ImageManager/Cvb.Net/SimpleStreamingGen3
This example program is located in your CVB installation under %CVB%Tutorial/ImageManager/Cvb.Net/SimpleStreamingGen3.
Program.cs:
// Example for simple streaming with the 3rd generation acquisition stack.
namespace SimpleStreamingGen3
class SimpleStreamingGen3
using (var device = DeviceFactory.Open(devices[0], AcquisitionStack.GenTL))
var stream = ((GenICamDevice)device).GetStream<CompositeStream>(0);
stream.Start();
for (int i = 0; i < 10; i++)
WaitStatus status;
using (var nodeMaps = NodeMapDictionary.FromComposite(composite))
Console.WriteLine($"Acquired image: {i}");
if (composite.Purpose == CompositePurpose.Image)
Console.WriteLine("is image");
else if (composite.Purpose == CompositePurpose.ImageList)
Console.WriteLine("is image list");
else if (composite.Purpose == CompositePurpose.MultiAoi)
Console.WriteLine("is multi aoi");
else if (composite.Purpose == CompositePurpose.RangeMap)
Console.WriteLine("is range map");
else if (composite.Purpose == CompositePurpose.PointCloud)
Console.WriteLine("is point cloud");
else if (composite.Purpose == CompositePurpose.ImageCube)
Console.WriteLine("is image cube");
else if (composite.Purpose == CompositePurpose.Custom)
Console.WriteLine("is custom");
Console.WriteLine("is something else");
stream.Abort();
static NodeMapDictionary FromComposite(Composite composite)
