CVBpy 14.0
All Classes Namespaces Functions Variables Properties Pages
HoldoutTestResultFactory Class Reference
Factory object for holdout tests. More...
Inherits TestResultFactory.
Properties
 feature_resolution = property
 int: The feature resolution (determines the size of the classification retina).
 interpolation = property
 int: Interpolation setting to be used for generating this object (see cvb.polimago.InterpolationType). More...
 lambda_ = property
 float: The regularization value to be used for generating the object. More...
 preprocessing = property
 str: Preprocessing code with which the object is to be generated.
Instantiates a HoldoutTestResultFactory object.
Property Documentation
◆ interpolation
static
Using interpolation will generate less artifacts, but requires more processor time.
◆ lambda_
lambda_ = property
static
Possible values range from 0 to 10, good starting values for experiments are usually around 0.01.
