#include <cvb/code_reader/code_reader.hpp>
void PrintResults(const std::vector<Result> &results);
auto &config = decoder->Config<Symbology::DataMatrix>();
config.Enable();
config.SetPolarity(Config::Polarity::DarkOnLight);
const auto imageFile =
CVB_LIT("tutorial/CodeReader/Images/DataMat/Surrounded.bmp");
const auto results = decoder->Execute(image->Plane(0));
PrintResults(results);
void PrintResults(const std::vector<Result> &results) {
std::cout << results.size() << " code(s) found.\n";
for (const auto result : results) {
if (result.DecodeStatus() == DecodeStatus::Success) {
std::cout
<< " ------------------------------------------------------------\n";
std::cout << " code with content:\n";
std::cout << result.Data() << "\n";
std::cout << " found at center: (" << result.Center().X() << "/"
<< result.Center().Y() << ")\n";
std::cout << " with corners at: ";
for (int k = 0; k < 4; k++)
std::cout << "(" << result.Corners()[k].X() << "/"
<< result.Corners()[k].Y() << ") ";
std::cout << "\n";
if (result.Result2D()) {
const auto result2D = result.Result2D();
std::cout << " size (width x height): " << result2D->Size().Width()
<< " x " << result2D->Size().Height() << "\n";
std::cout << " rows x columns: " << result2D->Rows() << " x "
<< result2D->Columns() << "\n";
std::cout << " Quality: " << result2D->Quality() << "\n";
std::cout
"------------------------------------------------------------\n\n";
} else {
std::cout << " Decoding failed.\n";
static std::unique_ptr< Decoder > Create()
