Factory object for holdout tests. More...
Inherits TestResultFactory.
Public Member Functions | |
| None | HoldoutTestResultFactory (self) |
| Instantiates a HoldoutTestResultFactory object. | |
Properties | |
| feature_resolution = property | |
| int: The feature resolution (determines the size of the classification retina). | |
| interpolation = property | |
| int: Interpolation setting to be used for generating this object (see cvb.polimago.InterpolationType). | |
| lambda_ = property | |
| float: The regularization value to be used for generating the object. | |
| preprocessing = property | |
| str: Preprocessing code with which the object is to be generated. | |
static |
Using interpolation will generate less artifacts, but requires more processor time.
static |
Possible values range from 0 to 10, good starting values for experiments are usually around 0.01.
