On this page you will find alle CVB libraries and applications. Several CVB libraries and applications are part of the CameraSuite/ImageManager license. If they are not, they will be marked in the tables as follows:
* Needs a foundation license.
** Needs a tool license.
Detailed information about the licensing can be found here.
| ImageManager | Basic library for - Image acquistion - Image handling - Point cloud handling (3D) |
| GenICamBrowser | Easy to use application to detect devices in the network and to get a live view without programming. | |
| Edit Bindings | Console application to detect and edit bindings between GenApi xml file and device. |
| GevServer** | Library with functions presenting any CVB image source as a GigE Vision camera. | |
| Movie** | Streaming CVB images into a standard AVI file. |
| Webstreaming** | Library for image conversion/compression and image transport. |
| Foundation* | Collection of optimised image processing functions. |
| Arithmetic* | Appling arithmetic and logical operators to images. |
| BayerToRGB* | Bayer to RGB conversion. | |
| Edge* | Detecting edges within an image. |
| LightMeter* | Generating histograms of intensity values and statistical measures. |
| Polarization* | Handling raw images from polarisation area and linescan cameras with polarization mosaic patterns. |
| TextOut* | Adding text to CVB images. | |
| Barcode** | Decoding one- and two-dimensional barcodes. |
| Blob** | Blob analysis. |
| Minos** | Pattern recognition, alignment and optical character recognition (OCR). |
| Polimago** SIL - Sample Image List** | Pattern classification, function estimation and image search. |
| Shape Finder** | Search tool to find previously trained objects in newly acquired images. |
| TeachBench** | Training utility for various pattern recognition algorithms (Minos, Polimago). |
| Metric* | Calibration of laser triangulation systems. |
| Match3D** | - 3D Matching of two point clouds (Match3D-ICP). |
| TeachBench** | Training utility for various pattern recognition algorithms (Matrch3D-DNC). |
| Spectral** | Basic handling of hyperspectral images and color conversion. |
| LogGUI | Tool to collect and show diagnostic data from all CVB modules. |
| License Manager | Tool to manage your CVB license. |
A list of all available activeX controls can be found here.
