Foundation/Cvb.Net/Metric3DCalibrationLaserPlane
This example program is located in your CVB installation under %CVB%Tutorial/Foundation/Cvb.Net/Metric3DCalibrationLaserPlane.
Program.cs:
// Example for **extrinsic calibration**, including the **correction of an inclined laser plane**, in a
// laser triangulation system using the AQS12 target.
namespace Metric3DCalibration
using ExtensionMethods;
class Program
Console.Write("Estimation of an affine transformation(correcting an inclined laser plane)\n\n");
var piece = GetAQS12Piece();
config.CalculateHomography = false;
var rangeMap = Image.FromFile(@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif");
Console.Write("Rangemap loaded with size of " + rangeMap.Width.ToString() + " x " + rangeMap.Height.ToString() + " from ");
Console.Write(@"%CVB%\Tutorial\Metric\Images\RangeMapCalibrationPattern.tif" + "\n");
var calibrator = Calibrator3D.FromFile<LaserPlaneCalibrator3D>(@"%CVB%\Tutorial\Metric\Images\SICalibration.json");
var cloud = calibrator.CreatePointCloud(rangeMap, PointCloudFlags.Float);
Console.Write("Dense point cloud created from rangemap and calibration file with " + cloud.NumPoints + " points.\n\n");
var segmentor = new AQS12DensePointCloudSegmentor(SegmentationMethod.KmeansClustering);
Point3Dd[] residuals;
var affineMatrix = Metric.CalculateCorrectionOfLaserPlaneInclinationFromAqs12Piece(cloud as DensePointCloud, segmentor, config, out residuals);
calibrator.CorrectionOfLaserPlaneInclination = Tuple.Create<AffineMatrix3D?, AffineTransformationParameters?>(affineMatrix.Item1, affineMatrix.Item2);
calibrator.CorrectionOfLaserPlaneInclination.Item1.Value.ShowTransformation();
if (calibrator.CorrectionOfLaserPlaneInclination.Item2 != null)
calibrator.CorrectionOfLaserPlaneInclination.Item2.Value.ShowTransformation();
Console.Write("Residuals:\n");
residuals.ShowXYZArray();
double desiredAccuracy = 0.05;
if (!residuals.CheckAccuracy(desiredAccuracy))
Console.Write("Results do not have desired accuracy. Check face segmentation and extracted AQS12 points...\n");
var facesAqs12 = segmentor.FaceSegmentationFromPiece(cloud as DensePointCloud);
var pointsAqs12 = segmentor.ExtractProjectedPointsFromPiece(cloud as DensePointCloud);
Console.Write("Extracted points from point cloud:\n");
pointsAqs12.ShowXYZArray();
var calibratedCloud = calibrator.CreatePointCloud(rangeMap, PointCloudFlags.Float);
Console.Write("The calibration was sucessful and accuracy is < " + desiredAccuracy.ToString() + " mm. :)\n");
public static AQS12Piece GetAQS12Piece()
var points = new Point3Dd[]
new Point3Dd(20.0018, 44.9941, 15.0000),
new Point3Dd(24.0018, 39.9942, 14.9994),
new Point3Dd(23.9994, 24.9972, 15.0001),
new Point3Dd(20.0021, 20.0035, 15.0011),
new Point3Dd(15.9994, 25.0079, 15.0016),
new Point3Dd(16.0000, 39.9919, 15.0010),
new Point3Dd(20.0095, 59.9985, 4.9902),
new Point3Dd(32.0093, 44.9958, 4.9909),
new Point3Dd(32.0052, 19.9925, 4.9920),
new Point3Dd(20.0021, 4.9961, 4.9939),
new Point3Dd( 8.0024, 19.9980, 5.0009),
new Point3Dd( 8.0065, 45.0009, 4.9984)
return new AQS12Piece(points, 0);
namespace ExtensionMethods
public static class Extensions
public static void ShowTransformation(this AffineMatrix3D trafo)
System.Text.StringBuilder sMessage = new System.Text.StringBuilder();
sMessage.Append("Translation:\n");
sMessage.Append(trafo.Translation.ToString());
sMessage.Append("\n\nTransformation matrix:\n");
sMessage.Append(trafo.Matrix.ToString());
sMessage.Append("\n\n");
Console.Write(sMessage.ToString());
public static void ShowTransformation(this AffineTransformationParameters trafoPara)
sMessage.Append("Rotation angles in [degree] about\n");
sMessage.Append("X: " + trafoPara.RotationAngles[0].ToString("N4") + "\n");
sMessage.Append("Y: " + trafoPara.RotationAngles[1].ToString("N4") + "\n");
sMessage.Append("Z: " + trafoPara.RotationAngles[2].ToString("N4") + "\n\n");
sMessage.Append("Inclination of laser plane in [degree] about\n");
sMessage.Append("X: " + trafoPara.InclinationX.ToString("N4") + "\n");
sMessage.Append("Z: " + trafoPara.InclinationZ.ToString("N4") + "\n\n");
sMessage.Append("Shear\n");
sMessage.Append("Syz: " + trafoPara.Syz.ToString("N5") + "\n");
sMessage.Append("Syx: " + trafoPara.Syx.ToString("N5") + "\n\n");
sMessage.Append("Scale\n");
sMessage.Append("X: " + trafoPara.Scale.X.ToString("N3") + "\n");
sMessage.Append("Y: " + trafoPara.Scale.Y.ToString("N3") + "\n");
sMessage.Append("Z: " + trafoPara.Scale.Z.ToString("N3") + "\n\n");
public static void ShowXYZArray(this Point3Dd[] xyz)
sMessage.Append("Point \t X \t Y \t Z \n");
for (int i = 0; i < 12; i++)
sMessage.Append(i + 1 + "\t" + xyz[i].X.ToString("N4") + " " + xyz[i].Y.ToString("N4") + " " + xyz[i].Z.ToString("N4") + "\n");
sMessage.Append("\n");
public static bool CheckAccuracy(this Point3Dd[] residuals, double desiredAccuracy)
foreach (Point3Dd residual in residuals)
if (residual.X > desiredAccuracy || residual.Y > desiredAccuracy || residual.Z > desiredAccuracy)
return false;
return true;
} // namespace ExtensionMethods
PointCloud CreatePointCloud(Image rangeMap)
static Calibrator3D FromFile(string fileName)
static CalibrationConfiguration FromAQS12Piece(AQS12Piece piece)
static Tuple< AffineMatrix3D, AffineTransformationParameters?> CalculateCorrectionOfLaserPlaneInclinationFromAqs12Piece(DensePointCloud cloud, AQS12DensePointCloudSegmentor segmentor, CalibrationConfiguration config, out Point3Dd[] residuals)
override string ToString()
