Helper class that takes care of pixel format conversion. More...
Public Member Functions | |
| None | PixelFormatConverter (self, int source_format, int destination_format) |
| Constructor. | |
| cvb.PixelFormatConverter | create (int source_format, int destination_format) |
| Creates a pixel format converter. | |
| None | execute (self, Union[cvb.Image, cvb.PFNCBuffer, cvb.Composite] source_object, cvb.Image destination_object) |
| Converts a PFNC compliant object to another pixel format. | |
Properties | |
| destination_format = property | |
| int: Gets the destination pixel format (see cvb.PfncFormat). | |
| source_format = property | |
| int: Gets the source pixel format (see cvb.PfncFormat). | |
Reinterpreting Images as PFNC Buffer
| None PixelFormatConverter | ( | self, | |
| int | source_format, | ||
| int | destination_format ) |
Constructor.
source_format : int Source pixel format (see cvb.PfncFormat).
destination_format : int Destination pixel format (see cvb.PfncFormat).
| cvb.PixelFormatConverter create | ( | int | source_format, |
cvb.PixelFormatConverter Requested pixel format converter.
| None execute | ( | self, | |
| Union[cvb.Image, cvb.PFNCBuffer, cvb.Composite] | source_object, | ||
| cvb.Image | destination_object ) |
If any of the given objects is not PFNC compliant then it throws a runtime exception.
source_object : Union[cvb.Image, cvb.PFNCBuffer, cvb.Composite] Data source to be converted.
destination_object : cvb.Image Destination object that stores the converted data.
