cvb_movie2/Cvb++/QtMovie2
This example program is located in your CVB installation under %CVB%Tutorial/cvb_movie2/Cvb++/QtMovie2.
#ifdef _MSC_VER
#pragma warning(push, 1)
#pragma warning(disable : 4702)
#endif
#include <QApplication>
#include <QIcon>
#include "main_widget.hpp"
#ifdef _MSC_VER
#pragma warning(pop)
#endif
QApplication application(argc, argv);
MainWidget mainWidget;
mainWidget.setWindowIcon(QIcon(":/qttutorial.png"));
mainWidget.show();
application.exec();
main_widget.cpp:
#include <QComboBox>
#include <QDir>
#include <QFileDialog>
#include <QGridLayout>
#include <QLabel>
#include <QLineEdit>
#include <QMessageBox>
#include <QPushButton>
#include <cvb/device.hpp>
#include <cvb/size_2d.hpp>
#include <cvb/movie2/recorder.hpp>
#include <cvb/movie2/recording_settings.hpp>
MainWidget::MainWidget() : QWidget() {
auto layout = new QGridLayout;
auto fileName = QDir::homePath() + QDir::separator() + "Documents" +
QDir::separator() + "Movie2ExampleVideo.avi";
movieFile_ = new QLineEdit(fileName);
auto btnFileSelect = new QPushButton("Record to...");
QObject::connect(btnFileSelect, &QPushButton::clicked, [=]() {
auto file = QFileDialog::getSaveFileName(this, "Record Video", fileName,
"Video Files (*.avi)");
if (file.isEmpty())
file = fileName;
movieFile_->setText(file);
imageView_ = new Cvb::UI::ImageView;
imageView_->SetUploadMode(Cvb::UI::UploadMode::Viewport);
imageView_->SetRenderEngine(Cvb::UI::RenderEngine::Raster);
imageView_->resize(800, 600);
QPushButton *openImgBtn = new QPushButton("Open Image");
QObject::connect(openImgBtn, &QPushButton::clicked, [=]() {
auto driver = QFileDialog::getOpenFileName(
this, "Load Image",
Cvb::UI::CvbToQt(Cvb::InstallPath() + CVB_LIT("tutorial")),
"CVB Emulator Image Lists (*.emu);;CVB Drivers (*.vin);;Images (*.bmp "
"*.png *.tif *.tiff *.jpg)");
Load(driver);
grabCheckBox_ = new QCheckBox("Grab");
QObject::connect(grabCheckBox_, &QCheckBox::stateChanged, [=](int state) {
if (state == Qt::CheckState::Checked) {
// Start streaming
streamHandler_->Run();
assert(streamHandler_->IsActive());
} else {
// Disable possible blocking of the UI if necessary
bool wait = imageView_->IsWaitForRepaintEnabled();
if (wait)
imageView_->SetWaitForRepaintEnabled(!wait);
// Stop streaming
streamHandler_->Finish();
// Reset the previous state
imageView_->SetWaitForRepaintEnabled(wait);
assert(!streamHandler_->IsActive());
auto recordCheckBox = new QCheckBox("Record");
QObject::connect(recordCheckBox, &QPushButton::clicked, [=]() {
if (!recorder_) {
// Start recording, Write to avi file is in HandleAsyncStream
Cvb::UI::QtToCvb(movieFile_->text()), imageView_->Image()->Size(),
Cvb::Movie2::RecorderPixelFormat::Mono, settings_);
} else {
// Stop recording (necessary to close the recording file correctly)
recorder_.reset();
// Show recording codecs of direct show engine
auto codecComboBox = new QComboBox();
auto codecs = settings_.AvailableCodecs();
for (const auto &codec : codecs)
codecComboBox->addItem(Cvb::UI::CvbToQt(codec));
codecComboBox->setCurrentText(Cvb::UI::CvbToQt(settings_.Codec()));
layout->addWidget(btnFileSelect, 0, 0);
layout->addWidget(movieFile_, 0, 1);
layout->addWidget(openImgBtn, 0, 2);
layout->addWidget(grabCheckBox_, 0, 3);
layout->addWidget(recordCheckBox, 1, 2, 1, 2);
layout->addWidget(codecComboBox, 2, 2, 1, -1);
layout->addWidget(imageView_, 1, 0, 3, 2);
CVB_LIT("tutorial/ClassicSwitch.emu")));
setLayout(layout);
// Load an image or driver
void MainWidget::Load(const QString &driver) {
QString fileName = driver;
if (fileName.isEmpty())
if (fileName.contains(".emu", Qt::CaseInsensitive))
fileName = fileName.replace("/", "\\"); // necessary for emu files
// Either load an image or device (vin or emu)
if (fileName.contains(".bmp", Qt::CaseInsensitive) ||
fileName.contains(".png", Qt::CaseInsensitive) ||
fileName.contains(".tif", Qt::CaseInsensitive) ||
fileName.contains(".jpg", Qt::CaseInsensitive)) {
imageView_->Refresh(image);
// Disable the grab check box for images
grabCheckBox_->setEnabled(false);
} else {
auto device = Cvb::DeviceFactory::Open(Cvb::UI::QtToCvb(fileName),
Cvb::AcquisitionStack::Vin);
// Connect the device with the ImageView
imageView_->Refresh(device->DeviceImage(), Cvb::UI::AutoRefresh::On);
// Create a stream handler
streamHandler_ = CustomStreamHandler::Create(device->Stream(), *this);
// Enable the grab check box for devices
grabCheckBox_->setEnabled(true);
QMessageBox::critical(this, "Error", QString(error.what()));
static std::unique_ptr< Recorder > Create(const String &path, Size2D< int > size, RecorderPixelFormat pixelFormat, const RecordingSettings &settings)
void SetUploadMode(Cvb::UI::UploadMode uploadMode)
main_widget.hpp:
#pragma once
#include <QCheckBox>
#include <QWidget>
// The main widget
class MainWidget : public QWidget {
Q_OBJECT
explicit MainWidget();
virtual ~MainWidget() {}
private:
void Load(const QString &driver);
protected:
private:
Cvb::UI::ImageView *imageView_ = nullptr;
QLineEdit *movieFile_ = nullptr;
QCheckBox *grabCheckBox_ = nullptr;
// The custom stream handler to handle image processing while grabbing
class CustomStreamHandler : public Cvb::SingleStreamHandler {
Create(const Cvb::StreamPtr &stream, MainWidget &mainWidget) {
return std::unique_ptr<CustomStreamHandler>(
new CustomStreamHandler(stream, mainWidget));
~CustomStreamHandler() { TryFinish(); }
private:
CustomStreamHandler(const Cvb::StreamPtr &stream, MainWidget &mainWidget)
: Cvb::SingleStreamHandler(stream), mainWidget_(mainWidget) {}
void HandleAsyncStream(const Cvb::StreamPtr &stream) override {
auto waitResult = stream->WaitFor(std::chrono::milliseconds(10000));
if (waitResult.Status != Cvb::WaitStatus::Ok)
// Write the image to the recorder file
if (mainWidget_.recorder_)
mainWidget_.recorder_->Write(*waitResult.Image);
MainWidget &mainWidget_;
std::shared_ptr<CustomStreamHandler> streamHandler_;
std::shared_ptr< Recorder > RecorderPtr
