Image Manager/Cvb++/CppMultiStream
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/CppMultiStream.
// Demonstrates an image acquisition application that uses multiple streams to acquire from. Requires:
// A connected and configured GenICam device, or a mock device that is provided by CVMockTL. If you
// prefer to execute this tutorial with the mock device, please pass the "--mock" switch to the
// executable.
#include <chrono>
#include <cvb/global.hpp>
// Constants:
static const constexpr int NUM_ELEMENTS_TO_ACQUIRE = 10;
{Cvb::WaitStatus::Timeout, "Timeout"}, {Cvb::WaitStatus::Abort, "Abort"}};
// Check if it is requested to run with a mock GenTL Producer.
bool demonstrateWithMock =
((argc > 1) &&
(std::string(argv[1]).find("--mock") != std::string::npos))
? true
: false;
// Configure the discovery flags.
auto discoverFlags =
Cvb::DiscoverFlags::IgnoreVins; // Ignores all of the CVB VINs.
// If it is requested to run with a mock, then additionally set an
// appropriate flag.
if (demonstrateWithMock)
discoverFlags |= Cvb::DiscoverFlags::IncludeMockTL; // Include CVMockTL.
// Retrieve a device.
auto infoList = Cvb::DeviceFactory::Discover(discoverFlags);
// Can't continue the demo if there's no device:
if (infoList.empty())
throw std::runtime_error("No devices found.");
// Determine the target device.
Cvb::String accessToken;
if (demonstrateWithMock) {
for (auto n = 0; (n < infoList.size()) && accessToken.empty(); ++n)
if (infoList.at(n).AccessToken().find("MockTL") != std::string::npos)
accessToken = infoList.at(n).AccessToken();
// Make sure if CVMockTL is on the candidate list.
if (accessToken.empty())
throw std::runtime_error("Could not find CVMockTL.");
} else
accessToken = infoList.front().AccessToken();
// Open the selected device.
infoList.front().AccessToken(), Cvb::AcquisitionStack::GenTL);
// Get all streams that belong to the device.
std::vector<Cvb::ImageStreamPtr> streams;
std::generate_n(std::back_inserter(streams), device->StreamCount(),
[&device, i = 0]() mutable {
return device->Stream<Cvb::ImageStream>(i++);
std::cout << "Stream count: " << streams.size() << "\n";
// Let all streams start data streaming.
for (const auto stream : streams)
stream->Start();
// Acquire data.
// Note: Getting the data is sequential here for simplicity;
// concurrent wait on different streams is the more likely use case.
for (auto imageIndex = 0; imageIndex < NUM_ELEMENTS_TO_ACQUIRE;
++imageIndex) {
for (auto streamIndex = 0u; streamIndex < streams.size(); ++streamIndex) {
const auto stream = streams[streamIndex];
auto [image, waitStatus, nodeMaps] = stream->WaitFor(TIMEOUT);
switch (waitStatus) {
std::cout << "Unknown wait status.\n";
case Cvb::WaitStatus::Abort:
std::cout << "Wait status not OK: " << WAIT_ERROR_STATES[waitStatus]
<< "\n";
continue;
case Cvb::WaitStatus::Ok:
std::cout << "Stream #" << streamIndex << ", Image #" << imageIndex;
std::cout << std::hex << ", Width: " << image->Width()
<< ", Height: " << image->Height() << "\n";
// Terminate the streaming.
stream->TryAbort();
