Common Vision Blox Libraries and Applications
On this page you will find alle CVB libraries and applications. Several CVB libraries and applications are part of the CameraSuite/ImageManager license. If they are not, they will be marked in the tables as follows:
* Needs a foundation license.
** Needs a tool license.
Detailed information about the licensing can be found here.
Image Acquisition
SDK
 ImageManager Basic library for
- Image acquistion
- Image handling
- Point cloud handling (3D)
Applications
 GenICamBrowser Easy to use application to detect devices in the network and to get a live view without programming.
 Edit Bindings Console application to detect and edit bindings between GenApi xml file and device.
Network Interfaces and Streaming
SDK
 GevServer** Library with functions presenting any CVB image source as a GigE Vision camera.
 Movie** Streaming CVB images into a standard AVI file.
 Webstreaming** Library for image conversion/compression and image transport.
Image Processing
SDK
- Image acquistion
- Image handling
 Foundation* Collection of optimised image processing functions.
 Arithmetic* Appling arithmetic and logical operators to images.
 BayerToRGB* Bayer to RGB conversion.
 Edge* Detecting edges within an image.
 LightMeter* Generating histograms of intensity values and statistical measures.
 Polarization* Handling raw images from polarisation area and linescan cameras with polarization mosaic patterns.
 TextOut* Adding text to CVB images.
 Barcode** Decoding one- and two-dimensional barcodes.
2D Object Recognition
SDK
 Blob** Blob analysis.
 Minos** Pattern recognition, alignment and optical character recognition (OCR).
 Polimago**
 SIL - Sample Image List**
Pattern classification, function estimation and image search.
 Shape Finder** Search tool to find previously trained objects in newly acquired images.
Applications
 TeachBench** Training utility for various pattern recognition algorithms (Minos, Polimago).
3D
SDK
- Image acquistion
- Image handling
 Metric* Calibration of laser triangulation systems.
 Match3D**
- 3D Matching of two point clouds (Match3D-ICP).
- CAD-based 3D object recognition (Match3D-DNC).
Applications
 TeachBench** Training utility for various pattern recognition algorithms (Matrch3D-DNC).
Hyperspectral Imaging
 Spectral** Basic handling of hyperspectral images and color conversion.
Error Logging
 LogGUI Tool to collect and show diagnostic data from all CVB modules.
License Manager
 License Manager Tool to manage your CVB license.
ActiveX Controls
A list of all available activeX controls can be found here.
