Image Manager/Cvb++/CppRdma
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/CppRdma.
// The CppRdma example shows how to stream from a GigE Vision Camera using RDMA for GEV. This enables
// high data rates without CPU load.
#include <string>
#include <vector>
#include <cvb/global.hpp>
static const constexpr int NUM_ELEMENTS_TO_ACQUIRE =
5000; // number of elements to be acquired
static const constexpr int FEEDBACK_INTERVAL =
NUM_ELEMENTS_TO_ACQUIRE / 10; // print progress
static const constexpr int NUM_FLOW_SETS =
10; // number flow sets to announce (usually buffers)
// RDMA transfer is part of the socket driver (GevSD) so the filter driver
// (GevFD) must be ignored.
Cvb::DiscoverFlags::IgnoreVins | Cvb::DiscoverFlags::IgnoreGevFD);
// The following will only work if there is a RDMA capable device connected
// to an RDMA capable network interface. Usually also a driver that allows
// user space access is required. See also
// * Windows: Network Direct Service Provider Interface (NDSPI)
// * Linux: librdmacm.so and libibverbs.so
auto &item = itemList.at(0);
// RDMA must be switched on explicitly otherwise the classic GVSP protocol
// will be used. This is just a request and may fail silently if RDMA is not
// supported. To verify that RDMA is supported and switched on you can check
// the "GevDataStreamingMode" in the TLDevice (Cvb::NodeMapID::TLDevice)
// node map and validate that it is set to "RDMA". The "RDMA" entry is only
// available if the device is RDMA capable.
item.SetParameter(CVB_LIT("UseRdma"), CVB_LIT("1"));
item.AccessToken(), Cvb::AcquisitionStack::GenTL);
auto payloadSize =
static_cast<double>(device->NodeMap(Cvb::NodeMapID::Device)
->Node<Cvb::IntegerNode>(CVB_LIT("PayloadSize"))
->Value());
// Note that RDMA requires GenDC containers as payload.
// The container will automatically be mapped to a composite for
// further processing.
auto dataStream = device->Stream<Cvb::CompositeStream>();
// The default and minimal number of flow sets is three but it is usually
// advisable to increase the number so that about one second can be
// buffered.
dataStream->RegisterManagedFlowSetPool(NUM_FLOW_SETS);
dataStream->Start();
auto startTime = std::chrono::high_resolution_clock::now();
Cvb::CompositePtr composite;
Cvb::WaitStatus waitStatus;
std::tie(composite, waitStatus, enumerator) =
dataStream->WaitFor(TIMEOUT);
switch (waitStatus) {
// abort cannot happen in single threaded scenarios
case Cvb::WaitStatus::Abort:
throw std::runtime_error("wait status unknown.");
case Cvb::WaitStatus::Timeout:
throw std::runtime_error("time out during wait");
case Cvb::WaitStatus::Ok:
if (i && i % FEEDBACK_INTERVAL == 0) {
// try to get the composite's first element as an image
auto firstElement = composite->ItemAt(0);
if (!Cvb::holds_alternative<Cvb::ImagePtr>(firstElement)) {
std::cout << "acquired composites: " << i << " which is not an image"
<< std::endl;
} else {
auto image = Cvb::get<Cvb::ImagePtr>(firstElement);
std::cout << "acquired images: " << i << " | size: " << image->Width()
<< " x " << image->Height() << std::endl;
auto endTime = std::chrono::high_resolution_clock::now();
auto durationMs = std::chrono::duration_cast<std::chrono::milliseconds>(
endTime - startTime)
.count();
dataStream->TryAbort();
// For RDMA streaming the data rate is usually interesting...
auto dataRate = static_cast<int>(
(static_cast<double>(NUM_ELEMENTS_TO_ACQUIRE) * payloadSize) /
(1000.0 * static_cast<double>(durationMs)));
std::cout << std::endl
<< "acquired " << NUM_ELEMENTS_TO_ACQUIRE << " buffers in "
<< durationMs << " ms ( " << dataRate << " MB/s )" << std::endl;
void RegisterManagedFlowSetPool(int flowSetCount)
WaitStatus
