CVBpy 14.1
PixelFormatConverter Class Reference
Helper class that takes care of pixel format conversion. More...
Inherits object.
Public Member Functions
None PixelFormatConverter (self, int source_format, int destination_format)
 Constructor. More...
cvb.PixelFormatConverter create (int source_format, int destination_format)
 Creates a pixel format converter. More...
None execute (self, Union[cvb.Image, cvb.PFNCBuffer, cvb.Composite] source_object, cvb.Image destination_object)
 Converts a PFNC compliant object to another pixel format. More...
Properties
 destination_format = property
 int: Gets the destination pixel format (see cvb.PfncFormat).
 source_format = property
 int: Gets the source pixel format (see cvb.PfncFormat).
Constructor & Destructor Documentation
◆ PixelFormatConverter()
None PixelFormatConverter (   self,
int  source_format,
Constructor.
source_format : int Source pixel format (see cvb.PfncFormat).
destination_format : int Destination pixel format (see cvb.PfncFormat).
Member Function Documentation
◆ create()
cvb.PixelFormatConverter create ( int  source_format,
cvb.PixelFormatConverter Requested pixel format converter.
◆ execute()
None execute (   self,
If any of the given objects is not PFNC compliant then it throws a runtime exception.
source_object : Union[cvb.Image, cvb.PFNCBuffer, cvb.Composite] Data source to be converted.
destination_object : cvb.Image Destination object that stores the converted data.
