description = "",
std::string transform_name = "");
Option *each(const std::function<void(std::string)> &func);
Validator *get_validator(const std::string &Validator_name = "");
Validator *get_validator(int index);
Option *needs(Option *opt) {
if (opt != this) {
needs_.insert(opt);
return this;
template <typename T = App> Option *needs(std::string opt_name) {
auto opt = static_cast<T *>(parent_)->get_option_no_throw(opt_name);
if (opt == nullptr) {
throw IncorrectConstruction::MissingOption(opt_name);
return needs(opt);
template <typename A, typename B, typename... ARG>
Option *needs(A opt, B opt1, ARG... args) {
needs(opt);
return needs(opt1, args...); // NOLINT(readability-suspicious-call-argument)
bool remove_needs(Option *opt);
Option *excludes(Option *opt);
template <typename T = App> Option *excludes(std::string opt_name) {
return excludes(opt);
Option *excludes(A opt, B opt1, ARG... args) {
excludes(opt);
return excludes(opt1, args...);
bool remove_excludes(Option *opt);
Option *envname(std::string name) {
envname_ = std::move(name);
return this;
template <typename T = App> Option *ignore_case(bool value = true);
template <typename T = App> Option *ignore_underscore(bool value = true);
Option *
multi_option_policy(MultiOptionPolicy value = MultiOptionPolicy::Throw);
Option *disable_flag_override(bool value = true) {
return this;
CLI11_NODISCARD int get_type_size() const { return type_size_min_; }
CLI11_NODISCARD int get_type_size_min() const { return type_size_min_; }
CLI11_NODISCARD int get_type_size_max() const { return type_size_max_; }
CLI11_NODISCARD bool get_inject_separator() const {
return inject_separator_;
CLI11_NODISCARD std::string get_envname() const { return envname_; }
CLI11_NODISCARD std::set<Option *> get_needs() const { return needs_; }
CLI11_NODISCARD std::set<Option *> get_excludes() const { return excludes_; }
CLI11_NODISCARD std::string get_default_str() const { return default_str_; }
CLI11_NODISCARD callback_t get_callback() const { return callback_; }
CLI11_NODISCARD const std::vector<std::string> &get_lnames() const {
return lnames_;
CLI11_NODISCARD const std::vector<std::string> &get_snames() const {
return snames_;
CLI11_NODISCARD const std::vector<std::string> &get_fnames() const {
return fnames_;
CLI11_NODISCARD const std::string &get_single_name() const {
if (!lnames_.empty()) {
return lnames_[0];
if (!snames_.empty()) {
return snames_[0];
if (!pname_.empty()) {
return pname_;
return envname_;
CLI11_NODISCARD int get_expected() const { return expected_min_; }
CLI11_NODISCARD int get_expected_min() const { return expected_min_; }
CLI11_NODISCARD int get_expected_max() const { return expected_max_; }
CLI11_NODISCARD int get_items_expected_min() const {
return type_size_min_ * expected_min_;
CLI11_NODISCARD int get_items_expected_max() const {
int t = type_size_max_;
return detail::checked_multiply(t, expected_max_)
? t
: detail::expected_max_vector_size;
CLI11_NODISCARD int get_items_expected() const {
return get_items_expected_min();
CLI11_NODISCARD bool get_positional() const { return !pname_.empty(); }
CLI11_NODISCARD bool nonpositional() const {
return (!lnames_.empty() || !snames_.empty());
CLI11_NODISCARD bool has_description() const { return !description_.empty(); }
CLI11_NODISCARD const std::string &get_description() const {
return description_;
Option *description(std::string option_description) {
description_ = std::move(option_description);
return this;
Option *option_text(std::string text) {
option_text_ = std::move(text);
return this;
CLI11_NODISCARD const std::string &get_option_text() const {
return option_text_;
get_name(bool positional = false,
bool all_options = false
) const;
void run_callback();
CLI11_NODISCARD const std::string &matching_name(const Option &other) const;
bool operator==(const Option &other) const {
return !matching_name(other).empty();
CLI11_NODISCARD bool check_name(const std::string &name) const;
CLI11_NODISCARD bool check_sname(std::string name) const {
return (detail::find_member(std::move(name), snames_, ignore_case_) >= 0);
CLI11_NODISCARD bool check_lname(std::string name) const {
return (detail::find_member(std::move(name), lnames_, ignore_case_,
ignore_underscore_) >= 0);
CLI11_NODISCARD bool check_fname(std::string name) const {
if (fnames_.empty()) {
return false;
return (detail::find_member(std::move(name), fnames_, ignore_case_,
CLI11_NODISCARD std::string get_flag_value(const std::string &name,
std::string input_value) const;
Option *add_result(std::string s);
Option *add_result(std::string s, int &results_added);
Option *add_result(std::vector<std::string> s);
CLI11_NODISCARD const results_t &results() const { return results_; }
CLI11_NODISCARD results_t reduced_results() const;
template <typename T> void results(T &output) const {
bool retval = false;
if (current_option_state_ >= option_state::reduced ||
(results_.size() == 1 && validators_.empty())) {
const results_t &res = (proc_results_.empty()) ? results_ : proc_results_;
retval = detail::lexical_conversion<T, T>(res, output);
} else {
results_t res;
if (results_.empty()) {
if (!default_str_.empty()) {
// _add_results takes an rvalue only
_add_result(std::string(default_str_), res);
_validate_results(res);
results_t extra;
_reduce_results(extra, res);
if (!extra.empty()) {
res = std::move(extra);
} else {
res.emplace_back();
} else {
res = reduced_results();
if (!retval) {
throw ConversionError(get_name(), results_);
template <typename T> CLI11_NODISCARD T as() const {
T output;
results(output);
return output;
CLI11_NODISCARD bool get_callback_run() const {
return (current_option_state_ == option_state::callback_run);
Option *type_name_fn(std::function<std::string()> typefun) {
type_name_ = std::move(typefun);
return this;
Option *type_name(std::string typeval) {
type_name_fn([typeval]() { return typeval; });
return this;
Option *type_size(int option_type_size);
Option *type_size(int option_type_size_min, int option_type_size_max);
void inject_separator(bool value = true) { inject_separator_ = value; }
Option *default_function(const std::function<std::string()> &func) {
default_function_ = func;
return this;
Option *capture_default_str() {
if (default_function_) {
default_str_ = default_function_();
return this;
Option *default_str(std::string val) {
default_str_ = std::move(val);
return this;
template <typename X> Option *default_val(const X &val) {
std::string val_str = detail::to_string(val);
auto old_option_state = current_option_state_;
results_t old_results{std::move(results_)};
results_.clear();
add_result(val_str);
// if trigger_on_result_ is set the callback already ran
if (run_callback_for_default_ && !trigger_on_result_) {
run_callback(); // run callback sets the state, we need to reset it
// again
} else {
_validate_results(results_);
current_option_state_ = old_option_state;
} catch (const ValidationError &err) {
// this should be done
results_ = std::move(old_results);
// try an alternate way to convert
std::string alternate = detail::value_string(val);
if (!alternate.empty() && alternate != val_str) {
return default_val(alternate);
get_name(),
std::string("given default value does not pass validation :") +
err.what());
} catch (const ConversionError &err) {
std::string("given default value(\"") + val_str +
"\") produces an error : " + err.what());
} catch (const CLI::Error &) {
throw;
default_str_ = std::move(val_str);
return this;
CLI11_NODISCARD std::string get_type_name() const;
private:
void _validate_results(results_t &res) const;
void _reduce_results(results_t &out, const results_t &original) const;
// Run a result through the Validators
std::string _validate(std::string &result, int index) const;
int _add_result(std::string &&result, std::vector<std::string> &res) const;
void OptionBase<CRTP>::copy_to(T *other) const {
other->group(group_);
other->required(required_);
other->ignore_case(ignore_case_);
other->ignore_underscore(ignore_underscore_);
other->configurable(configurable_);
other->disable_flag_override(disable_flag_override_);
other->delimiter(delimiter_);
other->always_capture_default(always_capture_default_);
other->multi_option_policy(multi_option_policy_);
CLI11_INLINE Option *Option::expected(int value) {
if (value < 0) {
expected_min_ = -value;
if (expected_max_ < expected_min_) {
expected_max_ = expected_min_;
allow_extra_args_ = true;
flag_like_ = false;
} else if (value == detail::expected_max_vector_size) {
expected_min_ = 1;
expected_max_ = detail::expected_max_vector_size;
flag_like_ = false;
} else {
expected_min_ = value;
expected_max_ = value;
flag_like_ = (expected_min_ == 0);
return this;
CLI11_INLINE Option *Option::expected(int value_min, int value_max) {
if (value_min < 0) {
value_min = -value_min;
if (value_max < 0) {
value_max = detail::expected_max_vector_size;
if (value_max < value_min) {
expected_min_ = value_max;
expected_max_ = value_min;
} else {
expected_max_ = value_max;
expected_min_ = value_min;
return this;
CLI11_INLINE Option *Option::check(Validator validator,
const std::string &validator_name) {
validator.non_modifying();
validators_.push_back(std::move(validator));
if (!validator_name.empty())
validators_.back().name(validator_name);
return this;
Option::check(std::function<std::string(const std::string &)> Validator,
std::string Validator_description, std::string Validator_name) {
validators_.emplace_back(Validator, std::move(Validator_description),
std::move(Validator_name));
validators_.back().non_modifying();
return this;
CLI11_INLINE Option *Option::transform(Validator Validator,
const std::string &Validator_name) {
validators_.insert(validators_.begin(), std::move(Validator));
if (!Validator_name.empty())
validators_.front().name(Validator_name);
return this;
Option::transform(const std::function<std::string(std::string)> &func,
std::string transform_description,
std::string transform_name) {
validators_.insert(validators_.begin(), Validator(
[func](std::string &val) {
val = func(val);
std::move(transform_description),
std::move(transform_name)));
return this;
Option::each(const std::function<void(std::string)> &func) {
[func](std::string &inout) {
func(inout);
std::string{});
return this;
CLI11_INLINE Validator *
Option::get_validator(const std::string &Validator_name) {
for (auto &Validator : validators_) {
if (Validator_name == Validator.get_name()) {
return &Validator;
if ((Validator_name.empty()) && (!validators_.empty())) {
return &(validators_.front());
throw OptionNotFound(std::string{"Validator "} + Validator_name +
" Not Found");
CLI11_INLINE Validator *Option::get_validator(int index) {
// This is an signed int so that it is not equivalent to a pointer.
if (index >= 0 && index < static_cast<int>(validators_.size())) {
return &(validators_[static_cast<decltype(validators_)::size_type>(index)]);
throw OptionNotFound("Validator index is not valid");
CLI11_INLINE bool Option::remove_needs(Option *opt) {
auto iterator = std::find(std::begin(needs_), std::end(needs_), opt);
if (iterator == std::end(needs_)) {
return false;
needs_.erase(iterator);
return true;
CLI11_INLINE Option *Option::excludes(Option *opt) {
if (opt == this) {
throw(IncorrectConstruction("and option cannot exclude itself"));
excludes_.insert(opt);
// Help text should be symmetric - excluding a should exclude b
opt->excludes_.insert(this);
// Ignoring the insert return value, excluding twice is now allowed.
// (Mostly to allow both directions to be excluded by user, even though the
// library does it for you.)
return this;
CLI11_INLINE bool Option::remove_excludes(Option *opt) {
auto iterator = std::find(std::begin(excludes_), std::end(excludes_), opt);
if (iterator == std::end(excludes_)) {
return false;
excludes_.erase(iterator);
return true;
template <typename T> Option *Option::ignore_case(bool value) {
if (!ignore_case_ && value) {
auto *parent = static_cast<T *>(parent_);
for (const Option_p &opt : parent->options_) {
if (opt.get() == this) {
continue;
const auto &omatch = opt->matching_name(*this);
if (!omatch.empty()) {
ignore_case_ = false;
throw OptionAlreadyAdded(
"adding ignore case caused a name conflict with " + omatch);
} else {
return this;
template <typename T> Option *Option::ignore_underscore(bool value) {
if (!ignore_underscore_ && value) {
continue;
ignore_underscore_ = false;
"adding ignore underscore caused a name conflict with " + omatch);
} else {
return this;
CLI11_INLINE Option *Option::multi_option_policy(MultiOptionPolicy value) {
if (value != multi_option_policy_) {
if (multi_option_policy_ == MultiOptionPolicy::Throw &&
expected_max_ == detail::expected_max_vector_size &&
expected_min_ > 1) { // this bizarre condition is to maintain backwards
// compatibility
// with the previous behavior of expected_ with vectors
return this;
CLI11_NODISCARD CLI11_INLINE std::string
Option::get_name(bool positional, bool all_options) const {
if (get_group().empty())
return {}; // Hidden
if (all_options) {
std::vector<std::string> name_list;
if ((positional && (!pname_.empty())) ||
(snames_.empty() && lnames_.empty())) {
name_list.push_back(pname_);
if ((get_items_expected() == 0) && (!fnames_.empty())) {
for (const std::string &sname : snames_) {
name_list.push_back("-" + sname);
if (check_fname(sname)) {
name_list.back() += "{" + get_flag_value(sname, "") + "}";
for (const std::string &lname : lnames_) {
name_list.push_back("--" + lname);
if (check_fname(lname)) {
name_list.back() += "{" + get_flag_value(lname, "") + "}";
} else {
return detail::join(name_list);
// This returns the positional name no matter what
if (positional)
return pname_;
// Prefer long name
return std::string(2, '-') + lnames_[0];
// Or short name if no long name
return std::string(1, '-') + snames_[0];
// If positional is the only name, it's okay to use that
return pname_;
CLI11_INLINE void Option::run_callback() {
bool used_default_str = false;
if (force_callback_ && results_.empty()) {
used_default_str = true;
add_result(default_str_);
if (current_option_state_ == option_state::parsing) {
current_option_state_ = option_state::validated;
if (current_option_state_ < option_state::reduced) {
_reduce_results(proc_results_, results_);
current_option_state_ = option_state::callback_run;
if (callback_) {
const results_t &send_results =
proc_results_.empty() ? results_ : proc_results_;
bool local_result = callback_(send_results);
if (used_default_str) {
// we only clear the results if the callback was actually used
// otherwise the callback is the storage of the default
results_.clear();
proc_results_.clear();
if (!local_result)
CLI11_NODISCARD CLI11_INLINE const std::string &
Option::matching_name(const Option &other) const {
static const std::string estring;
bool bothConfigurable = configurable_ && other.configurable_;
if (other.check_sname(sname))
return sname;
if (bothConfigurable && other.check_lname(sname))
return sname;
if (other.check_lname(lname))
return lname;
if (lname.size() == 1 && bothConfigurable) {
if (other.check_sname(lname)) {
return lname;
if (bothConfigurable && snames_.empty() && lnames_.empty() &&
!pname_.empty()) {
if (other.check_sname(pname_) || other.check_lname(pname_) ||
pname_ == other.pname_)
return pname_;
if (bothConfigurable && other.snames_.empty() && other.fnames_.empty() &&
!other.pname_.empty()) {
if (check_sname(other.pname_) || check_lname(other.pname_) ||
(pname_ == other.pname_))
return other.pname_;
if (ignore_case_ ||
ignore_underscore_) { // We need to do the inverse, in case we are
// ignore_case or ignore underscore
for (const std::string &sname : other.snames_)
if (check_sname(sname))
return sname;
for (const std::string &lname : other.lnames_)
if (check_lname(lname))
return lname;
return estring;
CLI11_NODISCARD CLI11_INLINE bool
Option::check_name(const std::string &name) const {
if (name.length() > 2 && name[0] == '-' && name[1] == '-')
return check_lname(name.substr(2));
if (name.length() > 1 && name.front() == '-')
return check_sname(name.substr(1));
std::string local_pname = pname_;
std::string local_name = name;
if (ignore_underscore_) {
local_pname = detail::remove_underscore(local_pname);
local_name = detail::remove_underscore(local_name);
if (ignore_case_) {
local_pname = detail::to_lower(local_pname);
local_name = detail::to_lower(local_name);
if (local_name == local_pname) {
return true;
if (!envname_.empty()) {
// this needs to be the original since envname_ shouldn't match on case
// insensitivity
return (name == envname_);
return false;
Option::get_flag_value(const std::string &name, std::string input_value) const {
static const std::string trueString{"true"};
static const std::string falseString{"false"};
static const std::string emptyString{"{}"};
// check for disable flag override_
if (disable_flag_override_) {
if (!((input_value.empty()) || (input_value == emptyString))) {
auto default_ind =
detail::find_member(name, fnames_, ignore_case_, ignore_underscore_);
if (default_ind >= 0) {
// We can static cast this to std::size_t because it is more than 0 in
// this block
if (default_flag_values_[static_cast<std::size_t>(default_ind)]
.second != input_value) {
if (input_value == default_str_ && force_callback_) {
return input_value;
throw(ArgumentMismatch::FlagOverride(name));
} else {
if (input_value != trueString) {
auto ind =
if ((input_value.empty()) || (input_value == emptyString)) {
if (flag_like_) {
return (ind < 0)
? trueString
: default_flag_values_[static_cast<std::size_t>(ind)].second;
return (ind < 0)
? default_str_
if (ind < 0) {
return input_value;
if (default_flag_values_[static_cast<std::size_t>(ind)].second ==
falseString) {
errno = 0;
auto val = detail::to_flag_value(input_value);
if (errno != 0) {
errno = 0;
return input_value;
return (val == 1) ? falseString
: (val == (-1) ? trueString : std::to_string(-val));
return input_value;
CLI11_INLINE Option *Option::add_result(std::string s) {
_add_result(std::move(s), results_);
return this;
CLI11_INLINE Option *Option::add_result(std::string s, int &results_added) {
results_added = _add_result(std::move(s), results_);
return this;
CLI11_INLINE Option *Option::add_result(std::vector<std::string> s) {
for (auto &str : s) {
_add_result(std::move(str), results_);
return this;
CLI11_NODISCARD CLI11_INLINE results_t Option::reduced_results() const {
results_t res = proc_results_.empty() ? results_ : proc_results_;
res = results_;
if (!res.empty()) {
results_t extra;
return res;
CLI11_INLINE Option *Option::type_size(int option_type_size) {
if (option_type_size < 0) {
// this section is included for backwards compatibility
type_size_max_ = -option_type_size;
type_size_min_ = -option_type_size;
} else {
type_size_max_ = option_type_size;
if (type_size_max_ < detail::expected_max_vector_size) {
type_size_min_ = option_type_size;
} else {
inject_separator_ = true;
if (type_size_max_ == 0)
required_ = false;
return this;
CLI11_INLINE Option *Option::type_size(int option_type_size_min,
int option_type_size_max) {
if (option_type_size_min < 0 || option_type_size_max < 0) {
option_type_size_min = (std::abs)(option_type_size_min);
option_type_size_max = (std::abs)(option_type_size_max);
if (option_type_size_min > option_type_size_max) {
type_size_max_ = option_type_size_min;
type_size_min_ = option_type_size_max;
} else {
type_size_min_ = option_type_size_min;
type_size_max_ = option_type_size_max;
if (type_size_max_ == 0) {
required_ = false;
if (type_size_max_ >= detail::expected_max_vector_size) {
return this;
CLI11_NODISCARD CLI11_INLINE std::string Option::get_type_name() const {
std::string full_type_name = type_name_();
if (!validators_.empty()) {
for (const auto &Validator : validators_) {
std::string vtype = Validator.get_description();
if (!vtype.empty()) {
full_type_name += ":" + vtype;
return full_type_name;
CLI11_INLINE void Option::_validate_results(results_t &res) const {
// Run the Validators (can change the string)
1) { // in this context index refers to the index in the type
int index = 0;
if (get_items_expected_max() < static_cast<int>(res.size()) &&
(multi_option_policy_ == CLI::MultiOptionPolicy::TakeLast ||
multi_option_policy_ == CLI::MultiOptionPolicy::Reverse)) {
// create a negative index for the earliest ones
index = get_items_expected_max() - static_cast<int>(res.size());
for (std::string &result : res) {
if (detail::is_separator(result) && type_size_max_ != type_size_min_ &&
index >= 0) {
index = 0; // reset index for variable size chunks
continue;
auto err_msg =
_validate(result, (index >= 0) ? (index % type_size_max_) : index);
if (!err_msg.empty())
throw ValidationError(get_name(), err_msg);
++index;
} else {
int index = 0;
if (expected_max_ < static_cast<int>(res.size()) &&
index = expected_max_ - static_cast<int>(res.size());
auto err_msg = _validate(result, index);
++index;
CLI11_INLINE void Option::_reduce_results(results_t &out,
const results_t &original) const {
// max num items expected or length of vector, always at least 1
// Only valid for a trimming policy
out.clear();
// Operation depends on the policy setting
switch (multi_option_policy_) {
case MultiOptionPolicy::TakeAll:
case MultiOptionPolicy::TakeLast: {
// Allow multi-option sizes (including 0)
std::size_t trim_size = std::min<std::size_t>(
static_cast<std::size_t>(std::max<int>(get_items_expected_max(), 1)),
original.size());
if (original.size() != trim_size) {
out.assign(original.end() -
static_cast<results_t::difference_type>(trim_size),
original.end());
} break;
case MultiOptionPolicy::Reverse: {
original.size());
if (original.size() != trim_size || trim_size > 1) {
original.end());
std::reverse(out.begin(), out.end());
} break;
case MultiOptionPolicy::TakeFirst: {
original.size());
out.assign(original.begin(),
original.begin() +
static_cast<results_t::difference_type>(trim_size));
} break;
case MultiOptionPolicy::Join:
if (results_.size() > 1) {
out.push_back(detail::join(
original, std::string(1, (delimiter_ == '\0') ? '\n' : delimiter_)));
case MultiOptionPolicy::Sum:
out.push_back(detail::sum_string_vector(original));
case MultiOptionPolicy::Throw:
default: {
auto num_min = static_cast<std::size_t>(get_items_expected_min());
auto num_max = static_cast<std::size_t>(get_items_expected_max());
if (num_min == 0) {
num_min = 1;
if (num_max == 0) {
num_max = 1;
if (original.size() < num_min) {
throw ArgumentMismatch::AtLeast(get_name(), static_cast<int>(num_min),
original.size());
if (original.size() > num_max) {
if (original.size() == 2 && num_max == 1 && original[1] == "%%" &&
original[0] == "{}") {
// this condition is a trap for the following empty indicator check on
// config files
out = original;
} else {
throw ArgumentMismatch::AtMost(get_name(), static_cast<int>(num_max),
original.size());
// this check is to allow an empty vector in certain circumstances but not if
// expected is not zero.
// {} is the indicator for an empty container
if (out.empty()) {
if (original.size() == 1 && original[0] == "{}" &&
get_items_expected_min() > 0) {
out.emplace_back("{}");
out.emplace_back("%%");
} else if (out.size() == 1 && out[0] == "{}" &&
CLI11_INLINE std::string Option::_validate(std::string &result,
int index) const {
std::string err_msg;
if (result.empty() && expected_min_ == 0) {
// an empty with nothing expected is allowed
return err_msg;
for (const auto &vali : validators_) {
auto v = vali.get_application_index();
if (v == -1 || v == index) {
err_msg = vali(result);
err_msg = err.what();
return err_msg;
CLI11_INLINE int Option::_add_result(std::string &&result,
std::vector<std::string> &res) const {
int result_count = 0;
// Handle the vector escape possibility all characters duplicated and starting
// with [[ ending with ]] this is always a single result
if (result.size() >= 4 && result[0] == '[' && result[1] == '[' &&
result.back() == ']' && (*(result.end() - 2) == ']')) {
// this is an escape clause for odd strings
std::string nstrs{'['};
bool duplicated{true};
for (std::size_t ii = 2; ii < result.size() - 2; ii += 2) {
if (result[ii] == result[ii + 1]) {
nstrs.push_back(result[ii]);
} else {
duplicated = false;
if (duplicated) {
nstrs.push_back(']');
res.push_back(std::move(nstrs));
++result_count;
return result_count;
if ((allow_extra_args_ || get_expected_max() > 1) && !result.empty() &&
result.front() == '[' &&
result.back() == ']') { // this is now a vector string likely from the
// default or user entry
result.pop_back();
result.erase(result.begin());
bool skipSection{false};
for (auto &var : CLI::detail::split_up(result, ',')) {
if (!var.empty()) {
result_count += _add_result(std::move(var), res);
if (!skipSection) {
if (delimiter_ == '\0') {
res.push_back(std::move(result));
++result_count;
} else {
if ((result.find_first_of(delimiter_) != std::string::npos)) {
for (const auto &var : CLI::detail::split(result, delimiter_)) {
if (!var.empty()) {
res.push_back(var);
++result_count;
} else {
++result_count;
#ifndef CLI11_PARSE
#define CLI11_PARSE(app, ...) \
try { \
(app).parse(__VA_ARGS__); \
} catch (const CLI::ParseError &e) { \
return (app).exit(e); \
#endif
namespace detail {
enum class Classifier {
NONE,
POSITIONAL_MARK,
SHORT,
LONG,
WINDOWS_STYLE,
SUBCOMMAND,
SUBCOMMAND_TERMINATOR
struct AppFriend;
} // namespace detail
namespace FailureMessage {
CLI11_INLINE std::string simple(const App *app, const Error &e);
CLI11_INLINE std::string help(const App *app, const Error &e);
} // namespace FailureMessage
enum class config_extras_mode : char { error = 0, ignore, ignore_all, capture };
class App;
using App_p = std::shared_ptr<App>;
namespace detail {
enable_if_t<!std::is_integral<T>::value || (sizeof(T) <= 1U),
Option *default_flag_modifiers(Option *opt) {
return opt->always_capture_default();
enable_if_t<std::is_integral<T>::value && (sizeof(T) > 1U),
return opt->multi_option_policy(MultiOptionPolicy::Sum)
->default_str("0")
->force_callback();
class Option_group;
class App {
friend Option;
friend detail::AppFriend;
protected:
// This library follows the Google style guide for member names ending in
// underscores
std::string name_{};
bool allow_extras_{false};
config_extras_mode allow_config_extras_{config_extras_mode::ignore};
bool prefix_command_{false};
bool has_automatic_name_{false};
bool disabled_{false};
bool pre_parse_called_{false};
bool immediate_callback_{false};
std::function<void(std::size_t)> pre_parse_callback_{};
std::function<void()> parse_complete_callback_{};
std::function<void()> final_callback_{};
OptionDefaults option_defaults_{};
std::vector<Option_p> options_{};
std::string usage_{};
std::function<std::string()> usage_callback_{};
std::string footer_{};
std::function<std::string()> footer_callback_{};
Option *help_ptr_{nullptr};
Option *help_all_ptr_{nullptr};
Option *version_ptr_{nullptr};
std::shared_ptr<FormatterBase> formatter_{new Formatter()};
std::function<std::string(const App *, const Error &e)> failure_message_{
FailureMessage::simple};
using missing_t = std::vector<std::pair<detail::Classifier, std::string>>;
missing_t missing_{};
std::vector<Option *> parse_order_{};
std::vector<App *> parsed_subcommands_{};
std::set<App *> exclude_subcommands_{};
std::set<Option *> exclude_options_{};
std::set<App *> need_subcommands_{};
std::set<Option *> need_options_{};
std::vector<App_p> subcommands_{};
bool fallthrough_{false};
bool subcommand_fallthrough_{true};
bool allow_windows_style_options_{
#ifdef _WIN32
true
#else
false
#endif
bool positionals_at_end_{false};
enum class startup_mode : char { stable, enabled, disabled };
startup_mode default_startup{startup_mode::stable};
bool configurable_{false};
bool validate_positionals_{false};
bool validate_optional_arguments_{false};
bool silent_{false};
bool allow_non_standard_options_{false};
std::uint32_t parsed_{0U};
std::size_t require_subcommand_min_{0};
std::size_t require_subcommand_max_{0};
std::size_t require_option_min_{0};
std::size_t require_option_max_{0};
std::string group_{"SUBCOMMANDS"};
std::vector<std::string> aliases_{};
Option *config_ptr_{nullptr};
std::shared_ptr<Config> config_formatter_{new ConfigTOML()};
#ifdef _WIN32
std::vector<std::string> normalized_argv_{};
std::vector<char *> normalized_argv_view_{};
#endif
App(std::string app_description, std::string app_name, App *parent);
explicit App(std::string app_description = "", std::string app_name = "")
: App(app_description, app_name, nullptr) {
set_help_flag("-h,--help", "Print this help message and exit");
App(const App &) = delete;
App &operator=(const App &) = delete;
virtual ~App() = default;
CLI11_NODISCARD char **ensure_utf8(char **argv);
App *callback(std::function<void()> app_callback) {
if (immediate_callback_) {
parse_complete_callback_ = std::move(app_callback);
} else {
final_callback_ = std::move(app_callback);
return this;
App *final_callback(std::function<void()> app_callback) {
return this;
App *parse_complete_callback(std::function<void()> pc_callback) {
parse_complete_callback_ = std::move(pc_callback);
return this;
App *preparse_callback(std::function<void(std::size_t)> pp_callback) {
pre_parse_callback_ = std::move(pp_callback);
return this;
App *name(std::string app_name = "");
App *alias(std::string app_name);
App *allow_extras(bool allow = true) {
allow_extras_ = allow;
return this;
App *required(bool require = true) {
required_ = require;
return this;
App *disabled(bool disable = true) {
disabled_ = disable;
return this;
App *silent(bool silence = true) {
silent_ = silence;
return this;
App *allow_non_standard_option_names(bool allowed = true) {
allow_non_standard_options_ = allowed;
return this;
App *disabled_by_default(bool disable = true) {
if (disable) {
default_startup = startup_mode::disabled;
} else {
default_startup = (default_startup == startup_mode::enabled)
? startup_mode::enabled
: startup_mode::stable;
return this;
App *enabled_by_default(bool enable = true) {
if (enable) {
default_startup = startup_mode::enabled;
} else {
default_startup = (default_startup == startup_mode::disabled)
? startup_mode::disabled
return this;
App *immediate_callback(bool immediate = true);
App *validate_positionals(bool validate = true) {
validate_positionals_ = validate;
return this;
App *validate_optional_arguments(bool validate = true) {
validate_optional_arguments_ = validate;
return this;
App *allow_config_extras(bool allow = true) {
if (allow) {
allow_config_extras_ = config_extras_mode::capture;
allow_extras_ = true;
} else {
allow_config_extras_ = config_extras_mode::error;
return this;
App *allow_config_extras(config_extras_mode mode) {
allow_config_extras_ = mode;
return this;
App *prefix_command(bool is_prefix = true) {
prefix_command_ = is_prefix;
return this;
App *ignore_case(bool value = true);
App *allow_windows_style_options(bool value = true) {
allow_windows_style_options_ = value;
return this;
App *positionals_at_end(bool value = true) {
positionals_at_end_ = value;
return this;
App *configurable(bool value = true) {
return this;
App *ignore_underscore(bool value = true);
App *formatter(std::shared_ptr<FormatterBase> fmt) {
formatter_ = fmt;
return this;
App *formatter_fn(
std::function<std::string(const App *, std::string, AppFormatMode)> fmt) {
formatter_ = std::make_shared<FormatterLambda>(fmt);
return this;
App *config_formatter(std::shared_ptr<Config> fmt) {
config_formatter_ = fmt;
return this;
CLI11_NODISCARD bool parsed() const { return parsed_ > 0; }
OptionDefaults *option_defaults() { return &option_defaults_; }
Option *add_option(std::string option_name, callback_t option_callback,
std::string option_description = "",
bool defaulted = false,
std::function<std::string()> func = {});
template <typename AssignTo, typename ConvertTo = AssignTo,
enable_if_t<!std::is_const<ConvertTo>::value, detail::enabler> =
detail::dummy>
AssignTo &variable,
std::string option_description = "") {
auto fun = [&variable](const CLI::results_t &res) { // comment for spacing
return detail::lexical_conversion<AssignTo, ConvertTo>(res, variable);
Option *opt =
add_option(option_name, fun, option_description, false, [&variable]() {
return CLI::detail::checked_to_string<AssignTo, ConvertTo>(variable);
opt->type_name(detail::type_name<ConvertTo>());
// these must be actual lvalues since (std::max) sometimes is defined in
// terms of references and references to structs used in the evaluation can
// be temporary so that would cause issues.
auto Tcount = detail::type_count<AssignTo>::value;
auto XCcount = detail::type_count<ConvertTo>::value;
opt->type_size(detail::type_count_min<ConvertTo>::value,
(std::max)(Tcount, XCcount));
opt->expected(detail::expected_count<ConvertTo>::value);
opt->run_callback_for_default();
return opt;
template <typename AssignTo, enable_if_t<!std::is_const<AssignTo>::value,
detail::enabler> = detail::dummy>
Option *add_option_no_stream(std::string option_name,
AssignTo &variable,
return detail::lexical_conversion<AssignTo, AssignTo>(res, variable);
Option *opt = add_option(option_name, fun, option_description, false,
[]() { return std::string{}; });
opt->type_name(detail::type_name<AssignTo>());
opt->type_size(detail::type_count_min<AssignTo>::value,
detail::type_count<AssignTo>::value);
opt->expected(detail::expected_count<AssignTo>::value);
return opt;
template <typename ArgType>
Option *add_option_function(std::string option_name,
const std::function<void(const ArgType &)>
&func,
auto fun = [func](const CLI::results_t &res) {
ArgType variable;
bool result = detail::lexical_conversion<ArgType, ArgType>(res, variable);
if (result) {
func(variable);
return result;
Option *opt =
add_option(option_name, std::move(fun), option_description, false);
opt->type_name(detail::type_name<ArgType>());
opt->type_size(detail::type_count_min<ArgType>::value,
detail::type_count<ArgType>::value);
opt->expected(detail::expected_count<ArgType>::value);
return opt;
Option *add_option(std::string option_name) {
return add_option(option_name, CLI::callback_t{}, std::string{}, false);
enable_if_t<std::is_const<T>::value &&
std::is_constructible<std::string, T>::value,
Option *add_option(std::string option_name, T &option_description) {
return add_option(option_name, CLI::callback_t(), option_description,
false);
Option *set_help_flag(std::string flag_name = "",
const std::string &help_description = "");
Option *set_help_all_flag(std::string help_name = "",
Option *set_version_flag(std::string flag_name = "",
const std::string &versionString = "",
const std::string &version_help =
"Display program version information and exit");
Option *set_version_flag(std::string flag_name,
std::function<std::string()> vfunc,
private:
Option *_add_flag_internal(std::string flag_name, CLI::callback_t fun,
std::string flag_description);
Option *add_flag(std::string flag_name) {
return _add_flag_internal(flag_name, CLI::callback_t(), std::string{});
template <typename T,
Option *add_flag(std::string flag_name, T &flag_description) {
return _add_flag_internal(flag_name, CLI::callback_t(), flag_description);
template <
typename T,
enable_if_t<
!detail::is_mutable_container<T>::value && !std::is_const<T>::value &&
!std::is_constructible<std::function<void(int)>, T>::value,
T &flag_result,
std::string flag_description = "") {
CLI::callback_t fun = [&flag_result](const CLI::results_t &res) {
using CLI::detail::lexical_cast;
return lexical_cast(res[0], flag_result);
auto *opt = _add_flag_internal(flag_name, std::move(fun),
std::move(flag_description));
return detail::default_flag_modifiers<T>(opt);
enable_if_t<!std::is_assignable<std::function<void(std::int64_t)> &,
T>::value,
std::vector<T> &flag_results,
CLI::callback_t fun = [&flag_results](const CLI::results_t &res) {
bool retval = true;
for (const auto &elem : res) {
flag_results.emplace_back();
retval &= lexical_cast(elem, flag_results.back());
return retval;
return _add_flag_internal(flag_name, std::move(fun),
Option *add_flag_callback(
std::function<void(void)> function,
std::string flag_description = "");
Option *add_flag_function(std::string flag_name,
function,
#ifdef CLI11_CPP14
function,
return add_flag_function(std::move(flag_name), std::move(function),
#endif
Option *set_config(std::string option_name = "",
std::string default_filename = "",
const std::string &help_message = "Read an ini file",
bool config_required = false);
bool remove_option(Option *opt);
template <typename T = Option_group>
T *add_option_group(std::string group_name,
std::string group_description = "") {
if (!detail::valid_alias_name_string(group_name)) {
"option group names may not contain newlines or null characters");
auto option_group =
std::make_shared<T>(std::move(group_description), group_name, this);
auto *ptr = option_group.get();
// move to App_p for overload resolution on older gcc versions
App_p app_ptr = std::dynamic_pointer_cast<App>(option_group);
add_subcommand(std::move(app_ptr));
return ptr;
App *add_subcommand(std::string subcommand_name = "",
std::string subcommand_description = "");
App *add_subcommand(CLI::App_p subcom);
bool remove_subcommand(App *subcom);
App *get_subcommand(const App *subcom) const;
CLI11_NODISCARD App *get_subcommand(std::string subcom) const;
get_subcommand_no_throw(std::string subcom) const noexcept;
CLI11_NODISCARD App *get_subcommand(int index = 0) const;
CLI::App_p get_subcommand_ptr(App *subcom) const;
CLI11_NODISCARD CLI::App_p get_subcommand_ptr(std::string subcom) const;
CLI11_NODISCARD CLI::App_p get_subcommand_ptr(int index = 0) const;
CLI11_NODISCARD App *get_option_group(std::string group_name) const;
CLI11_NODISCARD std::size_t count() const { return parsed_; }
CLI11_NODISCARD std::size_t count_all() const;
App *group(std::string group_name) {
group_ = group_name;
return this;
App *require_subcommand() {
require_subcommand_min_ = 1;
require_subcommand_max_ = 0;
return this;
App *require_subcommand(int value) {
if (value < 0) {
require_subcommand_min_ = 0;
require_subcommand_max_ = static_cast<std::size_t>(-value);
} else {
require_subcommand_min_ = static_cast<std::size_t>(value);
require_subcommand_max_ = static_cast<std::size_t>(value);
return this;
App *require_subcommand(std::size_t min, std::size_t max) {
require_subcommand_min_ = min;
require_subcommand_max_ = max;
return this;
App *require_option() {
require_option_min_ = 1;
require_option_max_ = 0;
return this;
App *require_option(int value) {
if (value < 0) {
require_option_min_ = 0;
require_option_max_ = static_cast<std::size_t>(-value);
} else {
require_option_min_ = static_cast<std::size_t>(value);
require_option_max_ = static_cast<std::size_t>(value);
return this;
App *require_option(std::size_t min, std::size_t max) {
require_option_min_ = min;
require_option_max_ = max;
return this;
App *fallthrough(bool value = true) {
fallthrough_ = value;
return this;
App *subcommand_fallthrough(bool value = true) {
subcommand_fallthrough_ = value;
return this;
explicit operator bool() const { return parsed_ > 0; }
virtual void pre_callback() {}
void clear();
void parse(int argc, const char *const *argv);
void parse(int argc, const wchar_t *const *argv);
private:
template <class CharT> void parse_char_t(int argc, const CharT *const *argv);
void parse(std::string commandline, bool program_name_included = false);
void parse(std::wstring commandline, bool program_name_included = false);
void parse(std::vector<std::string> &args);
void parse(std::vector<std::string> &&args);
void parse_from_stream(std::istream &input);
void failure_message(
std::function<std::string(const App *, const Error &e)> function) {
failure_message_ = function;
int exit(const Error &e, std::ostream &out = std::cout,
std::ostream &err = std::cerr) const;
CLI11_NODISCARD std::size_t count(std::string option_name) const {
return get_option(option_name)->count();
CLI11_NODISCARD std::vector<App *> get_subcommands() const {
return parsed_subcommands_;
std::vector<const App *>
get_subcommands(const std::function<bool(const App *)> &filter) const;
std::vector<App *> get_subcommands(const std::function<bool(App *)> &filter);
bool got_subcommand(const App *subcom) const {
// get subcom needed to verify that this was a real subcommand
return get_subcommand(subcom)->parsed_ > 0;
got_subcommand(std::string subcommand_name) const noexcept {
App *sub = get_subcommand_no_throw(subcommand_name);
return (sub != nullptr) ? (sub->parsed_ > 0) : false;
App *excludes(Option *opt) {
throw OptionNotFound("nullptr passed");
exclude_options_.insert(opt);
return this;
App *excludes(App *app) {
if (app == nullptr) {
if (app == this) {
throw OptionNotFound("cannot self reference in needs");
auto res = exclude_subcommands_.insert(app);
// subcommand exclusion should be symmetric
if (res.second) {
app->exclude_subcommands_.insert(this);
return this;
App *needs(Option *opt) {
need_options_.insert(opt);
return this;
App *needs(App *app) {
if (app == this) {
need_subcommands_.insert(app);
return this;
bool remove_excludes(App *app);
bool remove_needs(App *app);
App *usage(std::string usage_string) {
usage_ = std::move(usage_string);
return this;
App *usage(std::function<std::string()> usage_function) {
usage_callback_ = std::move(usage_function);
return this;
App *footer(std::string footer_string) {
footer_ = std::move(footer_string);
return this;
App *footer(std::function<std::string()> footer_function) {
footer_callback_ = std::move(footer_function);
return this;
config_to_str(bool default_also = false,
bool write_description = false) const {
return config_formatter_->to_config(this, default_also, write_description,
help(std::string prev = "", AppFormatMode mode = AppFormatMode::Normal) const;
CLI11_NODISCARD std::string version() const;
CLI11_NODISCARD std::shared_ptr<FormatterBase> get_formatter() const {
return formatter_;
CLI11_NODISCARD std::shared_ptr<Config> get_config_formatter() const {
return config_formatter_;
CLI11_NODISCARD std::shared_ptr<ConfigBase>
get_config_formatter_base() const {
// This is safer as a dynamic_cast if we have RTTI, as Config -> ConfigBase
#if CLI11_USE_STATIC_RTTI == 0
return std::dynamic_pointer_cast<ConfigBase>(config_formatter_);
#else
return std::static_pointer_cast<ConfigBase>(config_formatter_);
#endif
CLI11_NODISCARD std::string get_description() const { return description_; }
App *description(std::string app_description) {
description_ = std::move(app_description);
return this;
get_options(const std::function<bool(const Option *)> filter = {}) const;
get_options(const std::function<bool(Option *)> filter = {});
CLI11_NODISCARD Option *get_option_no_throw(std::string option_name) noexcept;
CLI11_NODISCARD const Option *
get_option_no_throw(std::string option_name) const noexcept;
CLI11_NODISCARD const Option *get_option(std::string option_name) const {
const auto *opt = get_option_no_throw(option_name);
throw OptionNotFound(option_name);
return opt;
Option *get_option(std::string option_name) {
return opt;
const Option *operator[](const std::string &option_name) const {
return get_option(option_name);
const Option *operator[](const char *option_name) const {
CLI11_NODISCARD bool get_fallthrough() const { return fallthrough_; }
CLI11_NODISCARD bool get_subcommand_fallthrough() const {
return subcommand_fallthrough_;
CLI11_NODISCARD bool get_allow_windows_style_options() const {
return allow_windows_style_options_;
CLI11_NODISCARD bool get_positionals_at_end() const {
return positionals_at_end_;
CLI11_NODISCARD std::string get_usage() const {
return (usage_callback_) ? usage_callback_() + '\n' + usage_ : usage_;
CLI11_NODISCARD std::string get_footer() const {
return (footer_callback_) ? footer_callback_() + '\n' + footer_ : footer_;
CLI11_NODISCARD std::size_t get_require_subcommand_min() const {
return require_subcommand_min_;
CLI11_NODISCARD std::size_t get_require_subcommand_max() const {
return require_subcommand_max_;
CLI11_NODISCARD std::size_t get_require_option_min() const {
return require_option_min_;
CLI11_NODISCARD std::size_t get_require_option_max() const {
return require_option_max_;
CLI11_NODISCARD bool get_prefix_command() const { return prefix_command_; }
CLI11_NODISCARD bool get_allow_extras() const { return allow_extras_; }
CLI11_NODISCARD bool get_disabled() const { return disabled_; }
CLI11_NODISCARD bool get_silent() const { return silent_; }
CLI11_NODISCARD bool get_allow_non_standard_option_names() const {
return allow_non_standard_options_;
CLI11_NODISCARD bool get_immediate_callback() const {
return immediate_callback_;
CLI11_NODISCARD bool get_disabled_by_default() const {
return (default_startup == startup_mode::disabled);
CLI11_NODISCARD bool get_enabled_by_default() const {
return (default_startup == startup_mode::enabled);
CLI11_NODISCARD bool get_validate_positionals() const {
return validate_positionals_;
CLI11_NODISCARD bool get_validate_optional_arguments() const {
return validate_optional_arguments_;
CLI11_NODISCARD config_extras_mode get_allow_config_extras() const {
return allow_config_extras_;
Option *get_help_ptr() { return help_ptr_; }
CLI11_NODISCARD const Option *get_help_ptr() const { return help_ptr_; }
CLI11_NODISCARD const Option *get_help_all_ptr() const {
return help_all_ptr_;
Option *get_config_ptr() { return config_ptr_; }
CLI11_NODISCARD const Option *get_config_ptr() const { return config_ptr_; }
Option *get_version_ptr() { return version_ptr_; }
CLI11_NODISCARD const Option *get_version_ptr() const { return version_ptr_; }
App *get_parent() { return parent_; }
CLI11_NODISCARD const App *get_parent() const { return parent_; }
CLI11_NODISCARD const std::string &get_name() const { return name_; }
CLI11_NODISCARD const std::vector<std::string> &get_aliases() const {
return aliases_;
App *clear_aliases() {
aliases_.clear();
return this;
CLI11_NODISCARD std::string get_display_name(bool with_aliases = false) const;
CLI11_NODISCARD bool check_name(std::string name_to_check) const;
CLI11_NODISCARD std::vector<std::string> get_groups() const;
CLI11_NODISCARD const std::vector<Option *> &parse_order() const {
return parse_order_;
remaining(bool recurse = false) const;
remaining_for_passthrough(bool recurse = false) const;
CLI11_NODISCARD std::size_t remaining_size(bool recurse = false) const;
protected:
void _validate() const;
void _configure();
void run_callback(bool final_mode = false,
bool suppress_final_callback = false);
CLI11_NODISCARD bool _valid_subcommand(const std::string &current,
bool ignore_used = true) const;
CLI11_NODISCARD detail::Classifier
_recognize(const std::string &current,
bool ignore_used_subcommands = true) const;
// The parse function is now broken into several parts, and part of process
void _process_config_file();
bool _process_config_file(const std::string &config_file, bool throw_error);
void _process_env();
void _process_callbacks();
void _process_help_flags(bool trigger_help = false,
bool trigger_all_help = false) const;
void _process_requirements();
void _process();
void _process_extras();
void _process_extras(std::vector<std::string> &args);
void increment_parsed();
void _parse(std::vector<std::string> &args);
void _parse(std::vector<std::string> &&args);
void _parse_stream(std::istream &input);
void _parse_config(const std::vector<ConfigItem> &args);
bool _parse_single_config(const ConfigItem &item, std::size_t level = 0);
bool _parse_single(std::vector<std::string> &args, bool &positional_only);
_count_remaining_positionals(bool required_only = false) const;
CLI11_NODISCARD bool _has_remaining_positionals() const;
bool _parse_positional(std::vector<std::string> &args, bool haltOnSubcommand);
CLI11_NODISCARD App *_find_subcommand(const std::string &subc_name,
bool ignore_disabled,
bool ignore_used) const noexcept;
bool _parse_subcommand(std::vector<std::string> &args);
bool _parse_arg(std::vector<std::string> &args,
detail::Classifier current_type, bool local_processing_only);
void _trigger_pre_parse(std::size_t remaining_args);
App *_get_fallthrough_parent();
_compare_subcommand_names(const App &subcom, const App &base) const;
void _move_to_missing(detail::Classifier val_type, const std::string &val);
void _move_option(Option *opt, App *app);
}; // namespace CLI
class Option_group : public App {
Option_group(std::string group_description, std::string group_name,
App *parent)
: App(std::move(group_description), "", parent) {
group(group_name);
// option groups should have automatic fallthrough
if (group_name.empty() || group_name.front() == '+') {
// help will not be used by default in these contexts
set_help_flag("");
set_help_all_flag("");
using App::add_option;
Option *add_option(Option *opt) {
if (get_parent() == nullptr) {
throw OptionNotFound("Unable to locate the specified option");
get_parent()->_move_option(opt, this);
return opt;
void add_options(Option *opt) { add_option(opt); }
template <typename... Args> void add_options(Option *opt, Args... args) {
add_option(opt);
add_options(args...);
using App::add_subcommand;
App *add_subcommand(App *subcom) {
App_p subc = subcom->get_parent()->get_subcommand_ptr(subcom);
subc->get_parent()->remove_subcommand(subcom);
add_subcommand(std::move(subc));
return subcom;
CLI11_INLINE void TriggerOn(App *trigger_app, App *app_to_enable);
std::vector<App *> apps_to_enable);
CLI11_INLINE void TriggerOff(App *trigger_app, App *app_to_enable);
CLI11_INLINE void deprecate_option(Option *opt,
const std::string &replacement = "");
inline void deprecate_option(App *app, const std::string &option_name,
const std::string &replacement = "") {
auto *opt = app->get_option(option_name);
deprecate_option(opt, replacement);
inline void deprecate_option(App &app, const std::string &option_name,
auto *opt = app.get_option(option_name);
CLI11_INLINE void retire_option(App *app, Option *opt);
CLI11_INLINE void retire_option(App &app, Option *opt);
CLI11_INLINE void retire_option(App *app, const std::string &option_name);
CLI11_INLINE void retire_option(App &app, const std::string &option_name);
namespace detail {
struct AppFriend {
#ifdef CLI11_CPP14
static decltype(auto) parse_arg(App *app, Args &&...args) {
return app->_parse_arg(std::forward<Args>(args)...);
static decltype(auto) parse_subcommand(App *app, Args &&...args) {
return app->_parse_subcommand(std::forward<Args>(args)...);
#else
static auto parse_arg(App *app, Args &&...args) ->
typename std::result_of<decltype (&App::_parse_arg)(App, Args...)>::type {
static auto parse_subcommand(App *app, Args &&...args) ->
decltype (&App::_parse_subcommand)(App, Args...)>::type {
#endif
static App *get_fallthrough_parent(App *app) {
return app->_get_fallthrough_parent();
CLI11_INLINE App::App(std::string app_description, std::string app_name,
App *parent)
: name_(std::move(app_name)), description_(std::move(app_description)),
parent_(parent) {
// Inherit if not from a nullptr
if (parent_ != nullptr) {
if (parent_->help_ptr_ != nullptr)
set_help_flag(parent_->help_ptr_->get_name(false, true),
parent_->help_ptr_->get_description());
if (parent_->help_all_ptr_ != nullptr)
set_help_all_flag(parent_->help_all_ptr_->get_name(false, true),
parent_->help_all_ptr_->get_description());
option_defaults_ = parent_->option_defaults_;
// INHERITABLE
failure_message_ = parent_->failure_message_;
allow_extras_ = parent_->allow_extras_;
allow_config_extras_ = parent_->allow_config_extras_;
prefix_command_ = parent_->prefix_command_;
immediate_callback_ = parent_->immediate_callback_;
ignore_case_ = parent_->ignore_case_;
ignore_underscore_ = parent_->ignore_underscore_;
fallthrough_ = parent_->fallthrough_;
validate_positionals_ = parent_->validate_positionals_;
validate_optional_arguments_ = parent_->validate_optional_arguments_;
configurable_ = parent_->configurable_;
allow_windows_style_options_ = parent_->allow_windows_style_options_;
group_ = parent_->group_;
usage_ = parent_->usage_;
footer_ = parent_->footer_;
formatter_ = parent_->formatter_;
config_formatter_ = parent_->config_formatter_;
require_subcommand_max_ = parent_->require_subcommand_max_;
CLI11_NODISCARD CLI11_INLINE char **App::ensure_utf8(char **argv) {
#ifdef _WIN32
(void)argv;
normalized_argv_ = detail::compute_win32_argv();
if (!normalized_argv_view_.empty()) {
normalized_argv_view_.clear();
normalized_argv_view_.reserve(normalized_argv_.size());
for (auto &arg : normalized_argv_) {
// using const_cast is well-defined, string is known to not be const.
normalized_argv_view_.push_back(const_cast<char *>(arg.data()));
return normalized_argv_view_.data();
#else
return argv;
#endif
CLI11_INLINE App *App::name(std::string app_name) {
std::string oname = name_;
name_ = app_name;
const auto &res =
_compare_subcommand_names(*this, *_get_fallthrough_parent());
if (!res.empty()) {
name_ = oname;
throw(OptionAlreadyAdded(app_name +
" conflicts with existing subcommand names"));
} else {
name_ = app_name;
has_automatic_name_ = false;
return this;
CLI11_INLINE App *App::alias(std::string app_name) {
if (app_name.empty() || !detail::valid_alias_name_string(app_name)) {
"Aliases may not be empty or contain newlines or null characters");
aliases_.push_back(app_name);
const auto &res =
if (!res.empty()) {
aliases_.pop_back();
"alias already matches an existing subcommand: " + app_name));
} else {
return this;
CLI11_INLINE App *App::immediate_callback(bool immediate) {
immediate_callback_ = immediate;
if (final_callback_ && !(parse_complete_callback_)) {
std::swap(final_callback_, parse_complete_callback_);
} else if (!(final_callback_) && parse_complete_callback_) {
return this;
CLI11_INLINE App *App::ignore_case(bool value) {
if (value && !ignore_case_) {
ignore_case_ = true;
auto *p = (parent_ != nullptr) ? _get_fallthrough_parent() : this;
const auto &match = _compare_subcommand_names(*this, *p);
if (!match.empty()) {
ignore_case_ = false; // we are throwing so need to be exception invariant
"ignore case would cause subcommand name conflicts: " + match);
return this;
CLI11_INLINE App *App::ignore_underscore(bool value) {
if (value && !ignore_underscore_) {
ignore_underscore_ = true;
"ignore underscore would cause subcommand name conflicts: " + match);
return this;
CLI11_INLINE Option *App::add_option(std::string option_name,
bool defaulted,
std::function<std::string()> func) {
Option myopt{option_name, option_description, option_callback, this,
allow_non_standard_options_};
if (std::find_if(std::begin(options_), std::end(options_),
[&myopt](const Option_p &v) { return *v == myopt; }) ==
std::end(options_)) {
if (myopt.lnames_.empty() && myopt.snames_.empty()) {
// if the option is positional only there is additional potential for
// ambiguities in config files and needs to be checked
std::string test_name = "--" + myopt.get_single_name();
if (test_name.size() == 3) {
test_name.erase(0, 1);
auto *op = get_option_no_throw(test_name);
if (op != nullptr && op->get_configurable()) {
"added option positional name matches existing option: " +
test_name));
} else if (parent_ != nullptr) {
for (auto &ln : myopt.lnames_) {
auto *op = parent_->get_option_no_throw(ln);
"added option matches existing positional option: " + ln));
for (auto &sn : myopt.snames_) {
auto *op = parent_->get_option_no_throw(sn);
"added option matches existing positional option: " + sn));
if (allow_non_standard_options_ && !myopt.snames_.empty()) {
for (auto &sname : myopt.snames_) {
if (sname.length() > 1) {
std::string test_name;
test_name.push_back('-');
test_name.push_back(sname.front());
if (op != nullptr) {
"added option interferes with existing short option: " +
sname));
for (auto &opt : options_) {
for (const auto &osn : opt->snames_) {
if (osn.size() > 1) {
test_name.push_back(osn.front());
if (myopt.check_sname(test_name)) {
throw(OptionAlreadyAdded("added option interferes with existing "
"non standard option: " +
osn));
options_.emplace_back();
Option_p &option = options_.back();
option.reset(new Option(option_name, option_description, option_callback,
this, allow_non_standard_options_));
// Set the default string capture function
option->default_function(func);
// For compatibility with CLI11 1.7 and before, capture the default string
// here
if (defaulted)
option->capture_default_str();
// Transfer defaults to the new option
option_defaults_.copy_to(option.get());
// Don't bother to capture if we already did
if (!defaulted && option->get_always_capture_default())
return option.get();
// we know something matches now find what it is so we can produce more error
// information
const auto &matchname = opt->matching_name(myopt);
if (!matchname.empty()) {
throw(OptionAlreadyAdded("added option matched existing option name: " +
matchname));
// this line should not be reached the above loop should trigger the throw
"added option matched existing option name")); // LCOV_EXCL_LINE
CLI11_INLINE Option *App::set_help_flag(std::string flag_name,
const std::string &help_description) {
// take flag_description by const reference otherwise add_flag tries to assign
// to help_description
if (help_ptr_ != nullptr) {
remove_option(help_ptr_);
help_ptr_ = nullptr;
// Empty name will simply remove the help flag
if (!flag_name.empty()) {
help_ptr_ = add_flag(flag_name, help_description);
help_ptr_->configurable(false);
return help_ptr_;
App::set_help_all_flag(std::string help_name,
// to flag_description
if (help_all_ptr_ != nullptr) {
remove_option(help_all_ptr_);
help_all_ptr_ = nullptr;
// Empty name will simply remove the help all flag
if (!help_name.empty()) {
help_all_ptr_ = add_flag(help_name, help_description);
help_all_ptr_->configurable(false);
CLI11_INLINE Option *App::set_version_flag(std::string flag_name,
const std::string &versionString,
const std::string &version_help) {
// to version_description
if (version_ptr_ != nullptr) {
remove_option(version_ptr_);
version_ptr_ = nullptr;
// Empty name will simply remove the version flag
version_ptr_ = add_flag_callback(
flag_name,
[versionString]() { throw(CLI::CallForVersion(versionString, 0)); },
version_help);
version_ptr_->configurable(false);
flag_name, [vfunc]() { throw(CLI::CallForVersion(vfunc(), 0)); },
version_help);
CLI11_INLINE Option *App::_add_flag_internal(std::string flag_name,
std::string flag_description) {
Option *opt = nullptr;
if (detail::has_default_flag_values(flag_name)) {
// check for default values and if it has them
auto flag_defaults = detail::get_default_flag_values(flag_name);
detail::remove_default_flag_values(flag_name);
opt = add_option(std::move(flag_name), std::move(fun),
std::move(flag_description), false);
for (const auto &fname : flag_defaults)
opt->fnames_.push_back(fname.first);
opt->default_flag_values_ = std::move(flag_defaults);
} else {
// flags cannot have positional values
if (opt->get_positional()) {
auto pos_name = opt->get_name(true);
remove_option(opt);
throw IncorrectConstruction::PositionalFlag(pos_name);
opt->multi_option_policy(MultiOptionPolicy::TakeLast);
opt->expected(0);
opt->required(false);
return opt;
CLI11_INLINE Option *App::add_flag_callback(
CLI::callback_t fun = [function](const CLI::results_t &res) {
bool trigger{false};
auto result = lexical_cast(res[0], trigger);
if (result && trigger) {
function();
return result;
App::add_flag_function(std::string flag_name,
function,
std::int64_t flag_count{0};
lexical_cast(res[0], flag_count);
function(flag_count);
return true;
->multi_option_policy(MultiOptionPolicy::Sum);
CLI11_INLINE Option *App::set_config(std::string option_name,
std::string default_filename,
const std::string &help_message,
bool config_required) {
// Remove existing config if present
if (config_ptr_ != nullptr) {
remove_option(config_ptr_);
config_ptr_ = nullptr; // need to remove the config_ptr completely
// Only add config if option passed
if (!option_name.empty()) {
config_ptr_ = add_option(option_name, help_message);
if (config_required) {
config_ptr_->required();
if (!default_filename.empty()) {
config_ptr_->default_str(std::move(default_filename));
config_ptr_->force_callback_ = true;
config_ptr_->configurable(false);
// set the option to take the last value and reverse given by default
config_ptr_->multi_option_policy(MultiOptionPolicy::Reverse);
return config_ptr_;
CLI11_INLINE bool App::remove_option(Option *opt) {
// Make sure no links exist
for (Option_p &op : options_) {
op->remove_needs(opt);
op->remove_excludes(opt);
if (help_ptr_ == opt)
if (help_all_ptr_ == opt)
auto iterator =
[opt](const Option_p &v) { return v.get() == opt; });
if (iterator != std::end(options_)) {
options_.erase(iterator);
return true;
return false;
CLI11_INLINE App *App::add_subcommand(std::string subcommand_name,
std::string subcommand_description) {
if (!subcommand_name.empty() && !detail::valid_name_string(subcommand_name)) {
if (!detail::valid_first_char(subcommand_name[0])) {
throw IncorrectConstruction(
"Subcommand name starts with invalid character, '!' and '-' and "
"control characters");
for (auto c : subcommand_name) {
if (!detail::valid_later_char(c)) {
std::string("Subcommand name contains invalid character ('") + c +
"'), all characters are allowed except"
"'=',':','{','}', ' ', and control characters");
CLI::App_p subcom = std::shared_ptr<App>(
new App(std::move(subcommand_description), subcommand_name, this));
return add_subcommand(std::move(subcom));
CLI11_INLINE App *App::add_subcommand(CLI::App_p subcom) {
if (!subcom)
throw IncorrectConstruction("passed App is not valid");
auto *ckapp =
(name_.empty() && parent_ != nullptr) ? _get_fallthrough_parent() : this;
const auto &mstrg = _compare_subcommand_names(*subcom, *ckapp);
if (!mstrg.empty()) {
"subcommand name or alias matches existing subcommand: " + mstrg));
subcom->parent_ = this;
subcommands_.push_back(std::move(subcom));
return subcommands_.back().get();
CLI11_INLINE bool App::remove_subcommand(App *subcom) {
for (App_p &sub : subcommands_) {
sub->remove_excludes(subcom);
sub->remove_needs(subcom);
auto iterator =
std::find_if(std::begin(subcommands_), std::end(subcommands_),
[subcom](const App_p &v) { return v.get() == subcom; });
if (iterator != std::end(subcommands_)) {
subcommands_.erase(iterator);
return true;
return false;
CLI11_INLINE App *App::get_subcommand(const App *subcom) const {
if (subcom == nullptr)
for (const App_p &subcomptr : subcommands_)
if (subcomptr.get() == subcom)
return subcomptr.get();
throw OptionNotFound(subcom->get_name());
CLI11_NODISCARD CLI11_INLINE App *
App::get_subcommand(std::string subcom) const {
auto *subc = _find_subcommand(subcom, false, false);
if (subc == nullptr)
throw OptionNotFound(subcom);
return subc;
App::get_subcommand_no_throw(std::string subcom) const noexcept {
return _find_subcommand(subcom, false, false);
CLI11_NODISCARD CLI11_INLINE App *App::get_subcommand(int index) const {
if (index >= 0) {
auto uindex = static_cast<unsigned>(index);
if (uindex < subcommands_.size())
return subcommands_[uindex].get();
throw OptionNotFound(std::to_string(index));
CLI11_INLINE CLI::App_p App::get_subcommand_ptr(App *subcom) const {
return subcomptr;
CLI11_NODISCARD CLI11_INLINE CLI::App_p
App::get_subcommand_ptr(std::string subcom) const {
if (subcomptr->check_name(subcom))
return subcomptr;
App::get_subcommand_ptr(int index) const {
if (index >= 0) {
return subcommands_[uindex];
CLI11_NODISCARD CLI11_INLINE CLI::App *
App::get_option_group(std::string group_name) const {
for (const App_p &app : subcommands_) {
if (app->name_.empty() && app->group_ == group_name) {
return app.get();
throw OptionNotFound(group_name);
CLI11_NODISCARD CLI11_INLINE std::size_t App::count_all() const {
std::size_t cnt{0};
for (const auto &opt : options_) {
cnt += opt->count();
for (const auto &sub : subcommands_) {
cnt += sub->count_all();
if (!get_name().empty()) { // for named subcommands add the number of times
// the subcommand was called
cnt += parsed_;
return cnt;
CLI11_INLINE void App::clear() {
parsed_ = 0;
pre_parse_called_ = false;
missing_.clear();
parsed_subcommands_.clear();
for (const Option_p &opt : options_) {
opt->clear();
for (const App_p &subc : subcommands_) {
subc->clear();
CLI11_INLINE void App::parse(int argc, const char *const *argv) {
parse_char_t(argc, argv);
CLI11_INLINE void App::parse(int argc, const wchar_t *const *argv) {
namespace detail {
// Do nothing or perform narrowing
CLI11_INLINE const char *maybe_narrow(const char *str) { return str; }
CLI11_INLINE std::string maybe_narrow(const wchar_t *str) {
return narrow(str);
CLI11_INLINE void App::parse_char_t(int argc, const CharT *const *argv) {
// If the name is not set, read from command line
if (name_.empty() || has_automatic_name_) {
has_automatic_name_ = true;
name_ = detail::maybe_narrow(argv[0]);
std::vector<std::string> args;
args.reserve(static_cast<std::size_t>(argc) - 1U);
for (auto i = static_cast<std::size_t>(argc) - 1U; i > 0U; --i)
args.emplace_back(detail::maybe_narrow(argv[i]));
parse(std::move(args));
CLI11_INLINE void App::parse(std::string commandline,
bool program_name_included) {
if (program_name_included) {
auto nstr = detail::split_program_name(commandline);
if ((name_.empty()) || (has_automatic_name_)) {
name_ = nstr.first;
commandline = std::move(nstr.second);
} else {
detail::trim(commandline);
// the next section of code is to deal with quoted arguments after an '=' or
// ':' for windows like operations
if (!commandline.empty()) {
commandline =
detail::find_and_modify(commandline, "=", detail::escape_detect);
if (allow_windows_style_options_)
commandline =
detail::find_and_modify(commandline, ":", detail::escape_detect);
auto args = detail::split_up(std::move(commandline));
// remove all empty strings
args.erase(std::remove(args.begin(), args.end(), std::string{}), args.end());
detail::remove_quotes(args);
} catch (const std::invalid_argument &arg) {
throw CLI::ParseError(arg.what(), CLI::ExitCodes::InvalidError);
std::reverse(args.begin(), args.end());
CLI11_INLINE void App::parse(std::wstring commandline,
parse(narrow(commandline), program_name_included);
CLI11_INLINE void App::parse(std::vector<std::string> &args) {
// Clear if parsed
if (parsed_ > 0)
clear();
// parsed_ is incremented in commands/subcommands,
// but placed here to make sure this is cleared when
// running parse after an error is thrown, even by _validate or _configure.
parsed_ = 1;
_validate();
_configure();
// set the parent as nullptr as this object should be the top now
parent_ = nullptr;
parsed_ = 0;
_parse(args);
run_callback();
CLI11_INLINE void App::parse(std::vector<std::string> &&args) {
// Clear if parsed
if (parsed_ > 0)
clear();
parsed_ = 1;
_validate();
_configure();
parent_ = nullptr;
parsed_ = 0;
_parse(std::move(args));
run_callback();
CLI11_INLINE void App::parse_from_stream(std::istream &input) {
if (parsed_ == 0) {
_validate();
_configure();
_parse_stream(input);
run_callback();
CLI11_INLINE int App::exit(const Error &e, std::ostream &out,
std::ostream &err) const {
if (e.get_name() == "RuntimeError")
return e.get_exit_code();
if (e.get_name() == "CallForHelp") {
out << help();
if (e.get_name() == "CallForAllHelp") {
out << help("", AppFormatMode::All);
if (e.get_name() == "CallForVersion") {
out << e.what() << '\n';
if (e.get_exit_code() != static_cast<int>(ExitCodes::Success)) {
if (failure_message_)
err << failure_message_(this, e) << std::flush;
CLI11_INLINE std::vector<const App *>
App::get_subcommands(const std::function<bool(const App *)> &filter) const {
std::vector<const App *> subcomms(subcommands_.size());
std::transform(std::begin(subcommands_), std::end(subcommands_),
std::begin(subcomms), [](const App_p &v) { return v.get(); });
if (filter) {
subcomms.erase(
std::remove_if(std::begin(subcomms), std::end(subcomms),
[&filter](const App *app) { return !filter(app); }),
std::end(subcomms));
return subcomms;
CLI11_INLINE std::vector<App *>
App::get_subcommands(const std::function<bool(App *)> &filter) {
std::vector<App *> subcomms(subcommands_.size());
if (filter) {
subcomms.erase(std::remove_if(std::begin(subcomms), std::end(subcomms),
[&filter](App *app) { return !filter(app); }),
return subcomms;
CLI11_INLINE bool App::remove_excludes(Option *opt) {
auto iterator =
std::find(std::begin(exclude_options_), std::end(exclude_options_), opt);
if (iterator == std::end(exclude_options_)) {
return false;
exclude_options_.erase(iterator);
return true;
CLI11_INLINE bool App::remove_excludes(App *app) {
auto iterator = std::find(std::begin(exclude_subcommands_),
std::end(exclude_subcommands_), app);
if (iterator == std::end(exclude_subcommands_)) {
return false;
auto *other_app = *iterator;
exclude_subcommands_.erase(iterator);
other_app->remove_excludes(this);
return true;
CLI11_INLINE bool App::remove_needs(Option *opt) {
auto iterator =
std::find(std::begin(need_options_), std::end(need_options_), opt);
if (iterator == std::end(need_options_)) {
return false;
need_options_.erase(iterator);
return true;
CLI11_INLINE bool App::remove_needs(App *app) {
auto iterator = std::find(std::begin(need_subcommands_),
std::end(need_subcommands_), app);
if (iterator == std::end(need_subcommands_)) {
return false;
need_subcommands_.erase(iterator);
return true;
CLI11_NODISCARD CLI11_INLINE std::string App::help(std::string prev,
AppFormatMode mode) const {
if (prev.empty())
prev = get_name();
prev += " " + get_name();
// Delegate to subcommand if needed
auto selected_subcommands = get_subcommands();
if (!selected_subcommands.empty()) {
return selected_subcommands.back()->help(prev, mode);
return formatter_->make_help(this, prev, mode);
CLI11_NODISCARD CLI11_INLINE std::string App::version() const {
std::string val;
// copy the results for reuse later
results_t rv = version_ptr_->results();
version_ptr_->clear();
version_ptr_->add_result("true");
version_ptr_->run_callback();
} catch (const CLI::CallForVersion &cfv) {
val = cfv.what();
version_ptr_->add_result(rv);
return val;
CLI11_INLINE std::vector<const Option *>
App::get_options(const std::function<bool(const Option *)> filter) const {
std::vector<const Option *> options(options_.size());
std::transform(std::begin(options_), std::end(options_), std::begin(options),
[](const Option_p &val) { return val.get(); });
if (filter) {
options.erase(
std::remove_if(std::begin(options), std::end(options),
[&filter](const Option *opt) { return !filter(opt); }),
std::end(options));
for (const auto &subcp : subcommands_) {
// also check down into nameless subcommands
const App *subc = subcp.get();
if (subc->get_name().empty() && !subc->get_group().empty() &&
subc->get_group().front() == '+') {
std::vector<const Option *> subcopts = subc->get_options(filter);
options.insert(options.end(), subcopts.begin(), subcopts.end());
return options;
CLI11_INLINE std::vector<Option *>
App::get_options(const std::function<bool(Option *)> filter) {
std::vector<Option *> options(options_.size());
if (filter) {
options.erase(
[&filter](Option *opt) { return !filter(opt); }),
std::end(options));
for (auto &subc : subcommands_) {
auto subcopts = subc->get_options(filter);
return options;
CLI11_NODISCARD CLI11_INLINE Option *
App::get_option_no_throw(std::string option_name) noexcept {
for (Option_p &opt : options_) {
if (opt->check_name(option_name)) {
return opt.get();
if (subc->get_name().empty()) {
auto *opt = subc->get_option_no_throw(option_name);
if (opt != nullptr) {
return opt;
return nullptr;
CLI11_NODISCARD CLI11_INLINE const Option *
App::get_option_no_throw(std::string option_name) const noexcept {
return opt.get();
for (const auto &subc : subcommands_) {
return opt;
return nullptr;
App::get_display_name(bool with_aliases) const {
if (name_.empty()) {
return std::string("[Option Group: ") + get_group() + "]";
if (aliases_.empty() || !with_aliases) {
return name_;
std::string dispname = name_;
for (const auto &lalias : aliases_) {
dispname.push_back(',');
dispname.push_back(' ');
dispname.append(lalias);
return dispname;
App::check_name(std::string name_to_check) const {
std::string local_name = name_;
local_name = detail::remove_underscore(name_);
name_to_check = detail::remove_underscore(name_to_check);
if (ignore_case_) {
local_name = detail::to_lower(name_);
name_to_check = detail::to_lower(name_to_check);
if (local_name == name_to_check) {
return true;
for (std::string les : aliases_) { // NOLINT(performance-for-range-copy)
les = detail::remove_underscore(les);
if (ignore_case_) {
les = detail::to_lower(les);
if (les == name_to_check) {
return true;
return false;
CLI11_NODISCARD CLI11_INLINE std::vector<std::string> App::get_groups() const {
std::vector<std::string> groups;
// Add group if it is not already in there
if (std::find(groups.begin(), groups.end(), opt->get_group()) ==
groups.end()) {
groups.push_back(opt->get_group());
return groups;
App::remaining(bool recurse) const {
std::vector<std::string> miss_list;
for (const std::pair<detail::Classifier, std::string> &miss : missing_) {
miss_list.push_back(std::get<1>(miss));
// Get from a subcommand that may allow extras
if (recurse) {
if (!allow_extras_) {
if (sub->name_.empty() && !sub->missing_.empty()) {
sub->missing_) {
// Recurse into subcommands
for (const App *sub : parsed_subcommands_) {
std::vector<std::string> output = sub->remaining(recurse);
std::copy(std::begin(output), std::end(output),
std::back_inserter(miss_list));
return miss_list;
App::remaining_for_passthrough(bool recurse) const {
std::vector<std::string> miss_list = remaining(recurse);
std::reverse(std::begin(miss_list), std::end(miss_list));
return miss_list;
App::remaining_size(bool recurse) const {
auto remaining_options = static_cast<std::size_t>(
std::count_if(std::begin(missing_), std::end(missing_),
[](const std::pair<detail::Classifier, std::string> &val) {
return val.first != detail::Classifier::POSITIONAL_MARK;
if (recurse) {
for (const App_p &sub : subcommands_) {
remaining_options += sub->remaining_size(recurse);
return remaining_options;
CLI11_INLINE void App::_validate() const {
// count the number of positional only args
auto pcount = std::count_if(std::begin(options_), std::end(options_),
[](const Option_p &opt) {
return opt->get_items_expected_max() >=
detail::expected_max_vector_size &&
!opt->nonpositional();
if (pcount > 1) {
auto pcount_req = std::count_if(
std::begin(options_), std::end(options_), [](const Option_p &opt) {
!opt->nonpositional() && opt->get_required();
if (pcount - pcount_req > 1) {
throw InvalidError(name_);
std::size_t nameless_subs{0};
app->_validate();
if (app->get_name().empty())
++nameless_subs;
if (require_option_min_ > 0) {
if (require_option_max_ > 0) {
if (require_option_max_ < require_option_min_) {
throw(InvalidError(
"Required min options greater than required max options",
ExitCodes::InvalidError));
if (require_option_min_ > (options_.size() + nameless_subs)) {
throw(InvalidError(
"Required min options greater than number of available options",
CLI11_INLINE void App::_configure() {
if (default_startup == startup_mode::enabled) {
disabled_ = false;
} else if (default_startup == startup_mode::disabled) {
disabled_ = true;
if (app->has_automatic_name_) {
app->name_.clear();
if (app->name_.empty()) {
app->fallthrough_ =
false; // make sure fallthrough_ is false to prevent infinite loop
app->prefix_command_ = false;
// make sure the parent is set to be this object in preparation for parse
app->parent_ = this;
app->_configure();
CLI11_INLINE void App::run_callback(bool final_mode,
bool suppress_final_callback) {
pre_callback();
// in the main app if immediate_callback_ is set it runs the main callback
// before the used subcommands
if (!final_mode && parse_complete_callback_) {
parse_complete_callback_();
// run the callbacks for the received subcommands
for (App *subc : get_subcommands()) {
if (subc->parent_ == this) {
subc->run_callback(true, suppress_final_callback);
// now run callbacks for option_groups
if (subc->name_.empty() && subc->count_all() > 0) {
// finally run the main callback
if (final_callback_ && (parsed_ > 0) && (!suppress_final_callback)) {
if (!name_.empty() || count_all() > 0 || parent_ == nullptr) {
final_callback_();
CLI11_NODISCARD CLI11_INLINE bool
App::_valid_subcommand(const std::string &current, bool ignore_used) const {
// Don't match if max has been reached - but still check parents
if (require_subcommand_max_ != 0 &&
parsed_subcommands_.size() >= require_subcommand_max_ &&
subcommand_fallthrough_) {
return parent_ != nullptr &&
parent_->_valid_subcommand(current, ignore_used);
auto *com = _find_subcommand(current, true, ignore_used);
if (com != nullptr) {
return true;
// Check parent if exists, else return false
if (subcommand_fallthrough_) {
return false;
CLI11_NODISCARD CLI11_INLINE detail::Classifier
App::_recognize(const std::string &current,
bool ignore_used_subcommands) const {
std::string dummy1, dummy2;
if (current == "--")
return detail::Classifier::POSITIONAL_MARK;
if (_valid_subcommand(current, ignore_used_subcommands))
return detail::Classifier::SUBCOMMAND;
if (detail::split_long(current, dummy1, dummy2))
return detail::Classifier::LONG;
if (detail::split_short(current, dummy1, dummy2)) {
if (dummy1[0] >= '0' && dummy1[0] <= '9') {
if (get_option_no_throw(std::string{'-', dummy1[0]}) == nullptr) {
return detail::Classifier::NONE;
return detail::Classifier::SHORT;
if ((allow_windows_style_options_) &&
(detail::split_windows_style(current, dummy1, dummy2)))
return detail::Classifier::WINDOWS_STYLE;
if ((current == "++") && !name_.empty() && parent_ != nullptr)
return detail::Classifier::SUBCOMMAND_TERMINATOR;
auto dotloc = current.find_first_of('.');
if (dotloc != std::string::npos) {
auto *cm = _find_subcommand(current.substr(0, dotloc), true,
ignore_used_subcommands);
if (cm != nullptr) {
auto res =
cm->_recognize(current.substr(dotloc + 1), ignore_used_subcommands);
if (res == detail::Classifier::SUBCOMMAND) {
return res;
CLI11_INLINE bool App::_process_config_file(const std::string &config_file,
bool throw_error) {
auto path_result = detail::check_path(config_file.c_str());
if (path_result == detail::path_type::file) {
std::vector<ConfigItem> values =
config_formatter_->from_file(config_file);
_parse_config(values);
return true;
} catch (const FileError &) {
if (throw_error) {
throw;
return false;
} else if (throw_error) {
throw FileError::Missing(config_file);
} else {
return false;
CLI11_INLINE void App::_process_config_file() {
bool config_required = config_ptr_->get_required();
auto file_given = config_ptr_->count() > 0;
if (!(file_given || config_ptr_->envname_.empty())) {
std::string ename_string =
detail::get_environment_value(config_ptr_->envname_);
if (!ename_string.empty()) {
config_ptr_->add_result(ename_string);
config_ptr_->run_callback();
auto config_files = config_ptr_->as<std::vector<std::string>>();
bool files_used{file_given};
if (config_files.empty() || config_files.front().empty()) {
throw FileError("config file is required but none was given");
for (const auto &config_file : config_files) {
if (_process_config_file(config_file, config_required || file_given)) {
files_used = true;
if (!files_used) {
// this is done so the count shows as 0 if no callbacks were processed
config_ptr_->clear();
bool force = config_ptr_->force_callback_;
config_ptr_->force_callback_ = false;
config_ptr_->force_callback_ = force;
CLI11_INLINE void App::_process_env() {
if (opt->count() == 0 && !opt->envname_.empty()) {
std::string ename_string = detail::get_environment_value(opt->envname_);
std::string result = ename_string;
result = opt->_validate(result, 0);
if (result.empty()) {
opt->add_result(ename_string);
if (sub->get_name().empty() ||
(sub->count_all() > 0 && !sub->parse_complete_callback_)) {
// only process environment variables if the callback has actually been
// triggered already
sub->_process_env();
CLI11_INLINE void App::_process_callbacks() {
// process the priority option_groups first
if (sub->get_name().empty() && sub->parse_complete_callback_) {
if (sub->count_all() > 0) {
sub->_process_callbacks();
sub->run_callback();
if ((*opt) && !opt->get_callback_run()) {
opt->run_callback();
if (!sub->parse_complete_callback_) {
CLI11_INLINE void App::_process_help_flags(bool trigger_help,
bool trigger_all_help) const {
const Option *help_ptr = get_help_ptr();
const Option *help_all_ptr = get_help_all_ptr();
if (help_ptr != nullptr && help_ptr->count() > 0)
trigger_help = true;
if (help_all_ptr != nullptr && help_all_ptr->count() > 0)
trigger_all_help = true;
// If there were parsed subcommands, call those. First subcommand wins if
// there are multiple ones.
if (!parsed_subcommands_.empty()) {
sub->_process_help_flags(trigger_help, trigger_all_help);
// Only the final subcommand should call for help. All help wins over help.
} else if (trigger_all_help) {
throw CallForAllHelp();
} else if (trigger_help) {
throw CallForHelp();
CLI11_INLINE void App::_process_requirements() {
// check excludes
bool excluded{false};
std::string excluder;
for (const auto &opt : exclude_options_) {
if (opt->count() > 0) {
excluded = true;
excluder = opt->get_name();
for (const auto &subc : exclude_subcommands_) {
if (subc->count_all() > 0) {
excluded = true;
excluder = subc->get_display_name();
if (excluded) {
if (count_all() > 0) {
throw ExcludesError(get_display_name(), excluder);
// if we are excluded but didn't receive anything, just return
// check excludes
bool missing_needed{false};
std::string missing_need;
for (const auto &opt : need_options_) {
if (opt->count() == 0) {
missing_needed = true;
missing_need = opt->get_name();
for (const auto &subc : need_subcommands_) {
if (subc->count_all() == 0) {
missing_need = subc->get_display_name();
if (missing_needed) {
throw RequiresError(get_display_name(), missing_need);
// if we missing something but didn't have any options, just return
std::size_t used_options = 0;
if (opt->count() != 0) {
++used_options;
// Required but empty
if (opt->get_required() && opt->count() == 0) {
throw RequiredError(opt->get_name());
// Requires
for (const Option *opt_req : opt->needs_)
if (opt->count() > 0 && opt_req->count() == 0)
throw RequiresError(opt->get_name(), opt_req->get_name());
// Excludes
for (const Option *opt_ex : opt->excludes_)
if (opt->count() > 0 && opt_ex->count() != 0)
throw ExcludesError(opt->get_name(), opt_ex->get_name());
// check for the required number of subcommands
if (require_subcommand_min_ > 0) {
if (require_subcommand_min_ > selected_subcommands.size())
throw RequiredError::Subcommand(require_subcommand_min_);
// Max error cannot occur, the extra subcommand will parse as an ExtrasError
// or a remaining item.
// run this loop to check how many unnamed subcommands were actually used
// since they are considered options from the perspective of an App
if (sub->disabled_)
continue;
if (sub->name_.empty() && sub->count_all() > 0) {
++used_options;
if (require_option_min_ > used_options ||
(require_option_max_ > 0 && require_option_max_ < used_options)) {
auto option_list = detail::join(options_, [this](const Option_p &ptr) {
if (ptr.get() == help_ptr_ || ptr.get() == help_all_ptr_) {
return ptr->get_name(false, true);
auto subc_list = get_subcommands([](App *app) {
return ((app->get_name().empty()) && (!app->disabled_));
if (!subc_list.empty()) {
option_list += "," + detail::join(subc_list, [](const App *app) {
return app->get_display_name();
throw RequiredError::Option(require_option_min_, require_option_max_,
used_options, option_list);
// now process the requirements for subcommands if needed
if (sub->disabled_)
continue;
if (sub->name_.empty() && sub->required_ == false) {
if (sub->count_all() == 0) {
if (require_option_min_ > 0 && require_option_min_ <= used_options) {
continue;
// if we have met the requirement and there is nothing in this option
// group skip checking requirements
if (require_option_max_ > 0 && used_options >= require_option_min_) {
continue;
if (sub->count() > 0 || sub->name_.empty()) {
sub->_process_requirements();
if (sub->required_ && sub->count_all() == 0) {
throw(CLI::RequiredError(sub->get_display_name()));
CLI11_INLINE void App::_process() {
// help takes precedence over other potential errors and config and
// environment shouldn't be processed if help throws
_process_help_flags();
// the config file might generate a FileError but that should not be
// processed until later in the process to allow for help, version and other
// errors to generate first.
// process env shouldn't throw but no reason to process it if config
// generated an error
_process_env();
} catch (const CLI::FileError &) {
// callbacks can generate exceptions which should take priority
// over the config file error if one exists.
throw;
CLI11_INLINE void App::_process_extras() {
if (!(allow_extras_ || prefix_command_)) {
std::size_t num_left_over = remaining_size();
if (num_left_over > 0) {
throw ExtrasError(name_, remaining(false));
if (sub->count() > 0)
sub->_process_extras();
CLI11_INLINE void App::_process_extras(std::vector<std::string> &args) {
args = remaining(false);
throw ExtrasError(name_, args);
sub->_process_extras(args);
CLI11_INLINE void App::increment_parsed() {
++parsed_;
if (sub->get_name().empty())
sub->increment_parsed();
CLI11_INLINE void App::_parse(std::vector<std::string> &args) {
increment_parsed();
_trigger_pre_parse(args.size());
bool positional_only = false;
while (!args.empty()) {
if (!_parse_single(args, positional_only)) {
if (parent_ == nullptr) {
_process();
// Throw error if any items are left over (depending on settings)
// Convert missing (pairs) to extras (string only) ready for processing in
// another app
args = remaining_for_passthrough(false);
} else if (parse_complete_callback_) {
_process_env();
run_callback(false, true);
CLI11_INLINE void App::_parse(std::vector<std::string> &&args) {
// this can only be called by the top level in which case parent == nullptr by
// definition operation is simplified
increment_parsed();
_parse_single(args, positional_only);
_process();
_process_extras();
CLI11_INLINE void App::_parse_stream(std::istream &input) {
auto values = config_formatter_->from_config(input);
increment_parsed();
_trigger_pre_parse(values.size());
_process();
_process_extras();
CLI11_INLINE void App::_parse_config(const std::vector<ConfigItem> &args) {
for (const ConfigItem &item : args) {
if (!_parse_single_config(item) &&
allow_config_extras_ == config_extras_mode::error)
throw ConfigError::Extras(item.fullname());
CLI11_INLINE bool App::_parse_single_config(const ConfigItem &item,
std::size_t level) {
if (level < item.parents.size()) {
auto *subcom = get_subcommand_no_throw(item.parents.at(level));
return (subcom != nullptr) ? subcom->_parse_single_config(item, level + 1)
: false;
// check for section open
if (item.name == "++") {
if (configurable_) {
increment_parsed();
_trigger_pre_parse(2);
parent_->parsed_subcommands_.push_back(this);
return true;
// check for section close
if (item.name == "--") {
if (configurable_ && parse_complete_callback_) {
run_callback();
return true;
Option *op = get_option_no_throw("--" + item.name);
if (op == nullptr) {
if (item.name.size() == 1) {
op = get_option_no_throw("-" + item.name);
op = get_option_no_throw(item.name);
} else if (!op->get_configurable()) {
auto *testop = get_option_no_throw(item.name);
if (testop != nullptr && testop->get_configurable()) {
op = testop;
auto *testop = get_option_no_throw("-" + item.name);
op = testop;
op = testop;
// If the option was not present
if (get_allow_config_extras() == config_extras_mode::capture) {
// Should we worry about classifying the extras properly?
missing_.emplace_back(detail::Classifier::NONE, item.fullname());
for (const auto &input : item.inputs) {
missing_.emplace_back(detail::Classifier::NONE, input);
return false;
if (get_allow_config_extras() == config_extras_mode::ignore_all) {
return false;
throw ConfigError::NotConfigurable(item.fullname());
if (op->empty()) {
std::vector<std::string> buffer; // a buffer to use for copying an modifying
// inputs in a few cases
bool useBuffer{false};
if (item.multiline) {
if (!op->get_inject_separator()) {
buffer = item.inputs;
buffer.erase(std::remove(buffer.begin(), buffer.end(), "%%"),
buffer.end());
useBuffer = true;
const std::vector<std::string> &inputs = (useBuffer) ? buffer : item.inputs;
if (op->get_expected_min() == 0) {
if (item.inputs.size() <= 1) {
// Flag parsing
auto res = config_formatter_->to_flag(item);
bool converted{false};
if (op->get_disable_flag_override()) {
auto val = detail::to_flag_value(res);
if (val == 1) {
res = op->get_flag_value(item.name, "{}");
converted = true;
if (!converted) {
errno = 0;
if (res != "{}" || op->get_expected_max() <= 1) {
res = op->get_flag_value(item.name, res);
op->add_result(res);
return true;
if (static_cast<int>(inputs.size()) > op->get_items_expected_max() &&
op->get_multi_option_policy() != MultiOptionPolicy::TakeAll) {
if (op->get_items_expected_max() > 1) {
throw ArgumentMismatch::AtMost(
item.fullname(), op->get_items_expected_max(), inputs.size());
if (!op->get_disable_flag_override()) {
throw ConversionError::TooManyInputsFlag(item.fullname());
// if the disable flag override is set then we must have the flag values
// match a known flag value this is true regardless of the output value,
// so an array input is possible and must be accounted for
for (const auto &res : inputs) {
bool valid_value{false};
if (op->default_flag_values_.empty()) {
if (res == "true" || res == "false" || res == "1" || res == "0") {
valid_value = true;
} else {
for (const auto &valid_res : op->default_flag_values_) {
if (valid_res.second == res) {
valid_value = true;
if (valid_value) {
} else {
throw InvalidError("invalid flag argument given");
return true;
op->add_result(inputs);
op->run_callback();
return true;
CLI11_INLINE bool App::_parse_single(std::vector<std::string> &args,
bool &positional_only) {
bool retval = true;
detail::Classifier classifier =
positional_only ? detail::Classifier::NONE : _recognize(args.back());
switch (classifier) {
case detail::Classifier::POSITIONAL_MARK:
args.pop_back();
positional_only = true;
if ((!_has_remaining_positionals()) && (parent_ != nullptr)) {
retval = false;
} else {
_move_to_missing(classifier, "--");
case detail::Classifier::SUBCOMMAND_TERMINATOR:
// treat this like a positional mark if in the parent app
args.pop_back();
retval = false;
case detail::Classifier::SUBCOMMAND:
retval = _parse_subcommand(args);
case detail::Classifier::LONG:
case detail::Classifier::SHORT:
case detail::Classifier::WINDOWS_STYLE:
// If already parsed a subcommand, don't accept options_
retval = _parse_arg(args, classifier, false);
case detail::Classifier::NONE:
// Probably a positional or something for a parent (sub)command
retval = _parse_positional(args, false);
if (retval && positionals_at_end_) {
// LCOV_EXCL_START
throw HorribleError("unrecognized classifier (you should not see this!)");
// LCOV_EXCL_STOP
return retval;
App::_count_remaining_positionals(bool required_only) const {
std::size_t retval = 0;
if (opt->get_positional() && (!required_only || opt->get_required())) {
if (opt->get_items_expected_min() > 0 &&
static_cast<int>(opt->count()) < opt->get_items_expected_min()) {
retval += static_cast<std::size_t>(opt->get_items_expected_min()) -
opt->count();
return retval;
CLI11_NODISCARD CLI11_INLINE bool App::_has_remaining_positionals() const {
((static_cast<int>(opt->count()) < opt->get_items_expected_min()))) {
return true;
return false;
CLI11_INLINE bool App::_parse_positional(std::vector<std::string> &args,
bool haltOnSubcommand) {
const std::string &positional = args.back();
Option *posOpt{nullptr};
if (positionals_at_end_) {
// deal with the case of required arguments at the end which should take
// precedence over other arguments
auto arg_rem = args.size();
auto remreq = _count_remaining_positionals(true);
if (arg_rem <= remreq) {
if (opt->get_positional() && opt->required_) {
if (static_cast<int>(opt->count()) < opt->get_items_expected_min()) {
if (validate_positionals_) {
std::string pos = positional;
pos = opt->_validate(pos, 0);
if (!pos.empty()) {
continue;
posOpt = opt.get();
if (posOpt == nullptr) {
// Eat options, one by one, until done
(static_cast<int>(opt->count()) < opt->get_items_expected_max() ||
opt->get_allow_extra_args())) {
if (!pos.empty()) {
continue;
posOpt = opt.get();
if (posOpt != nullptr) {
parse_order_.push_back(posOpt);
if (posOpt->get_inject_separator()) {
if (!posOpt->results().empty() && !posOpt->results().back().empty()) {
posOpt->add_result(std::string{});
if (posOpt->get_trigger_on_parse() &&
posOpt->current_option_state_ == Option::option_state::callback_run) {
posOpt->clear();
posOpt->add_result(positional);
if (posOpt->get_trigger_on_parse()) {
posOpt->run_callback();
args.pop_back();
return true;
if ((subc->name_.empty()) && (!subc->disabled_)) {
if (subc->_parse_positional(args, false)) {
if (!subc->pre_parse_called_) {
subc->_trigger_pre_parse(args.size());
return true;
// let the parent deal with it if possible
if (parent_ != nullptr && fallthrough_) {
return _get_fallthrough_parent()->_parse_positional(
args, static_cast<bool>(parse_complete_callback_));
auto *com = _find_subcommand(args.back(), true, false);
if (com != nullptr &&
(require_subcommand_max_ == 0 ||
require_subcommand_max_ > parsed_subcommands_.size())) {
if (haltOnSubcommand) {
return false;
args.pop_back();
com->_parse(args);
return true;
auto *parent_app = (parent_ != nullptr) ? _get_fallthrough_parent() : this;
com = parent_app->_find_subcommand(args.back(), true, false);
if (com != nullptr && (com->parent_->require_subcommand_max_ == 0 ||
com->parent_->require_subcommand_max_ >
com->parent_->parsed_subcommands_.size())) {
return false;
throw CLI::ExtrasError(name_, args);
if (parent_ != nullptr && name_.empty()) {
return false;
_move_to_missing(detail::Classifier::NONE, positional);
args.pop_back();
if (prefix_command_) {
_move_to_missing(detail::Classifier::NONE, args.back());
args.pop_back();
return true;
App::_find_subcommand(const std::string &subc_name, bool ignore_disabled,
bool ignore_used) const noexcept {
for (const App_p &com : subcommands_) {
if (com->disabled_ && ignore_disabled)
continue;
if (com->get_name().empty()) {
auto *subc =
com->_find_subcommand(subc_name, ignore_disabled, ignore_used);
if (subc != nullptr) {
return subc;
if (com->check_name(subc_name)) {
if ((!*com) || !ignore_used)
return com.get();
return nullptr;
CLI11_INLINE bool App::_parse_subcommand(std::vector<std::string> &args) {
if (_count_remaining_positionals(/* required */ true) > 0) {
return true;
auto *com = _find_subcommand(args.back(), true, true);
if (com == nullptr) {
// the main way to get here is using .notation
auto dotloc = args.back().find_first_of('.');
com = _find_subcommand(args.back().substr(0, dotloc), true, true);
args.back() = args.back().substr(dotloc + 1);
args.push_back(com->get_display_name());
args.pop_back();
if (!com->silent_) {
parsed_subcommands_.push_back(com);
com->_parse(args);
auto *parent_app = com->parent_;
while (parent_app != this) {
parent_app->_trigger_pre_parse(args.size());
parent_app->parsed_subcommands_.push_back(com);
parent_app = parent_app->parent_;
return true;
throw HorribleError("Subcommand " + args.back() + " missing");
return false;
CLI11_INLINE bool App::_parse_arg(std::vector<std::string> &args,
bool local_processing_only) {
std::string current = args.back();
std::string arg_name;
std::string value;
std::string rest;
switch (current_type) {
if (!detail::split_long(current, arg_name, value))
throw HorribleError("Long parsed but missing (you should not see this):" +
args.back());
if (!detail::split_short(current, arg_name, rest))
throw HorribleError("Short parsed but missing! You should not see this");
if (!detail::split_windows_style(current, arg_name, value))
"windows option parsed but missing! You should not see this");
"parsing got called with invalid option! You should not see this");
auto op_ptr = std::find_if(std::begin(options_), std::end(options_),
[arg_name, current_type](const Option_p &opt) {
if (current_type == detail::Classifier::LONG)
return opt->check_lname(arg_name);
if (current_type == detail::Classifier::SHORT)
return opt->check_sname(arg_name);
// this will only get called for
// detail::Classifier::WINDOWS_STYLE
return opt->check_lname(arg_name) ||
// Option not found
while (op_ptr == std::end(options_)) {
// using while so we can break
if (subc->name_.empty() && !subc->disabled_) {
if (subc->_parse_arg(args, current_type, local_processing_only)) {
return true;
current_type == detail::Classifier::SHORT && current.size() > 2) {
std::string narg_name;
std::string nvalue;
detail::split_long(std::string{'-'} + current, narg_name, nvalue);
[narg_name](const Option_p &opt) {
return opt->check_sname(narg_name);
if (op_ptr != std::end(options_)) {
arg_name = narg_name;
value = nvalue;
rest.clear();
// don't capture missing if this is a nameless subcommand and nameless
// subcommands can't fallthrough
return false;
// now check for '.' notation of subcommands
auto dotloc = arg_name.find_first_of('.', 1);
// using dot notation is equivalent to single argument subcommand
auto *sub = _find_subcommand(arg_name.substr(0, dotloc), true, false);
if (sub != nullptr) {
std::string v = args.back();
args.pop_back();
arg_name = arg_name.substr(dotloc + 1);
if (arg_name.size() > 1) {
args.push_back(std::string("--") + v.substr(dotloc + 3));
current_type = detail::Classifier::LONG;
} else {
auto nval = v.substr(dotloc + 2);
nval.front() = '-';
if (nval.size() > 2) {
// '=' not allowed in short form arguments
args.push_back(nval.substr(3));
nval.resize(2);
args.push_back(nval);
current_type = detail::Classifier::SHORT;
auto val = sub->_parse_arg(args, current_type, true);
if (val) {
if (!sub->silent_) {
parsed_subcommands_.push_back(sub);
// deal with preparsing
increment_parsed();
// run the parse complete callback since the subcommand processing is
// now complete
if (sub->parse_complete_callback_) {
sub->_process_help_flags();
sub->run_callback(false, true);
return true;
args.pop_back();
args.push_back(v);
if (local_processing_only) {
return false;
// If a subcommand, try the main command
return _get_fallthrough_parent()->_parse_arg(args, current_type, false);
// Otherwise, add to missing
args.pop_back();
_move_to_missing(current_type, current);
return true;
args.pop_back();
// Get a reference to the pointer to make syntax bearable
Option_p &op = *op_ptr;
if (op->get_inject_separator()) {
if (!op->results().empty() && !op->results().back().empty()) {
op->add_result(std::string{});
if (op->get_trigger_on_parse() &&
op->current_option_state_ == Option::option_state::callback_run) {
op->clear();
int min_num =
(std::min)(op->get_type_size_min(), op->get_items_expected_min());
int max_num = op->get_items_expected_max();
// check container like options to limit the argument size to a single type if
// the allow_extra_flags argument is set. 16 is somewhat arbitrary (needs to
// be at least 4)
if (max_num >= detail::expected_max_vector_size / 16 &&
!op->get_allow_extra_args()) {
auto tmax = op->get_type_size_max();
max_num = detail::checked_multiply(tmax, op->get_expected_min())
? tmax
: detail::expected_max_vector_size;
// Make sure we always eat the minimum for unlimited vectors
int collected = 0; // total number of arguments collected
int result_count =
0; // local variable for number of results in a single arg string
// deal with purely flag like things
if (max_num == 0) {
auto res = op->get_flag_value(arg_name, value);
parse_order_.push_back(op.get());
} else if (!value.empty()) { // --this=value
op->add_result(value, result_count);
collected += result_count;
// -Trest
} else if (!rest.empty()) {
op->add_result(rest, result_count);
rest = "";
// gather the minimum number of arguments
while (min_num > collected && !args.empty()) {
std::string current_ = args.back();
args.pop_back();
op->add_result(current_, result_count);
if (min_num > collected) { // if we have run out of arguments and the minimum
// was not met
throw ArgumentMismatch::TypedAtLeast(op->get_name(), min_num,
op->get_type_name());
// now check for optional arguments
if (max_num > collected ||
op->get_allow_extra_args()) { // we allow optional arguments
auto remreqpos = _count_remaining_positionals(true);
// we have met the minimum now optionally check up to the maximum
while ((collected < max_num || op->get_allow_extra_args()) &&
!args.empty() &&
_recognize(args.back(), false) == detail::Classifier::NONE) {
// If any required positionals remain, don't keep eating
if (remreqpos >= args.size()) {
if (validate_optional_arguments_) {
std::string arg = args.back();
arg = op->_validate(arg, 0);
if (!arg.empty()) {
op->add_result(args.back(), result_count);
args.pop_back();
// Allow -- to end an unlimited list and "eat" it
if (!args.empty() &&
_recognize(args.back()) == detail::Classifier::POSITIONAL_MARK)
args.pop_back();
// optional flag that didn't receive anything now get the default value
if (min_num == 0 && max_num > 0 && collected == 0) {
auto res = op->get_flag_value(arg_name, std::string{});
// if we only partially completed a type then add an empty string if allowed
// for later processing
if (min_num > 0 && (collected % op->get_type_size_max()) != 0) {
if (op->get_type_size_max() != op->get_type_size_min()) {
} else {
throw ArgumentMismatch::PartialType(
op->get_name(), op->get_type_size_min(), op->get_type_name());
if (op->get_trigger_on_parse()) {
op->run_callback();
rest = "-" + rest;
args.push_back(rest);
return true;
CLI11_INLINE void App::_trigger_pre_parse(std::size_t remaining_args) {
if (!pre_parse_called_) {
pre_parse_called_ = true;
if (pre_parse_callback_) {
pre_parse_callback_(remaining_args);
} else if (immediate_callback_) {
if (!name_.empty()) {
auto pcnt = parsed_;
missing_t extras = std::move(missing_);
clear();
parsed_ = pcnt;
missing_ = std::move(extras);
CLI11_INLINE App *App::_get_fallthrough_parent() {
throw(HorribleError("No Valid parent"));
auto *fallthrough_parent = parent_;
while ((fallthrough_parent->parent_ != nullptr) &&
(fallthrough_parent->get_name().empty())) {
fallthrough_parent = fallthrough_parent->parent_;
return fallthrough_parent;
CLI11_NODISCARD CLI11_INLINE const std::string &
App::_compare_subcommand_names(const App &subcom, const App &base) const {
static const std::string estring;
if (subcom.disabled_) {
return estring;
for (const auto &subc : base.subcommands_) {
if (subc.get() != &subcom) {
if (subc->disabled_) {
continue;
if (!subcom.get_name().empty()) {
if (subc->check_name(subcom.get_name())) {
return subcom.get_name();
if (!subc->get_name().empty()) {
if (subcom.check_name(subc->get_name())) {
return subc->get_name();
for (const auto &les : subcom.aliases_) {
if (subc->check_name(les)) {
return les;
// this loop is needed in case of ignore_underscore or ignore_case on one
// but not the other
for (const auto &les : subc->aliases_) {
if (subcom.check_name(les)) {
return les;
// if the subcommand is an option group we need to check deeper
const auto &cmpres = _compare_subcommand_names(subcom, *subc);
if (!cmpres.empty()) {
return cmpres;
// if the test subcommand is an option group we need to check deeper
if (subcom.get_name().empty()) {
const auto &cmpres = _compare_subcommand_names(*subc, subcom);
return cmpres;
return estring;
CLI11_INLINE void App::_move_to_missing(detail::Classifier val_type,
const std::string &val) {
if (allow_extras_ || subcommands_.empty()) {
missing_.emplace_back(val_type, val);
// allow extra arguments to be places in an option group if it is allowed
// there
if (subc->name_.empty() && subc->allow_extras_) {
subc->missing_.emplace_back(val_type, val);
// if we haven't found any place to put them yet put them in missing
CLI11_INLINE void App::_move_option(Option *opt, App *app) {
if (opt == nullptr) {
throw OptionNotFound("the option is NULL");
// verify that the give app is actually a subcommand
bool found = false;
if (app == subc.get()) {
found = true;
if (!found) {
throw OptionNotFound("The Given app is not a subcommand");
if ((help_ptr_ == opt) || (help_all_ptr_ == opt))
throw OptionAlreadyAdded("cannot move help options");
if (config_ptr_ == opt)
throw OptionAlreadyAdded("cannot move config file options");
auto iterator =
const auto &opt_p = *iterator;
if (std::find_if(std::begin(app->options_), std::end(app->options_),
[&opt_p](const Option_p &v) { return (*v == *opt_p); }) ==
std::end(app->options_)) {
// only erase after the insertion was successful
app->options_.push_back(std::move(*iterator));
} else {
throw OptionAlreadyAdded("option was not located: " + opt->get_name());
} else {
throw OptionNotFound("could not locate the given Option");
CLI11_INLINE void TriggerOn(App *trigger_app, App *app_to_enable) {
app_to_enable->enabled_by_default(false);
app_to_enable->disabled_by_default();
trigger_app->preparse_callback(
[app_to_enable](std::size_t) { app_to_enable->disabled(false); });
std::vector<App *> apps_to_enable) {
for (auto &app : apps_to_enable) {
app->enabled_by_default(false);
app->disabled_by_default();
trigger_app->preparse_callback([apps_to_enable](std::size_t) {
for (const auto &app : apps_to_enable) {
app->disabled(false);
CLI11_INLINE void TriggerOff(App *trigger_app, App *app_to_enable) {
app_to_enable->disabled_by_default(false);
app_to_enable->enabled_by_default();
[app_to_enable](std::size_t) { app_to_enable->disabled(); });
app->disabled_by_default(false);
app->enabled_by_default();
app->disabled();
const std::string &replacement) {
Validator deprecate_warning{[opt, replacement](std::string &) {
std::cout << opt->get_name()
<< " is deprecated please use '"
<< replacement << "' instead\n";
return std::string();
"DEPRECATED"};
deprecate_warning.application_index(0);
opt->check(deprecate_warning);
if (!replacement.empty()) {
opt->description(opt->get_description() + " DEPRECATED: please use '" +
replacement + "' instead");
CLI11_INLINE void retire_option(App *app, Option *opt) {
App temp;
auto *option_copy =
temp.add_option(opt->get_name(false, true))
->type_size(opt->get_type_size_min(), opt->get_type_size_max())
->expected(opt->get_expected_min(), opt->get_expected_max())
->allow_extra_args(opt->get_allow_extra_args());
app->remove_option(opt);
auto *opt2 = app->add_option(option_copy->get_name(false, true),
"option has been retired and has no effect");
opt2->type_name("RETIRED")
->default_str("RETIRED")
->type_size(option_copy->get_type_size_min(),
option_copy->get_type_size_max())
->expected(option_copy->get_expected_min(),
option_copy->get_expected_max())
->allow_extra_args(option_copy->get_allow_extra_args());
// LCOV_EXCL_START
// something odd with coverage on new compilers
Validator retired_warning{[opt2](std::string &) {
std::cout << "WARNING " << opt2->get_name()
<< " is retired and has no effect\n";
// LCOV_EXCL_STOP
retired_warning.application_index(0);
opt2->check(retired_warning);
CLI11_INLINE void retire_option(App &app, Option *opt) {
retire_option(&app, opt);
CLI11_INLINE void retire_option(App *app, const std::string &option_name) {
auto *opt = app->get_option_no_throw(option_name);
retire_option(app, opt);
auto *opt2 =
app->add_option(option_name, "option has been retired and has no effect")
->expected(0, 1)
->default_str("RETIRED");
// LCOV_EXCL_START
// LCOV_EXCL_STOP
CLI11_INLINE void retire_option(App &app, const std::string &option_name) {
retire_option(&app, option_name);
namespace FailureMessage {
CLI11_INLINE std::string simple(const App *app, const Error &e) {
std::string header = std::string(e.what()) + "\n";
std::vector<std::string> names;
// Collect names
if (app->get_help_ptr() != nullptr)
names.push_back(app->get_help_ptr()->get_name());
if (app->get_help_all_ptr() != nullptr)
names.push_back(app->get_help_all_ptr()->get_name());
// If any names found, suggest those
if (!names.empty())
header +=
"Run with " + detail::join(names, " or ") + " for more information.\n";
return header;
CLI11_INLINE std::string help(const App *app, const Error &e) {
std::string("ERROR: ") + e.get_name() + ": " + e.what() + "\n";
header += app->help();
return header;
} // namespace FailureMessage
namespace detail {
std::string convert_arg_for_ini(const std::string &arg, char stringQuote = '"',
char literalQuote = '\'',
bool disable_multi_line = false);
std::string ini_join(const std::vector<std::string> &args, char sepChar = ',',
char arrayStart = '[', char arrayEnd = ']',
char stringQuote = '"', char literalQuote = '\'');
void clean_name_string(std::string &name, const std::string &keyChars);
std::vector<std::string> generate_parents(const std::string &section,
std::string &name,
char parentSeparator);
void checkParentSegments(std::vector<ConfigItem> &output,
const std::string &currentSection,
} // namespace detail
static constexpr auto multiline_literal_quote = R"(''')";
static constexpr auto multiline_string_quote = R"(""")";
namespace detail {
CLI11_INLINE bool is_printable(const std::string &test_string) {
return std::all_of(test_string.begin(), test_string.end(), [](char x) {
return (isprint(static_cast<unsigned char>(x)) != 0 || x == '\n' ||
x == '\t');
CLI11_INLINE std::string convert_arg_for_ini(const std::string &arg,
char stringQuote,
char literalQuote,
bool disable_multi_line) {
if (arg.empty()) {
return std::string(2, stringQuote);
// some specifically supported strings
if (arg == "true" || arg == "false" || arg == "nan" || arg == "inf") {
return arg;
// floating point conversion can convert some hex codes, but don't try that
// here
if (arg.compare(0, 2, "0x") != 0 && arg.compare(0, 2, "0X") != 0) {
using CLI::detail::lexical_cast;
double val = 0.0;
if (lexical_cast(arg, val)) {
if (arg.find_first_not_of("0123456789.-+eE") == std::string::npos) {
return arg;
// just quote a single non numeric character
if (arg.size() == 1) {
if (isprint(static_cast<unsigned char>(arg.front())) == 0) {
return binary_escape_string(arg);
if (arg == "'") {
return std::string(1, stringQuote) + "'" + stringQuote;
return std::string(1, literalQuote) + arg + literalQuote;
// handle hex, binary or octal arguments
if (arg.front() == '0') {
if (arg[1] == 'x') {
if (std::all_of(arg.begin() + 2, arg.end(), [](char x) {
return (x >= '0' && x <= '9') || (x >= 'A' && x <= 'F') ||
(x >= 'a' && x <= 'f');
return arg;
} else if (arg[1] == 'o') {
[](char x) { return (x >= '0' && x <= '7'); })) {
return arg;
} else if (arg[1] == 'b') {
[](char x) { return (x == '0' || x == '1'); })) {
return arg;
if (!is_printable(arg)) {
if (detail::has_escapable_character(arg)) {
if (arg.size() > 100 && !disable_multi_line) {
return std::string(multiline_literal_quote) + arg +
multiline_literal_quote;
return std::string(1, stringQuote) + detail::add_escaped_characters(arg) +
stringQuote;
return std::string(1, stringQuote) + arg + stringQuote;
CLI11_INLINE std::string ini_join(const std::vector<std::string> &args,
char sepChar, char arrayStart, char arrayEnd,
char stringQuote, char literalQuote) {
bool disable_multi_line{false};
std::string joined;
if (args.size() > 1 && arrayStart != '\0') {
joined.push_back(arrayStart);
disable_multi_line = true;
std::size_t start = 0;
for (const auto &arg : args) {
if (start++ > 0) {
joined.push_back(sepChar);
if (!std::isspace<char>(sepChar, std::locale())) {
joined.push_back(' ');
joined.append(convert_arg_for_ini(arg, stringQuote, literalQuote,
disable_multi_line));
if (args.size() > 1 && arrayEnd != '\0') {
joined.push_back(arrayEnd);
return joined;
generate_parents(const std::string &section, std::string &name,
char parentSeparator) {
std::vector<std::string> parents;
if (detail::to_lower(section) != "default") {
if (section.find(parentSeparator) != std::string::npos) {
parents = detail::split_up(section, parentSeparator);
} else {
parents = {section};
if (name.find(parentSeparator) != std::string::npos) {
std::vector<std::string> plist = detail::split_up(name, parentSeparator);
name = plist.back();
plist.pop_back();
parents.insert(parents.end(), plist.begin(), plist.end());
// clean up quotes on the parents
detail::remove_quotes(parents);
} catch (const std::invalid_argument &iarg) {
throw CLI::ParseError(iarg.what(), CLI::ExitCodes::InvalidError);
return parents;
CLI11_INLINE void checkParentSegments(std::vector<ConfigItem> &output,
auto parents =
detail::generate_parents(currentSection, estring, parentSeparator);
if (!output.empty() && output.back().name == "--") {
std::size_t msize = (parents.size() > 1U) ? parents.size() : 2;
while (output.back().parents.size() >= msize) {
output.push_back(output.back());
output.back().parents.pop_back();
if (parents.size() > 1) {
std::size_t common = 0;
std::size_t mpair =
(std::min)(output.back().parents.size(), parents.size() - 1);
for (std::size_t ii = 0; ii < mpair; ++ii) {
if (output.back().parents[ii] != parents[ii]) {
++common;
if (common == mpair) {
output.pop_back();
} else {
while (output.back().parents.size() > common + 1) {
for (std::size_t ii = common; ii < parents.size() - 1; ++ii) {
output.emplace_back();
output.back().parents.assign(parents.begin(),
parents.begin() +
static_cast<std::ptrdiff_t>(ii) + 1);
output.back().name = "++";
} else if (parents.size() > 1) {
for (std::size_t ii = 0; ii < parents.size() - 1; ++ii) {
parents.begin() +
// insert a section end which is just an empty items_buffer
output.back().parents = std::move(parents);
CLI11_INLINE bool hasMLString(std::string const &fullString, char check) {
if (fullString.length() < 3) {
return false;
auto it = fullString.rbegin();
return (*it == check) && (*(it + 1) == check) && (*(it + 2) == check);
inline auto find_matching_config(std::vector<ConfigItem> &items,
const std::vector<std::string> &parents,
const std::string &name, bool fullSearch)
-> decltype(items.begin()) {
if (items.empty()) {
return items.end();
auto search = items.end() - 1;
do {
if (search->parents == parents && search->name == name) {
return search;
if (search == items.begin()) {
--search;
} while (fullSearch);
return items.end();
inline std::vector<ConfigItem>
ConfigBase::from_config(std::istream &input) const {
std::string line;
std::string buffer;
std::string currentSection = "default";
std::string previousSection = "default";
std::vector<ConfigItem> output;
bool isDefaultArray =
(arrayStart == '[' && arrayEnd == ']' && arraySeparator == ',');
bool isINIArray =
(arrayStart == '\0' || arrayStart == ' ') && arrayStart == arrayEnd;
bool inSection{false};
bool inMLineComment{false};
bool inMLineValue{false};
char aStart = (isINIArray) ? '[' : arrayStart;
char aEnd = (isINIArray) ? ']' : arrayEnd;
char aSep = (isINIArray && arraySeparator == ' ') ? ',' : arraySeparator;
int currentSectionIndex{0};
std::string line_sep_chars{parentSeparatorChar, commentChar, valueDelimiter};
while (getline(input, buffer)) {
std::vector<std::string> items_buffer;
std::string name;
line = detail::trim_copy(buffer);
std::size_t len = line.length();
// lines have to be at least 3 characters to have any meaning to CLI just
// skip the rest
if (len < 3) {
continue;
if (line.compare(0, 3, multiline_string_quote) == 0 ||
line.compare(0, 3, multiline_literal_quote) == 0) {
inMLineComment = true;
auto cchar = line.front();
while (inMLineComment) {
if (getline(input, line)) {
detail::trim(line);
} else {
if (detail::hasMLString(line, cchar)) {
inMLineComment = false;
continue;
if (line.front() == '[' && line.back() == ']') {
if (currentSection != "default") {
detail::generate_parents(currentSection, name, parentSeparatorChar);
output.back().name = "--";
currentSection = line.substr(1, len - 2);
// deal with double brackets for TOML
if (currentSection.size() > 1 && currentSection.front() == '[' &&
currentSection.back() == ']') {
currentSection = currentSection.substr(1, currentSection.size() - 2);
if (detail::to_lower(currentSection) == "default") {
} else {
detail::checkParentSegments(output, currentSection,
inSection = false;
if (currentSection == previousSection) {
++currentSectionIndex;
} else {
currentSectionIndex = 0;
previousSection = currentSection;
continue;
// comment lines
if (line.front() == ';' || line.front() == '#' ||
line.front() == commentChar) {
continue;
std::size_t search_start = 0;
if (line.find_first_of("\"'`") != std::string::npos) {
while (search_start < line.size()) {
auto test_char = line[search_start];
if (test_char == '\"' || test_char == '\'' || test_char == '`') {
search_start =
detail::close_sequence(line, search_start, line[search_start]);
++search_start;
} else if (test_char == valueDelimiter || test_char == commentChar) {
--search_start;
} else if (test_char == ' ' || test_char == '\t' ||
test_char == parentSeparatorChar) {
++search_start;
} else {
search_start = line.find_first_of(line_sep_chars, search_start);
// Find = in string, split and recombine
auto delimiter_pos = line.find_first_of(valueDelimiter, search_start + 1);
auto comment_pos = line.find_first_of(commentChar, search_start);
if (comment_pos < delimiter_pos) {
delimiter_pos = std::string::npos;
if (delimiter_pos != std::string::npos) {
name = detail::trim_copy(line.substr(0, delimiter_pos));
std::string item =
detail::trim_copy(line.substr(delimiter_pos + 1, std::string::npos));
bool mlquote = (item.compare(0, 3, multiline_literal_quote) == 0 ||
item.compare(0, 3, multiline_string_quote) == 0);
if (!mlquote && comment_pos != std::string::npos) {
auto citems = detail::split_up(item, commentChar);
item = detail::trim_copy(citems.front());
if (mlquote) {
// multiline string
auto keyChar = item.front();
item = buffer.substr(delimiter_pos + 1, std::string::npos);
detail::ltrim(item);
item.erase(0, 3);
inMLineValue = true;
bool lineExtension{false};
bool firstLine = true;
if (!item.empty() && item.back() == '\\') {
item.pop_back();
lineExtension = true;
} else if (detail::hasMLString(item, keyChar)) {
// deal with the first line closing the multiline literal
item.pop_back();
item.pop_back();
item.pop_back();
if (keyChar == '\"') {
item = detail::remove_escaped_characters(item);
inMLineValue = false;
while (inMLineValue) {
std::string l2;
if (!std::getline(input, l2)) {
line = l2;
detail::rtrim(line);
if (detail::hasMLString(line, keyChar)) {
line.pop_back();
line.pop_back();
line.pop_back();
if (lineExtension) {
detail::ltrim(line);
} else if (!(firstLine && item.empty())) {
item.push_back('\n');
firstLine = false;
item += line;
if (!item.empty() && item.back() == '\n') {
item.pop_back();
} else {
detail::trim(l2);
lineExtension = false;
firstLine = false;
if (!l2.empty() && l2.back() == '\\') {
l2.pop_back();
item += l2;
items_buffer = {item};
} else if (item.size() > 1 && item.front() == aStart) {
for (std::string multiline;
item.back() != aEnd && std::getline(input, multiline);) {
detail::trim(multiline);
item += multiline;
if (item.back() == aEnd) {
items_buffer =
detail::split_up(item.substr(1, item.length() - 2), aSep);
} else {
items_buffer =
detail::split_up(item.substr(1, std::string::npos), aSep);
} else if ((isDefaultArray || isINIArray) &&
item.find_first_of(aSep) != std::string::npos) {
items_buffer = detail::split_up(item, aSep);
item.find_first_of(' ') != std::string::npos) {
items_buffer = detail::split_up(item, '\0');
} else {
} else {
name = detail::trim_copy(line.substr(0, comment_pos));
items_buffer = {"true"};
parents =
detail::process_quoted_string(name);
// clean up quotes on the items and check for escaped strings
for (auto &it : items_buffer) {
detail::process_quoted_string(it, stringQuote, literalQuote);
} catch (const std::invalid_argument &ia) {
throw CLI::ParseError(ia.what(), CLI::ExitCodes::InvalidError);
if (parents.size() > maximumLayers) {
continue;
if (!configSection.empty() && !inSection) {
if (parents.empty() || parents.front() != configSection) {
continue;
if (configIndex >= 0 && currentSectionIndex != configIndex) {
continue;
parents.erase(parents.begin());
inSection = true;
auto match = detail::find_matching_config(output, parents, name,
allowMultipleDuplicateFields);
if (match != output.end()) {
if ((match->inputs.size() > 1 && items_buffer.size() > 1) ||
allowMultipleDuplicateFields) {
// insert a separator if one is not already present
if (!(match->inputs.back().empty() || items_buffer.front().empty() ||
match->inputs.back() == "%%" || items_buffer.front() == "%%")) {
match->inputs.emplace_back("%%");
match->multiline = true;
match->inputs.insert(match->inputs.end(), items_buffer.begin(),
items_buffer.end());
} else {
output.back().name = std::move(name);
output.back().inputs = std::move(items_buffer);
std::string ename;
detail::generate_parents(currentSection, ename, parentSeparatorChar);
while (output.back().parents.size() > 1) {
return output;
CLI11_INLINE std::string &clean_name_string(std::string &name,
const std::string &keyChars) {
if (name.find_first_of(keyChars) != std::string::npos ||
(name.front() == '[' && name.back() == ']') ||
(name.find_first_of("'`\"\\") != std::string::npos)) {
if (name.find_first_of('\'') == std::string::npos) {
name.insert(0, 1, '\'');
name.push_back('\'');
} else {
if (detail::has_escapable_character(name)) {
name = detail::add_escaped_characters(name);
name.insert(0, 1, '\"');
name.push_back('\"');
return name;
CLI11_INLINE std::string ConfigBase::to_config(const App *app,
bool default_also,
bool write_description,
std::string prefix) const {
std::stringstream out;
std::string commentLead;
commentLead.push_back(commentChar);
commentLead.push_back(' ');
std::string commentTest = "#;";
commentTest.push_back(commentChar);
commentTest.push_back(parentSeparatorChar);
std::string keyChars = commentTest;
keyChars.push_back(literalQuote);
keyChars.push_back(stringQuote);
keyChars.push_back(arrayStart);
keyChars.push_back(arrayEnd);
keyChars.push_back(valueDelimiter);
keyChars.push_back(arraySeparator);
std::vector<std::string> groups = app->get_groups();
bool defaultUsed = false;
groups.insert(groups.begin(), std::string("OPTIONS"));
for (auto &group : groups) {
if (group == "OPTIONS" || group.empty()) {
if (defaultUsed) {
continue;
defaultUsed = true;
if (write_description && group != "OPTIONS" && !group.empty()) {
out << '\n' << commentChar << commentLead << group << " Options\n";
for (const Option *opt : app->get_options({})) {
// Only process options that are configurable
if (opt->get_configurable()) {
if (opt->get_group() != group) {
if (!(group == "OPTIONS" && opt->get_group().empty())) {
continue;
std::string single_name = opt->get_single_name();
if (single_name.empty()) {
continue;
auto results = opt->reduced_results();
std::string value =
detail::ini_join(results, arraySeparator, arrayStart, arrayEnd,
bool isDefault = false;
if (value.empty() && default_also) {
if (!opt->get_default_str().empty()) {
value = detail::convert_arg_for_ini(
opt->get_default_str(), stringQuote, literalQuote, false);
} else if (opt->get_expected_min() == 0) {
value = "false";
} else if (opt->get_run_callback_for_default() ||
!opt->get_required()) {
value = "\"\""; // empty string default value
} else {
value = "\"<REQUIRED>\"";
isDefault = true;
if (!opt->get_fnames().empty()) {
value = opt->get_flag_value(single_name, value);
} catch (const CLI::ArgumentMismatch &) {
bool valid{false};
for (const auto &test_name : opt->get_fnames()) {
value = opt->get_flag_value(test_name, value);
single_name = test_name;
valid = true;
continue;
if (!valid) {
value =
detail::ini_join(opt->results(), arraySeparator, arrayStart,
arrayEnd, stringQuote, literalQuote);
if (write_description && opt->has_description()) {
if (out.tellp() != std::streampos(0)) {
out << '\n';
out << commentLead
<< detail::fix_newlines(commentLead, opt->get_description())
<< '\n';
clean_name_string(single_name, keyChars);
std::string name = prefix + single_name;
if (commentDefaultsBool && isDefault) {
name = commentChar + name;
out << name << valueDelimiter << value << '\n';
auto subcommands = app->get_subcommands({});
for (const App *subcom : subcommands) {
if (subcom->get_name().empty()) {
if (!default_also && (subcom->count_all() == 0)) {
continue;
if (write_description && !subcom->get_group().empty()) {
out << '\n' << commentLead << subcom->get_group() << " Options\n";
/*if (!prefix.empty() || app->get_parent() == nullptr) {
out << '[' << prefix << "___"<< subcom->get_group() << "]\n";
} else {
std::string subname = app->get_name() + parentSeparatorChar +
"___"+subcom->get_group(); const auto *p = app->get_parent();
while(p->get_parent() != nullptr) {
subname = p->get_name() + parentSeparatorChar +subname;
p = p->get_parent();
out << '[' << subname << "]\n";
out << to_config(subcom, default_also, write_description, prefix);
if (!subcom->get_name().empty()) {
continue;
std::string subname = subcom->get_name();
clean_name_string(subname, keyChars);
if (subcom->get_configurable() &&
(default_also || app->got_subcommand(subcom))) {
out << '[' << prefix << subname << "]\n";
} else {
std::string appname = app->get_name();
clean_name_string(appname, keyChars);
subname = appname + parentSeparatorChar + subname;
while (p->get_parent() != nullptr) {
std::string pname = p->get_name();
clean_name_string(pname, keyChars);
subname = pname + parentSeparatorChar + subname;
out << to_config(subcom, default_also, write_description, "");
} else {
prefix + subname + parentSeparatorChar);
if (write_description && !out.str().empty()) {
std::string outString = commentChar + commentLead +
detail::fix_newlines(commentChar + commentLead,
app->get_description()) +
'\n';
return outString + out.str();
return out.str();
Formatter::make_group(std::string group, bool is_positional,
std::vector<const Option *> opts) const {
out << "\n" << group << ":\n";
for (const Option *opt : opts) {
out << make_option(opt, is_positional);
return out.str();
CLI11_INLINE std::string Formatter::make_positionals(const App *app) const {
std::vector<const Option *> opts = app->get_options([](const Option *opt) {
return !opt->get_group().empty() && opt->get_positional();
if (opts.empty())
return {};
return make_group(get_label("POSITIONALS"), true, opts);
CLI11_INLINE std::string Formatter::make_groups(const App *app,
// Options
for (const std::string &group : groups) {
app->get_options([app, mode, &group](const Option *opt) {
return opt->get_group() == group // Must be in the right group
&& opt->nonpositional() // Must not be a positional
&& (mode != AppFormatMode::Sub // If mode is Sub, then
|| (app->get_help_ptr() != opt // Ignore help pointer
&& app->get_help_all_ptr() !=
opt)); // Ignore help all pointer
if (!group.empty() && !opts.empty()) {
out << make_group(group, false, opts);
// Removed double newline between groups for consistency of help text
// if(group != groups.back())
// out << "\n";
return out.str();
CLI11_INLINE std::string Formatter::make_description(const App *app) const {
std::string desc = app->get_description();
auto min_options = app->get_require_option_min();
auto max_options = app->get_require_option_max();
if (app->get_required()) {
desc += " " + get_label("REQUIRED") + " ";
if (min_options > 0) {
if (max_options == min_options) {
desc += " \n[Exactly " + std::to_string(min_options) +
" of the following options are required]";
} else if (max_options > 0) {
desc += " \n[Between " + std::to_string(min_options) + " and " +
std::to_string(max_options) +
} else {
desc += " \n[At least " + std::to_string(min_options) +
desc += " \n[At most " + std::to_string(max_options) +
" of the following options are allowed]";
return (!desc.empty()) ? desc + "\n\n" : std::string{};
CLI11_INLINE std::string Formatter::make_usage(const App *app,
std::string name) const {
std::string usage = app->get_usage();
if (!usage.empty()) {
return usage + "\n\n";
out << '\n';
if (name.empty())
out << get_label("Usage") << ':';
out << name;
// Print an Options badge if any options exist
std::vector<const Option *> non_pos_options =
app->get_options([](const Option *opt) { return opt->nonpositional(); });
if (!non_pos_options.empty())
out << " [" << get_label("OPTIONS") << "]";
// Positionals need to be listed here
std::vector<const Option *> positionals =
app->get_options([](const Option *opt) { return opt->get_positional(); });
// Print out positionals if any are left
if (!positionals.empty()) {
// Convert to help names
std::vector<std::string> positional_names(positionals.size());
std::transform(
positionals.begin(), positionals.end(), positional_names.begin(),
[this](const Option *opt) { return make_option_usage(opt); });
out << " " << detail::join(positional_names, " ");
// Add a marker if subcommands are expected or optional
if (!app->get_subcommands([](const CLI::App *subc) {
return ((!subc->get_disabled()) && (!subc->get_name().empty()));
.empty()) {
out << ' ' << (app->get_require_subcommand_min() == 0 ? "[" : "")
<< get_label(app->get_require_subcommand_max() < 2 ||
app->get_require_subcommand_min() > 1
? "SUBCOMMAND"
: "SUBCOMMANDS")
<< (app->get_require_subcommand_min() == 0 ? "]" : "");
out << "\n\n";
return out.str();
CLI11_INLINE std::string Formatter::make_footer(const App *app) const {
std::string footer = app->get_footer();
if (footer.empty()) {
return std::string{};
return '\n' + footer + "\n\n";
CLI11_INLINE std::string Formatter::make_help(const App *app, std::string name,
AppFormatMode mode) const {
// This immediately forwards to the make_expanded method. This is done this
// way so that subcommands can have overridden formatters
if (mode == AppFormatMode::Sub)
return make_expanded(app, mode);
if ((app->get_name().empty()) && (app->get_parent() != nullptr)) {
if (app->get_group() != "SUBCOMMANDS") {
out << app->get_group() << ':';
detail::streamOutAsParagraph(out, make_description(app),
description_paragraph_width_,
""); // Format description as paragraph
out << make_usage(app, name);
out << make_positionals(app);
out << make_groups(app, mode);
out << make_subcommands(app, mode);
out, make_footer(app),
footer_paragraph_width_); // Format footer as paragraph
return out.str();
CLI11_INLINE std::string Formatter::make_subcommands(const App *app,
std::vector<const App *> subcommands = app->get_subcommands({});
// Make a list in definition order of the groups seen
std::vector<std::string> subcmd_groups_seen;
for (const App *com : subcommands) {
if (!com->get_group().empty() && com->get_group().front() != '+') {
out << make_expanded(com, mode);
continue;
std::string group_key = com->get_group();
if (!group_key.empty() &&
std::find_if(subcmd_groups_seen.begin(), subcmd_groups_seen.end(),
[&group_key](std::string a) {
return detail::to_lower(a) ==
detail::to_lower(group_key);
}) == subcmd_groups_seen.end())
subcmd_groups_seen.push_back(group_key);
// For each group, filter out and print subcommands
for (const std::string &group : subcmd_groups_seen) {
out << '\n' << group << ":\n";
std::vector<const App *> subcommands_group =
app->get_subcommands([&group](const App *sub_app) {
return detail::to_lower(sub_app->get_group()) ==
detail::to_lower(group);
for (const App *new_com : subcommands_group) {
if (new_com->get_name().empty())
continue;
if (mode != AppFormatMode::All) {
out << make_subcommand(new_com);
} else {
out << new_com->help(new_com->get_name(), AppFormatMode::Sub);
out << '\n';
return out.str();
CLI11_INLINE std::string Formatter::make_subcommand(const App *sub) const {
std::string name = " " + sub->get_display_name(true) +
(sub->get_required() ? " " + get_label("REQUIRED") : "");
out << std::setw(static_cast<int>(column_width_)) << std::left << name;
detail::streamOutAsParagraph(out, sub->get_description(), right_column_width_,
std::string(column_width_, ' '), true);
out << '\n';
return out.str();
CLI11_INLINE std::string Formatter::make_expanded(const App *sub,
out << sub->get_display_name(true) << '\n';
detail::streamOutAsParagraph(out, make_description(sub),
" "); // Format description as paragraph
if (sub->get_name().empty() && !sub->get_aliases().empty()) {
detail::format_aliases(out, sub->get_aliases(), column_width_ + 2);
out << make_positionals(sub);
out << make_groups(sub, mode);
out << make_subcommands(sub, mode);
out, make_footer(sub),
out << '\n';
return out.str();
CLI11_INLINE std::string Formatter::make_option(const Option *opt,
bool is_positional) const {
if (is_positional) {
const std::string left =
" " + make_option_name(opt, true) + make_option_opts(opt);
const std::string desc = make_option_desc(opt);
out << std::setw(static_cast<int>(column_width_)) << std::left << left;
if (!desc.empty()) {
bool skipFirstLinePrefix = true;
if (left.length() >= column_width_) {
out << '\n';
skipFirstLinePrefix = false;
detail::streamOutAsParagraph(out, desc, right_column_width_,
skipFirstLinePrefix);
} else {
const std::string namesCombined = make_option_name(opt, false);
const std::string opts = make_option_opts(opt);
// Split all names at comma and sort them into short names and long names
const auto names = detail::split(namesCombined, ',');
std::vector<std::string> vshortNames;
std::vector<std::string> vlongNames;
std::for_each(names.begin(), names.end(),
[&vshortNames, &vlongNames](const std::string &name) {
if (name.find("--", 0) != std::string::npos)
vlongNames.push_back(name);
vshortNames.push_back(name);
// Assemble short and long names
std::string shortNames = detail::join(vshortNames, ", ");
std::string longNames = detail::join(vlongNames, ", ");
// Calculate setw sizes
const auto shortNamesColumnWidth =
static_cast<int>(column_width_ / 3); // 33% left for short names
const auto longNamesColumnWidth = static_cast<int>(
std::ceil(static_cast<float>(column_width_) / 3.0f *
2.0f)); // 66% right for long names and options, ceil result
int shortNamesOverSize = 0;
// Print short names
if (shortNames.length() > 0) {
shortNames = " " + shortNames; // Indent
if (longNames.length() == 0 && opts.length() > 0)
shortNames += opts; // Add opts if only short names and no long names
if (longNames.length() > 0)
shortNames += ",";
if (static_cast<int>(shortNames.length()) >= shortNamesColumnWidth) {
shortNames += " ";
static_cast<int>(shortNames.length()) - shortNamesColumnWidth;
out << std::setw(shortNamesColumnWidth) << std::left << shortNames;
} else {
out << std::setw(shortNamesColumnWidth) << std::left << "";
// Adjust long name column width in case of short names column reaching into
// long names column
(std::min)(shortNamesOverSize,
longNamesColumnWidth); // Prevent negative result with
// unsigned integers
const auto adjustedLongNamesColumnWidth =
longNamesColumnWidth - shortNamesOverSize;
// Print long names
if (longNames.length() > 0) {
if (opts.length() > 0)
longNames += opts;
if (static_cast<int>(longNames.length()) >= adjustedLongNamesColumnWidth)
longNames += " ";
out << std::setw(adjustedLongNamesColumnWidth) << std::left << longNames;
} else {
out << std::setw(adjustedLongNamesColumnWidth) << std::left << "";
if (out.str().length() > column_width_) {
out << '\n';
out << '\n';
return out.str();
CLI11_INLINE std::string Formatter::make_option_name(const Option *opt,
if (is_positional)
return opt->get_name(true, false);
return opt->get_name(false, true);
CLI11_INLINE std::string Formatter::make_option_opts(const Option *opt) const {
if (!opt->get_option_text().empty()) {
out << " " << opt->get_option_text();
} else {
if (opt->get_type_size() != 0) {
if (!opt->get_type_name().empty())
out << " " << get_label(opt->get_type_name());
out << " [" << opt->get_default_str() << "] ";
if (opt->get_expected_max() == detail::expected_max_vector_size)
out << " ...";
else if (opt->get_expected_min() > 1)
out << " x " << opt->get_expected();
if (opt->get_required())
out << " " << get_label("REQUIRED");
if (!opt->get_envname().empty())
out << " (" << get_label("Env") << ":" << opt->get_envname() << ")";
if (!opt->get_needs().empty()) {
out << " " << get_label("Needs") << ":";
for (const Option *op : opt->get_needs())
out << " " << op->get_name();
if (!opt->get_excludes().empty()) {
out << " " << get_label("Excludes") << ":";
for (const Option *op : opt->get_excludes())
return out.str();
CLI11_INLINE std::string Formatter::make_option_desc(const Option *opt) const {
return opt->get_description();
CLI11_INLINE std::string Formatter::make_option_usage(const Option *opt) const {
// Note that these are positionals usages
out << make_option_name(opt, true);
if (opt->get_expected_max() >= detail::expected_max_vector_size)
out << "...";
else if (opt->get_expected_max() > 1)
out << "(" << opt->get_expected() << "x)";
return opt->get_required() ? out.str() : "[" + out.str() + "]";
} // namespace CLI
bool operator==(const EdgeResult &lhs, const EdgeResult &rhs) noexcept
std::exception_ptr GetLastError() noexcept
y
classifier
Definition Minos_CodeExample01.py:11
x
str version()
cvb.Angle max(cvb.Angle a, cvb.Angle b)
cvb.Angle min(cvb.Angle a, cvb.Angle b)
cmdline_parser.cpp:
#include "cmdline_parser.hpp"
CmdLineParser::CmdLineParser() {
app_.set_help_flag();
help_flag = app_.add_flag("-h,--help", "Show this help message.");
app_.add_flag("--list-ips", parsed_.list_ips,
"List available IPv4 addresses for the CVB GEV server.");
app_.add_option("--width", parsed_.width,
"Set the width of the image to stream.");
app_.add_option("--height", parsed_.height,
"Set the height of the image to stream.");
app_.add_option("--ip", parsed_.ip,
"Bind the server to a specific IPv4 address.")->default_val(parsed_.ip);
app_.add_option("--driver,-d", parsed_.driver,
"Choose the server driver type.")
->check(CLI::IsMember({ "filter", "socket" }))->default_val(parsed_.driver);;
app_.add_option("--duration", parsed_.duration,
"Test duration in seconds.")->default_val(parsed_.duration);
int CmdLineParser::parse(int argc, char *argv[]) {
CLI11_PARSE(app_, argc, argv);
if (help_flag && help_flag->count() > 0) {
std::cout << app_.help() << std::endl;
std::exit(0);
} catch (const CLI::ParseError &e) {
return app_.exit(e);
cmdline_parser.hpp:
#pragma once
#include "CLI11.hpp"
#include <cstdint>
#include <string>
#include <vector>
struct ParsedArgs {
bool list_ips = false;
uint16_t width = 0;
uint16_t height = 0;
std::string ip = "172.31.102.83";
std::string driver = "filter";
uint16_t duration = 10;
class CmdLineParser {
private:
ParsedArgs parsed_;
CLI::App app_{"CVB GEV Server speed test"};
CLI::Option *help_flag = nullptr;
CmdLineParser();
int parse(int argc, char *argv[]);
const ParsedArgs &get() const { return parsed_; }
// Example for ** GEV (GigE Vision) Server Speed Test**
#include "ramp_image.hpp"
#include <cvb/composite.hpp>
#include <cvb/driver/multi_part_image.hpp>
#include <cvb/gevserver/logical_network_interface.hpp>
#include <cvb/gevserver/node_map.hpp>
#include <cvb/gevserver/server.hpp>
#include <cvb/gevserver/stream.hpp>
#include <cvb/plane_enumerator.hpp>
#include <cvb/utilities/utilities.hpp>
#include <memory>
#include <stdexcept>
CmdLineParser parser;
int parse_result = parser.parse(argc, argv);
if (parse_result != 0)
return parse_result;
const auto &args = parser.get();
// Handle --list-ips option: print available network interfaces
if (args.list_ips) {
auto interfaces =
std::cout << "Available network interfaces:\n";
for (const auto &iface : interfaces) {
std::cout << " - " << iface.IPAddress() << "\n";
// Validate that the provided IP matched one of the available interfaces
auto interfaces =
auto it = std::find_if(
interfaces.begin(), interfaces.end(),
[&](const auto &iface) { return iface.IPAddress() == args.ip; });
if (it == interfaces.end()) {
std::cerr << "Invalid IP: " << args.ip << std::endl;
return 1;
std::cout << "Using IP: " << args.ip << "\nStarting GEV server..." << std::endl;
if (args.width == 0 || args.height == 0) {
std::cerr << "Width and/or height can not be 0" << std::endl;
return 1;
// Define image size and pixel format for streaming
auto size = Cvb::Size2D<int>{args.width, args.height};
auto pixelFormat = Cvb::PfncFormat::Mono8; // default mono8
auto driver = (args.driver == "socket")
? Cvb::GevServer::DriverType::Socket
: Cvb::GevServer::DriverType::Filter;
// Create and start the GEV Server
auto server =
Cvb::GevServer::Server::CreateWithConstSize(size, pixelFormat, driver);
server->Start(args.ip);
std::cout << "GEV server is running" << std::endl;
std::cout << "Waiting for client to connect and start aquisition..." << std::endl;
Cvb::GevServer::State previousState = Cvb::GevServer::State::Disconnected;
bool acquisitionStarted = false;
while (!acquisitionStarted)
auto state = server->State();
if (state != previousState)
switch (state)
case Cvb::GevServer::State::AcquisitionEnabled:
std::cout << "Acquisition started by client" << std::endl;
acquisitionStarted = true;
case Cvb::GevServer::State::Connected:
std::cout << "Client connected, waiting for acquisition..." << std::endl;
case Cvb::GevServer::State::Configuration:
std::cout << "Server in configuration state, waiting for acquisition..." << std::endl;
case Cvb::GevServer::State::Disconnected:
std::cout << "No client connected, waiting..." << std::endl;
std::cout << "Server in unknown state, waiting..." << std::endl;
previousState = state;
std::this_thread::sleep_for(std::chrono::milliseconds(100));
auto stream = server->Stream();
stream->SetResendBuffersCount(0);
const std::unique_ptr<Cvb::Image> image =
createRampImage(args.width, args.height);
std::size_t const imageSizeBytes =
static_cast<std::size_t>(args.width) * static_cast<std::size_t>(args.height);
std::size_t totalBytesSent = 0;
std::size_t framesSent = 0;
auto testDuration = std::chrono::seconds(args.duration);
auto startTime = std::chrono::high_resolution_clock::now();
std::cout << "Starting image acquisition for " << args.duration << " seconds" << std::endl;
while (std::chrono::high_resolution_clock::now() - startTime < testDuration) {
stream->Send(*image);
totalBytesSent += imageSizeBytes;
framesSent++;
catch (const std::exception& ex) {
std::cerr << "Send failed: " << ex.what() << std::endl;
auto endTime = std::chrono::high_resolution_clock::now();
double elapsedSec = std::chrono::duration<double>(endTime - startTime).count();
// Calculate actual throughput
double throughputMBs =
static_cast<double>(totalBytesSent) / (1000.0 * 1000.0) / elapsedSec;
std::cout << "\nAcquisition finished\n"
<< "Total frames sent: " << framesSent << "\n"
<< "Total data uploaded: " << totalBytesSent / (1000.0 * 1000.0) << " MB\n"
<< "Elapsed time: " << elapsedSec << " s\n"
<< "Average throughput: " << throughputMBs << " MB/s" << std::endl;
} catch (const std::exception &ex) {
std::cerr << "An error occurred: " << ex.what() << std::endl;
return 1;
static ServerPtr CreateWithConstSize(Size2D< int > size, PfncFormat pixelFormat, GevServer::DriverType driverType=GevServer::DriverType::Auto)
cvbbool_t Filter(PROJECTIONEX Pin, cvbval_t *kernel, size_t lSize, PROJECTIONEX &Pout)
static std::vector< LogicalNetworkInterface > GetAllAvailable()
ramp_image.cpp:
#include "cvb/image_plane.hpp"
#include "cvb/plane.hpp"
// Function that creates a ramp image with increasing pixel values
std::unique_ptr<Cvb::Image> createRampImage(uint16_t width, uint16_t height,
uint8_t baseValue) {
auto image = Cvb::Image::Create(Cvb::Size2D<int>{width, height}, 1,
std::uint8_t *base = nullptr;
if (!image->Plane(0).TryContiguousAccess(base))
throw std::runtime_error("Image memory is not contiguous");
for (int y = 0; y < height; ++y) {
std::uint8_t *row = base + y * width;
for (int x = 0; x < width; ++x)
row[x] = static_cast<std::uint8_t>(baseValue + y + x);
return image;
static DataType Int8BppUnsigned() noexcept
static std::unique_ptr< Image > Create(Size2D< int > size, int numPlanes=1, DataType dataType=DataType::Int8BppUnsigned())
ramp_image.hpp:
#pragma once
#include <cstdint>
#include <memory>
#include <mutex>
#include <vector>
uint8_t baseValue = 0);
