User guide for configuration your acquisition hardware with Common Vision Blox.
| Acquisition Hardware | |
| GigE Vision Devices | |
| USB3 Vision Devices | |
| CoaXPress Devices | |
| CameraLink Devices | |
To be able to acquire images from acquisition devices CVB and the appropriate hardware drivers have to be installed on your system.
The hardware independent architecture of CVB requires a video interface file (vin) to be loaded when an image acquisition device is used (e.g. CVB GenICam driver (GenICam.vin) for GenICam compliant devices.) The *.vin format is proprietary to CVB and supports a wide variety of interfaces for acquisition, line scan acquisition, triggered acquisition and many more.
Following CVB downloads are available:
CVB Download
Installation and Setup
Manufacturer specific Hardware with CVB driver
The video interface (vin) file format is used for all Common Vision Blox drivers. There are vin-files available for a vast range of different image acquisition devices like frame grabbers, cameras or vision systems.
Please refer to the CVB Download area for driver download matching the CVB versions.
Get a Quick Start with:
| System Browser | Get an overview of the vision system components. |
| GenICam Browser | Search and configure GenICam compliant hardware. |
| License Manager | Manage the CVB Licenses. |
Find applications and tutorials:
%CVB%Applications and %CVB%Tutorial/opt/cvb/bin and tutorials under /opt/cvb/tutorialRefer also Installation and Setup
The System Browser can be used for GenICam compliant devices to:
Start the System Browser from: %CVB%Tutorial\Image Manager\Cvb.Net\bin\Release\SystemBrowser.exe
License information:
Network information:
Diagnostic data:
Live view:
Get a live view by double clicking the camera and use the Node Map camera configuration options, Statistics and Discovery information.
The GenICam Browser can be used to:
%CVB%ApplicationsDetailed information about the GenICam Browser can be found in the following documents:
| GenICam Browser | Detailed description of the GenICam Browser Application. |
| ⭐ Step-By-Step Guide | Configure your cameras with the step-by-step guide of the GenICam Browser. |
It is recommended to start with the Step-By-Step Guide and look up for detailed information in the manual of the GenICam Browser if needed.
Complete License Management can be handled with License Manager. An overview over all available licenses can be found here.
A detailed description of the different license methods can be found in section Licensing.
Following documentations and information sources are available:
Please check the CVB Web pages for updates to this driver in form of a CVB service pack or a hotfix. Therefore please visit CVB User Forum Download area and choose the CVB Version or Operating System.
For any kind of problem you encounter with CVB GenICam driver it is very helpful to record the error logging (Log window in GenICam Browser or LogGUI.exe in %CVB%Applications). Please have also a look at the description of Acquisition Statistic, Trouble Shooting and Error logging.
