Foundation (CVFoundation.dll) 15.0
CVFAlignmentConfiguration Struct Reference
Data Fields
double Correspondence
 Minimum value for correspondence of two points to be considered for alignment.
size_t MaxIterations
 Maximum iterations of ICP.
double MinImprovement
 Value for early stopping criteria.
bool Prealign
 If true the target will be prealigned by moving it to the mean of the source set as a first alignment step.
double Tolerance
Struct to configure alignment.
Field Documentation
◆ MinImprovement
If the norm of alignment changes less than this value, the alignment is considered converged.
◆ Tolerance
double Tolerance
If the norm of alignment falls below this value, the alignment is considered successfull.
