A set of parameters, which is used to configure linescan calibration calculated with function cvb.foundation.create_line_scan_calibration. More...
Public Member Functions | |
| None | LineScanCalibrationConfiguration (self, int max_iterations=50, float poly_degree=3, float tolerance=1e-6, int scan_direction=cvb.ScanDirection.Y, int pre_defined_pixel_size_mode=cvb.PreDefinedPixelSizeMode.DoNotUse, float pixel_size=1) |
| Default linescan calibration configuration. | |
Properties | |
| max_iterations = property | |
| int: The number of maximal iterations for all non linear solvers in the calibration algorithm. | |
| pixel_size = property | |
| float: The pixel size of transformed image. | |
| poly_degree = property | |
| int: A positive (or zero) integer value that defines the polynomial to be used. | |
| pre_defined_pixel_size_mode = property | |
| int: The decision if it uses predefined pixel size (see cvb.foundation.PreDefinedPixelSizeMode). | |
| scan_direction = property | |
| int: The scanning direction of camera (see cvb.foundation.ScanDirection). | |
| tolerance = property | |
| float: The value for early stopping criteria. | |
| None LineScanCalibrationConfiguration | ( | self, | |
| int | max_iterations = 50, | ||
| float | poly_degree = 3, | ||
| float | tolerance = 1e-6, | ||
| int | scan_direction = cvb.ScanDirection.Y, | ||
| int | pre_defined_pixel_size_mode = cvb.PreDefinedPixelSizeMode.DoNotUse, | ||
| float | pixel_size = 1 ) |
max_iterations : int Number of maximal iterations for all nonlinear solvers in the calibration algorithm.
poly_degree : float A positive (or zero) integer value that defines the polynomial to be used. Note, that currently only a polynomial of degree 3 is supported.
tolerance : float Value for early stopping criteria.
scan_direction : int Scanning direction of camera (see cvb.foundation.ScanDirection).
pre_defined_pixel_size_mode : int Decision if predefined pixel size needs to be used (see cvb.foundation.PreDefinedPixelSizeMode).
pixel_size : float Pixel size of transformed image.
static |
This value will only be considered, if LineScanCalibrationConfiguration.pre_defined_pixel_size_mode is set to cvb.foundation.PreDefinedPixelSizeMode.Use. The pixel size of the transformed image will be equal to this value. The pixel_size must have the same units as reference_distance_calibration_points and reference_width_stripes specified in cvb.foundation.create_line_scan_calibration.
static |
static |
If this value is set to cvb.foundation.PreDefinedPixelSizeMode.Use, the transformed image will have a fixed pixel size. The desired pixel size has to be set via LineScanCalibrationConfiguration.pixel_size.
