CVBpy 15.0
LineScanCalibrationConfiguration Class Reference
A set of parameters, which is used to configure linescan calibration calculated with function cvb.foundation.create_line_scan_calibration. More...
Public Member Functions
None LineScanCalibrationConfiguration (self, int max_iterations=50, float poly_degree=3, float tolerance=1e-6, int scan_direction=cvb.ScanDirection.Y, int pre_defined_pixel_size_mode=cvb.PreDefinedPixelSizeMode.DoNotUse, float pixel_size=1)
 Default linescan calibration configuration.
Properties
 max_iterations = property
 int: The number of maximal iterations for all non linear solvers in the calibration algorithm.
 pixel_size = property
 float: The pixel size of transformed image.
 poly_degree = property
 int: A positive (or zero) integer value that defines the polynomial to be used.
 pre_defined_pixel_size_mode = property
 int: The decision if it uses predefined pixel size (see cvb.foundation.PreDefinedPixelSizeMode).
 scan_direction = property
 int: The scanning direction of camera (see cvb.foundation.ScanDirection).
 tolerance = property
 float: The value for early stopping criteria.
Constructor & Destructor Documentation
◆ LineScanCalibrationConfiguration()
None LineScanCalibrationConfiguration ( self,
int max_iterations = 50,
float poly_degree = 3,
float tolerance = 1e-6,
int scan_direction = cvb.ScanDirection.Y,
int pre_defined_pixel_size_mode = cvb.PreDefinedPixelSizeMode.DoNotUse,
float pixel_size = 1 )
max_iterations : int Number of maximal iterations for all nonlinear solvers in the calibration algorithm.
poly_degree : float A positive (or zero) integer value that defines the polynomial to be used. Note, that currently only a polynomial of degree 3 is supported.
tolerance : float Value for early stopping criteria.
scan_direction : int Scanning direction of camera (see cvb.foundation.ScanDirection).
pre_defined_pixel_size_mode : int Decision if predefined pixel size needs to be used (see cvb.foundation.PreDefinedPixelSizeMode).
pixel_size : float Pixel size of transformed image.
Property Documentation
◆ pixel_size
static
This value will only be considered, if LineScanCalibrationConfiguration.pre_defined_pixel_size_mode is set to cvb.foundation.PreDefinedPixelSizeMode.Use. The pixel size of the transformed image will be equal to this value. The pixel_size must have the same units as reference_distance_calibration_points and reference_width_stripes specified in cvb.foundation.create_line_scan_calibration.
◆ poly_degree
static
◆ pre_defined_pixel_size_mode
static
If this value is set to cvb.foundation.PreDefinedPixelSizeMode.Use, the transformed image will have a fixed pixel size. The desired pixel size has to be set via LineScanCalibrationConfiguration.pixel_size.
