CVB GenICam User Guide
GenICam Standard
The GenICam™ standard (Generic Interface for Cameras) provides a generic software interface for any kind of vision acquisition devices, independent of their hardware interface. It allows access to devices such as cameras or strobe controllers via a standardised interface, no matter which technology-such as GigE Vision, CameraLink, CameraLink HS, CoaXPress or USB3 Vision-is used.
The GenICam standard consists of different modules, each addressing a specific part of a typical vision system:
  • GenTL: GENeric Transport Layer is the transport layer interface for enumerating cameras, grabbing images from the camera and moving images to the user application.
  • GenApi: GENeric Application Programming Interface enables listing and configuration of features available with a device.
  • SFNC: The Standard Features Naming Convention defines the name, type and behaviour of the device settings.
  • CLProtocol: CLProtocol is a GenTL module allowing CameraLink cameras to be addressed using GenICam.
For more information refer the EMVA homepage: http://www.emva.org/standards-technology/genicam/
CVB Driver Structure
Compared to manufacturer specific SDKs Common Vision Blox with GenICam offers manufacturer independence and increased image acquisition functionality. Hardware compatibility is accomplished by using CVB's vin driver technology supporting various acquisition technologies including any GenICam GenTL provider (transport layer). Being the GenICam GenTL standard maintainers we can assure best support for compliant GenTL providers.
The following acquisition device interface standards are generally used for new applications:
For cameras to connect directly to a PC:
  • GigE Vision
  • USB3 Vision
For the fastest applications that will require a frame grabber:
  • CameraLink
  • CameraLink HS
  • CoaXPress
  • Fire Wire (IEEE 1394)
The hardware independent architecture of CVB requires a video interface file (vin) to be loaded, when an image acquisition device is used.
The *.vin format is proprietary to CVB and supports a wide variety of interfaces for acquisition, line scan acquisition, triggered acquisition and many more.
CVB included Description File Info Interworking with
GenICam GenTL Consumer
for interchangeable Transport Layer usage
GenICam
Video Interface Driver
GenICam.vin
%CVB%Drivers (Windows)
/opt/cvb/drivers (Linux)
any GenTL Producer
GigE Vision GenTL Producer Transport Layer for GigE GEVTL.cti
GENICAM_GENTL64_PATH,
GENICAM_GENTL32_PATH
compliant devices
USB3 Vision GenTL Producer Transport Layer for USB3 CVUSBTL.cti
compliant devices
Emulator Hardware emulation *.avi , *.emu video files
The video interface (vin) file format is used for all Common Vision Blox drivers. There are vin-files available for a vast range of different image acquisition devices like frame grabbers, cameras or vision systems. Please refer to the CVB download area  for driver download matching the CVB versions.
Additional supported  hardware integrations Description File Info Download and install for usage with CVB
3rd party GenTL Producer
refer Other Transport Layer
Camera Link,
Camera Link HS,
FireWire (IEEE1394),
CoaXPress,
USB2,
Analogue,
Active Silicon Firebird Framegrabber
Transport Layer,
can be accessed by GenTL Consumer in CVB due to GenICam compliance
example:
Vimba1394TL.cti
VimbaCLConfigTL.cti
TLActiveSilicon.cti
1. CVB
2. manufacturer hardware control software (e.g. runtime or SDK)
Devices will then appear as a GenICam devices in CVB’s
Applications.
example: Allied Vision Vimba software for GenICam transport
layer support.
Manufacturer specific hardware driver for Frame Grabber or Camera integration, developed by STEMMER IMAGING CVxyz VIN Driver for grabber and cameras without GenICam example:
CVSiSoMe.vin for Silicon Software Frame Grabber,
CVXcelera...vin for DALSA Frame Grabber
CVuEye.vin for IDS cameras
1. CVB
3. CVB vin-driver for this hardware
3rd party developed drivers DDK based proprietary driver *.vin Hardware supplier
The majority of vin-files are developed by STEMMER IMAGING, a Driver Developers Kit (DDK) is available for larger image acquisition hardware manufacturers to purchase. For further information on purchasing the DDK please contact STEMMER IMAGING.
Additional supported  software  integrations Description File Info Download and install for usage with CVB
CVB Software Driver for 3rd party Applications Sherlock CVB Driver,
Vision Pro CVB Driver
1. CVB
2. 3rd Party Application (e.g. IPD Sherlock, Cognex Vision Pro)
3. CVB software driver for this product
example: Sherlock CVB driver, VisionPro CVB driver
4. Vision Hardware dependant Driver and Software (refer above)
Supported Operating systems and other system requirements for the GenICam driver
  • Microsoft Windows 32-bit / 64-bit
  • Linux 32-bit / 64-bit (Ubuntu, Mint, Kubuntu), Yocto (OpenEmbedded Linux)
  • Support for ARM platforms
For more details please refer to Release Notes chapter.
If possible use the newest CVB version because of many improvements in the GenICam package.
GenICam Driver Options
The GenICam driver GenICam.vin uses the driver specific initialization file GenICam.ini to set up the communication and data handling parameters for its associated devices.
Its default location is
  • Windows: %CVBDATA%Drivers (If a different file should be used for GenICam setup, the path entry in the registry must be adjusted.)
  • Linux: /etc/opt/cvb/drivers
The GenICam.ini file can be changed and saved over the menu opened by Options button in GenICamBrowser Configured Devices:
Driver and Device Options for the selected device can be saved by clicking the Save Button.
Transport Layer
Information about all supported Transport Layer (*.cti files) can be found in GenICam Browser in the Available Devices window. In this example the STEMMER IMAGING CVB USB3 Vision (CVUSBTL) and the GigE Vision Transport Layer (GEVTL) are available.
Nodemap
A nodemap displayed in the Property Grid is part of the Transport Layer and therefore available for all  GenICam compliant cameras. Nodemaps are based on the acquisition hardware *.xml file and structured in different ports:
DevicePort
DeviceTLPort
DataStreamPort
FactoryPort
InterfacePort
TLPort
If the device has no *.xml file in its memory a "Nodemap unavailable" message is returned when the device is opened. Be aware that setting a correct XML file for the device is a precondition, if there are problems, refer trouble shooting section.
For Parameter Reference refer to GenICam Standard, SFNC (Standard Features Naming Convention) part.
Get access to the nodemaps via GenICam Browser:
DevicePort
This is the port, which contains the nodemap for the device (remote device). It is the normal nodemap for all device features and is used by default and is returned with the CV GenApi function NMHGetNodeMap().
Programmatically it is referenced in the header file (iDC_GenICam.h) over the enumeration DC_PARAM_GENICAM with: DC_DEVICE_PORT_NODEMAP = 0x00000500
DeviceTLPort
This is the port, which contains the nodemap for the device module of the GenTL. The device module represents the GenTL Producers' proxy for one physical remote device. The responsibility of the device module is to enable the communication with the remote device and to enumerate and instantiate data stream modules. The device module also presents signaling- and module configuration capabilities.
Programmatically it is referenced in the header file (iDC_GenICam.h) over the enumeration DC_PARAM_GENICAM with: DC_DEVICE_NODEMAP = 0x00000400
DataStreamPort
This is the port, which contains the nodemap for the Data Stream module. A single (image) data stream from the device is represented by the Data Stream module. The purpose of this module is to provide the acquisition engine and to maintain the internal buffer pool. Beside that the Data Stream module also presents Signaling and module configuration capabilities.
Programmatically it is referenced in the header file (iDC_GenICam.h) over the enumeration DC_PARAM_GENICAM with: DC_DATASTREAM_NODEMAP = 0x00000600
UpdateStatistics
This is a command, which refreshes the more expensive statistics (those without a polling icon).
NumBuffersQueued
Number of buffers which, at a given point in time, can take new data. Only queued buffers can take new image data. Buffers, which are not queued, are basically locked. In CVB, before a G2Grab starts, all announced buffers are also queued for acquisition. So until the first image starts the NumBuffersQueued = NumBuffersAnnounced. While the first image is transferred the number of queued images is one less than at the start. After the first image finished until the first call to G2Wait the NumBuffersQueued = NumBuffersAnnounced-1 and the pending frames = 1. After G2Wait and before the second image starts NumBuffersQueued = NumBuffersAnnounced-1, delivered buffers=1, pending frames=0. And so on.
NumBuffersAnnounced
These are the buffers known to the GenTL which can hold image data. Only known buffers can be queued (and thus filled with incoming frame data). This has direct influence on the amount of memory allocated by the driver to hold image data.
NumBuffersAwaitDelivery
The number of buffers which have been filled with image data and which are not yet collected by (delivered to) the application (e.g. via G2Wait or ImageSnappedEvent).
NumBuffersInIncompleteList
Number of buffers which have been started to fill but are not yet done. In case this (internal) incomplete list is full the buffer will, depending on the configuration of the driver, delivered as corrupt buffer to the host application or discarded. In other words this counter indicates that a new frame arrived but the old one is not complete yet due to missing packets. It is only updated when packet resend is enabled.
NumFramesLostQueueUnderrun
This is a lost frame counter indicating that an new incoming frame from a camera could not be filled because no buffers where queued. This normally means that the processing is too slow and cannot keep up with the frame-rate of the camera.
NumFramesCorruptOnDelivery
Number of images which were corrupt (not complete) when delivered through G2Wait. A corrupt delivered image cannot/will not be completed after delivery.
NumFramesStarted
The number of buffers taken from the input queue. This means the number of frames the GenTL tries to fill with incoming data.
FramesCorrupt
Number of images which were corrupt on arrival in the host no matter if or if not resend requests have been issued. This setting indicates if something is wrong with the transmission. In case the user wants to discard corrupt images he needs to configure his video interface/TL accordingly. A corrupt image is an image which in the first run did not arrive properly. This includes also images which for example had missing packets and which have been completed later on using resend requests. So a corrupt image may not be corrupt on delivery because the transport mechanisms underneath corrected the failure.
NumPacketsReceived
This is related to GigE and indicates the number of data packets (not frames) received on the GigE Vision streaming channel. received.
NumResends
This is related to GigE and indicates the number of resend requests issued by the host. If this number increases it indicates that something is wrong with the data transmission. Possible reasons may be: Settings of the network card, CPU-load on the host, cable/switch problems, bandwidth problems on the Link (only incremented if missing packets occur and packet resend is enabled). Following examples show how to access features within a CVB program.
Sample Code in C++:
CameraConfig example
FactoryPort
This is the port which contains the NodeMap for the Factory, which represents the GenICam.vin driver.
Programmatically it is referenced in the header file (iDC_GenICam.h) over the enumeration DC_PARAM_GENICAM with: DC_FACTORY_NODEMAP = 0x00000100
InterfacePort
This is the port which contains the NodeMap for the interface module. An interface module represents one physical interface in the system. For Ethernet based Transport Layer technologies this would be a Network Interface Card (NIC), for a Camera Link based implementation this would be one frame grabber board. The enumeration and instantiation of available devices on this interface is the main role of this module. The interface module also presents signaling and module configuration capabilities.
Programmatically it is referenced in the header file (iDC_GenICam.h) over the enumeration DC_PARAM_GENICAM with: DC_INTERFACE_NODEMAP = 0x00000300
python Code Example: DeviceConfiguration example
TLPort
This is the port which contains the NodeMap for the system module. For every GenTL Consumer the system module as the root of the hierarchy is the entry point to a GenTL Producer software driver. It represents the whole system (not global, just the whole system of the GenTL Producer driver) on the host side from the GenTL libraries point of view. The main task of the system module is to enumerate and instantiate available interfaces covered by the implementation. The system module also provides signaling capability and configuration of the module's internal functionality.
Programmatically it is referenced in the header file (iDC_GenICam.h) over the enumeration DC_PARAM_GENICAM with: DC_TL_NODEMAP = 0x00000200
Camera XML file
Getting GenICam XML information
A GenICam device is always equipped with a certain version of firmware. Every firmware revision has a dedicated XML file to describe the abilities and features of the device. When opening a camera its XML file is going to be read when the device is plugged in for the first time. The downloaded structure serves as the base for the property grid (Nodemap).
Set the XML file
To set a new XML file, run the EditBindings console application. With this console application you can see the current linked *.xml file and you can add/delete/bind a new XML file. For future access to the device, the XML file is saved within a database on the host machine and loaded automatically whenever the camera is connected. Camera xml files for Common Vision Blox are saved under %CVBDATA%GenICam\xml\Registry\Files (Windows) and /var/opt/cvb/GenICam/xml (Linux). It is possible that an XML file is changed over time by the vendor to simplify the interface, while the firmware remains the same. It then suffices to set the new XML file with the CVB EditBindings application since the internal functionality remains the same. In case a new revision of camera firmware is published, it is generally distributed by STEMMER IMAGING with further remarks about the changes made as well as the installation procedure. If you don't find an appropriate update please contact our technical support.
Installation
To be able to acquire images from GenICam compliant devices the CVB GenICam driver (GenICam.vin) has to be installed on your system. This is done by default with every CVB installation.
CVB Download
The complete CVB setup includes the GenICam Driver automatically and installs all necessary libraries, controls, sample programs in source code, documentation, the vin-driver, the siNetFilter GigE Vision Filter Driver and the transport layers for GigE Vision and USB 3 Vision.
Download the installation package to a local drive.
Do not install over the network. Since the network connection will be reset during the installation, this will result in a damaged driver setup.
‍Windows:
Install CVB by executing the CommonVisionBlox*.exe1
  • Reboot
After installation the
  • following environment variables are set
    %CVB%    > ProgramFiles
    %CVBDATA%   > ProgramData
    %CVBCONFIG%  > ProgramData since CVB 13
  • GenICam.vin file is available in %CVB%Drivers
  • GenICam.ini file is available in %CVBDATA%Drivers
  • applications and tutorials are under %CVB%Applications and %CVB%Tutorial
  • GenICamBrowser is in Start Menu STEMMER  IMAGING Common Vision Blox and under %CVB%Applications
1 Hints for installation of the STEMMER IMAGING Filter Driver for GigE: The setup will try to install the siNetFilter GigE Vision Filter Driver. Press the “Proceed Installation” button to install the driver for all NICs. This may appear several times depending on the number of NICs in your system. In some cases the setup will not be able to install the driver at this time and the installation will continue after the next reboot. More detailed information about the siFilter Driver Installation can be found in the siFilter Driver Installation section.
‍Linux (refer also GettingStardedGuide.txt):
Install CVB with write access (chmod a+x *.sh) by executing in terminal window:
> ./install_cvb.sh 2
  • Reboot
After CVB installation the
  • GenICam.vin file is available in /opt/cvb/drivers
  • GenICam.ini file is available in /etc/opt/cvb/drivers
  • documentation can be found under /opt/cvb/doc
  • tutorials can be found under /opt/cvb/tutorial
To run an example it has to compiled first with sudo make. Maybe gcc has to be installed before.
  • Libraries are in /opt/cvb/lib
  • GenICamBrowseris in /opt/cvb/bin
2 If no camera is available or the acquisition does not work with USB3 Vision devices, follow the steps in Linux GettingStartedGuide.txt (refer installation package).
In case of GenICam compliant hardware, used with Common Vision Blox, the GenICam Browser is to be taken or the GenICam.vin driver has to be loaded by other applications/tutorials. If needed, install the Grabber SDK or Runtime (e.g. Teledyne Dalsa CamExpert, Silicon Software MicroDisplay) and device driver provided by the device manufacturer.
Note: Please check the CVB Web for drivers and updates or contact technical support. If updated versions are available, they are distributed together with an updated User Guide and a list of new features or fixes in the Release Notes.
Registry-Entries
Registry entries concerning the use of the Common Vision Blox GenICam driver are located at the following key in the Windows registry:
HKEY_LOCAL_MACHINE\SOFTWARE\COMMON VISION BLOX\IMAGE MANAGER\STEMMER IMAGING
The following entry exists: CV GenICam Driver INI-File=$(CVB)\Drivers\GenICam.ini
Details regarding the INI-file are explained here.
GenICam Browser
The GenICam Browser is used to detect connected devices via available Transport Layers and configure them.
  • Windows: Start Menu STEMMER  IMAGING Common Vision Blox and under %CVB%Applications
  • Linux: /opt/cvb/bin
After detection and configuration the specific device and driver data have to be saved as Configured Devices. To open the Common Vision Blox (CVB) *.vin driver (CVB video interface) at least one device has to be stored and accessible in Configured Devices (green camera icon).
To test the correct device settings close the device in GenICam Browser and open a Common Vision Blox application (e.g. CVB Viewer or one of the Image Manager tutorials)
  • Open the application
  • Select 'File'
  • Select 'Open...'
  • Select the vin file from %CVB%Drivers (Windows) or /opt/cvb/drivers (Linux)
To access the devices and load the *.vin device driver all CVB tools and tutorials can be used in the same way.
Device specific features as Turbo Drive can be tested and used in tools and tutorials accessing *.vin driver only, not with GenICam Browser, which uses the Transport Layer.
All CVB GenICam core elements are represented in GenICam Browser:
  • Driver specific configuration file (GenICam.ini) - represented in Configured Devices
  • Transport Layer  - listed in Available Devices / Advanced Config
    GigE Vision - GEVTL.cti with Filter Driver (GEVFD.dll, GEVFDX.dll, siFilterIP.sys, siNetFilter.sys) and Socket Driver (GEVSD.dll)
    USB 3 Vision - CVUSBTL.cti)
  • Camera parameter description file (*.xml) - displayed in Property Grid / Nodemap.
    The XML description is the code that is to be interpreted according to features, registers and ports - SFNC based.
Configuration
The GenICam standard provides a wide range of configurable parameters, the most important ones are described on the following pages. These parameters are generally subdivided into mandatory features as well as custom ones, which might not be implemented by every manufacturer. This can result in minor differences in the setup of specific functionality between device vendors.
The GenICam.vin Common Vision Blox GenICam driver reads the specific driver configuration from the file GenICam.ini which can be found under:
Refer also CVB Driver Structure chapter for overview of driver configuration options and differences.
On the following pages there are guides for:
  • getting a live view using the GenICam Browser,
  • storing settings in the GenICam.ini file,
  • changing image settings,
  • use cases
  • hardware dependent interface configuration (GigE Vision, USB3 Vision, other Transport Layers)
Getting started
Getting Started   with the CVB Configurator and follow the checklist for configuration of:
  • driver
  • acquisition hardware interface
  • devices
Open the GenICam Browser
After starting GenICam Browser for the first time, the available transport layer (TL), available interfaces and devices are listed in a tree view under Available Devices.
Discover Available Devices
To search for available devices and to refresh the Available Devices tree use the Ignore Subnet Discover button. All available devices show up in Available Devices window. If you are using Linux, there are further actions to be taken. Please have a look at the Ignore Subnet Discover on Linux section.
Hardware relevant configuration steps have to be considered, refer:
GigE Vision
USB3 Vision
Different camera symbol colors representing status information. Not displayed devices pointing to missing interface configuration. For details refer GenICam Browser User Guide in Help menu or hints in the GenICam Browser Logging window.
The Linux kernel usually filters broadcasts into wrong subnets. In order to spot cameras with an IP not matching the subnet of the NIC, this feature is essential though. Luckily you can turn the filtering off. Create a bash (.sh) file with following content and execute it.
#!/bin/bash
for filter in /proc/sys/net/ipv4/conf/*/rp_filter; do echo 0 > $filter; done
Even though this may only last until the next reboot, it is good practice to enable the strict filtering again, after setting a valid IP, by writing a 1 to the config. Especially if your PC is connected to the internet or any other untrustworthy network!
Disabling the filter only for the NIC the camera is connected to in the first place is even safer:
#!/bin/bash
echo 0 | tee /proc/sys/net/ipv4/conf/all/rp_filter \
/proc/sys/net/ipv4/conf/<your NIC>/rp_filter
For more information concern reading this introduction to Reverse Path Filtering.
Open a Device for Live View
Doubleclick on the device (use Filter Driver in Windows and Socket Driver in Linux), which has a green camera icon now, or use the Open Device button to get a live view and to configure the device. The device will be opened in the Device View. On the left side a live image is shown, on the right side you will find the property grid to configure the device. In Available Devices the device shows up with an orange icon (device is open). In the Logging part of the application you get some detailed information. To get a single image use the Snap button, to start the acquisition press the Grab button and to stop the acquisition press the Stop button.
Persistent Settings in GenICam Driver
Driver Specific Configuration Files
The driver specific configuration file is the GeniCam.ini-file (refer %CVBDATA%Drivers directory). To set up and store the communication and data handling parameters for GenICam, this ini-file is required.   This file is updated automatically when changing parameters in the Device Options for configured devices in GenICam Browser. So normally there is no need to manually edit the ini-file.
Options stored in GenICam.ini (example for GigE device)
[SYSTEM] Settings which apply to all devices of that kind in the system
NumCameras=1 Number of cameras
CreateAutoIni=0 internally used for the Device Configurator
AutoSwitchEnable=0 If set to 1 the driver loads the first configured device which is available. e.g. if the first device is not available AutoSwitchEnable=0 would cause an Error Loading Image file. If set to 1 it would show the second device with no error.
DeviceUpdateTimeout=-1
AutoConfigExecuted=1 internally used for the Device Configurator
[CHANNNEL_0] Settings which apply only to the first device [DEV0]. Please add additional sections for [DEV1] ... according to your system setup
TL=GevTL.cti Link to used transport layer
Interface=FD::Mac->00:AB:11:22:CD:33 FD:: FilterDriver is used
SD:: SocketDriver is used
Mac->Interface MAC-Address
Device=::‍ID->00:AB:11:22:CD:33::192.168.1.1 Device Identification: ID, IP, MAC or Username
Default is configuration via ID e.g. ::‍ID->00-00-00-00-00-00::10.0.1.1, which is a combination of MAC and IP address.
NumBuffer=3 Number of buffers allocated at vin startup:
Acquiring images and using image processing functions with high CPU workload simultaneously can still lead to lost frames. Use the G2GetGrabStatus CVB-function to show the lost frames. To avoid lost images it is possible to increase the image buffer. In times of high workloads the images will be buffered. CVB takes the oldest image for processing. This principle just works for tasks where the high workload of the CPU is not steady so that CVB is capable of emptying the buffers from time to time. As a rule of thumb use as many buffers as the frames you acquire per second. Then the driver buffers one second.
PacketSize=-1 Size of a data packet. For optimized performance adapt to NIC Jumbo Frame (Jumbo Packet) size.
   -1 = Default (1500 is used as packet size default value).
    0 = Auto
   >1 = Set to value
Can be used to reduce cpu usage.
Attention: The network interface must also be configured to accept jumbo frames. Used switches in the network have to support jumbo frames also.
InterPacketDelay=-1 Sets the delay between data packets. Adapt to NIC optimized Inter Packet delay.
An increase in this delay can reduce the peak bandwidth of a device.
   1 Use Default
   >= 0 Set to specified Value
PixelFormat=5 Pixel format of the CVB Image
   0 = Raw image what ever the device delivers
   1 = Mono 8Bit
   2 = RGB 8Bit
   3 = Mono 16Bit
   4 = RGB 16Bit
   5 = Auto Detect (default) eg converts high bit to 8 bit see chapter Color Formats and Pixeldepth
   option 2: For a bayer color camera the driver would do an 2x2 RGB conversion
RotateImage=0 The image can be logically rotated in multiples of 90°:
   0 = None
   1 = 90deg
   2 = 180deg
   3 = 270deg
AccessMode=4 The mode to open a device:
   2 - Read Only: used when the device is slave in a Multicast setup (not controllable by application)
    3 - Control : used when the device is the Multicast Master (controlled by application)
   4 - Exclusive: peer to peer connection. This is the normal mode.
   5 - Control with Enable Switchover: used when the device is the Multicast Master (controlled by application) and switchover should be enabled
   6 - Control with Switchover Request: used when the application wants to take over the control of the device
      (switchover has to be enabled by another application and switchover key is required for authentication).
AttachChunk=0 Enable or disable chunk data.
WidthOverride=-1 Optional grabber only value if the Transport Layer overrides width from the device. Please use this value thoughtfully!
HeightOverride=-1 Optional grabber only value if the Transport Layer overrides height from the device. Please use this value thoughtfully!
PacketResend=1 Activate or deactivate the packet resend mechanism for the specific device. Since CVB 12.00.000 the packet resend is activated by default.
HeartbeatTimeout=-1 This timeout controls how long the device waits for a signal from the application until it cancels that connection to that application.
   -1 Use Default
   >= 500 Set to specified value
MCMasterMode=0 1 = Device is Multicast Master. If Master mode is choosen, AccessMode must one of the control modes, otherwise the driver will not load correctly.
MCSession=224.64.16.1 The IP Address of the Multicast session.
MCNoJoin=1 Multicast join (0) / no join (1). With join enabled (NoJoin = 0) the control device joins the stream. Set to 0 to get images on all devices.
UseTurboDrive=0 Enable (1) or Disable (0) Turbo Drive (for Dalsa cameras supporting this feature only).
NumConvertThreads=1 Number of threads used to convert / decompress images in parallel (min = 1, max = 16)
SwitchoverKey=0x0 The authentication key (hexadecimal key 16bit unsigned) to take over control in Multicast switchover session.
Persistant Settings in Camera User Set
User Sets
Every GenICam camera supports a functionality to save at least one User Set over the User Set Selector, i.e. a user exclusive camera features configuration. User configurations can be set and also be chosen to be the default configuration loaded when the camera is switched on with setting the Power-Up Configuration Selector.
  • Select a User Set
  • Save configuration into selected User Set
  • Configure the User Set as Power-up Configuration Selector
The factory configuration is not touched at all, such that restoring the initial settings at a later point in time is possible with Device Reset.
Image Settings
Changing the image resolution
How to rotate the image from the camera
Converting images from Color cameras with bayer sensors
White Balance
By default, CVB automatically detects the correct preprocessing for the pixel format / color format the camera delivers (default parameter Auto Detect at Device Options  > CVB Color Format menu or  direct in the GenICam.ini-file). For example if the camera delivers 8 Bit Bayer data, CVB converts the image to a RGB 24 image using an 2x2 RGB conversion. If a 8 Bit Mono image is detected, the raw 8 Bit image is used.
Another example would be for a camera delivering 10 Bit monochrome data which needs to be scaled down to 8 Bit monochrome data. In this case you could set the Pixel Format in the driver to 8 Bit monochrome (also with Device Options > CVB Color Format menu or  direct in the GenICam.ini-file).
Supported source color formats:
  • Mono 8Bit
  • Mono 10Bit
  • Mono 12Bit
  • Mono 16Bit
  • Bayer 8Bit
  • Bayer 10Bit
  • Mono 10Bit Packed (GigE only)
  • Mono 12Bit Packed (GigE only)
  • All Formats as Raw
When the Pixel Format is set to Raw in the driver, all source formats are supported. In this case the image is not converted after acquisition.
Supported conversions:
All Color formats can be converted to RGB 24. All Mono formats can be converted to Mono 8. For hints dealing with high bit images ( > 8 Bit) in CVB please refer to the Common Vision Blox Manual.
If you change a setting in the camera which changes the resolution or pixel size of the image, you need to update the image object by using the IImageRect Interface. Refer this section for more information.
For most of the supported image acquisition devices (cameras or frame grabbers) it is possible to rotate the image fast via an entry in Device Options -> Rotate Image.
Supported values are:
0: Rotate 0 degrees
1: Rotate 90 degrees
2: Rotate 180 degrees
3: Rotate 270 degrees
CVB also offers general functions for rotating images (e.g. RotateImage, CreateMatrixTransformedImage, CreateMatrixTransformedImageEx). Those functions take some time to perform.
Converting images from Color cameras with Bayer sensors
Debayering (conversion into RGB images) can be done with different methods, depending on the camera model and the drivers in use. It is not recommended to convert frames to RGB in cameras before transmission if the frame rate is extremely high. This is because raw Bayer requires only 8/10 Bit versus the 24 Bit necessary for RGB.
  • Debayering by the CVB GenICam driver:
    By default the GenICam VIN converts raw Bayer coded images into 8 Bit RGB images. This is done via a basic 2x2 decoding in order to get the maximum  performance. In this mode the raw Bayer image from camera is not seen by the application. The CVB image seen by the application is a RGB image. This behavior can be changed by selecting a different PixelFormat (which by default is set to Auto) in the the GenICam Browser Device Options -> CVB Color Format (refer above). There the user is free to select a “Raw” output in order get the raw Bayer image. In this case no conversion is applied and the original image from the camera is passed to the application.
  • Debayering via Software:
    If other options are not available or desired, the Debayering operation can also be performed in software after image transmission. This generally allows the greatest degree of flexibility and thus yields the best quality results (e.g. 3x3 debayering). The high performance CVB BayerToRGB tool has been developed to allow easy integration of this task.
  • Debayering in the camera:
    Certain camera models, like the Dalsa Genie series, are capable of doing the Debayering and white balancing within the camera, i.e. on-chip. The images are then transferred as RGB. It is of course still possible to transfer raw Bayer format. In the Property Grid it is possible to see the actual settings of white balancing and in which format the image is transferred. Settings and output image for a RGB image:
Please select the desired Pixel Format via the Property Grid - or your own CVB Application and save the format you choosed via the parameter set User Sets.
User Set Selector User Set1
User Set Default Selector User Set1 ( default configuration )
User Set Save Execute Button
White Balance
Some cameras do not support white balance, other cameras can only use white balance with RGB output with a reduced frame rate. For such cases it is necessary to transfer the Bayer image and execute white balance in extra software programs. CVB provides the white balance functionality in the library with the Image Manager functions CalculateWhiteBalance and ApplyWhiteBalance.
To test these functions the Common Vision Blox Viewer can be used:
  • Open the Common Vision Blox Viewer, load the GenICam Driver and select the context menu "Extras -> White Balance"
  • Click on "Set" to adjust the White Balance. Afterwards you can show the results by checking the "Apply" caption.
  • If the determined scale factors for the different colors should be shown or changed, use the "Edit Scale Factors" caption.
  For cameras supporting white balance based on GenICam BalanceWhiteAuto parameter there are settings via the NodeMap available, such as:
Use cases - Practical configuration examples
This chapter contains descriptions on setting up features like
  • Multiple Cameras
  • Software Trigger
  • External Trigger
  • Exposure Time
  • etc.
Handling Multiple Cameras
Multiple Cameras in GenICam Browser
If you want to open multiple devices, you can click on the device (use Filter Driver in Windows and Socket Driver in Linux), which has a green camera icon and use the button 'Open additional device'. When another device is already open you will be asked, if you want to keep other devices open.
Selecting a camera and parallel access
If you load the GenICam.vin driver into your CVB Tutorial/CVB application (for example CVB Viewer), the driver boots with whatever camera is entered as Device0 in your GenICam ini-file. To access other cameras in your application, you have to change the CamPort/Device selection. CVB Viewer allows live acquisition and display from multiple cameras parallel, for port change refer following picture.
If you plugged off the camera designated as Device0 you might not see any image. If you intend to access the next available camera in this case, set the AutoSwitchEnable to "1" in the GenICam initialization file.
Refer also:
In your application you can use the ICameraSelect2 Interface to select between multiple cameras. The index maps to the order number specified in your GenICam.ini-file.
The GenICam driver uses a driver specific initialization file to set up the communication and data handling parameters for its associated devices. Its default location is %CVBDATA%Drivers. If a different file should be used for GenICam setup, the path entry in the registry must be adjusted.
Exposure Time and Long Time Exposure
Exposure Control Features
The exposure time is not a mandatory GenICam feature. Nodenames for the camera exposure time might also be different between model from different manufacturers. The number of acquirable images of course depends on how long each single frame is going to be exposed. As long as the Acquisition Frame Rate value is on its maximum, the camera will try to acquire as much frames as possible. The upper limit of possible frames is however set by the exposure time. Exposure time can be directly set as a duration in µs. Increasing the exposure time reduces the acquisition frame rate and vice versa!
ExposureMode = Timed / TriggerWith / TriggerControlled
  Timed       : exposure with defined duration (ExposureTime), start with FrameStart or LineStart
  TriggerWith : exposure time defined by frame or line trigger signal width.
    RisingEdge or LevelHigh -> exposure duration equals trigger HIGH,
    FallingEdge or LevelLow  -> exposure duration equals trigger LOW
  TriggerControlled : exposure duration based on one or more trigger signals
ExposureTime   = <value>us
Exposure time in CVB: The CV Gen API itself provides no dedicated function to dynamically set the Exposure Time directly. Please implement Exposure Time settings as described in the Common Vision Box Manual in the chapter Image Manager - GenICam Library.
Setting Long Time Exposure (LTE)
As the values for standard exposure times (in us) are too low for LTE applications, the exposure time can be set with Pulse Width Control. Shutter mode will be invalidated automatically when using Pulse Width Control.
Acquisition and Trigger Control: First, the Exposure Mode has to be be set to "Pulse Width Control", because the values for standard exposure times (in us) are too low for LTE applications. This automatically invalidates the Shutter Mode, i.e. its configuration has no influence on image acquisition anymore.
Digital I/O: To set the correct signal routing, one of the freely programmable signal lines (Line Source) has to be selected, in this case "Pulse Generator 0".
Pulse Generators: To configure the signal itself with the duration of exposure, its Start Point, Length and End Point can be modified according to individual timing requirements. With a Pixel Clock of 60 MHz the exposure time is about 300 ms in example below. The computation of the exposure time can be found in the camera's manual in chapter "Pulse generators". To run Pulse Width Control with Software Trigger the settings are as follows:
Exposure Mode Pulse-width control
Line Selector Pulse Generator 0
Line Source Software Trigger 0
Pulse Generator Selector Pulse Generator 0
Clear Mode for the Pulse High / Low Level | Rising / Falling Edge
Multicast with CVB
For Multicast Switchover and Unconditional Streaming checkout the according topic.
Common Vision Blox supports Multicast.  With Multicast, it is possible to send packets to all devices in the same network. In IPv4, the address range from 224.0.0.0 to 239.255.255.255 is reserved for Multicast. By Joining, the master will also join the Multicast session and be able to receive a stream. If NoJoin is set, the master will not be part of the multicast session and only act as device controller without a stream. The configuration can be done using the GenTL or the CVB GenICam driver. For additional use of  the feature Turbo Drive, which is supported by all Genie Nano cameras, the configuration has to be done with the CVB GenICam driver, because the Turbo Drive feature is implemented in the driver.
Tested Software versions:
Operating system: Ubuntu 20.04 || Windows 10
Common Vision Blox: 13.04.002
‍For Multicast with Socket Driver (SD) please consider the Network Configuration, especially for Multicast with Socket Driver.
1) Configuration using GenTL (SI GEV TL) in GenICam Browser
‍If your goal is to just setup and stream a camera to all network devices, this is the right configuration for you.
Master (Read/Write) configuration:
  • Open GenICam Browser
  • Configure and save your device settings
  • Right-click on the configured device
  • Select Open Mode -> Control
  • Select Master and No Switchover and confirm with Set
  Slave (ReadOnly) configuration:
  • Select Open Mode -> ReadOnly
2) Configuration using CVB GenICam.vin driver
A) Using the  GenICam.ini file
‍If your goal is to setup and stream a camera to all network devices, but the camera should be opened with a tool like the CVB Viewer by loading the GenICam.vin driver or by calling a Cvb::DeviceFactory::Open("path/to/GenICam.vin"), use this configuration.
To configure the GenICam.ini file there are three viable options:
  • configuring the GenICam.ini file in %CVBDATA%\Drivers directory on Windows or in etc/opt/cvb/drivers on Ubuntu with a text editor
  • configuring the GenICam.ini file using the GenICam Browser Configured Devices (same as above, the saved configuration is always automatically written to the GenICam.ini file)
  • configuring the GenICam.ini file using the GenICam Browser Configured Devices but this time using the Configured Device Options by right clicking on the configured device (see below)
Configuration and saving options  top right of the GenICam Browser:
  • Set the AccessMode = 3 (Control)
  • Set MCMasterMode = 1
  • Set the AccessMode = 2 (ReadOnly)
  • Set MCMasterMode = 0
B) Using Discovery properties in code (advanced)
‍If your goal is to set up and stream a camera to all network devices and the camera should be completely managed by code or you wish to use the Switchover feature in an unconditional streaming context (code only), prefer this configuration over 2)A) because 2)A) requires to change the GenICam.ini file, which makes no sense in a code only scenario.
When a programming only solution is desired, above properties can be set to the discovered device. Please note that there might be minor differences depending on the loaded driver (GevSD/GevFD) which can be chosen upon device discovery. To add multicast properties to the device before it is opened, call .SetParameter(...) on the device that should be opened. For a reference of possible parameters and spelling, please refer to the GenICam.ini file entries, which are mirrored in their behavior here. Also configuring like described under 1) or 2)A) is possible and then copying the parameters and values for use with SetParameter().
// Discover all devices with the search criteria defined by the DiscoverFlags
auto devices = Cvb::DeviceFactory::Discover(Cvb::DiscoverFlags::IgnoreVins | Cvb::DiscoverFlags::IgnoreGevSD);
// Set access mode to the device, here we just assume device 0 to be the desired device
devices[0].SetParameter(CVB_LIT("AccessMode"), CVB_LIT("3"));
// Can be kept as 0 (join = no join disabled) to get images on all devices
devices[0].SetParameter(CVB_LIT("MCNoJoin"), CVB_LIT("0"));
// Keep master mode set to true on reconnect after application crash.
// If the master is set to 0, the MC session will be closed.
devices[0].SetParameter(CVB_LIT("MCMasterMode"), CVB_LIT("1"));
// Optionally set a session, this is also the default multicast session.
devices[0].SetParameter(CVB_LIT("MCSession"), CVB_LIT("224.64.16.1"));
Multicast with CVB with Switchover and Unconditional Streaming
For normal Multicast (without Switchover and Unconditional Streaming) checkout the according topic.
When using Multicast, a special feature combination using switchover and unconditional streaming makes it possible to keep the camera running on application crashes and re-set the master with configuration access for the device. This would normally not be possible, as an application crash of the master application would lead to a headless camera which is only controlled by the now unavailable host (if unconditional streaming is available but no switchover) or would stop the camera from streaming (if switchover is available but not unconditional streaming). For availability of both switchover and unconditional streaming, please refer to your specific camera model and device firmware. If the camera supports both feature, the following will describe the setup using CVB:
All configurations can be copied from above setup (take your pick) with following additions:
‍To enable switchover, set Enable Switchover (in 1)) or set Open Mode to Control Enable Switchover in 2)A) or call .SetParameter(CVB_LIT("AccessMode"), CVB_LIT("5")); on the device that should be opened.
By enabling switchover, the device is in access mode "control". If a second application now tries to connect to the device, only the access modes read only and Request Switchover aka. Control Request Switchover, or .SetParameter(CVB_LIT("AccessMode"), CVB_LIT("6")); are sensible access modes. Trying to gain exclusive access on a switchover enabled device is also possible, but all other devices will be locked out from the device connection then.
Additionally, the switchover feature supports a Switchover Key which is a 16 bit value entered as four characters. The key is set when initially opening the device with the switchover enable command and is saved to the device. If a switchover request is received, the Switchover Key set along the switchover request must match the key used on the initial device opening with the switchover enable command. Otherwise no access is granted. The key remains valid until the device is completely closed.
To set the Switchover Key using the device discovery, use: .SetParameter(CVB_LIT("SwitchoverKey"), CVB_LIT("0x0000"));
If no Switchover Key is set, the key will be 0 in all cases, which also works just fine. The idea behind the key is more of an additional barrier to shield against involuntary external access to a GEV connected device.
‍To take control of a  switchover enabled device, set Request Switchover (in 1)) or set Open Mode to Control Request Switchover in 2)A) or call .SetParameter(CVB_LIT("AccessMode"), CVB_LIT("6")); on the device that should be opened.
‍To enable unconditional streaming tick the option in the device node map or set the node map option on the opened device in code.
devices[0].SetParameter(CVB_LIT("AccessMode"), CVB_LIT("5")); // 5 = Control Enable Switchover
// The Key is optional and 0 if not set, feel free to not set the parameter
devices[0].SetParameter(CVB_LIT("SwitchoverKey"), CVB_LIT("0x0"));
Trigger Configuration
There are two ways to trigger the image in the camera. Either hardware (electrical signal to the camera’s trigger input) or software (set a feature in the camera within controlling software to take an image). The GenICam standard part SNFC therefore defines  feature semantics and the behavior for trigger modes.
Acquisition Trigger Modes
  • Free running (TriggerMode=Off):
    Frame rate values supported are sensor specific. Maximum frame rates are dependent on the required exposure.
  • External trigger (TriggerMode=On):
    Exposures are controlled by an trigger signal (external or software).
    The specific input line is selected by the Trigger Source feature.
Trigger Source Types (with TriggerMode=On)
  • TriggerSource=Software
    An exposure trigger is generated via the Ethernet network connection. Please be aware that software triggers are not time accurate due to network latency and sequential command jitter.
  • TriggerSource=Line x
    With the rising or falling edge of the external trigger signal on Line x, a signal is generated on the image acquisition device which starts the readout of sensor data as in self-trigger mode.
    The chronological sequence of the external trigger defines the line rate and thus the exposure time of the sensor.
A platform independent C++ code example for software trigger can be found in the MultiOSConsole Example (Camera.cpp) of the Image Manager:
Windows:        %CVB%Tutorial\Image Manager\VC\VCMultiOSConsole
Linux:        /opt/cvb/tutorial/ImageManager/ComplexMultiOSConsoleExample
Software Trigger Configuration
To activate it, the Trigger Mode must be set to "On" . Trigger Source must be set to "Software" and Exposure Mode to "Timed". For a quick test, the Trigger Software field in the GenICam Property Grid provides an Execute button to send a signal.
To test the configuration within a software solution, the trigger can be either sent via the the GenAPI (refer CVB Manual chapter Image Manager - GenICam Library) or  the ISoftwareTrigger interface (e.g. VB.NET Grabber OCX Example) which is shown in CVB tutorials. Also it can be used with CVB Viewer:
On arrival of a software signal, the image will be captured and processed by the application. Be aware that there exists a standard timout interval.  If the delay between the trigger signals is too large, this will result in Timout Error messages (CVB error #4). Change the timeout value to a higher value in this case.
For details regarding the ISoftwareTrigger Interface please refer to the SDK -> Supported Interfaces chapter.
External Trigger Configuration
Since the trigger is obtained from an external device in this case, Trigger Mode must be set to "On". At the same time the Trigger Source must be changed to "Line x" (refer also pin assignment for standard Hirose in camera manuals) and Line x has to be configured to be an Input.
Example configuration (GenICam SFNC notation) for an external triggered acquisition that will start the capture of each frame on the rising edge of the signal incoming from Line 1:
TriggerSelector = FrameStart;
TriggerMode = On;
TriggerActivation = RisingEdge;
TriggerSource = Line1;
LineSelector   = Line1;
LineMode   = Input;
LineInverter = False;
With these settings the camera is in "active mode" for each incoming trigger in Line 1. Refer device manuals for trigger details.
Example configuration within a camera property grid (parameter notation may differ between  GenICam SFNC and cameras):
To test the chosen configuration with a CVB application, the camera must be set to Grab mode. On arrival of an external signal, the image will be captured and processed by the application. Be aware that there exists a standard timout interval. If the delay between external trigger signals is too large, this will result in Timeout Error messages (CVB error #4). Change the timeout value to a higher value in this case.
Synchronize the cameras to expose at the same time
This can be achieved by connecting the same external trigger signal to one of the digital inputs of each camera or using PTP for GigE.
Master / Slave Configuration
Some cameras can be connected as a Daisy Chain (e.g. Allied Vision FireWire models). The Master camera is triggering the slave camera(s).
  • CameraOut1 is connected to next CameraIn1
  • SyncOut1/StrobeOut1 set to "Exposing"
The configuration of the cameras is done in CVB Property Grid:
Master camera settings:
  • Trigger Mode: ON
  • Exposure Mode: Timed
  • Exposure Output is then active for triggering the slave camera
  • Exposure Time: microseconds
  • Frequence control through Darktime value
Slave camera settings:
  • Trigger Mode: ON
  • ExposureMode: OFF
There  may be a delay between the exposure output of the master camera and starting of the exposure of the slave camera and also a jitter between the trigger signal on the input of the slave camera and starting the exposure. It is recommended to externally trigger both cameras, if the cameras should operate synchronously with higher frame rates to avoid the delay.
GigE Vision
GigE Vision standard
From the user's perspective, the GigE Vision standard consists of three parts:
Device Discovery
As this is a network protocol, devices must be found first. For this, the GigE Vision standard allows users to search for cameras in a sub-network. Cameras, in this case, play a passive part and respond to queries. The response to a query also contains information on the devices discovered, e.g., names and versions.
GVCP (GigE Vision Control Protocol)
The core purpose of the GVCP is the control of cameras on a register basis. An application reads out and writes individual data blocks. Every data block (register) represents one or several features such as the exposure time for the sensor.
GVSP (GigE Vision Streaming Protocol)
GVSP provides a protocol for streaming non-compressed and - since version 2.0 - also compressed data streams.
GigE Vision performance
The performance level of a GigE Vision system depends strongly on the hardware and software components and their configuration. The maximum data rate from 125 MByte/s is just a theoretical number as within this 125 MByte also data are send which are not directly related to the image. A realistic, stable payload value for image calculation is  100MByte/s.
Below and in the next chapters  performance considerations and settings are described.
System Requirements
  • GigE Vision-compliant camera hardware,
  • Ethernet Cable with minimum Cat 5e standard required. Cat 6 is preferred for long distances. Unshielded cables must not being used in general.
    (CAT6 cables can be used for frequencies up to 250 MHz, whereas CAT6a cables can be used up to 500 MHz, fulfilling the bandwidth requirements of 10-Gigabit-Ethernet.)
  • Network Interface Card (NIC) supporting 1000Mb/s and Jumbo Packets. It has to be configured with optimal Performance Settings.
  • If a switch is used the switch has to support 1000Mb/s and Jumbo Packets (Frames) too. Refer Switch Selection.
Driver Implementation
Due to the fact that the GigE Vision standard is a mere protocol description, generic driver implementations are possible. The simplest and most portable solution is to use the operating system IP network stack. This is often referred to as socket driver because all large operating systems provide the socket interface for network access (e.g. Windows Sockets or POSIX Sockets). However, normally this solution offers the poorest performance. Improvements are available by adopting the so-called high performance or filter drivers. Typical of both driver types is that they bypass the generic operating system network stack to provide better performance by specialised implementation. The driver runs in the operating system kernel and can therefore work on network data with the highest priority. Image data compilation already occurs in the driver and the image as a whole is transferred to the application. Because the network stack is bypassed, less CPU capacity is bound up and data security improves (fewer lost packages) due to the higher CPU priority. Even if the implementation of both driver types is different (driver directly for one network chip or generically for all network cards in the Windows filter stack), both offer the same improved performance for the protocol structure of GigE Vision.
Network Topologies
Single camera on a dedicated NIC
The most simple setup is a single camera on a dedicated NIC (no other network traffic) with a point to point network connection. In order to retrieve their IP address, GEV cameras are configured to use DHCP by default and the same applies when configuring a NIC under Microsoft Windows. If there is no DHCP server (which is likely on a point to point connection) the camera and the NIC will, after a while, fall back to a mode called LLA. In this mode both ends (camera and host) will pick a random IP address. If you want to eliminate the time delay until they fall back to LLA you have to assign static IP addresses. In this type of scenario the bandwidth and data latency is optimal. Depending on which components are used and your system specification you can expect to get over 100MB/sec.
Single camera on a corporate Network
With a camera connected to a corporate network the scenario is only slightly different since a corporate network will usually have a DHCP server and both the camera and the PC will get their IP address from it. On the other hand, you cannot be sure that there won’t be other cameras on the network. In large set-ups there is a good chance that the system will address the wrong device. The bandwidth usage on such a system might be critical since it will affect the corporate network.
Multiple cameras on a single NIC
In this setup the IP address assignment is similar to the previous sections. The main concern in this case is the bandwidth. If in such a system the peak bandwidth is above one Gbit you have to make sure that either the switches can buffer enough data to sustain that peak or you have to limit the bandwidth of the cameras by setting the InterPacket delay of the cameras. The InterPacket delay is a mandatory bootstrap register of a GEV device. It can be set using the CV GenApiGrid Control (NodeMap) and then saving this to the profile of the camera to restore the setting on the next boot up. For some cameras this is controlled over the StreamBytesPerSecond parameter.
Multiple cameras on multiple NICs
With multiple network interfaces you get better performance than with a single NIC but the IP-address assignment is a little bit more complicated. You have to make sure that each NIC is running on a separate subnet. If you have two NIC's running on the same subnet under windows, one cannot predict which NIC will be used to send the packet. If the packet is sent via the “wrong” NIC which is not connected to the correct camera, this camera will never see the packet and a connection will not be established.
The overall performance of a GigE Vision system setup depends on the network hardware components (network interface card, switch, camera, cable) as well as their appropriate configuration, which is described in the following chapters. Additionally to this there are some camera dependent GigE network features, which are described here.
TCP/IP Settings
Set the Camera IP address
Jumbo Packets
Firewall and VPN Settings
InterPacket Delay
Turbo Drive
Precision Time Protocol
Link Aggregation
siFilter Driver
TCP/IP Settings
To establish a connection to any GigE Vision device, both the Network Interface Card NIC and the GigE Vision device must have a valid IP in the same subnet range. Addresses can be assigned both dynamically and statically.
  • GigE Vision devices try to inquire an address over DHCP by default.
    Given that there is a DHCP server for the network, the device obtains a valid IP by itself.
Windows: Linux:
  • If there is no DHCP server present, the LLA (link local address) method is used for this auto-IP configuration.
    The NIC automatically assigns an IP address in the 169.254.x.x subnet range. It is crucial that DHCP is enabled even when LLA is the preferred configuration mode. Only one NIC on the PC should use LLA, otherwise it can lead to IP conflicts.
Windows: Linux:
  • Usage of static IP addresses is recommended because of dynamically assigned addresses are essentially random, i.e. a specific order of more than one camera on a single network interface cannot be guaranteed after a restart. In a life system setup where every camera has its specific role, such behavior is generally unwanted, therefore use static addressing when the camera system works as desired. Refer next section.
GigE Vision must be identified by an unique IP address. Addresses can be assigned both dynamically and statically. Per default, GigE cameras try to establish a connection to the host machine based on dynamic addresses. When plugged in, the camera first sends out a number of DHCP requests. If no answer is received within a fixed period of time (usually 60 s), the systems tries to auto configure the network via the LLA (Link Local Address) addressing scheme. LLA only works when both links are configured to be set dynamically (DHCP).
After starting GenICam Browser for the first time, the available transport layers (TL), available interfaces and devices are listed in a tree view under Available Devices. To search for available devices and to refresh the Available Devices tree use the Discover button. All available devices show up as green cameras. GigE devices are displayed under SI GEV TL:
Static IP addressing is available in two different forms:
  • arbitrary addresses can be either assigned in a persistent fashion (Static IP) or
  • only until the next power cycle of the camera device (Force IP).
In both cases, the address must be set within the NIC and with an application interfacing the camera.
1) Settings on the Network Interface Card
Windows: Network and Internet, Network Connections Linux: Network connections
2) Settings for the camera
The camera may have another IP address configured or set as default. In the below example on the GenICam Browser the camera is found in another subnet (yellow icon). The camera IP address info can be read by left clicking the camera symbol or right mouse click -> Info. Access status here is NoAccess (Invalid IP).
Setting the IP address matching the NIC configuration is to be done over the configuration in Available Devices  menu:
Force IP (fix over this power cycle):
After each temporary IP setting it will be asked for storing it as static IP to keep the setting over restarts. Select 'No' in in case of temporary IP, valid for this power cycle. With 'Yes' the IP address is set as static.
Static IP (always fix):
With both settings the camera icon has to be green with Access status: ReadWrite.
There are mandatory
which influence the performance of the system and the stability of the data transfer over the network card. This section will describe which settings should be optimized for maximum performance and minimal CPU usage. But it shows also which features can have massive impact in the stability of the data transfer. Wrong settings can result in a huge amount of lost packets that even whole images are discarded.
The variance of NIC performance settings depends on the used operating system and is described in detail in the following sections.
Receive Buffers
Sets the number of buffers used by the driver when copying data to the protocol memory. Increasing this value can enhance the receive performance, but also consumes system memory. Receive Descriptors are data segments that enable the adapter to allocate received packets to memory. Each received packet requires one Receive Descriptor, and each descriptor uses 2KB of memory.
Flow Control
Interrupt Moderation Rate
Sets the Interrupt Throttle Rate (ITR), the rate at which the controller moderates interrupts. The default setting is optimized for common configurations. Changing this setting can improve network performance on certain network and system configurations. When an event occurs, the adapter generates an interrupt which allows the driver to handle the packet. At greater link speeds, more interrupts are created, and CPU rates also increase. This results in poor system performance. When you use a higher ITR setting, the interrupt rate is lower, and the result is better system performance. NOTE: A higher ITR rate also means the driver has more latency in handling packets. If the adapter is handling many small packets, lower the ITR so the driver is more responsive to incoming and outgoing packets.
Jumbo Frames / Jumbo Packets
Enables or disables Jumbo Frame capability. If large packets make up the majority of traffic and more latency can be tolerated, Jumbo Frames can reduce CPU utilization and improve wire efficiency. Jumbo frames have a strong impact on the performance of the GigE Vision system. Jumbo frames are packages with more than the Ethernet MTU (Maximum Transmission Unit) of 1500 bytes. Less header data is transmitted, which allows more capacity to be available for user data.
Usage Considerations
Enable Jumbo Frames only if devices across the network support them and are configured to use the same frame size. When setting up Jumbo Frames all involved network devices, be aware that different network devices calculate Jumbo Frame sizes differently. Some devices include the header information in the frame size while others do not. Intel adapters do not include header information in the frame size. Jumbo Frames only support TCP/IP. Using Jumbo frames at 10 or 100 Mb/s can result in poor performance or loss of link.
When configuring Jumbo Frames on a switch, set the frame size 4 bytes higher for CRC, plus four bytes if using VLANs or QoS packet tagging.
Jumbo Frames can cause lost packets or frames when activated in the network card and the camera. But this is normally a side effect caused by the other settings mentioned before, which is only visible with Jumbo Frames. This means that, if you have trouble when using Jumbo Frames, try to find the cause in the previously mentioned settings instead of deactivating the Jumbo Frames.
Interrupt Throtteling (10 GigE only)
This parameter should be changed only if you observe performance problems with 10 GigE devices. Windows throttling mechanism Because multimedia programs require more resources, the Windows networking stack implements a throttling mechanism to restrict the processing of non-multimedia network traffic to 10 packets per millisecond.
Performance Settings under Windows
To optimize the network card under Windows open the Network Properties Dialog (Start->Control Panel->Network Connections), right click on the network connection used. Select "Properties” from the context menu to get the Windows network configuration dialog. Depending on the network card driver, some of the settings described below may occur under a separate dialog page.
Receive Buffers
This parameter has to be set to the maximum available value. If it is too low you can loose huge amount of packets while streaming images
If your network card does not have this option you have to update your network card driver.
If it is not available with the newest driver use another network card.
Flow Control
This parameter has to be disabled. This feature regulates the network traffic which is something we do not want while streaming images.
For this feature there are no general rules available which setting has to be used. It depends on the network card and the internal bandwidth of the system. If you want to have the lowest CPU load then you have to use the maximum value (Extreme). But with some systems we saw problems with this setting. Then you can loose packets or even whole frames. On some systems also low values can cause these problems. If you have problems with lost packets or lost frames, change this setting to Off. This is the most secure setting - but also the setting with the highest CPU load.
Jumbo Frames are necessary when the maximum network bandwidth is needed. E.g. when using a fast camera or a high resolution camera. Because of this the recommendation is to always use Jumbo Frames when possible.
NOTE: When activated in the network card this does not mean that Jumbo Frames are used. This only means that the network card can handle Jumbo Frames.
To really use Jumbo Frames this has to be activated in the camera by setting the packet size to the appropriate value. The appropriate value depends on the maximum available packet size in the camera and the maximum setting in the network card. As recommendation use 8192 as PacketSize if supported by camera and network card, it was used very often without problems. Normally, if Jumbo Frames are disabled, this does not cause problems with lost packets or lost frames. But as the camera is not able to send the images as fast as they are acquired from the sensor you can have a visible delay in the live image. On the other hand Jumbo Frames can cause lost packets or frames when activated in the network card and the camera. But this is normally a side effect caused by the other settings mentioned before, which is only visible with Jumbo Frames. This means that if you have trouble when using Jumbo Frames try to find the cause in the previously mentioned settings instead of deactivating the Jumbo Frames.
The throttling will come into effect only when you are running multimedia programs that are time sensitive. However, this throttling mechanism can potentially cause a decrease in network performance during the active multimedia playback period. This decrease in performance is likely to occur only on high speed networks that are saturated to maximum capacity. By default, the value for the NetworkThrottlingIndex registry entry is set to 10.
Refer Registry entry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile\
Value type: DWORD
Value data: From integer 1 through integer 70 (Decimal) (Decimal)
When the NetworkThrottlingIndex registry entry does not exist, the behavior resembles the default behavior. Network throttling can be completely turned off by setting the value to FFFFFFFF (hexadecimal). You must restart the computer after you make a change to the value of the NetworkThrottlingIndex registry entry.
Performance Settings under Linux
To optimize the network card under Linux open the Network Connections Dialog or with direct terminal commands. Using the dialog window the "Wired connection x” from the list has to be selected and the "Edit" button to has be used.
Receive Buffers
This parameter has to be set to the maximum available value. If it is too low you can loose huge amount of packets while streaming images. To change the Receive Descriptors on Linux you need to download ethtool from the installed packet manager.
Get Descriptor Information from eth2: > sudo ethtool -g eth2
Set Receive Descriptors of eth2 to 2048: > sudo ethtool -G eth2 rx 2048
for eth2 set: > sudo ifconfig eth2 mtu 8192 up or with the dialog:
NOTE: When activated in the network card this does not mean that Jumbo Frames are used. This only means that the network card can handle Jumbo Frames. To really use Jumbo Frames this has to be activated in the camera by setting the packet size to the appropriate value. The appropriate value depends on the maximum available packet size in the camera and the maximum setting in the network card. As recommendation use 8192 as PacketSize if supported by camera and network card, it was used very often without problems. Normally, if Jumbo Frames are disabled, this does not cause problems with lost packets or lost frames. But as the camera is not able to send the images as fast as they are acquired from the sensor, you can have a visible delay in the live image.
Configuring Jumbo Frames/Packets
This section provides a step-by-step instruction to configure a PC and a GigE Vision camera to use jumbo packets. CVB and the Genicam vin-driver needs to be installed and a camera has to be attached and accessible (reachable IP addresses, etc).
1) Set up the NIC to process Jumbo Packets first
a) Set up a NIC to allow Jumbo Packets under Windows
b) Set up a NIC to allow Jumbo Packets under Linux
2) Configuring CVB Genicam Driver and Camera to use Jumbo Packets
In the GenICam Browser select the device to be configured and click the Device Options button:
PacketSize parameter can then be changed to the optimum value. Which value should be used depends on the used hardware. A network card has a maximum PacketSize. But also a switch and the camera can have a maximum supported PacketSize. So this parameter must not exceed the maximum PacketSize from one of the used hardware devices. As recommendation use 8192 as Jumbo Frames packet size if supported by camera and network card. Some cameras/network cards/switches only support a maximum PacketSize < 8192. In this case try to harmonize the packet size over all involved components in the setup  (camera, switch, network card, driver)  to the same value.
Now you can set the size of the packets with the Packet Size parameter Device options dialog which writes the value into the GenICam.ini File.
For cameras providing a PacketSize range within specific limits the possible PacketSize values can be determined using the NodeMap (PropertyGrid) in GenICam Browser. To check if a value for PacketSize will be accepted you can always retrieve the info with selecting the PacketSize feature and read the GenICam Node GevSCPSPacketSize info (range between 512 and 9216 in the example below).
3) When used - enable Jumbo Packets in the switch
Jumbo Frames have to be also enabled when using a switch. When configuring Jumbo Frames on a switch, set the frame size - if requested - 4 bytes higher for CRC, plus four bytes if using VLANs or QoS packet tagging.
Example:
Firewalls can block GigE Vision packets and slow down the system performance. Therefore it is important to disable all firewalls within the camera connection setup when there are connection problems.
The following steps are necessary to switch off the Windows software firewall. For Linux there is no configuration necessary. If you have a hardware firewall (which is available on some NICs) disable those firewalls also.
Also any VPN software running on the system may contain a "Stateful Firewall" which is active even if no tunnel is established. This firewall will block traffic from the camera. In order to work with GEV devices and depending on the VPN software you use, you have to disable your VPN software.
Windows only:
1) Open the Firewall Customize Settings dialog (Start -> Control Panel -> Systems and Security -> Windows Firewall -> Turn Windows Firewall on or off):
2) Select the "Turn Off Windows Firewall" option to disable the firewall for the type of network which is used for the camera connection.
3) Close all dialogs with the "OK" button to apply the changes.
Using Inter Packet Delay with GigE Cameras
Consider the settings from GigE Vision -> Network Configuration chapter first.
Inter Packet Delay is a parameter to control the data rate from cameras. It is important in multi-camera scenarios.
With Inter Packet Delay cameras can be slowed down while acquisition by adding delays between the sent packets. Other devices are able to send data then too. Inter Packet Delay together with Frame Rate settings and Exposure Time is important as soon as you connect multiple cameras to one network port exceeding together the maximum data rate. Gigabit Ethernet provides 1 Gb/s (Gigabit per second) Bandwith  ~ 100 MB/s (Megabytes per second) assuming an optimal network hardware and configuration. In such a system you may have to limit the bandwidth of the cameras by setting the frame rate and the Inter Packet Delay.
Tune and Test the Inter Packet Delay
  • Calculate the max. Frame Rate for each camera considering the needed bandwidth:
    Bandwidth = Resolution x Bytes per pixel x FrameRate x Number of cameras
    which is for the example below using 3 cameras:  100 MB/s = (1936x1216) x 1 x Frame Rate x 3 => max. Frame Rate for each camera ~ 14 fps
  • Now with increasing the Inter Packet Delay you can add a delay time between packets/frames send by the cameras and so increase the Frame Rate values to an optimum (e.g.16 fps)
If the optimum between Inter Packet Delay and Acquisition Frame Rate is determined, the setting has to be saved in the device options.
Save Inter Packet Delay
Use the Device Options (Driver Options for the selected device) dialog window in GenICam Browser :
Inter Packet Delay based on GevSCPD with different camera models
Adding a packet delay between packets during transmission is always based on GenICam Transport Layer Control feature GevSCPD but the representation in camera NodeMaps may differ.
In the following there are some examples how to find the feature.
AV GigE example:
They have a feature called "BandwidthControlMode" which is set to "StreamBytesPerSecond" by default. With "StreamBytesPerSecond"  the bandwidth which is used by a camera can be changed directly in bytes per second. (e.g. 2 cameras -> StreamBytesPerSecond / 2)
DALSA GigE example:
JAI GigE example:
Turbo Drive
Currently, only Teledyne Dalsa cameras support this non-standard feature. To make sure your camera supports TurboDrive and to find out the correct TurboDrive version, which can be set later on, please refer to the manual of the firmware currently installed on your Teledyne Dalsa camera.
Specific Teledyne DALSA GigE Vision cameras (e.g. Genie Nano, Linea) supporting a Turbo Transfer mode > TurboDrive feature. This feature allows an increase of the frame rate while loss-less data compression and transmission via Gigabit Ethernet extend the capability of the data throughput (typically 100 MBytes/s) achievable with GigE Vision systems.
Common Vision Blox can handle this Turbo Transfer mode and therefore improve the transfer rates until double the standard throughput (depending on image settings). To set the feature and test it please follow the 2 steps:
1) The feature has to be enabled and saved (for devices supporting TurboDrive) in the GenICam.vin driver:
a) in GenICam Browser Configured Devices -> Device Options dialog window.
b)   Set the Turbo Drive Feature in CVB Viewer within the GenICam.ini file:
2) Turbo Drive can be tested and used in tools and tutorials accessing *.vin driver only, not with GenICam Browser, which uses the Transport Layer.
Therefore use a tutorial from %CVB%Tutorial directory and load the GenICam.vin driver or use the CVB Viewer.
Acquisition Frame Rate (Std::AcquisitionFrameRate)- specifies the camera internal frame rate, in Hz.
Maximum Sustained Frame Rate(Cust::maxSustainedFrameRate) - maximum sustained frame rate that can be achieved by the camera in the current configuration (Resolution, Pixel Format and the camera's internal bandwidth limitations). When TurboDrive is enabled, this value also takes the feature transferAverageBlockSize into account.
Example with Genie Nano M1940, running with Turbo Drive and 64,40 fps:
Data Rate = Resolution * Frame Rate * Bit depth = (1290*1080) * 64,4 fps * 8 Bit = 134 MByte transfered over GigE with Turbo Drive.
Precision Time Protocol PTP
Precision time protocol for synchronising several cameras in an Ethernet network
The Precision Time Protocol (PTP) IEEE 1588 enables the exact cycle synchronisation of several devices in an Ethernet system. When the clocks of the devices such as cameras, PCs and sensors, are synchronised, future software image triggers can be synchronised within 2 μs. The GigE Vision 2.0 standard has incorporated PTP IEEE 1588 and warrants maximum compatibility between machine vision hardware and software suppliers in future.
Synchronisation of several cameras cameras supporting PTP are put in a special PTP mode which manages and defines the synchronisation of the camera clocks. The device clock of the master is output with the timestamp of the camera and synchronises several cameras. When the PTP mode is set to 'master', 'slave' or 'auto', the camera synchronisation starts in the network, provided one device is configured as master.
The process starts with the "master" camera which sends a "sync" message via multicast messaging. The "slave" camera calculates the time difference between its internal cycle and that of the master camera. In addition, Delay Request Message (by the slave) and Delay Response Message (by the master) are sent to synchronise the slave clock with the master cycle. When the time difference of the clock is ≤2 μs, the cameras are in synchronous mode. In addition to the exchange of synchronisation messages, the clocks are constantly readjusted by filters and statistical methods in order to eliminate deviations due to the physical layers, the network, repeater or switch.
Configure Cameras supporting PTP
Settings in Property Grid (consider camera specific parameter name variance):
  • General settings
      Acquisition -> Trigger ->
        TriggerMode = On
        TriggerSource = FixedRate
      Acquisition -> AcquisitionFrameRateAbs = 1 for testing with 1 fps
      Acquisition -> AcquisitionMode = Continuous
      EventControl ->
        EventSelector = PtpSyncLocked
        EventNotification = On
  • Master
    GigE -> PTP -> GevPtpMode = Master
  • Slave
    GigE -> PTP -> GevPtpMode = Slave
Wait until GigE -> PTP -> PtpStatus has changed from Syncing to Slave. Start acquisition on both cameras.
Set on both cameras the GigE -> PTP -> PtpAcquisitionGateTime to a higher value than GigE -> Timestamp -> GevTimestampValue (get the current GevTimestampValue with GigE -> Timestamp -> GevTimestampControlLatch).
Ensure, that PtpAcquisitionGateTime is still in future after setting on both cameras.
Acquisition stops on both cameras, when PtpAcquisitionGateTime is reached, the cameras run synchronous.
Example: PTP parameter in Nodemap of Dalsa camera
Example: PTP parameter in Nodemap of AV camera
Link Aggregation LAG
GigE Cameras supporting LAG (Link Aggregate Group)
Cameras supporting LAG (Link Aggregate Group or NIC Teaming) offer 2 GigE ports for image acquisition, so the available bandwith is duplicated to 230 MB/s with optimized network hardware. These ports have to be combined as a Link Aggregate Group. To use the LAG (for example AVT GX-series cameras) the settings of the NIC and the camera have to be adjusted.
NIC (Network Adapter Settings):
Windows:
  •    Right click Network Connections -> Properties -> Configure ...
  •    Select Teaming tab -> enable "Team this adapter with other adapters"
  •    New Team... -> specify a name
  •    Select the two Ethernet ports to which the camera will be connected. These ports will form the LAG or TEAM
  •    Choose Static Link Aggregation
The LAG group will now be configured. Once completed the properties of the TEAM (LAG) that has just been created will appear. A new Network Connections Icon corresponding to the LAG group is created.   After the NIC is prepared for LAG and the camera is connected with both Ethernet cables CVB can be used for the camera set up like it is recommended in the following:
STEP 1
Please perform all CVB GigE Performance settings as recommended for all GigE devices.
STEP 2
  • Open the GenICam Browser
  • Now the GeniCam Property grid (Nodemap) should be visible
  • Please set Menu Options-Max Visibility to Guru
  • In the NodeMap GigE set up the parameter GevSCPSPacketSize to 9014
  • Save this settings in a UserSet e.g. UserSet1
STEP 3
  • Select your camera and click on "Open Device"
  • Open the Nodemap DataStream Port via tab "DataStream Port" and set the following parameters:
  • Enable Packet Resend: True
  • Num OOO Packets before Resend: 100 - 200
Please take in mind that this two parameters cant be saved in the camera user settings. The settings are done interactively for testing as here described. If you have your own application please check and set the parameters via the Nodemap functionality of the CVB Image Manager. Please have a look at the CVB Manual and the sample code for retrieving Nodemap information from the DataStream Port.
STEP 4 (optional)
For performance and reliability tests please use the Common Vision Blox Viewer. Open the Nodemap DataStream Port and the Device Nodemap via the Genicam menu and configure as described above in STEP 3. Additional please open the Acquisition Statistics via the Extras menu and get information about lost or pending images.
This documentation is for Windows only!
To use Multicast with Socket Driver on Windows (especially on the client side) some settings might be necessary. Generally it is strongly recommended to disable the firewall. Please follow the instructions on Firewall and VPN Settings.
If you still encounter issues, please check following settings:
1) Allow Inbound Connections in Public Profile of Windows Firewall
Go to Start -> Control Panel -> Systems and Security -> Windows Firewall, then continue with following steps:
2) Allow an App through Windows Firewall
‍Make sure that the application appears only once in this list.
3) Turn off Internet Protocol IPv6
On the used Ethernet connection open its properties and disable IPv6.
4) Deactivate Virtual Boxes
Sometimes Virtual Boxes can have affects on getting images, so the according network connections should be disabled.
siNetFilter Driver Installation
Windows only
The siNetFilter Driver for GigE Vision technology is used to bypass the standard network stack (used by the operating system) for all data stream packets. It filters GigE Vision related data packets and transfers them directly to an application-provided data buffer. This greatly reduces the CPU load of the system. All non GigE Vision data stream related packets are unaffected.
Basically all CVB installations contain the siNetFilter Driver for GigE Vision. (refer %CVB%Hardware/StemmerImaging/siNetFilter)
Under certain circumstances it could be necessary to uninstall / reinstall / update / disable or enable the GigE Vision Filter Driver.   Consider always the maximum number of Filter Drivers configured on your system when installing filter driver  (except Windows 10):
(each NIC counts as one siNetFilter Driver, other Filter Driver maybe installed without recognition, e.g. through VBox, VPN, etc. - so maximum has to be increased)
Reinstall siNetFilter GigE Vision Filter Driver
If you have uninstalled the siNetFilter Driver you can reinstall it.
1) Open your Network Properties Dialog (Start -> Control Panel -> Network Connections) right click on the network connection used.
Select "Properties" from the context menu to get the network configuration dialog.
2) Click the "Install" button to open the following dialog.
3) Select "Service" and click the "Add" button.
4) Select the siNetFilter Driver and click the “OK” button.
5) The setup will now try to install the siNetFilter Driver.
Press the "Proceed with Installation" button to install the driver for all NICs.
It may appear several times depending on the number of NICs in your system.
6) Close all dialogs with the "OK" button to apply the changes.
Update siNetFilter GigE Vision Filter Driver
To update the siNetFilter Driver these steps are necessary.
1) Open you Network Properties Dialog (Start -> Control Panel -> Network Connections) right click on the network connection used.
Select "Properties" from the context menu to get the Windows network configuration dialog.
3) Select "Service" and click on the "Add" button.
4) Click the "Have Disk" button.
5) Click the "Search…" button and the "Browse..." button in the next window.
6) Select the destination directory which contains the siNetFilter Driver and select the *.inf file.
Click the "Open" button to proceed.
7) Click the "OK" button to proceed.
8) Press the "OK" button in the next dialog.
9) The setup will now try to install the siNetFilter Driver. Press the "Proceed with Installation" button to install the driver for all NICs. It may appear several times depending on the number of NICs in your system.
10) Close all dialogs with the "OK" button to apply the changes.
Disable siNetFilter GigE Vision Filter Driver
Following steps are necessary to disable the driver for a specific NIC. You must repeat these steps for each NIC for which the GigE Vision siNetFilter Drivers need to be disabled. Disabling the Filter Driver does not count down the maximum number of Filter Drivers configured on your system.
2) Uncheck the check box for the siNetFilter Driver.
Enable siNetFilter GigE Vision Filter Driver
When you disabled the siNetFilter Driver for a specific NIC you can enable it again.
1) Open you Network Properties Dialog (Start -> Control Panel -> Network Connections) right click on the network connection used. Select "Properties" from the context menu to get the network configuration dialog.
2) Check the check box for the siNetFilter Driver.
Uninstall siNetFilter GigE Vision Filter Driver
To uninstall the siNetFilter Driver on all NICs follow these steps.
2) Select (not uncheck!) the siNetFilter Driver.
3) Press the Uninstall button and follow the instructions (it might be necessary to reboot the system afterwards).
4) Close all dialogs with the "OK" button to apply the changes.
USB3 Vision
USB3 Vision standard
USB3 Vision is a mere protocol or "on the wire" standard, based on USB3.0 standard using USB 3.0 ports. This means that only the data package layout and a bootstrap register map is defined. It ensures that a USB3 Vision device needs a certain "basic intelligence" without having to reload firmware. No manufacturer specific drivers will need to be installed on the host, provided that USB3 Vision compliant software is installed. USB3 Vision uses the GenICam GenApi device description for camera control.   USB3 Vision defines a transport layer for:
  •    Device detection
  •    Register access
  •    Streaming data
  •    Event handling
Furthermore USB3 Vision provides an interface to GenICam.
USB3 Vision performance
USB 3.0 operates at a bandwidth of 5 Gbit/s enabling net data rates of substantially more than 350 MBytes/s.
System Requirements
  • USB external or on-board Host controller card with USB 3.0 ports (usually marked  blue )
  • USB 3.0 cable (maximum length 5m, we highly recommend the use of machine vision validated USB cables, rather than the cheaper consumer cables)
  • On Windows 8 and newer USB3 host controllers run using a Microsoft driver.
    No vendor driver should be required.
  • On Windows 7 USB3 host controllers require vendor specific drivers and/or firmware updates to work properly.
    At the moment we can only recommend two chip-set vendors:
    • Intel: Intel is only available on board. The required drivers are usually bundled with the main board software.
    • Renesas: Renesas also provides extension cards for USB3. The following drivers are required (unfortunately exact chipset is printed on the chip in super tiny letters)
      • Renesas Bus Driver for D720200 and D70200A controllers 2.1.39
      • Renesas Bus Driver for D720201 and D720202 controllers 3.0.23
    Chipset  vendor and product ID of the host controller can be read from windows device manager.
    • First find your USB3 (xhci) Host Controller and open the properties and details.
    • Vendor IDs (e.g.VEN_8086 for Intel) and Hardware IDs will give hints for the chipset.
Configuration
  • USB3 Vision cameras easily can be connected to the PC using USB 3.0 cable and are shown as available devices in GenICam Browser.
  • USB 3.0 comes with new connectors, therefore care needs to be taken when integrating legacy devices and USB 3.0 devices. It should be noted that USB 3.0 is no longer compatible with the "old" USB 1.1 controllers.
  • Driver Details: From version 12.0 versions onward CVB will provide a U3V class driver. This driver is currently a generic USB user space driver named LibUsbK (on Windows) or the generic USB kernel driver (on Linux). Both are available form source and not intellectual property of STEMMER IMAGING.
    The driver is installed automatically. To uninstall other drivers use the Windows Device Manager. The USB driver does not support the functionality Auto Switch which can be set in the Driver Specific Configuration Files. If Auto Switch is enabled the driver loads the first configured device which is available. But only for GigE cameras and not for U3V cameras it is possible to verify their availability. Therefore, when U3V cameras are configured the camera port must be manually switched in order to load the next available device.
  • Hardware Compatibility: Some useful hardware performance information can be checked using lsual command line tool. Under Windows “lsual.exe”  is available in the folder %CVB%Hardware\StemmerImaging\Utilities. Call this in a console window (cmd.exe).
A typical output of lsual when a JAI USB GO is connected:
Most interesting parameter is the Speed Support: Super has to be supported.
Other Transport Layer
  • CoaXPress
  • Cameralink
  • CameraLink HS
  • FireWire on Allied Vision FireWire cameras
Transport Layer are installed within the manufacturers software (SDK) setup for the frame grabbers and cameras. CVB driver packages for supported frame grabbers and cameras of different manufacturers are provided on the CVB download pages.
CVB user forum
After installation drivers can be found under %CVB%Drivers. A CVB Camera Suite or Image Manager License releases the usage of those Transport Layer within Common Vision Blox.
Find Transport Layer
Available Transport Layer are displayed in GenICam Browser:
CVB GenICam Transport Layer (*.cti files)  can be found for example under: %CVB%GenICam\bin\win64_x64\TLIs   (Windows 64 Bit) or /opt/cvb/drivers/genicam (Linux)
Environment variable for GenICam TLs to find all *.cti files:
GENICAM_GENTL64_PATH
Windows (check with cmd shell command "set"):
Example CVB: C:\Program Files\STEMMER IMAGING\Common Vision Blox\GenICam\bin\win64_x64\TLIs
or %CVB%GenICam\bin\win64_x64\TLIs
Example other supplier, e.g. Allied Vision with Vimba or Active Silicon:
similar for 32 Bit system
Linux (check with cmd shell command "env"): GENICAM_GENTL64_PATH=/opt/cvb/drivers/genicam
Some functions (e.g.IP assignment) are available with CVB GenICam TLs only.
Hide Transport Layer
in GenICam Browser:
Use Frame Grabber Transport Layer
Registry-Entries: Registry entries affecting the use of Common Vision Blox drivers are located within the following key of the Windows registry.
in HKEY_LOCAL_MACHINE\Software\Common Vision Blox\Image Manager\...
Remove Transport Layer
CVB application problems caused by a foreign Transport Layer can be solved by renaming this from *.cti to any other name (e.g. *.cti.off).
SDK
This chapter provides information about supported programming interfaces and hints for the use of the CVB vin-driver with your image acquisition device. In general the programming hints refer to related detailed chapters in the section Image Manager.
Please be aware that examples mentioned here are related to the newest CVB version, downloadable in the CVB user forum.
CVB provides a set of interfaces for all main features of an image acquisition device such as grab, software trigger, ringbuffer and much more grouped by functionality:
  • Driver (dll and Grabber/Linescan/DigIO/RingBuffer ActiveX Control):
    This library contains functions to control all image acquisition device drivers. Find functionality with: BoardSelect and CameraSelect, DeviceControl, NodeMapHandle, Grab, Snap, Trigger, Image, Buffer, etc.
  • Gen API (CVGenApi.dll and GenICam ActiveX Control):
    The GenAPI is part of the GenICam™ standard whereas the transport layer is typically provided by the camera or software vendor. The XML files are provided by the relevant vendor. At runtime, it may be necessary to modify individual camera features or present these to the end user. This can be achieved, on the one hand, using the CV Gen Api functions for accessing the CVB GenICam interface and, on the other, the Common Vision Gen Api Grid Control. Find functionality with: NodeMap, NM, Node, N, Load, Save, Get, Set, Info, etc.
  • Image (dll and ActiveX Grid Control):
    This core library contains functions to generate, manage and manipulate image objects. Find functionality with: Area, Matrix, Map, Rect, Coordinate, Dongle, License, Tool, Draw, Fill, Flood, Image, Create, Copy, Set, Write, Error, Object, etc.
  • Display (ActiveX Control):
    This core library contains functions to control every aspect of displaying images Find functionality with: Display, Object, Overlay, Area, Label, Image, Window, etc.
  • Utilities (dll):
    This library contains functions for accessing CVB image data directly as well as functions that are not directly associated with CVB e.g. High Performance counters.
Supported Interfaces - GenICam Driver
For general information on all CVB driver interfaces please refer the Common Vision Blox Manual - Image Manager chapter.
Supported interfaces to control a GenICam compliant device using the GenICam.vin are:
ICameraSelect2
IDeviceControl
IGrab2/IGrabber
IImageRect
INodeMapHandle/INodeMapHandle2
INotify
IRegPort
IRingBuffer
ISoftwareTrigger
Details regarding the supported interfaces with the CVB GenICam driver are presented on the next pages.
Mentioned Tutorials can be found in
%CVB%Tutorial directory (Windows) or
/opt/cvb/tutorial (Linux)
ICameraSelect2 Interface: switching between different devices
The ICameraSelect2 interface allows to switch between different connected cameras or image acquisition devices. The switching between devices is realized in CVB via the
  • CS2SetCamPort functions of the Driver Library together with CS2GetCamPort and CS2GetNumPorts or
  • CamPort property of the Grabber ActiveX Control.
A description of both possibilities can be found in the Common Vision Blox Manual. To test the basic functionality, please use  the Common Vision Blox Viewer (button Show Grabber properties).
A platform independent C++ code example can be found in the MultiOSConsole example (Camera.cpp) of the Image Manager
IDeviceControl Interface
IDeviceControl Interface: controlling hardware settings
The IDeviceControl interface offers the possibility to set or change hardware (i.e. camera) parameters directly over CVB.
The IDeviceControl Interface can be accessed through the CV Grabber Control or the Driver-DLL using:
  • DCStrCommand and DCBinaryCommand function of the Driver-Dll  or
  • CV Grabber Control - SendStringCommand or SendBinaryCommand method.
Refer Common Vision Blox Manual Image Manager documentation for details.
Avaialble command values: The complete list can be found in the specific %CVB%Lib\iDC_*.h header file.
For example, the %CVB%Lib\iDC_GenICam.h for GenICam devices.
Often used command strings are listed here:
DC_BUFFER_INFO_TIMESTAMP: This is the time stamp received from the acquisition hardware saved to the acquired buffer in the memory.
DC_BUFFER_INFO_IMAGEID: This is the image id received from the acquisition hardware saved to the acquired buffer in the memory.
DC_BUFFER_INFO_NUM_PACKETS_MISSING: This is the number of missing packets from the image transfer of a GigE Vision camera related to the acquired image of the currently used buffer.
DC_BUFFER_INFO_DELIVERED_TRAILER_HEIGHT: This parameter is for variable image height. It can be used for LineScan cameras to know how many lines are valid in the buffer.
Command ID can be tested also over the Grabber Properties window in CVB Viewer or VC Sizable Display example in %CVB%Tutorial\Image Manager\VC.
A description of the command types can be found in the Common Vision Blox Manual. To test the feature please use the CVB Image Manager Tutorial: VB Grabber OCX or one of the following examples:
VC++ Example Code: retrieve ImageID (from the VC++ GenICam Simple Demo)
long outSize = sizeof(__int64);
__int64 outParam = 0;
// Send command  DC_BUFFER_INFO_IMAGEID   = 0x00000900
if (m_cvGrabber.SendBinaryCommand(DeviceCtrlCmd(0x00000900, DC_GET), NULL,0, reinterpret_cast<long*>(&outParam), &outSize))
// Print obtained value
cout << " ImgID: " << outParam;
VC++ Example Code: retrieve lost packets from last frame
bool LastBufferCorrupt(IMG hDriver)
cvbuint64_t packetsMissing = 0;
size_t size = sizeof(cvbuint64_t);
cvbres_t result = DCBinaryCommand(hDriver,
DeviceCtrlCmd(DC_BUFFER_INFO_NUM_PACKETS_MISSING, DC_GET),
NULL, 0,
&packetsMissing, size);
return result >= 0 && packetsMissing > 0;
void * IMG
VC++ Example Code: read the variable Image Height for Line Scan Cameras
#include <IDC_GenICam.h>
cvbuint64_t imageHeight = 0;
cvbres_t result = DCBinaryCommand(m_Img,
DeviceCtrlCmd(DC_BUFFER_INFO_DELIVERED_TRAILER_HEIGHT, DC_GET),
NULL, 0,
&imageHeight, size);
IGrab2/IGrabber Interface
IGrab2/IGrabber Interface: image acquisition
The IGrab2 interface was designed to do a continuous image acquisition into a image ring buffer and to be able to protect certain image buffers against overwriting. It provides functions for starting and stopping the acquisition, wait for an image, etc. All functions of this interface are also used by the CV Image Control if you start an acquisition by setting it's Grab property to TRUE. The function G2GetGrabStatus with its options* offers information about the image acquisition which can be used for monitoring and analysis.
Option examples:
G2INFO_NumPacketsReceived
This is related to GigE and indicates the number of data packets received on the GigE Vision streaming channel.
G2INFO_NumResends
This is related to GigE and indicates the number of resend requests issued by the host. If this number increases, it indicates that something is wrong with the data transmission. Possible reasons may be: Settings of the network card, CPU-load on the host, cable/switch problems, bandwidth problems on the Link.
The IGrabber interface is used for single image acquisition (snap). A detailed description of the interfaces can be found in the Common Vision Blox Manual.
A platform independent C++ code example is the MultiOSConsole example (Camera.cpp) of the Image Manager
IImageRect Interface
This interface can be used to change the resolution of the image or to inform the driver for resolution changes made previously in the hardware.
Changing Resolution over IImageRect
For cameras allowing to read out a reduced size or parts of the image this can be used with the IImageRect Interface. The settings can be adjusted with the
  • ImageOffset and the ImageSize method of the CV Grabber Control or the
  • corresponding functions of the IImageRect Interface of the Driver Library.
Both approaches are documented in the Common Vision Blox Manual. For testing, please use the CVB Image Manager Tutorials.
Inform the driver about changed  resolution or pixel format
With GenICam compliant cameras settings as resolution, pixel format and - if supported - binning or partial scan, can be changed in the camera directly. If one of these settings is changed, the image object has to be updated. You can restart the application or inform the driver about the changed resolution or pixel size. This is necessary as the underlying image object holds preinitialised buffers where the image stream from the camera is written to. When the size of the image changes the underlying image object need to be informed and the  buffers need to be reinitialized.
To do that you need to:
  • Change the setting in the camera (PixelType, image size, binning etc.) as described in the Camera Manual.
  • Call the IRImageSize function of the IImageRect with the IMAGERECT_CMD_RESET parameter.
  • This function will return a new image handle.
  • Pass this new handle to all components which reference the original image handle.
  • The original image handle does not hold a reference to the driver object anymore.
    Normally this image is not needed anymore and should be released with the ReleaseObject function.
C# Example Code:
SharedImg imgNew;
int width = 0;
int height = 0;
int bResult = Cvb.Driver.IImageRect.IRImageSize
(m_cvImage.Image,
Cvb.Driver.IImageRect.TImageRectCMD.IMAGERECT_CMD_RESET,
ref width,
ref height,
out imgNew);
if (bResult >= 0 && imgNew != 0)
// Put new Image into Image and Display Control
m_cvImage.Image = imgNew;
m_cvDisplay.Image = m_cvImage.Image;
m_cvDisplay.Refresh();
// imgNew Object is not needed anymore as it is available in the Image OCX
// dispose it here.
imgNew.Dispose();
// Update NodeMap and GenApiGrid
this.ReadGenICamInfos();
// Register all Callbacks
this.RegisterCallbacks();
For details regarding the IImageRect interface please refer to the description in the Common Vision Blox Manual.
INodeMapHandle/INodeMapHandle2 Interface
INodeMapHandle Interface: access to the GenICam Nodemap
This interface is used to obtain access to the GenICam NodeMap for the current device (e.g. a GigE Vision camera). INodeMapHandle is part of the Driver Library and provides functions to set and retrieve values from the NodeMap. A description of the INodeMapHandle functions can be found in the Common Vision Blox Manual.
Sample Code in C++ (CVB 2017 - 13.x.x)
// Check if INodemap interface is available
if (CanNodeMapHandle((IMG)m_cvImg.GetImage()))
NODEMAP nodeMap = nullptr;
// Get NodeMap from Camera
cvbres_t result = NMHGetNodeMap(reinterpret_cast<IMG>(m_cvImg.GetImage()), nodeMap);
if (result >= 0)
NODE exposureTimeNode = nullptr;
result = NMGetNode(nodeMap, "ExposureTime", exposureTimeNode);
if (result >= 0)
// Set the Exposuretime to 20ms
result = NSetAsFloat(exposureTimeNode, 20000);
ReleaseObject(exposureTimeNode);
ReleaseObject(nodeMap);
// TODO result < 0 => error
cvbbool_t CanNodeMapHandle(IMG Image)
cvbbool_t ReleaseObject(OBJ &Object)
Please see also the introduction of the INodeMap Interface in Common Vision Blox Manual. For testing purposes, please use the CVB GenICam Tutorial: VCSimpleDemo or CSGenICamExample (%CVB%Tutorial\Hardware\GenICam).
INodeMapHandle2 Interface description: access to different Nodemaps
A GenTL exports a number of separate Nodemaps to access logical parts of the driver. Beside the well known device Nodemap a GenTL Producer provides a Nodemap to configure the Datastream and to get statistical data. Other technologies might as well have multiple Nodemaps. INodemapHandle2 allows to enumerate the various Nodempas and to get access.
INotify Interface
INotify Interface description: callback functions for events
This interface allows to register callback functions for events like disconnect/reconnect or events generated by the device. In case such an event carries additional data, it is passed to the callback function. Refer also examples from Connection Monitoring chapter.
VC++ Example Code (CVB 2017 - 13.x.x):
void CVCSizeableDisplayDlg::OnImageUpdatedCvgrabberctrl()
// update attached OCXs
m_Img = reinterpret_cast<IMG>(m_cvGrabber.GetImage());
m_cvImg.SetImage(m_cvGrabber.GetImage());
m_cvDisp.SetImage(m_cvGrabber.GetImage());
if (CanNotify(m_Img))
cvbint64_t info = FALSE;
cvbres_t result = NOGetStatus(m_Img, CVNO_EID_DEVICE_DISCONNECTED, CVNO_INFO_IS_AVAILABLE, info);
if (result < 0 || !info)
m_cvDisp.SetStatusUserText("No MetaData available");
// we do not need to unregister the callback:
intptr_t disconnectedEventCookie = -1;
result = NORegister(m_Img, CVNO_EID_DEVICE_DISCONNECTED, &CVCSizeableDisplayDlg::DeviceDisconnected, this, disconnectedEventCookie);
if (result < 0)
m_cvDisp.SetStatusUserText("Error registering DisconnectedEvent!");
// Event that gets called when a camera was disconnected.
// EventID  - The event ID.
// Buf      - The buffer.
// Size     - Size of Buffer in bytes.
// DataType - Defines the datatype for the INotify data. See CVNotifyDatatypes for possible types.
// UserData - User provided pointer to private data which gets passed to the event callback function.
void __stdcall CVCSizeableDisplayDlg::DeviceDisconnected(CVNotifyEvent_t EventID, void *Buf, size_t Size, CVNotifyDatatype_t DataType, void *UserData)
CVCSizeableDisplayDlg* dlg = reinterpret_cast<CVCSizeableDisplayDlg*>(UserData);
dlg->m_cvDisp.SetStatusUserText("Device disconnected!");
cvbbool_t CanNotify(IMG Image)
cvbval_t CVNotifyEvent_t
long DataType
C# Example Code (CVB 2017 - 13.x.x)
private void cvGrabber_ImageUpdated(object sender, System.EventArgs e)
// image handling
cvDisplay.Image = cvImage.Image;
// check if INotify is supported.
if (Driver.INotify.CanNotify(cvImage.Image))
// check if DeviceDisconnected is supported.
long info;
Driver.INotify.NOGetStatus(cvDisplay.Image, Driver.INotify.CVNotifyEventID.DEVICE_DISCONNECTED, Driver.INotify.CVNotifyInfoCmd.IS_AVAILABLE, out info);
// if DeviceDisconnected is supported.
IntPtr cookie;
if (info)
// register event.
Driver.INotify.NORegister(cvDisplay.Image, Driver.INotify.CVNotifyEventID.DEVICE_DISCONNECTED, DeviceDisconnectedEvent, Handle, out cookie);
MessageBox.Show("Driver does not support DeviceDisonnected!");
Debug.WriteLine("Driver does not support INotify!");
// eventID  - The event ID.
// buffer   - The buffer.
public void DeviceDisconnectedEvent(Cvb.Driver.INotify.CVNotifyEventID eventID, IntPtr buffer, int Size,
Cvb.Driver.INotify.CVNotifyDataType DataType, IntPtr UserData)
// user output:
MessageBox.Show("Device disconnected!");
// error handling.
IRegPort Interface
The IRegPort interface provides low level access to the current device. It is recommended that you use the high level interfaces e.g. handled by the CV GenICam Control. A description of this can be found in the Common Vision Blox Manual.
IRingBuffer Interface
IRingbuffer Interface: image acquisition using ringbuffer
The ring buffer was designed to do a continuous acquisition into an image ring buffer. It protects image buffers against overwriting and can buffer several images if the following processing takes longer than the image acquisition for a short period of time. The ring buffer is used automatically with every CVB image acquisition and a default size of 3 buffers. It is recommend to use a value around the expected framerate so that a period of one second can be buffered. This can be modified in the option settings of the GenICam Browser.
The IRingbuffer interface can be used to modify the number of used buffers programmatic. It supports also other ring buffer modes. The access to the IRingbuffer interface can be done in CVB via the
  • RingBuffer-functions of the Driver Library respectively the use of the
  • RingBuffer Control. A description of both RingBuffer-implementations can be found in the Common Vision Blox Manual. For testing purposes, please use the CVB Image Manager Tutorials: VC Ringbuffer Example.
ISoftwareTrigger Interface description - software controlled triggering
The ISoftwareTrigger interface permits the sending of a software controlled Trigger to the camera without any external trigger signal. To use the software trigger the camera or device has to be set to software trigger. The camera configuration can be customized with the GenICam Browser. In CVB the trigger feature is set with the
  • GenerateSoftwareTrigger method of the Grabber Control or the
  • function STTrigger of the ISoftware Trigger Interface of the Driver-Dll.
The documentation for both possibilities is available in the Common Vision Blox Manual.
A platform independent C++ code example can be found in the MultiOSConsole Example (Camera.cpp) of the Image Manager
Windows: %CVB%Tutorial\Image Manager\VC\VCMultiOSConsole
Linux: /opt/cvb/tutorial/ImageManager/ComplexMultiOSConsoleExample
Practical configuration examples can be found in the Use Cases - Trigger Configuration chapter of this manual.
With our GenICam architecture it is possible to be informed if a device disconnects or reconnects. This is called Connection Monitoring and  is supported with GigE Vision.
This feature can be useful if a device temporarily loose its power and the connection needs to be re-established. The Connection Monitoring is realized over the INotify interface with its DEVICE_DISCONNECTED and DEVICE_RECONNECT event.
Important Notes:
  • Configure the devices with a persistent IP address and do not use DHCP to be able to get reconnected events.
  • When the camera is reconnected the driver should be reloaded to ensure if camera and driver are in correct status again.
  • There is no need to reload the driver when you do not use special driver configuration (working with defaults).
  • Do not unload (ReleaseObject) the camera IMG inside the callback thread.
  • Do not call G2Freeze() and G2Grab() within the callback itself.
  • The callback functions should only be used to inform your acquisition state that it need to be stopped or started.
  • The INotify callbacks are fired from an internal thread context, thus be careful when accessing the GUI.
Sample code how to use the INotify Interface for Connection Monitoring:
C++ Connection Monitoring Example (CVB 2017 - 13.x.x)
#include <atomic>
#include <cassert>
#include <sstream>
#include <stdexcept>
#include <thread>
#include <iCVCImg.h>
#include <iCVCDriver.h>
#include <iDC_GenICam.h>
// main function is below
// vvvvvvvvvvvvvvvvvvvvvv
class Camera
IMG handle_; // the driver image
std::atomic<bool> isConnected_; // the connection state
Camera()
: handle_(OpenCamera())
, isConnected_(true)
InitCamera();
Camera(const Camera &) = delete; // no copy
Camera &operator =(const Camera &) = delete; // no copy
virtual ~Camera()
Unload();
bool IsConnected() const
return isConnected_;
void Reload()
// this method cannot be implemented with any exception safety:
// to get a clean start we need to unload first
Unload();
handle_ = OpenCamera();
InitCamera();
private:
// opens the first camera and returns its handle; throws on error
static IMG OpenCamera()
if(const char *cvbDir = std::getenv("CVB"))
std::stringstream path;
path << cvbDir << "Drivers/GenICam.vin";
IMG handle = nullptr;
if(LoadImageFile(path.str().c_str(), handle))
return handle;
throw std::runtime_error("Error opening GenICam.vin");
void InitCamera()
assert(CanNotify(handle_));
assert(IsEventAvailable(CVNO_EID_DEVICE_DISCONNECTED));
assert(IsEventAvailable(CVNO_EID_DEVICE_RECONNECT));
RegisterEvent(CVNO_EID_DEVICE_DISCONNECTED, &Camera::OnDisconnectedDispatcher);
RegisterEvent(CVNO_EID_DEVICE_RECONNECT, &Camera::OnReconnectDispatcher);
bool IsEventAvailable(CVNotifyEvent_t id) const
cvbint64_t status = 0;
if(cvbres_t error = NOGetStatus(handle_, id, CVNO_INFO_IS_AVAILABLE, status))
throw std::runtime_error("Error getting INotify event availability");
return status != 0;
void RegisterEvent(CVNotifyEvent_t id, CVBDRIVER_NOTIFY_CB callback)
intptr_t ignored = 0; // we do not want to unregister the event
if(cvbres_t error = NORegister(handle_, id, callback, this, ignored))
throw std::runtime_error("Error registering INotify event");
static void __stdcall OnDisconnectedDispatcher(CVNotifyEvent_t /*id*/, void * /*buffer*/, size_t /*bufferSize*/, CVNotifyDatatype_t /*bufferDataType*/, void *pThis)
// called from non-main thread context
reinterpret_cast<Camera *>(pThis)->OnDisconnected();
void OnDisconnected()
isConnected_ = false;
static void __stdcall OnReconnectDispatcher(CVNotifyEvent_t /*id*/, void * /*buffer*/, size_t /*bufferSize*/, CVNotifyDatatype_t /*bufferDataType*/, void *pThis)
reinterpret_cast<Camera *>(pThis)->OnReconnect();
void OnReconnect()
isConnected_ = true;
void Unload()
ReleaseObject(handle_);
assert(handle_ == nullptr);
int main()
try
Camera camera;
std::cout << "Opened first GenICam camera (connected)...";
bool connected = true;
while(true)
if(connected != camera.IsConnected())
connected = !connected; // toggle local state
if(!connected)
std::cout << "Disconnected! Waiting for reconnect...";
std::cout << "Reconnected! Reloading...";
camera.Reload();
std::cout << " done.";
std::this_thread::sleep_for(std::chrono::milliseconds(100));
catch(std::exception &ex)
std::cerr << ex.what() << "";
return 0;
cvbbool_t LoadImageFile(const char *FileName, IMG &ImageOut)
C# Connection Monitoring Example (CVB 2017 - 13.x.x)
using System;
using System.Threading.Tasks;
using System.Diagnostics;
using static Cvb.Image;
using static Cvb.Driver.INotify;
namespace ConnectionMonitoringExample
class Program
static void Main(string[] args)
try
Camera camera = new Camera();
Console.WriteLine("Loaded first connected GenICam camera.");
while (true)
if (connected != Camera.IsConnected)
if (!connected)
Console.WriteLine("Camera disconnected, waiting for  reconnected event!");
Console.WriteLine("Camera reconnected, reloading...");
camera.Reload();
Console.WriteLine("Camera is up and ready");
connected = true;
catch (Exception ex)
Console.WriteLine(ex.Message);
class Camera : IDisposable
// The delegates MUST be stored as they are given to native code  which is not visible
// for the garbage collector
private static NONOTIFYCALLBACK disconnectedEvent;
private static NONOTIFYCALLBACK reconnectedEvent;
private IMG _handle; // handle of the driver
public Camera()
_handle = OpenCamera();
InitCamera();
private static IMG OpenCamera()
IMG camera;
string driverString = Environment.ExpandEnvironmentVariables("\%CVB\%" + @"\Drivers\GenICam.vin");
bool success = LoadImageFile(driverString, out camera);
if (!success)
throw new Exception("Camera could not be loaded");
return camera;
#region Finalizer / IDisposable
~Camera()
Dispose(false);
public void Dispose()
Dispose(true);
GC.SuppressFinalize(this);
protected virtual void Dispose(bool disposing)
if (!IsDisposed)
ReleaseObj(_handle);
_handle = IntPtr.Zero;
public bool IsDisposed
return _handle != IntPtr.Zero;
#endregion
public static bool IsConnected { get; private set; } = true;
void InitCamera()
Debug.Assert(CanNotify(_handle)); Debug.Assert(IsEventAvailable(CVNotifyEventID.DEVICE_DISCONNECTED));
Debug.Assert(IsEventAvailable(CVNotifyEventID.DEVICE_RECONNECT));
disconnectedEvent = DeviceDisconnectedEvent;
reconnectedEvent = DeviceReconnectedEvent;
RegisterEvent(CVNotifyEventID.DEVICE_DISCONNECTED,disconnectedEvent);
RegisterEvent(CVNotifyEventID.DEVICE_RECONNECT, reconnectedEvent);
Debug.WriteLine("Camera initialized");
private bool IsEventAvailable(CVNotifyEventID id)
long status = 0;
if (NOGetStatus(_handle, id, CVNotifyInfoCmd.IS_AVAILABLE, out status) < 0)
throw new NotSupportedException("Error getting INotify event  availability");
return status != 0;
private void RegisterEvent(CVNotifyEventID id, NONOTIFYCALLBACK callback)
IntPtr cookie;
long info;
info = NORegister(_handle, id, callback, IntPtr.Zero, out cookie);
if (info < 0)
Console.WriteLine("Registering INotifyEvent failed!");
Debug.WriteLine("Event" + id.ToString() + "initialized!");
private static void DeviceDisconnectedEvent(CVNotifyEventID eventID, IntPtr buffer, int Size, CVNotifyDataType DataType, IntPtr UserData)
// event is fired from a driver thread that is not the UI thread!
IsConnected = false;
Task.Run(() =>
Debug.WriteLine("Disconnected event triggered successfully!");
private static void DeviceReconnectedEvent(CVNotifyEventID eventID, IntPtr buffer, int Size, CVNotifyDataType DataType, IntPtr UserData)
Task.Run(() =>
IsConnected = true;
Debug.WriteLine("Reconnected event triggered successfully!");
public void Reload()
Unload();
InitCamera();
Debug.WriteLine("Camera reloaded!");
void Unload()
Debug.Assert(_handle == IntPtr.Zero);
cvbres_t NOGetStatus(IMG Image, CVNotifyEvent_t eventID, CVNotifyInfo_t StatusCmd, cvbint64_t &Info)
variant_alternative_t< I, variant< TS... > > & get(variant< TS... > &var)
Accessing GenICam Driver parameters
If you want to access the GenICam camera parameters in your application, you have to retrieve the CVB NodeMap handle from the driver using theINodeMapHandle Interface. You can then pass this handle to the CV GenApi Grid Control or access the features using the functions of the GenICam Library. For details regarding the INodeMapHandle interface please refer to the description related to the Common Vision Blox Manual Image Manager chapter.
Get time stamp - GenICam driver
There are two different timestamps. One time stamp is output by the camera, independent of the image. The other time stamp is given by the camera when the camera acquires an image. Every acquired image gets a time stamp from the camera.
In the following paragraphs both timestamps and how to retrieve them will be explained.
Image time stamp - according to the acquired image
Camera time stamp - independent of the image
Get image timestamp - GenICam driver
Purpose: This time stamp is used for example to archive images acquired together with the acquisition time.
There are different possibilities to retrieve the time stamp As a recommendation please use the IDeviceControl Interface of the CVB GenICam driver to retrieve the time stamp.
  1. IDeviceControl Interface
  2. IGrab2 Interface
  3. IRingbuffer Interface
The favourite method is to retrieve the time stamp via the IDeviceControl interface supported by the GenICam.vin driver.
A) Using CVCDriver.dll
Please use the command DCBinaryCommand or DCStringCommand of the CVCDriver.dll to retrieve the time stamp as a 64 Bit long value. Especially for VB.Net DCStringCommand should be used. The command ID (0x800, DC_GET) must be sent to the driver. The value 800 must be given in hexadecimal.
VB.Net Example Code:
Dim Param As String
Dim str As String = ""
Dim iCmd As Long
Dim iResult As Long
Dim iOutStrSize As Long
Dim pOutString As String
Dim lTimestamp As Long
' set command ID; the parameter constant timestamp (&H800) can be retrieved from the header file
' Lib\C\iDC_GenICam.h
iCmd = Cvb.Driver.IDeviceControl.DeviceCtrlCmd(&H800, Cvb.Driver.IDeviceControl.DC_OPERATION.GET)
' retrieve the size of the output buffer
m_cvGrabber.SendStringCommand(iCmd, Param, "", _iSize)
m_cvGrabber.SendStringCommand(iCmd, Param, pOutString, _iSize)
' In the variable pOutString the current timestamp value is retrieved.
' parse hex string to decimal long timestamp value
pOutString = pOutString.Replace("0x", "").ToUpper()
Long.TryParse(pOutString, Globalization.NumberStyles.HexNumber, Application.CurrentCulture, lTimestamp)</p>|
B) CVB Grabber Control
Using the CV Grabber Control please call the method SendBinaryCommand (…) or SendStringCommand (…). The time stamp is retrieved as a hex String value and must be converted to a 64 bit value. For VB.Net the SendStringCommand must be used. The command ID (0x800, DC_GET) must be sent to the driver. The value 800 must be given in hexadecimal (see VB.Net Example below).
VC++ Example Code:
// includes
#include iDC_GenICam.h
// Send command with the parameter constant timestamp (&H800) see iDC_GenICam.h
if (m_cvGrabber.SendBinaryCommand(DeviceCtrlCmd(0x00000800, DC_GET), NULL, 0, reinterpret_cast<long*>(&outParam), &outSize))
// Print timestamp value
cout << " Timestamp: " << outParam;
IGrab2 Interface
With the function G2GetGrabStatus (GRAB_INFO_TIMESTAMP ) of the CVCDriver.dll or the GetGrab2Status method of the CV Image Control the time stamp value can be retrieved as double value. Note that the internal time stamp is an int64 type which means that you loose accuracy when you retrieve the time stamp value with the IGrab2 Interface. For more accuracy of the time stamp value please use the IDeviceControl Interface for GenICam compliant devices.
Another possibility is to use the CV RingBuffer control and call the method GetTimestamp to retrieve the 64 bit time stamp value of type long, when the image is acquired by the camera.
Get camera timestamp - GenICam driver
Timestamps could be used to check if several cameras are running synchronously. But it is still possible that the timestamps can drift apart. The “TimestampControlReset” must be pressed to check for synchronous acquisition. Through this timestamp it can be monitored, if the camera is running synchronously to the time of the PC.
For retrieving the timestamp the Common Vision Blox GenICam API (Library or Control)must be used.
Retrieving the timestamp from a GenICam compliant camera may work as the following:
  • The camera timestamp can be retrieved via the Nodemap of the camera. (see screenshot below)
  • The nodes “TimestampControlLatch”, “TimestampTickFrequency”, Timestamp Value” and “TimestampControlReset” are used to retrieve the timestamp.
    TimestampTickFrequency: 64 Bit value indicating the number of timestamp clock ticks in one second. This value varies for different GigE cameras. This value is permanent and must be retrieved only once from the camera.
    TimestampValue: The current timestamp from the camera, that is retrieved by pressing the execute button from the node “Timestamp Control Latch”.
    TimestampControlLatch: Execute must be pressed to retrieve the current timestamp from the camera in the node “TimestampValue”.
    TimestampControlReset: Resets the timestamp count of the device. The current timestamp from the node must be divided by the “Timestamp Tick Frequency”. The calculated value is given in seconds.
Screenshot of the GeniCam property grid showing the mentionend features (consider possible parameter name variance):
VB.Net Example: Using the GenICam Library
This example shows how to retrieve the different parameters (mentioned above) for the time stamp evaluation from the Nodemap of the camera.
' get Nodes with the given NodeName
Dim _frequency As Long = 0
Dim _frequencyNode As Long = 0
Dim _timestampValue As Long = 0
Dim _nodeTimestampValue As Long = 0
Dim _nodeControlLatch As Long = 0
' get Time Stamp Tick Frequency node
Cvb.GenApi.NMGetNode(_Nodemap, "GevTimestampTickFrequency", _frequencyNode)
' get timestamp tick frequency 64 bit value
Cvb.GenApi.NGetAsFloat(_frequencyNode, value)
' get timestamp tick value node
Cvb.GenApi.NMGetNode(_Nodemap, "GevTimestampValue", _nodeTimestampValue)
' get get current timestamp tick value
Cvb.GenApi.NGetAsInteger(_nodeTimestampValue, _timestampValue)
' get Timestamp Control Latch Node
Cvb.GenApi.NMGetNode(_Nodemap, "GevTimestampControlLatch", _nodeControlLatch)
' get press the timestamp control latch execute
Cvb.GenApi.NSetAsBoolean(_nodeControlLatch, True)
' get current timestamp tick value
Sample Programs
Example programs with source code for all supported API's using the GenICam Driver, the GenICam Library and the CV GenApi Grid Control are installed with the setup and
are also available within Common Vision Blox API Overview. They are available via the
  • Start menu entry Common Vision Blox - Hardware - GenICam or via the
  • file explorer in the directory ..\Common Vision Blox\Tutorial\.... (%CVB%Tutorial) for Windows  or in /opt/cvb/tutorial directory for Linux.
For GenICam it is recommended to use the CSGenICamExample, VCGenICamGrabConsoleExample or the CSGrabConsole example as reference. A platform independent example for Windows and Linux is the VCMultiOSConsole tutorial.
However, you can also use all other examples loading the GenICam.vin driver and connecting GenICam compliant devices.
  1. Start one of the CVB tutorials such as the VCSizeableDisplay and click on the Open button.
  2. Select the GenICam.vin driver from the ..\Common Vision Blox\Drivers folder (Windows) and you will see an image from the camera.
  3. Enable the Grab checkbox to display a live image from the camera.
A detailed description of the CVB Tutorials can be found in the Common Vision Blox Manual.
Release Notes
Find the Release Notes with vin-driver versions online under Version History or refer to the Common Vision Blox Release Notes (also located in your start menu and in the doc sub-directory of your Common Vision Blox installation).
FAQ - GenICam
Basic definitions
GigE Vision FAQ
USB3 Vision FAQ
Also refer CVB user forum.
FAQ - Basic definitions
What is GenICam?
Where do I get the GenICam spec?
Where do I get the Vision Standard specifications?
Can GenICam be applied to other interfaces like Firewire or USB2?
If something is GenICam compliant does it need to be GigE Vision Compliant?
What is GenICam?
The target of GenICam is to provide complete plug & play functionality for imaging applications. Every GenICam camera contains a GenAPI XML description that lists the available camera features. In this way, different cameras with different features can be addressed via the same software interface without any problem. So it allows 3rd party software like CVB to implement a generic software interface. For more information please look at www.genicam.org.
GenICam is hosted by the EMVA ( European Machine Vision Association ). Further info can be found under www.genicam.org.
The Vision Standards are maintained and owned by the Automated Imaging Association ( AIA ). Since they own the right we can not simply give it away. Refer the www.automate.org for following standards:
  • GigE Vision,
  • USB3 Vision,
  • Camera Link,
  • Camera Link HS.
CoaXPress is hosted by the Japan Industrial Imaging Association (JIIA), see www.jiia.org.
The goal of the GenICam design was to support not only GigE Vision but also IEEE-1394 as well. GenICam can also be used to control any other kind of device such USB, but since there is no real standard for these technologies it really is up to the manufacturer to make sure the devices work with GenICam.
Some people say that GenICam is the compatibility layer. A device which is GigE Vision compliant must also be GenICam compliant since GigE Vision has a mandatory reference to GenICam. This is not the case in reverse however, since GenICam can also be used on other technologies. It therefore can not have a fixed reference to GigE Vision.
GigE Vision FAQ
What's the difference between GigE and GigE Vision?
Is there a reference implementation for GigE?
How about 10 GigE?
What is DHCP?
What is LLA?
What is a NIC?
What is a filter driver?
Is it possible to use wireless networks to transfer my image data?
Is it possible to use Multicast with GigE Vision?
Is GigE Vision IPv6 ready?
Why do I need to spend money on a switch or on a network card?
I'm trying to select a switch. What are the parameters I should look for?
Can I connect more than one camera per network interface?
Why doesn't GEV use QOS (quality of service) to control the flow of data?
What's the CPU load caused by GigE Vision?
Can I use my laptop?
What is the maximum performance of one GigE NIC?
What is the data latency compared to a frame grabber?
What is the round trip time on a GEV setup?
What do I have to know if I want to use a fibre connection?
UDP is a "not reliable" protocol. Why is UDP used?
How fast is the control protocol?
Can I use Fast Ethernet or 10MBit connections?
Is power over Ethernet available for GEV cameras?
Is there a Linux implementation for GEV?
What cable do I need?
Is a Gig E Vision connection robust?
What happens if a packet gets lost? Does the application get notified when the data is corrupt and can it do a resend. What latency can this cause?
What happens if the network fails?
How does GigE Vision recover if the network fails? Does it need to be reinitialized?
Is GigE Vision applicable to just cameras or could it be used for vision related peripherals like Lighting and timing controllers?
Can a GigE Vision device be simulated in software to enable fast data transfer between different computers?
Can I use multiple filter drivers for one NIC?
Can I change the order in which the filter driver is placed into the driver stack?
Can I use network analyzer software on my GigE Vision system?
Can I use software VPN on my GigE Vision system?
Which software packages are known to cause problems on a GigE Vision system and how can I solve those problems?
Can I optimize my network card for GigE Vision?
I can adjust the size of the receive descriptor list on my NIC. What does that mean?
I can adjust the interrupt rate on my NIC. What does that mean?
Which network ports are used by GigE Vision?
GigE means Gigabit Ethernet and is the general Ethernet network technology combined with the bandwidth specification Gigabit. GigE Vision (GEV) is the name of a network protocol, optimized for machine vision, maintained by the AIA (Automated Imaging Association) designed to control machine vision devices (cameras) and to transfer their data (images) as effectively as possible across IP networks. Although GigE Vision contains GigE in its name, the protocol also works on lower bandwidth, although at least GigE is recommended.
No, there is no reference implementation. The standard is available only as a PDF Document. GEV products are bound to a self certification process. Compliance test software will be available however.
How about 10 GigE?
The protocol used on 10 GigE is no different to the one used on slower connections. Therefore, 10GigE should simply just work. The only problem might be the performance. You can not simply multiply it by 10 since you will reach the limitations of the PC. The other factor is the cost, since 10GigE is still a little expensive. To get exact numbers we would have to investigate and that has not yet been done.
What is DHCP?
DHCP (Dynamic Host Configuration Protocol) is a protocol which allows a device on the network to request a free (not used by another device) IP address from a DHCP server. See https://en.wikipedia.org/wiki/DHCP.
What is LLA?
If a device is configured to use DHCP but can not find a DHCP server it will, after a certain time, automatically fall back to a mode called linked local address (LLA). On IPv4 networks (which is what we usually have) that means that the device assigns itself an IP in the range 169.254.x.x where the x.x are picked randomly with a subnet mask 255.255.0.0. It then tries to broadcast to the network to find out it that IP is already taken. If the IP is free, it will be used. If it is already taken, another address will be tried (https://en.wikipedia.org/wiki/Link-local_address). IP V4 address range for LLA is 169.254.1.0 through 169.254.254.255 according to RFC 3927.
What is a NIC?
A NIC is a "network interface card". This does not really mean the card itself but a single network connector. So, for example, if you have a motherboard with 2 on board GigE interfaces (2x RJ45) you have two NICs in your system. If you have a multi port network card each RJ45 (that is the name of a well known ethernet connector) on that multi port card (max. known is a 4 port card from Intel) is referred to as a separate NIC.
A filter driver is a kernel-mode driver which normally resides between the upper-level protocol and the lower-level miniport drivers (on a Windows based system). For GigE Vision technology it is used to bypass the standard network stack (used by the operating system) for all data stream packets. It filters GigE Vision related data packets and transfers them directly to an application-provided data buffer. This greatly reduces the CPU load of the system. All non GigE Vision data stream related packets are unaffected.
In principle there is no problem running a GEV camera over a wireless connection. The problem here is one of reliability. Wireless networks dynamically adjust their speed depending on the connection quality. This means that if the connection quality suddenly drops for some reason, a lot of packets will be dropped on the network. This leads to an avalanche of resend requests from the host (which did not receive the packets) and in the worst case scenario, this will cause the whole connection to the camera to fail. So, in principle, yes it will work but it is neither guaranteed or recommended.
The short answer is YES. The long answer is: Multicast is a Layer 3 IP protocol implementation. GEV is on Layer 4 so in general GEV will simply use the different IPs associated with Multicast ranges. The question is, whether the hardware (switches) and the software you are using supports it. CVB did not support Multicast from the first version on but in further releases. Please refer to the actual specific GenICam Driver Release Notes.
It is prepared but not yet implemented. All points where IPs are stored in the device are prepared but are not part of the current standard.
There are big performance differences between different network cards from different vendors (driver performance, on-board memory etc.). We prefer Intel for the network card given the choice. For switches it is a bit more complicated and we need to evaluate certain features on a case by case basis. Just because a product says ‘Gigabit Ethernet’ it does not guarantee that is provides the best performance.
Firstly it is important to say that it can be very hard to get the required information on a specific switch. There are no fixed expressions or specific numbers. So one vendor might call it xxx and the other yyy. We only can give you descriptions that relate to technical behavior.
In general: If you cannot find a specific value in the documentation you can always contact the manufacturer to get the information directly or you might simply assume that this switch is not good enough in this aspect because the vendor has attempted to hide it.
Switching Bandwidth: Is the overall bandwidth a switch can handle across all ports
Max packet rate: Max number of packets per second across all ports.
Jumbo Packets: Maximal packet size possible. With the growing size of packets we get less overhead and better performance on the transmission.
Layer 2 / Layer 3: You need Layer 3 switches if you need multicast. Otherwise it is not that important.
Memory for packet storage: If you have multiple cameras connected to a switch and one gigabit link to the host you might end up with a peak bandwidth above one gigabit. In this case a switch with memory can buffer the packets and send them out with a small delay.
SFP slots: If you need to run your network across fibre instead of copper most switches don’t have direct fibre ports but little slots where you can plug-in a little stick called SFP (small form factor pluggable) which holds the actual fibre connection. These SFP add to the cost of the system because they are not included in the price of the switch.
Number of Ports: Is the actual number of cables/fibres and therefore devices you can connect to your switch. Watch out - sometimes, if you have SFP-Slots in your switch they share a ports with a copper RJ45. So for example: we have a 12 Port Netgear GigE switch in our portfolio. It has 12 RJ45 copper connectors and 12 SFP slots. That means that every RJ45 shares a port with an SFP-Slot and you can only use either, not both, ports.
Managed switches: Most managed switches allow you to configure one of the ports as a monitoring port. That means that all packet traffic is mirrored on this port, which can help when debugging potential problems. This also manages switches, and maintains an error log which again helps to detect network cable problems.
Vendors are:
  • Netgear
  • SMC
  • HP
  • Hirschmann
  • Cisco
Yes, the number of cameras that can be connected to a single NIC is not limited in practice. So it really depends on bandwidth and latency, and hence no general answer. The more cameras you connect the more you have to think about peak bandwidth and latency.
One reason is that QOS with IPv4 is cooperative between the connected devices. It is not necessarily reliable or even forced as it is with other technologies. This might change in Ipv6 once that is supported. The other problem with QOS is that one cannot really predict the bandwidth that a triggered camera might use. There might be a peak bandwidth of 1 gpps one moment, while in the next second there might be no transfer for one minute! Also, with GigE you are not limited to a specific number of cameras you can connect. You could have 100 cameras all triggered at the same time but only once per minute. How would you share their bandwidth? What has been implemented however is a mechanism called inter-packet delay. This puts a small delay between the sending of packets which enables you to limit the bandwidth of a single camera and leave it to the switch to buffer and serialize the data from multiple cameras.
This really depends on the system you use, the bandwidth of the camera, the packet size, the driver software and the performance of your network components. The new multi-core CPUs are ideal for GEV because the operating system can distribute the load among them.
Yes, but bear in mind that a Laptop might not have the same performance as a desktop system. It mainly depends on the CPU and on the connection between the NIC and the memory. There are machines out there which use PCIe which has a better performance then PCI. The worst scenario would be a connection via PCMCIA.
Depending on your system configuration you can stream above 100MB/s sustained through one NIC. That does not mean that you can easily extrapolate this to two, three or four NICs. If you have applications close to that limit it is recommended that you contact the technical support of STEMMER IMAGING respectively your local distributor.
The short answer is: That depends on the system. The long answer is more difficult. It really depends on the camera in use, the network setup, the packet size, the PC and the system load. Assuming the camera is connected directly (no switch or router, no lost packets on the network) and with almost no CPU load on the receiving system, the latency is in the µs region. Every switch would add to that (again depending on the switch) probably in the lower µs range. But all this is a simple delay and is relatively easy to handle since it is the same with every image. The worst situation is a jitter in the arrival of images depending on the transmission quality and on the system load. If you have to perform a resend with a GigE camera, this adds to the data latency which is not predictable.
To measure a roundtrip time we used a camera which indicated the end of frame transfer in the camera by a digital output signal. We triggered an image in the camera and as soon as the application reviewed the complete image it set another digital output signal in the camera. We measured the delay between the two signals with an oscilloscope. Once again, the time depends on various factors. We measured a roundtrip time of about 3.5 ms. This gives a realistic estimation on what such a delay would be in a real application.
The biggest difference here is selecting and handling the fibre itself. There are a number of different connectors available, different fibres and different wavelength etc. But all this relates to the physical layer, not to GEV. For GEV there is NO difference between using a fibre connection or copper. If you need help setting up a fibre connection and/or choosing the right components please contact the technical support of STEMMER IMAGING respectively your local distributor.
That is true, but this is the reason why we have GEV. Since UDP is a connectionless protocol and since it does not have mechanisms to cope with lost packages we put a protocol layer on top so that we take care of these weaknesses while still maintaining the optimal performance at the lowest possible integration costs. We chose UDP instead of TCP because of performance and cost reasons.
See also FAQ Is a Gig E Vision connection robust?
On an average system it takes between 0.5 ms and 2 ms (depending on the device and the network setup) to write a GEV register from the issue of the Write Reg command until the PC has the acknowledge. This timing is for a direct link.
Apart from the limited bandwidth, GEV cameras should work just fine on Fast Ethernet (100MBit) or Ethernet (10MBit). The only problem might occur if the link on the camera is 1GBit to a switch and then 10MBit or 100MBit from the switch to the host. In that case the camera does not know about the limited connection and will send the packets at full Gigabit speed. The switch can not forward that bandwidth and will drop packets. The host will see the missing packets and request resending. For such a setup you have to limit the bandwidth of the camera or use a switch with internal memory to temporarily buffer the packets.
No, not yet, due to the size of the components and their limited power. There might be products in the future.
That is dependant on your software vendor.
GigE specifies Cat5e cabling, but to be on the safe side we recommend Cat6 cables which have better shielding. Cat7 cables are available for higher frequencies but as yet there are no connectors defined.
Is a GigE Vision connection robust?
The short answer would have to be yes.
The long answer would need to explain why this is the case since a UDP base protocol like GigE Vision sits on top of a Gigabit ethernet connection which is is not reliable as such. With UDP we face two major problems. The first is that UDP is not connection oriented so we need to have a mechanism that enables each end to check that the other end is still available. The 2nd problem is lost packets due to a number of different reasons.
So to solve the connection question, GigE Vision implements a mechanism called Heartbeat. This enables the camera to determine whether the host is still up and running. The other problem is covered by the control protocol.
The packet loss is handled in different ways. With the control protocol, a lost package is detected by a ‘send and acknowledge’ mechanism. The streaming, in order to achieve better performance, works with a different method. Each data packet has a unique id so that the receiving host can identify missing packets and send a resend request to the device ‘on-demand’. The device will store a certain number of packets and on receiving such a request it will resend the data.
This solution, in combination with a CRC (checksum) makes GigE to the most robust transfer technology we have so far in Machine Vision. With CameraLink there is no possibility of identifying corrupt data, e.g. flipped bits due to too long cables. With 1394 on the other hand we can also identify corrupt packets but don't have such a resend mechanism. So without enumerating all technologies in this document, GigE Vision is as reliable as it can be.
On the other hand there will be a higher data latency which will be added to the data transfer and camera control when something goes wrong. And it is even worse, because we can not deterministically predict these latencies when we assume that a control protocol packet gets lost, the camera sends no acknowledgement. The host will wait a certain time until a timeout arrives and resend that command. This time the packet might get through, but the acknowledgement now get's lost. Finally the third attempt works. This, of course, would be on a very very bad connection but this could happen. So the comfort of having a safe connection brings a less deterministic behavior timewise. How much this impacts the performance, really depends on the connection you are using, the components involved and the load on the host. If nothing goes wrong and the connection does not loose packets we have NO performance loss.
Please also refer to the following FAQ's:
See FAQ Is a Gig E Vision connection robust?.
That really depends on the network topology. In general, if the network fails, the application will know about it and it try to reestablish the connection.
If the network fails the device and the host will loose the link and will disconnect. Common Vision Blox (CVB) fires an CVCError-event announcing an Acquisition Error . Then the GenICam Driver has to be reloaded.
Devices which don't need to stream data can simply use the control protocol only and not expose a streaming channel. In this way GigE Vision can be used as a simple control protocol.
Yes of course it can. Since GigE Vision uses standard network protocol mechanisms it can be implemented in software on the host.
You can use more than one filter driver for one NIC e.g. if you have SDK's or GigE Vision devices from several vendors on a single system. The maximum number of filter drivers for one NIC is limited. There is one major drawback using multiple filter drivers on a single NIC. Assume you have installed 2 filter drivers from 2 different vendors. You have a GigE Vision device from each vendor which is processed by the filter driver of that vendor.
Your network stack will normally look something like this:
PROTOCOLDRIVER (upper-level)
FILTERDRIVER_B
FILTERDRIVER_A
MINIPORTDRIVER (lower-level)
NIC
Device_A + Device_B
All data stream packets from Device_A are filtered in FILTERDRIVER_A.
All data stream packets from Device_B are filtered in FILTERDRIVER_B.
But all data stream packets from Device_B have to pass FILTERDRIVER_A before they are processed by FILTERDRIVER_B.
This will cause additional CPU load. The more drivers you have in the stack the more CPU load you will get. You can use different filter drivers on different NIC's. without causing additional CPU load when you disable (not uninstall) the unused driver for this NIC.
No you can not. This is controlled by the operating system. You can not select which driver is lower or higher in the stack.
You should not. If you use a network analyzer software like Wireshark on your GigE Vision system you might run into problems. Wireshark for example uses the WinPCap kernel mode protocol driver to analyze all incoming and outgoing packets. Depending on the order in which the operating system has installed the filter drivers and WinPCap in the network stack, your filter driver might not receive any GigE Vision data stream packet. In that case you will get no GigE Vision data!
You should not. We have seen problems e.g. using VPN software from Cisco. There are similar reasons for this as mentioned under FAQ Can I use network analyzer software on my GigE Vision system?
VPN Software e.g.: Cisco VPN (Solution: disable network service called Deterministic Network Enhancer + Stop VPN service with "net stop cvpnd") Network Analyzing Software like Wireshark (Solution: uninstall WinPCap)
See also FAQ's Can I use network analyzer software on my GigE Vision system? and Can I use software VPN on my GigE Vision system?
Yes you can. The optimization depends on the hardware you are using. So bear in mind that you should always use the proper hardware.
  1. Install the latest drivers for your NIC.
  2. Try to enable Jumbo Packages if your NIC has this feature.
  3. Increase the size of the receive descriptor list entries on your network card to the maximum value.
  4. Decrease the number of interrupts generated by the NIC.
Please have a look at our recommendations for the Performance Settings.
This sets the number of buffers used by the NIC driver that are used to copy data to the system memory (normally done with DMA). Increasing this value can enhance receive performance, but also consumes system memory. Receive descriptors are data segments that enable the adapter to allocate received packets to memory. Each received packet requires one receive descriptor, and each descriptor uses certain amount of memory (e.g. 2kB for a INTEL Pro/1000). If the number of receive descriptors is to low than the NIC might run out of memory which will cause packet loss. For GigE Vision this might cause a lot of packet resend requests.
Depending on the NIC you are using, you can decrease the number of interrupts generated by the NIC. This has some influence on the CPU load. On a INTEL Pro/1000 card you can decrease the number of interrupts that are generated by setting the "Interrupt Moderation Rate" to "Extreme". For other network cards there are similar ways of decreasing the interrupt rate.
GigE Vision consists of a control and a streaming part. Only the control  connection is claiming a static port on the device end (UDP 3956), which  is also registered with IANA. The control connection source port as well  as the streaming connection port(s) are dynamically allocated from the  ephemeral port range 49152 through 65536.
USB3 Vision FAQ
What is the difference between USB3 and USB3Vision?
USB3 Vision is a machine vision standard, maintained by the AIA (Automated Imaging Association), designed to control machine vision devices (cameras) and to transfer their data (images) as effectively as possible across USB3.0 interfaces.
What about CVB, USB3 and USB3 Vision?
CVB supports every “USB3 Vision” camera, as it implements the USB3 Vision standard, please note that “Vision” is important, as there are USB3 cameras on the market which do not follow the standard is not a USB3 Vision camera - the GenICam.vin driver will not work with this camera and you have to use the extra drivers for the camera (e.g. CVB IDS Driver for IDS USB cameras). Is there a reference implementation for USB3 Vision? No, there is no reference implementation. The standard is available only as a PDF Document.
Can CVB with Sherlock support USB3.0 Vision Cameras?
Yes, because Sherlock can be used with any image source supported by CVB it will also support USB3 Vison cameras.
Service
Documentation
Please also take a look at the specific camera manual supplied by the manufacturer.
The CVB related documentation for the CVB Driver is available via the Start menu entry STEMMER IMAGING-Common Vision Blox-Documentation-Hardware-GenICam.
Further documentation can be found in the Common Vision Blox Manual. More detailed hints and information regarding hardware and software configuration of GenICam Devices under CVB can be found in
Updates
Please check the CVB Web pages for updates to this driver in form of a CVB service pack or a hotfix. Therefore please visit the CVB User Forum Download area and choose the CVB Version or Operating System and navigate to the section List of available Updates. For any kind of problem you encounter it is very helpful to record the error logging of the CVB GeniCam driver. Please have a look at the description of the Error logging.
Technical Support
Report the versions of Common Vision Blox, Operating System and the devices serial numbers. Use the support contact form.
License
The license options are described in the CVB Manual. Complete License Management is to be handled with License Manager.   If there is a CVB watermark in the Device View/Video interface following reasons are possible.
- The license entry is missing. Camera Suite License covers GigE and USB3 vision Transport Layer.
- The license entry does not cover the actual Transport Layer usage. For other Transport Layer integration an Image Manager License is needed.
For GigE Vision or USB3 Vision devices in the GenICam Browser the License key can be retrieved for available devices using the Retrieve License key. The browser has to be started as Administrator or Root before.
Through MAC address/USB serial number of the camera you will immediately receive the appropriate licence key for the CVB CameraSuite license.
GigE Checklist
The camera is not seen in the GenICam Browser
  • Make sure the IP addresses of the Camera and the Network Interface Card-NIC the camera is connected to and the switch (when used), are on the same subnet.
  • If you have multiple NICs in the system make sure they don’t share the same subnets, otherwise this can result in unpredictable behavior.
  • Check if the Firewall of the network port the camera is connected to is disabled.
  • Make sure that you use GBit Network cards and switches.
  • Try to ping the network ports used with the camera setup.
  • Is a PoE Injector necessary (laptop) ?
  • Try the connection to the camera on another NIC / PC.
  • Check that the camera is really GenICam compliant.
The Camera can be opened in the GenICam Browser but data can’t be streamed
  • Check your Firewall settings
    The firewall must be disabled on the network port the camera is connected to or the firewall must be configured in a way that allows the CVB-GEV driver to communicate with the camera.
    The UDP control port in the camera is fix. Streaming source port, and the message channel source port in the camera are dynamic.
    They are set by the driver.
    So the only way is to enable all traffic from a defined IP address of the camera to the host.
  • Also, some VPN connection have a stateful firewall integrated.
  • Increase the receive buffer size of your network card.
  • If the camera is configured to use JumboPackets make sure your network components (switches, NIC) are capable of processing JumboPackets.
The Camera can be opened in the GenICam Browser but there is only one black image when grab is active
  • Check Exposure Time, light and lens cap
Getting a large number of missing packets only
  • If you are using components with lower transmission rates than 1GBit, the camera will nevertheless send data at full speed (1Gbit) but the system as a whole can only handle 100Mbit (or less). In such cases many packets will be dropped and the camera will not be able to transfer complete images. Either configure your network to operate only on one speed or increase the inter-packet delay in the camera so that it does not exceed the speed.
USB3 Checklist
Hardware limitations and incompatibilities to be considered with USB3 Vision technology
  • USB3 ports are to be used, they are mostly marked blue and should be as near as possible to the mainboard (onboard).
  • Cable length is recommended no longer than than 5m.
  • When the cable is not plugged in completely it might be recognized as USB2 since not all pins are connected.
  • If an USB 3 adapter card with PCI Express 1x is used on a system which has PCI Express 1.0 slots then the maximum possible bandwidth is 250MB/s. But for cameras with higher bandwith a modern mainboard with a newer PCI Express version is needed.
  • Refer also the USB3 Vision System Requirements.
Installing the CVB USB3 Vision driver on a Windows based computer can require to uninstall other drivers
If you connect a USB 3 Vision Device  Windows is searching for the best fitting driver for this device. If CVB is installed and no other driver is available which supersedes the CVB ones then it is installed and the device should work. But if Windows choose the wrong driver we need to uninstall the other driver with the Windows Device Manager. Then the driver will be used.
USB3 Drivers under Linux
Within Linux there is normally one USB3 Driver. And this driver should work for all. Otherwise there is no output from lsual.
How can I get furher USB3 devices hardware information?
In the folder %CVB%\Hardware\StemmerImaging\Utilities: Use “lsual –l” in a console window.
Device is detected, but it is not visible in the application?
The chipset driver might also be too old. Please install the newest available driver for your chipset. Refer USB3 Vision System Requirements.
Camera show vital signs but image acquisition is not possible
For this camera an external power supply through the 12-pin Hirose connector is essential.
Trouble Shooting
The camera is not seen in the GenICam Browser/GenICam Device Configurator
I can open the camera in the GenICam Browser/GenICam Device Configurator but get a white picture
I can open the camera in the GenICam Browser/GenICam Device Configurator but get a flickering picture
Image contains a logo or is complete grey
Error message: Nodemap unavailable
The CVB pixel type is wrong
I get a large number of lost frames
The acquired images show defects
I can acquire images but the GigEVision events from the camera are not fired
GigE Cameras disappear in the GenICam Browser
Occasionally Time Out errors when performing image acquisition with Software Trigger
How can I enable Packet Resend in the driver?
How can I discard corrupt frames in the driver?
How can I find the installed transport layer ?
The camera is not seen in the GenICam Device Configurator / GenICam Browser
For GigE Vision make sure the IP addresses of both the camera and the NIC the camera is connected to, are on the same subnet,if you have multiple NIC's in the system make sure they don’t share the same subnet's. Otherwise this can result in unpredictable behavior. Refer GigE Vision checklist.
For USB3 Vision please ensure that USB 3.0 ports are used and all other hardware requirements are fulfilled. Refer USB3 checklist. Seldom it could be necessary to delete the GenIcam XML file and directory manually: %CVBDATA%GenICam and start the application again. For all other vision hardware components (cameras, grabber) ensure that the necessary software and driver is installed.
I can open the camera in the GenICam Browser but get a white picture
Change the Display Engine type from OpenGL to Raster. Display Engine can be changed only if no device is open. If the selection is disabled, all devices must be closed.
This can occur with high performance cameras or multi-camera scenarios which are producing pictures with a higher bandwith than the communication link is able to transfer (GigE Vision, USB3 Vision).
Cameras transfers empty pictures as soon as a bottleneck is detected. This can be observed with the flickering effect on freerun pictures  in CVB and watching the Data Stream Port statistic values. Exposure time adaption, Framerate decreasing to a value matching the transfer capabilities and optimizing the network configuration for GigE hardware should solve the problem.
Image contains a logo or complete grey images ( value 128) appear
If the cameras are not licensed via CameraSuite or any other valid Image Manager license like a dongle, a Node-locked or Triallicense there are sent some kind of distorted images. This could be either a logo as a watermark in the left top part of the image:
or that grey images with a grey value of 128 appear from time to time. Additional there appears a red text overlay in the display which says " Common Vision Blox evaluation".
If the device has no XML file in its memory "Nodemap unavailable" message is returned when a device is opened. Be aware that setting a correct XML file for the device is a precondition - so it has to be (re)generated. Availability, version and binding information of a camera GenICam XML-file can be checked with the EditBindings application. Sometimes it could be necessary to backup and delete the GenIcam XML file and directory manually: %CVBDATA%GenICam and start the application again.
Check or change the pixel format setting with the GenICam Device Configurator - Device Settings. Please refer to the Common Vision Blox Manual for more details.
Check the hardware components and configuration if they inter-work with the camera configuration and capability. Most problems are caused due to unsatisfactory performance.
If sections of the acquired images are missing or random noise is visible, the reason is probably a transmission problem. The following image shows an example of this type of transmission problems:
Maybe you see black lines or lines with old image data. Check the hardware components and configuration if they inter-work with the camera configuration and capability. Please refer the corresponding chapters in this User Guide for optimization.
Disable the firewall. Enable the events with the EventNotification feature.
GigE Cameras disappear in the CVB GenICam Browser
The system was already working and without changing anything the GigE camera does not appear any more in the GenICam Browser. But it is possible to PING the camera. Means IP configuration and camera is OK. Solution: Please delete the following file in the CVB Root path ..\Genicam\Registry\xml\db.xml Restart the CVB GenICam Browser and you should see the GigE camera again connected.
This problem may occur mainly on cameras with high data rate. Check the hardware components and configuration if they inter-work with the camera configuration and capability. Please refer the corresponding chapters in this User Guide for optimization.
By default packet resend is disabled in the driver. To activate it you need access to the DataStream Nodemap of the driver. In the NodeMaps section you can read how to access the DataStream Nodemap. There is also an example in C++ how to enable the Packet Resend.
By default corrupt frames are passed thrue the driver. You can disable pass corrupt frames with the DataStream Nodemap of the driver. In the NodeMaps section you can read how to access the DataStream Nodemap. There is also an example in C++ how to discard corrupt frames.
How can I find the installed transport layer?
Transport Layer environment variable: GENICAM_GENTL64_PATH to find all *.cti files
  • Windows: can be checked with cmd shell command "set": refer screen shot example below
  • Linux: can be also checked with cmd shell command "env": e.g. GENICAM_GENTL64_PATH=/opt/cvb/drivers/genicam
Data, Error Logging and Statistics
Save camera properties in a *.gcs (GenICam Settings) file
In GenICam Browser: Properties > Options > Save Properties > Select All:
Save Logging
In GenICam Browser Logging window the log data can be saved as *.log file.
Acquisition Statistic
GenICam Browser offers Statistic values since CVB 2017:
CVB Viewer gives you also the possibility to see acquisition statistics about transfer and lost images.
Also the FramesCorrupt parameter at the Nodemap Stream Port can be monitored:
Number of images which were corrupt on arrival in the host no matter if or if not resend requests have been issued. This setting indicates if something is wrong with the transmission. A corrupt image is an image which in the first run did not arrive properly and points to transmission problems caused by bandwith limitations.
Error Logging
Since CVB 2017 the LogGUI application LogGUI.exe can be used for logging: %cvb%Applications
For all other versions before follow following steps:
Windows:
1) Create Environment Variable CVBLOG=%CVBDATA%\log
2) Create Folder %CVBDATA%\log
3) Load Driver once and three *.json files are created
  • GenICamVIN.log.config.json
  • GEVSD.log.config.json
  • GevTL.log.config.json
  • USBTL.log.config.json
4) Now you can activate the logging in every json file for the corresponding module
e.g. To activate the logging for the GenICam.vin driver open the GenICamVIN.log.config.json and change "destination" and "level" like this:
"log":
"destination": "console",
"destination_option_0": "none",
"destination_option_1": "file",
"destination_option_2": "console",
"destination_option_3": "trace",
"destination_option_4": "service",
"file":
"name": "C:\\Temp\\GenICamVIN.log"
"level": "0xFF",
"level_option":
"none": "0",
"info": "0x0F",
"warn": "0x07",
"err": "0x03",
"fatal": "0x01",
"debug": "0x3F",
"trace": "0x1F",
"all": "0xFF"
If "destination": "file", is used the "name": has to have an absolute path to where you want to safe the log file. Please note that you have to use either "\\" or "/" as the separator in the path to the logging file.
1) You can choose a different target folder if you want. But the target folder in the environment variable has to be created manually
2) GenICamVIN.log.config.json: logging from the GenICam.vin driver
3) GEVSD.log.config.json: logging from the socket driver
4) GevTL.log.config.json: logging from the STEMMER IMAGING GigE Vision Transport Layer
5) USBTL.log.config.json: logging from the STEMMER IMAGING USB 3 Vision Transport Layer
Linux -Debugging
Run GenICam Browser with flag –debug. This will generate a Debug.log in the same directory. Within /opt/cvb/bin you have to run debugging with sudo. Or you make a symbolic link to GenICamBrowser to your home directory.
Then you can run it without sudo:
In your home directory: ln –s /opt/cvb/bin/GenICamBrowser GenICamBrowser
