Common Vision Blox Logging GUI
What is the LogGUI?
CVB Logging GUI (LogGUI)  is an application which has been added to Common Vision Blox for easy collection of diagnostic data from all Common Vision Blox modules that provide such information. It contains powerful log watching capabilities and therefore gives additional information on the image acquisition and also error messages.
The LogGUI always starts with module default, containing all supported CVB modules and offers following Log Level values:
User Guide
Location of LogGUI
OS Location
Windows CVBApplications > LogGUI.exe
Linux /opt/cvb/bin > LogGUI
Use Cases
For simply logging with default settings and saving the log file follow the chapters:
Logging
Save, Copy and Clear Logs
For logging with a special configuration file or selection of special modules and levels follow the chapters:
Configure Logging
Logging
For logging and analyzing the log follow the chapters:
Configure Logging
Logging
Expert Settings
Search and Find
Logging
Button Overview Logging
Start Logging
Stop Logging
Save the log window entries to file
Copy the log window entries to clipboard
Clear the log window
Logging
Start Logging by
  • pressing the button and
  • starting the application (e.g. GenICam Browser).
Stop Logging by pressing the button.
Enabled Auto Scroll in View automatically scrolls while logging and keeps the latest log message on top.
Log Messages
Log and error messages are shown in the Logging window.
Save the log window content
Save the Log window content as *.log file by pressing the button.
The Logfile can be opened using any editor:
Configure Logging
To customize the Logging the configuration offers selection options for modules and levels to be logged. For configuring the log levels and the modules, open the Configuration (Configuration Mode = User Mode):
Within the Configuration window:
Please do not forget to save the new settings with the save button:
A configuration file (.json) can be loaded or reset (File > Open config…, Reset config file).
Stop and restart the logging.
Modify Parameters
Modify the parameters (trace level) for an configure module.
Insert
Insert a special module with a defined trace level.
Delete
Delete a special module with a defined trace level.
Detached Configuration windows
Save Log Window content
To save the log window entries to a file, use the Save button.
Copy Log Window content
To copy the log window entries to the clipboard, use the Copy button.
Clear Log Window content
You can clear the log window to get an empty window with the Clear button.
Save complete Log as JSON
To save the complete log entries to a JSON file, use the Save log as JSON button in 'File'.
Save the complete log entries to JSON file
Load Log from JSON
To load a JSON file with log entries, use the Load log from JSON button in 'File'
Load a JSON file with log entries
Search and Find
Use Search   Find… to find an expression:
Expert Settings
This chapter describes the filter and sorting options for experts Log customization:
 Filter Options
 View Options
Expert Mode
Filter Options
Use the Filter function to include or exclude expressions (multiple expressions can be added):
Switch on/off the Filter Option:
It is also possible to go to a specific line:
View Options
Your current view options are automatically stored, when exiting the application.
It is possible to reset the original view with View > Reset view to default.
Sort columns
Configure own View
Change time display format
Time references
Preferences
Sort columns
You can sort the columns to get the LogLevel or the Modules grouped simply by clicking on the column name:
Configure own View
Another possibility to configure your own view is to select individual columns and sort them as you like:
The number of maximum log messages defines the number of log messages, which are stored.
If more than the maximum are logged, the older log messages will be overwritten.
Changing the time display format** either shows the time stamp as date and time or as seconds:
Or use the right click :
Time references
With right click on the logging a specific line can be set as time reference (or unset).
Multiple time references can be set.
Preferences
With Edit > Preferences... the number of lines to prerecord can be defined:
Expert Mode
With Expert Mode Log Levels and destinations can be configured.
Default setting is as follows:
