CVB Hardware Configuration Guide
User guide for configuration your acquisition hardware with Common Vision Blox.
Acquisition Hardware
GigE Vision Devices
USB3 Vision Devices
CoaXPress Devices
CameraLink Devices
CVB Installation
To be able to acquire images from acquisition devices CVB and the appropriate hardware drivers have to be installed on your system.
The hardware independent architecture of CVB requires a video interface file (vin) to be loaded when an image acquisition device is used (e.g. CVB GenICam driver (GenICam.vin) for GenICam compliant devices.) The *.vin format is proprietary to CVB and supports a wide variety of interfaces for acquisition, line scan acquisition, triggered acquisition and many more.
Following CVB downloads are available:
CVB Download
Installation and Setup
GigE Vision Devices
USB3 Vision Devices
  • Connect Camera to USB3 Port
    Your USB3 Vision Device must be connected into an USB external or on-board Host controller card with USB 3.0 ports (usually marked blue).
    Use therefore an USB 3.0 cable:
    - maximum length 5m,
    - we highly recommend the use of machine vision validated USB cables
  • Start the CVB GenICam Browser and search for available devices
    For details refer GenICam Browser User Guide.
  • Configure Device Driver parameters
  • Configure Camera Features using the Nodemap in Property Grid
    For feature availability and options refer to the camera manuals
CoaxPress / Camera Link
Manufacturer specific Hardware with CVB driver
The video interface (vin) file format is used for all Common Vision Blox drivers. There are vin-files available for a vast range of different image acquisition devices like frame grabbers, cameras or vision systems.
Please refer to the CVB Download area for driver download matching the CVB versions.
  • Install board and connect camera using appropriate cables.
  • Install Manufacturers Software and set Up the board
  • Download and Install the CVB Driver for this Hardware.
    A detailed documentation can be found in the CVB Hardware User Guides.
  • Search for Device Driver and configure it according to the Configuration Guide.
  • Start an example application that loads a *.vin driver.
  • Load the *.vin driver.
  • Configure Camera Features using a Camera Control Tool (vendor specific configuration tool, e.g. CamExpert, Jai Control Tool,...).
    For feature availability and options refer to the hardware manual.
Applications and Tools
Get a Quick Start with:
System Browser Get an overview of the vision system components.
GenICam Browser Search and configure GenICam compliant hardware.
License Manager Manage the CVB Licenses.
Find applications and tutorials:
  • for Windows in Start Menu or under %CVB%Applications and %CVB%Tutorial
  • for Linux tools in /opt/cvb/bin and tutorials under /opt/cvb/tutorial
Refer also Installation and Setup
System Browser
The System Browser can be used for GenICam compliant devices to:
  • get an overview of the vision system components: computer, interfaces, cameras, CVB software, licenses
  • get a simple live view with the detected cameras
  • save diagnostic information.
Start the System Browser from: %CVB%Tutorial\Image Manager\Cvb.Net\bin\Release\SystemBrowser.exe
License information:
Network information:
Diagnostic data:
Live view:
Get a live view by double clicking the camera and use the Node Map camera configuration options, Statistics and Discovery information.
GenICam Browser
The GenICam Browser can be used to:
  • Windows: Start Menu STEMMER  IMAGING Common Vision Blox and under %CVB%Applications
  • Linux: /opt/cvb/bin
Detailed information about the GenICam Browser can be found in the following documents:
GenICam Browser Detailed description of the GenICam Browser Application.
⭐ Step-By-Step Guide Configure your cameras with the step-by-step guide of the GenICam Browser.
It is recommended to start with the Step-By-Step Guide and look up for detailed information in the manual of the GenICam Browser if needed.
License Manager
Complete License Management can be handled with License Manager. An overview over all available licenses can be found here.
A detailed description of the different license methods can be found in section Licensing.
Documentation
Following documentations and information sources are available:
Service
Updates
Please check the CVB Web pages for updates to this driver in form of a CVB service pack or a hotfix. Therefore please visit CVB User Forum Download area and choose the CVB Version or Operating System.
For any kind of problem you encounter with CVB GenICam driver it is very helpful to record the error logging (Log window in GenICam Browser or LogGUI.exe in %CVB%Applications). Please have also a look at the description of Acquisition Statistic, Trouble Shooting and Error logging.
Technical Support
  • configuration hints in sections before,
  • Trouble Shooting section,
  • save logs and hardware configuration settings. Report also the versions of Common Vision Blox, Operating System and the devices serial numbers.
Request Hotline Support
Discuss in User Forum
