Functions and types used to work with pixel data. More...
Typedefs | |
| typedef cvbbool_t(* | TFLine) (void *pPrivate, cvbval_t LinesToDo) |
| Start of or end of scan line callback function. | |
| typedef void(* | TFNonlinear) (void *pPrivate, double &X, double &Y) |
| Callback function that defines the transformation used in the CreateTransformedImage function. | |
| typedef cvbbool_t(* | TFPixelBinary) (void *pPrivate, void *pPixel1, void *pPixel2, cvbdim_t X, cvbdim_t Y) |
| Pixel callback for binary scanning functions. | |
| typedef cvbbool_t(* | TFPixelUnary) (void *pPrivate, void *pPixel, cvbdim_t X, cvbdim_t Y) |
| Pixel callback for unary scanning functions. | |
| typedef cvbbool_t(* | TFProgress) (void *pPrivate, cvbval_t StepsTotal, cvbval_t StepsDone) |
| Callback for providing progress feedback. | |
| typedef cvbval_t | THistogram[256] |
| Value histogram for one 8 BitsPerPixel IImageVPA plane. | |
Enumerations | |
| enum | TNormalizeMode { Normalize_MeanVariance = 0 , Normalize_MinMax = 1 } |
| Normalization mode used by CreateNormalizedImage. More... | |
| enum | TSubPixelMode { SP_None = 0 , SP_Parabolic_Fast = 1 , SP_Parabolic_Accurate = 2 , SP_Gauss = 3 } |
| Modes for calculating results at sub pixel accuracy. More... | |
Functions | |
| cvbbool_t | ApplyWhiteBalance (IMG Image, double GainRed, double GainGreen, double GainBlue) |
| Performs an in-place white balance on the given Image, applying the three gain factors. | |
| cvbbool_t | CalculateWhiteBalance (IMG Image, TArea Area, double &GainRed, double &GainGreen, double &GainBlue) |
| Calculate the white balance factors. | |
| cvbbool_t | CreateColorFeatureImage (IMG ImageIn, IMG &ImageOut) |
| Creates a 9-planar output image from an RGB ImageIn. | |
| cvbbool_t | CreateColorTransform (IMG ImageIn, cvbval_t OutNumPlanes, cvbbool_t WrapAroundOverflow, void *Coefficients, IMG &ImageOut) |
| Creates an n-planar output image using a linear combination of the planes of ImageIn. | |
| cvbres_t | CreateFlatfieldCorrectedImage (IMG ImageIn, IMG ImageFlat, IMG ImageDark, double Gain, IMG &ImageOut) |
| Performs a flat field correction on the given ImageIn with optional correction of the fix pattern noise. | |
| cvbbool_t | CreateInversePolarImage (IMG ImageIn, double Alpha0, double InnerRadius, IMG &ImageOut) |
| Creates an image with the inverse of the transformation performed by CreatePolarImage or CreatePolarImageEx. | |
| cvbbool_t | CreateLinearCombinationImage (IMG ImageIn, cvbbool_t WrapAroundOverflow, void *Coefficients, IMG &ImageOut) |
| Creates a monochrome output image using a linear combination of the planes of ImageIn. | |
| cvbbool_t | CreateMeanVarianceImage (IMG ImageIn, IMG &ImageMean, IMG &ImageStandardDeviation) |
| Creates a mean and a standard deviation image over all planes of ImageIn. | |
| cvbbool_t | CreateMinMaxImage (IMG ImageIn, IMG &ImageMin, IMG &ImageMax) |
| Creates a minimum and a maximum image over all planes of ImageIn. | |
| cvbbool_t | CreateNormalizedImage (IMG ImageIn, TNormalizeMode Mode, double TargetMeanMin, double TargetStandardDeviationMax, IMG &ImageOut) |
| Creates a normalized image of ImageIn. | |
| cvbbool_t | CreateOverlayFromPixelList (PIXELLIST PixelList, IMG ImageIn, IMG &ImageOut) |
| Creates a new image that has overlay bits set according to the coordinates in PixelList. | |
| cvbbool_t | CreatePixelListFromOverlay (IMG ImageIn, cvbval_t PixelListDimension, cvbval_t Left, cvbval_t Top, cvbval_t Right, cvbval_t Bottom, PIXELLIST &PixelList) |
| Creates an IPixelList from the coordinates of ImageIn pixels with set overlay bits. | |
| cvbbool_t | CreatePolarImage (IMG ImageIn, double CenterX, double CenterY, double Alpha0, double InnerRadius, double OuterRadius, IMG &ImageOut) |
| Creates a polar transformed image using linear interpolation from a full ring (360°). . | |
| cvbbool_t | CreatePolarImageEx (IMG ImageIn, double CenterX, double CenterY, double Alpha0, double AlphaTotal, double InnerRadius, double OuterRadius, IMG &ImageOut) |
| Creates a polar transformed image using linear interpolation where the ring segment can be fully specified. | |
| cvbbool_t | CreateTransformedImage (IMG ImageIn, cvbval_t Width, cvbval_t Height, TFNonlinear Transformation, void *pPrivate, IMG &ImageOut) |
| Creates an arbitrarily transformed, linear interpolated image from the given ImageIn. | |
| cvbval_t | FindMaxima (IMG Image, cvbval_t PlaneIndex, cvbval_t Left, cvbval_t Top, cvbval_t Right, cvbval_t Bottom, cvbval_t Locality, cvbval_t Threshold, PIXELLIST &MaximaList) |
| Search an image for maxima of gray values. | |
| cvbbool_t | FindMaximaEx (IMG Image, cvbval_t PlaneIndex, cvbval_t Left, cvbval_t Top, cvbval_t Right, cvbval_t Bottom, cvbval_t Locality, double Threshold, PIXELLIST &MaximaList) |
| Search an Image for local maxima of gray values without sub-pixel accuracy. | |
| cvbbool_t | FindSubPixelMaxima (IMG Image, cvbdim_t PlaneIndex, cvbdim_t Left, cvbdim_t Top, cvbdim_t Right, cvbdim_t Bottom, cvbdim_t Locality, double Threshold, TSubPixelMode SubPixelMode, cvbdim_t Radius, PIXELLIST &MaximaList) |
| Search an Image for local maxima of gray values with optional sub-pixel accuracy. | |
| cvbbool_t | ImageHistogram (IMG Image, cvbval_t PlaneIndex, cvbdensity_t Density, TArea Area, THistogram &Histogram) |
| Calculates the histogram of the 8 bit per plane Image plane at PlaneIndex. | |
| cvbbool_t | InversePolarTransform (IMG ImageIn, double CenterX, double CenterY, double Alpha0, double InnerRadius, IMG ImageOut) |
| Calculates the inverse of the transformation performed by CreatePolarImage or CreatePolarImageEx. | |
| cvbval_t | ScanImageBinary (IMG Image1, IMG Image2, TArea Area, cvbdensity_t Density, cvbval_t ShiftX, cvbval_t ShiftY, cvbbool_t UseCS, TFPixelBinary FPixel, TFLine FStartLine, TFLine FEndLine, void *pPrivate) |
| Scans the Area in all planes of the given Image1 and Image2. | |
| cvbval_t | ScanImageUnary (IMG Image, TArea Area, cvbdensity_t Density, cvbbool_t UseCS, TFPixelUnary FPixel, TFLine FStartLine, TFLine FEndLine, void *pPrivate) |
| Scans the Area in all planes of the Image. | |
| cvbval_t | ScanPlaneBinary (IMG Image1, IMG Image2, cvbval_t PlaneIndex1, cvbval_t PlaneIndex2, TArea Area, cvbdensity_t Density, cvbval_t ShiftX, cvbval_t ShiftY, cvbbool_t UseCS, TFPixelBinary FPixel, TFLine FStartLine, TFLine FEndLine, void *pPrivate) |
| Scans the Area in single planes of the given Image1 and Image2. | |
| cvbval_t | ScanPlaneUnary (IMG Image, cvbval_t PlaneIndex, TArea Area, cvbdensity_t Density, cvbbool_t UseCS, TFPixelUnary FPixel, TFLine FStartLine, TFLine FEndLine, void *pPrivate) |
| Scans the Area in a single plane with PlaneIndex of the Image. | |
| typedef cvbbool_t(* TFLine) (void *pPrivate, cvbval_t LinesToDo) |
This callback function type is used to indicate a new line or the end of a line depending on its registration in the calling function.
| [in] | pPrivate | Pointer to user data given in via the calling function; e.g. pointer to object. |
| [in] | LinesToDo | Number of lines left to scan. |
| typedef void(* TFNonlinear) (void *pPrivate, double &X, double &Y) |
| [in] | pPrivate | Private data pointer that was given to the calling function (e.g. CreateTransformedImage). |
| [in,out] | X | Input is the X component of the pixel coordinate to be transformed; write the transformed value back on this one (overwrite). |
| [in,out] | Y | Input is the Y component of the pixel coordinate to be transformed; write the transformed value back on this one (overwrite). |
| typedef cvbbool_t(* TFPixelBinary) (void *pPrivate, void *pPixel1, void *pPixel2, cvbdim_t X, cvbdim_t Y) |
This callback function type is used by the scan functions ScanImageBinary and ScanPlaneBinary. This function pointer is called for each pixel in the selected TArea.
| [in] | pPrivate | Pointer to user data given in via ScanPlaneUnary or ScanImageUnary; e.g. pointer to object. |
| [in] | pPixel1 | Pointer to the current pixel at (X, Y) in Image1. The actual layout of the data depends on the calling function. |
| [in] | pPixel2 | Pointer to the current pixel at (X, Y) in Image2. The actual layout of the data depends on the calling function. |
| [in] | X | Current x coordinate in pixel coordinates. |
| [in] | Y | Current y coordinate in pixel coordinates. |
| typedef cvbbool_t(* TFPixelUnary) (void *pPrivate, void *pPixel, cvbdim_t X, cvbdim_t Y) |
This callback function type is used by the scan functions ScanPlaneUnary and ScanImageUnary. This function pointer is called for each pixel in the selected TArea.
| [in] | pPixel | Pointer to the current pixel at (X, Y). The actual layout of the data depends on the calling function. |
| typedef cvbbool_t(* TFProgress) (void *pPrivate, cvbval_t StepsTotal, cvbval_t StepsDone) |
The feedback provided by this function can e.g. be used to display a progress indicator during a lengthy operation.
| [in] | pPrivate | Private data pointer given to the calling function. |
| [in] | StepsTotal | Total number of steps that are going to be performed in the lengthy operation. |
| [in] | StepsDone | Number of steps that have already been performed. |
| typedef cvbval_t THistogram[256] |
This array stores 256 values in the range [0 .. 255]. Every index in this array refers to a gray value. The value in the histogram at that location (index) is the count of that gray value in the inspected AOI.
| enum TNormalizeMode |
| enum TSubPixelMode |
| Enumerator | |
| SP_Parabolic_Fast | Approximates a paraboloid. Fastest, but least accurate sub pixel mode. The shape of the extremum is assumed to be parabolic. The fit in this case is a linear fit, providing a slightly lower accuracy than a full-fledged least-squares fit. For most applications this mode is a reasonable trade-off, because typically the deviation of the local maxima from the actual parabolic shape causes more significant errors in the measurement than the difference between the linear fit and the least squares fit. |
| SP_Parabolic_Accurate | Best fit paraboloid approximation. Reasonably fast and accurate sub pixel mode. Performs a full least-squares fit of the extremum to a parabolic shape (in contrast to the linear fit in SP_Parabolic_Fast). This is an approximation of a Gaussian distribution SP_Gauss. |
| SP_Gauss | Gaussian distribution fit. Slowest, but most accurate sub pixel mode. Performs a least-squares fit of the extremum to a Gaussian intensity distribution. |
| cvbbool_t ApplyWhiteBalance | ( | IMG | Image, |
| double | GainRed, | ||
| double | GainGreen, | ||
| double | GainBlue ) |
Gray values exceeding the cvbdatatype_t dynamic range will be truncated.
The following BytesPerPixel for signed and unsigned integer cvbdatatype_t values are supported: 1, 2, 4, and 8. For floating point cvbdatatype_t values only 4 and 8 BytesPerPixel are supported.
| [in] | Image | Image object handle on which to perform the white balance operation. |
| [in] | GainRed | Gain for the red channel. |
| [in] | GainGreen | Gain for the green channel. |
| [in] | GainBlue | Gain for the blue channel. |
| cvbbool_t CalculateWhiteBalance | ( | IMG | Image, |
| TArea | Area, | ||
| double & | GainRed, | ||
| double & | GainGreen, | ||
| double & | GainBlue ) |
| [in] | Image | Image object handle from which to calculate the gain factors. |
| [in] | Area | aoi in which to calculate the gain factors; the aoi is assumed to contain a portion of the image, that should be of neutral color, not saturated to white or black |
| [out] | GainRed | gain factor for the red channel |
| [out] | GainGreen | gain factor for the green channel |
| [out] | GainBlue | gain factor for the blue channel |
This function does the same as MantoColourTransform, a function that was originally published in the Manto.dll. It requires an image with 3 planes (R, G, B) as input and produces a result image with 9 planes (R, G, B, RG, RB, GB, R², G², B²).
| [in] | ImageIn | Image object handle of the source image. |
| [in] | ImageOut | Variable to receive the handle of the output image. |
| cvbbool_t CreateColorTransform | ( | IMG | ImageIn, |
| cvbval_t | OutNumPlanes, | ||
| cvbbool_t | WrapAroundOverflow, | ||
| void * | Coefficients, | ||
| IMG & | ImageOut ) |
The arrangement of the Coefficients array is complex:
Therefore, assume that the ImageIn has m planes and the ImageOut n planes. The coefficient array needs (m + 1) * n elements. These elements are:
For each pixel the following calculation is done using the coefficients for the output planes as described above:
| [in] | OutNumPlanes | Number of planes in the output image. |
| [in] | WrapAroundOverflow | true for wrap around at the upper/lower limit of the cvbdatatype_t range; false for truncation. |
| [in] | Coefficients | double array as described above. |
| [out] | ImageOut | Variable to receive the output image handle. |
| cvbres_t CreateFlatfieldCorrectedImage | ( | IMG | ImageIn, |
| IMG | ImageFlat, | ||
| IMG | ImageDark, | ||
| double | Gain, | ||
To use this function, create a background image where the pixels' gray values span a range of roughly 50% to 75% of available dynamic range (fox example 128 to 192 in the case of 8Bit images). Optionally also take a dark image (e.g. by putting a lens cap on).
The flat field correction is being calculated using the formula:
ImageOut = (ImageIn - ImageDark) / (ImageFlat - ImageDark) * Gain
If no ImageDark was specified (nullptr) the calculation shortens to:
ImageOut = ImageIn / ImageFlat * Gain
| [in] | ImageIn | The input image handle. |
| [in] | ImageFlat | The flat image showing the background. |
| [in] | ImageDark | Optional dark image; nullptr for none. |
| Gain | A gain value that may be used to adjust the brightness of ImageOut. Usually roughly the average gray value of ImageIn is used. | |
| [out] | ImageOut | Variable to receive the handle of the resulting image. |
| cvbbool_t CreateInversePolarImage | ( | IMG | ImageIn, |
| double | Alpha0, | ||
| double | InnerRadius, | ||
This function transforms the content of a rectangular image into a ring or ring segment. For a detailed explanation on Alpha0 and InnerRadius see the documentation of CreatePolarImageEx.
The ring (segment) will be centered in the resulting ImageOut, which is created via CreateCompatibleImage. The resulting width and height are twice the OuterRadius that is calculated as follows:
OuterRadius = ImageHeight (ImageIn) - 1 + InnerRadius The background of the image's planes are initialized with the cvbdatatype_t dependent default value: GetDatatypeMinMaxVal (ImageDatatype (ImageIn, plane), max, min): (max - min) / 2
Angles are measured clockwise and an angle of 0° describes a line segment in direction of the positive x-axis.
| [in] | ImageIn | Image object handle containing the data to be transformed. |
| [in] | Alpha0 | Start angle in degrees for ImageOut. |
| [in] | InnerRadius | Inner radius in pixels for ImageOut. |
| [out] | ImageOut | Variable to receive the handle of the result image. |
| cvbbool_t CreateLinearCombinationImage | ( | IMG | ImageIn, |
The number of elements in Coefficients must be ImageDimension (ImageIn) + 1, where the last element is an offset and the elements before it are the factors for the planes. For each pixel the following calculation is done:
The method is a shorthand for:
| [in] | Coefficients | double array with weight coefficients and an offset as the last element. |
ImageMean is a single-plane image that will contain the mean value over all planes in ImageIn at their respective coordinate. The same is true for ImageStandardDeviation which contains the standard deviation respectively.
| [out] | ImageMean | Variable to receive the handle of the mean image object. |
| [out] | ImageStandardDeviation | Variable to receive the handle of the standard deviation image object. |
ImageMin is a single-plane image that will contain the minimum value over all planes in ImageIn at their respective coordinate. The same is true for ImageMax which contains the maximum value respectively.
| [out] | ImageMin | Variable to receive the handle of the minimum image object. |
| [out] | ImageMax | Variable to receive the handle of the maximum image object. |
| cvbbool_t CreateNormalizedImage | ( | IMG | ImageIn, |
| TNormalizeMode | Mode, | ||
| double | TargetMeanMin, | ||
| double | TargetStandardDeviationMax, | ||
With the Mode parameter two possible procedures can be selected:
| [in] | Mode | Normalize_MinMax or Normalize_MeanVariance (standard deviation). |
| [in] | TargetMeanMin | Either target mean or min depending on Mode. |
| [in] | TargetStandardDeviationMax | Either target standard deviation or max depending on Mode. |
First ImageOut is created via CreateCompatibleImage with forced overlay bit (DT_Overlay). If ImageIn is overlay capable the overlays bits are copied with the pixel data to ImageOut; if not the overlay bits are reset to 0 while copying.
Then for each Pixel coordinate (x and y) in the PixelList, the overlay bit of the corresponding image pixel will be set. If a Pixel from the PixelList lies outside the ImageIn boundaries, it will be ignored.
| [in] | PixelList | Pixel list handle of object that contains the overlay coordinate information. F |
| [in] | ImageIn | Input image handle of object providing the source pixel data. |
| [out] | ImageOut | Variable to receive the image handle that is the resulting IImageVPA with DT_Overlay |
| cvbbool_t CreatePixelListFromOverlay | ( | IMG | ImageIn, |
| cvbval_t | PixelListDimension, | ||
| cvbval_t | Left, | ||
| cvbval_t | Top, | ||
| cvbval_t | Right, | ||
| cvbval_t | Bottom, | ||
| PIXELLIST & | PixelList ) |
For each pixel in the given region (Left, Top, Right, Bottom) in ImageIn with the overlay bit being set (DT_Overlay), a Pixel is added to the newly created PixelList. Each new Pixel has the x and y Component set accordingly. Any additional PixelList __Component__s are set to 0.
| [in] | ImageIn | Image handle of overlay capable image object to analyze. |
| [in] | PixelListDimension | Number of __Component__s for the PixelList to be created. Range is [2 .. 256]. |
| [in] | Left | Left edge of the AOI in pixel coordinates. |
| [in] | Top | Top edge of the AOI in pixel coordinates. |
| [in] | Right | Right edge of the AOI in pixel coordinates (inclusive). |
| [in] | Bottom | Bottom edge of the AOI in pixel coordinates (inclusive). |
| [out] | PixelList | Variable to receive the resulting IPixelList handle. |
| cvbbool_t CreatePolarImage | ( | IMG | ImageIn, |
| double | CenterX, | ||
| double | CenterY, | ||
| double | OuterRadius, | ||
This is a shorthand for CreatePolarImageEx with AlphaTotal = 360°:
| [in] | ImageIn | Image object handle of the image to be transformed. |
| [in] | CenterX | Positive X coordinate of transformation center. |
| [in] | CenterY | Positive Y coordinate of transformation center. |
| [in] | Alpha0 | Angle in degrees where to start the polar transformation. |
| [in] | InnerRadius | Inner radius in pixels for transformation. |
| [in] | OuterRadius | Outer radius in pixels for transformation. |
| [out] | ImageOut | Variable to receive the handle to the transformed image object. |
| cvbbool_t CreatePolarImageEx | ( | IMG | ImageIn, |
| double | AlphaTotal, | ||
In the image above (300×300) the parameters are roughly as follows:
| CenterX, CenterY | 150,150 | (yellow point) | ||
| Alpha0 | 100° | (line that ends with green point) | ||
| AlphaTotal | 185° | (line that ends with red point) | ||
| InnerRadius | 80 | (line segment from yellow to white point) | ||
| OuterRadius | 120 | (line segment from yellow to green or red point) |
Angles are measured clockwise and an angle of 0° describes a line segment in direction of the positive x-axis. The AlphaTotal defines the length of the ring segment. Thus the line segment that ends with the red point has the absolute angle of Alpha0 + AlphaTotal.
The resulting dimensions of ImageOut, which is created via CreateCompatibleImage, are calculated as follows:
(OuterRadius and InnerRadius are inclusive)
| [in] | CenterX | Positive X component of pixel coordinate of transformation center. |
| [in] | CenterY | Positive Y component of pixel coordinate of transformation center. |
| [in] | AlphaTotal | Positive, non-0 total radial angle in degrees. |
| cvbbool_t CreateTransformedImage | ( | IMG | ImageIn, |
| cvbval_t | Width, | ||
| cvbval_t | Height, | ||
| TFNonlinear | Transformation, | ||
| void * | pPrivate, | ||
This function creates a new image via CreateCompatibleImage with the given Width and Height. The Transformation callback function is used for transforming each pixel coordinate.
| [in] | Width | Width of the target image to be created. |
| [in] | Height | Height of the target image to be created. |
| [in] | Transformation | Callback for coordinate transformation. |
| [in] | pPrivate | Pointer to user data, e.g. object pointer, passed in each call to Transformation. |
| [out] | ImageOut | Variable to receive the handle to the result image. |
| cvbval_t FindMaxima | ( | IMG | Image, |
| cvbval_t | PlaneIndex, | ||
| cvbval_t | Locality, | ||
| cvbval_t | Threshold, | ||
| PIXELLIST & | MaximaList ) |
A local maximum is defined as the brightest pixels above a Threshold and surrounded by pixels of lower intensity. No two local maxima are allowed to be closer to each other than defined by the parameter Locality.
The following BytesPerPixel for signed and unsigned integer cvbdatatype_t values are supported: 1, 2. Additionally signed 4 BytesPerPixel is supported.
| [in] | Image | Handle of the image object to be searched in for local maxima. |
| [in] | PlaneIndex | Plane of source Image to search in. |
| [in] | Right | Right edge (inclusive) of the AOI in pixel coordinates. |
| [in] | Bottom | Bottom edge (inclusive) of the AOI in pixel coordinates. |
| [in] | Locality | Positive minimum L1 distance in pixels between two neighboring maxima. |
| [in] | Threshold | Minimum gray value for a local maximum to be considered. |
| [out] | MaximaList | Variable to receive the IPixelList containing all maxima points (x, y, gray value). |
| cvbbool_t FindMaximaEx | ( | IMG | Image, |
| double | Threshold, | ||
This is an alias for FindSubPixelMaxima with:
| [in] | Threshold | Minimum gray value for a local maximum to be considered. Note that the minimal possible value for the image's pixel type is never eligible to be a local maximum (e.g. if the image uses 8 bits per pixel unsigned, pixels with value 0 will never be a local maximum even if the threshold has been set to 0. |
| cvbbool_t FindSubPixelMaxima | ( | IMG | Image, |
| cvbdim_t | PlaneIndex, | ||
| cvbdim_t | Left, | ||
| cvbdim_t | Top, | ||
| cvbdim_t | Right, | ||
| cvbdim_t | Bottom, | ||
| cvbdim_t | Locality, | ||
| TSubPixelMode | SubPixelMode, | ||
| cvbdim_t | Radius, | ||
The local maxima are being searched for at pixel accuracy. Then an optional step can be applied, that generates sub-pixel accurate results by fitting a selectable model to the gray values within the specified Radius (see TSubPixelMode). The Radius is only used with SP_Parabolic_Accurate and SP_Gauss. For SP_Parabolic_Fast the Radius is always 1 (8-connected).
The result reported by this function will have a bias of the order of 0.5 to 1.0 pixels towards the border of the Image and away from the real location of the maximum.
This is an artifact that stems from the fact that the images in Common Vision Blox are internally extended beyond their border by up to four pixels in order to accommodate filter operations with larger filter masks. This extension is implemented by repeating the outermost pixel rows and columns, leading to a notable deviation of a maximum that lies right on the border from its assumed parabolic or Gaussian shape.
In a real-world application, the accuracy that can be reached by using a parabolic or Gaussian fit will be limited to no less than roughly 0.005 pixels.
This is not an artifact of the calculation that is being carried out, but rather the result of a difference between the model applied and the reality - if the sub pixel calculations are being carried out on an artificial image where the gray value distribution perfectly matches the assumed model (Gaussian or parabolic) then the sub pixel measurement results will - within the limits of numerical accuracy - perfectly fit the parameters used during generation of the gray value distribution.
| [in] | SubPixelMode | Model/mode with which to determine the sub pixel accurate position of the local maxima. |
| [in] | Radius | Defines the L1 norm radius over which the sub pixel fit of the local maxima should be performed (used only for SP_Parabolic_Accurate and SP_Gauss). Valid values are in the range [0 .. 4] (0 forces SubPixelMode SP_None). |
| cvbbool_t ImageHistogram | ( | IMG | Image, |
| cvbdensity_t | Density, | ||
| TArea | Area, | ||
| THistogram & | Histogram ) |
The histogram is the representation of the distribution of the pixel values in the given Area of the plane identified by PlaneIndex in the given Image. For 8 bit per plane there a 256 possible bins (one for each possible pixel value [0 .. 255]). Each bin contains the count of the respective pixel value in the whole Area. Thus the index 0 in Histogram will contain the number of all pure black pixels in the Area.
| [in] | Image | Image object handle of the source image. |
| [in] | PlaneIndex | Image plane index for which the histogram is to be calculated. |
| [in] | Density | Processing density from 1 to 1000, where 1000 means all pixels (100%). |
| [in] | Area | Area of interest in image coordinates for which the histogram is calculated. |
| [out] | Histogram | Array to be filled with the histogram data. |
| cvbbool_t InversePolarTransform | ( | IMG | ImageIn, |
| IMG | ImageOut ) |
The ring (segment) will be centered around (CenterX, CenterY) in the ImageOut, which has to have the same cvbdatatype_t as ImageIn. The resulting width and height of the ring are twice the OuterRadius that is calculated as follows:
OuterRadius = ImageHeight (ImageIn) - 1 + InnerRadius Regions outside the ring (segment) are not affected.
| [in] | ImageOut | Image object to which the transformation is written. |
| cvbval_t ScanImageBinary | ( | IMG | Image1, |
| IMG | Image2, | ||
| TArea | Area, | ||
| cvbval_t | ShiftX, | ||
| cvbval_t | ShiftY, | ||
| cvbbool_t | UseCS, | ||
| TFPixelBinary | FPixel, | ||
| TFLine | FStartLine, | ||
| TFLine | FEndLine, | ||
| void * | pPrivate ) |
For each pixel (FPixel), each beginning of a line (FStartLine) and each end of a line (FEndLine), the respective callback function is called. The scanning is limited to the Area and Density. If any callback function returns false, the processing is aborted. The function then reports the number of processed pixels until the abort.
This function supports any cvbdatatype_t as only the pointers to the pixels are given in the FPixel callback. As this function works on all planes, the pPixel1 and pPixel2 parameters of the FPixel callback function will point to the first element in a pointer array with the length of ImageDimension (Image) + 1. The first element is the pointer to the pixelin plane 0, the second is the pointer to the pixel in plane 1, and so on. The last entry is a nullptr to terminate the array.
| [in] | Image1 | Image object handle of the first image. |
| [in] | Image2 | Image object handle of the second image. |
| [in] | Area | Area of interest to be scanned. |
| [in] | ShiftX | Horizontal shift in pixels between the two source images. |
| [in] | ShiftY | Vertical shift in pixels between the two source images |
| [in] | UseCS | true, if the coordinate system is used and the Area should be transformed; false otherwise. |
| [in] | FPixel | Optional callback to process each pixel that lies within the Area and matches the selected Density. |
| [in] | FStartLine | Optional callback to signal each beginning of a new line. |
| [in] | FEndLine | Optional callback to signal each end of a line. |
| [in] | pPrivate | Pointer to user data like an object pointer. This pointer is passed to all callbacks. |
| cvbval_t ScanImageUnary | ( | IMG | Image, |
| TArea | Area, | ||
| TFPixelUnary | FPixel, | ||
This function supports any cvbdatatype_t as only the pointers to the pixels are given in the FPixel callback. As this function works on all planes, the pPixel parameter of the FPixel callback function will point to the first element in a pointer array with the length of ImageDimension (Image) + 1. The first element is the pointer to the pixel in plane 0, the second is the pointer to the pixel in plane 1, and so on. The last entry is a nullptr to terminate the array.
| cvbval_t ScanPlaneBinary | ( | IMG | Image1, |
| IMG | Image2, | ||
| cvbval_t | PlaneIndex1, | ||
| cvbval_t | PlaneIndex2, | ||
| TArea | Area, | ||
This function supports any cvbdatatype_t as only the pointers to the pixels are given in the FPixel callback. As this function only works on one plane respectively, the pPixel1 and pPixel2 parameters of the FPixel callback function will only point to one element.
| [in] | PlaneIndex1 | Index of Image1 object's plane. |
| [in] | PlaneIndex2 | Index of Image2 object's plane. |
| cvbval_t ScanPlaneUnary | ( | IMG | Image, |
| TArea | Area, | ||
This function supports any cvbdatatype_t as only the pointer to the pixel is given in the FPixel callback. As this function only works on one plane, the pPixel parameter of the FPixel callback function will only point to this one element.
| [in] | PlaneIndex | Index of plane to be scanned. |
