Configuration - VinDevice Node Map and VinBuffer Node Map
This code example demonstrates how and when a VinDevice node map and a VinBuffer node map can be retrieved.
using namespace Cvb;
auto devices = DeviceFactory::Discover(
DiscoverFlags::IgnoreVins); // (1)
devices.front().AccessToken(), AcquisitionStack::GenTL); // (2)
auto vinDeviceNodeMap = device->NodeMap(NodeMapID::VinDevice); // (3)
auto dataStream = device->Stream<Cvb::ImageStream>(); // (4)
dataStream->Start(); // (5)
auto [image, waitStatus, enumerator] = dataStream->WaitFor(std::chrono::milliseconds(3000)); // (6)
auto vinBufferNodeMap = device->NodeMap(Cvb::NodeMapID::VinDevice); // (7)
dataStream->TryAbort(); // (8)
void Start() override
using (var devices = DeviceFactory.Discover(DiscoverFlags.IgnoreVins)) // (1)
using (var device = DeviceFactory.Open(devices[0], AcquisitionStack.GenTL)) // (2)
using (var vinDeviceNodeMap = device.NodeMaps[NodeMapNames.VinDevice]) // (3)
var stream = ((GenICamDevice)device).GetStream<ImageStream>(0); // (4)
stream.Start(); // (5)
using (var image = stream.Wait(out WaitStatus status)) // (6)
using (var nodeMaps = NodeMapDictionary.FromImage(image))
using (var vinBufferNodeMap = nodeMaps[NodeMapNames.VinBuffer]) // (7)
stream.TryAbort(); // (8)
static NodeMapDictionary FromImage(MultiPartImage image)
cvb.DiscoverFlags.IgnoreVins) # (1)
devices[0].access_token, cvb.AcquisitionStack.GenTL) # (2)
vin_device_node_map = device.node_maps["VinDevice"] # (3)
stream = device.stream(cvb.ImageStream, 0) # (4)
stream.start() # (5)
image, status, node_maps = stream.wait() # (6)
vin_buffer_node_map = node_maps["VinBuffer"] # (7)
stream.abort() # (8)
  1. Get a list of devices.
  2. Open a GenICam device.
  3. Retrieve the VinDevice node map.
  4. Instantiate a TLDataStream module.
  5. Start data streaming.
  6. Wait for a buffer delivery completion.
  7. Retrieve the VinBuffer node map.
  8. Stop data streaming.
