CVBpy 15.0
ReadResultCode39Code93 Class Reference
Derived from ReadResult and gives specific access to Code39 and Code93 results. More...
Inherits ReadResult1D.
Properties
 full_ascii = property
 bool: Specifies the use of a full ASCII description of the code, only used with the Code 39 and the Code 93.
- Properties inherited from ReadResult1D
 grade_result = property
 cvb.barcode.GradeResult1D: Barcode Read Result does not contain any valid grading results.
 characters_read = property
 int: The return value contains the number of characters in the read barcode.
 decode_time = property
 int: The return value specifies the time consumed for decoding in units of ms.
 location = property
 List[cvb.Point2D]: Location of the barcode inside the image.
 num_words = property
 int: Contains the number of code words composing the read barcode.
 resolution = property
 float: The resolution specifies the smallest width unit in the code in multiples of a 10th of a pixel.
 result = property
 int: Result of a read operation (note that read operations may partly succeed, which is not considered an error; see cvb.barcode.DecodeResult).
 text = property
 str: The text content of the barcode.
 type = property
 int: Symbology of the decoded result (see cvb.barcode.Symbology). More...
