ImageManager/Cvb.Net/FlowSetPool
This example program is located in your CVB installation under %CVB%Tutorial/ImageManager/Cvb.Net/FlowSetPool.
Program.cs:
// Example of managing buffer allocation for image streaming.
namespace FlowSetPool
class FlowSetPool
using (var device = DeviceFactory.Open(devices[0], AcquisitionStack.GenTL))
stream.RegisterManagedFlowSetPool(100);
Console.WriteLine($"Buffers allocated: {stream.FlowSetCount}");
stream.DeregisterFlowSetPool();
stream.RegisterManagedFlowSetPool(200);
stream.Start();
for (int i = 0; i < 10; i++)
WaitStatus status;
using (var nodeMaps = NodeMapDictionary.FromImage(image))
// processing here...
stream.Abort();
static NodeMapDictionary FromImage(MultiPartImage image)
