Calibration object to apply zig zag algorithm to the range map of a laser triangulation cameras. More...
Inherits LaserPlaneCalibrator3D.
Additional Inherited Members | |
Public Member Functions inherited from Calibrator3D | |
Union[cvb.Calibrator3DAT, cvb.LaserPlaneHomographyCalibrator3D, cvb.LaserPlaneZigZagCalibrator3D, cvb.FactorsCalibrator3D, cvb.MatrixCalibrator3D, cvb.PinholeCameraCalibrator3D] | load (str file_name) |
Loads a 3D calibration from file. More... | |
None | save (self, str file_name) |
Write the current content calibrator to a file. More... | |
Properties inherited from LaserPlaneCalibrator3D | |
correction_of_laser_plane_inclination = property | |
Tuple[Optional[cvb.AffineMatrix3D], Optional[cvb.AffineTransformationParameters]]: Gets and sets the correction of the laser plane inclination (affine transformation) of the calibrator - may be None. More... | |
sensor_settings = property | |
cvb.SensorSettings: Gets sensor settings. | |
y_factor = property | |
float: Gets the y factor (encoder step). | |
Properties inherited from Calibrator3D | |
extrinsic_matrix = property | |
cvb.AffineMatrix3D: Gets and sets the extrinsic transformation matrix (rigid body transformation) of the calibrator. | |
range_map_ignore_value = property | |
Optional[float]: Gets or sets value to be ignored in range map - may be None. | |
