Image Manager/Cvb++/QtStreamDisplay
This example program is located in your CVB installation under %CVB%Tutorial/Image Manager/Cvb++/QtStreamDisplay.
// The QtStreamDisplay example shows a display with a stream from a GenICam device with Qt.
#include <QApplication>
#include <QIcon>
#include <cvb/async/async.hpp>
QApplication app(argc, argv);
path += CVB_LIT("drivers/CVMock.vin");
// use command line argument if provided.
if (argc > 1) {
std::string inputPath(argv[1]);
path = Cvb::String(inputPath.begin(), inputPath.end());
// expand environment variables in path
path = Cvb::ExpandPath(path);
// open a device
auto device = Cvb::DeviceFactory::Open(path, Cvb::AcquisitionStack::Vin);
// connect the device image to the UI
view.setWindowIcon(QIcon(":/qttutorial.png"));
view.SetUploadMode(Cvb::UI::UploadMode::Viewport);
view.SetRenderEngine(Cvb::UI::RenderEngine::Raster);
view.Refresh(device->DeviceImage(), Cvb::UI::AutoRefresh::On);
view.show();
// get the first stream of the device
// or use device->Stream(index) to get another stream
// create an acquisition handler for that stream and run it.
// Actually the guard starts it, and will finish it when destructed.
// There are two ways to run the acquisition:
// - Either via stream->Start() and stream->Wait() in a separate thread
// - or via SingleStreamHandler (Run() / Finish())
Cvb::SingleStreamHandler::Create(stream), Cvb::AutoRun::Yes);
return app.exec();
static std::unique_ptr< SingleStreamHandler > Create(const Driver::StreamPtr &stream)
void SetUploadMode(Cvb::UI::UploadMode uploadMode)
void Refresh(Cvb::UI::RefreshMode refreshMode)
void SetRenderEngine(Cvb::UI::RenderEngine renderEngine)
