ImageManager/Cvb.Net/SimpleStreamingGen2
This example program is located in your CVB installation under %CVB%Tutorial/ImageManager/Cvb.Net/SimpleStreamingGen2.
Program.cs:
// Example for simple streaming with the (deprecated) 2nd generation acquisition stack.
namespace SimpleStreamingGen2
class SimpleStreamingGen2
using (var device = DeviceFactory.Open(devices[0], AcquisitionStack.Vin))
var stream = device.Stream;
stream.Start();
for (int i = 0; i < 10; i++)
WaitStatus status;
Console.WriteLine($"Acquired image: {i} | Timestamp: {image.RawTimestamp}");
stream.Abort();
