A wrapped image wraps another pixel buffer without owning it. More...
Inherits Image.
Public Member Functions | |
| cvb.WrappedImage | from_buffer (Any buffer, int layout=cvb.BufferLayout.HeightWidthPlane) |
| Wraps, without copying, the given python buffer in an image. More... | |
Public Member Functions inherited from Image | |
| None | Image (self, *Any args, **Any kwargs) |
| Supports the same arguments as cvb.Image.create or cvb.Image.load. More... | |
| cvb.Image | clone (self) |
| Creates a new image object, that is a copy of the current instance. More... | |
| None | copy (self, cvb.Image target_image, Optional[cvb.Rect] source_rect, Optional[cvb.Point2D] target_position) |
| Copies the image data from the source rectangle of this image to the target position inside the target image. More... | |
| cvb.Image | create (int width, int height, Optional[int] num_planes, Optional[cvb.DataType] data_type) |
| Creates an uninitialized image with the given parameters. More... | |
| cvb.Image | create (cvb.Size2D size, Optional[int] num_planes, Optional[cvb.DataType] data_type) |
| cvb.Image | from_images (int mapping, List[cvb.Image] images) |
| Create an image that is the result of concatenating a series of input images. More... | |
| cvb.Image | from_pixel_format (cvb.Size2D size, int format) |
| cvb.Image | from_pixel_format (int width, int height, int format) |
| cvb.Image | from_planes (int mapping, List[cvb.ImagePlane] planes) |
| Create an image that is the result of concatenating a series of input planes. More... | |
| List[float] | get_pixel (self, cvb.Point2D position) |
| Gets the pixel values for all planes at a give position (as float list). More... | |
| cvb.Point2D | image_to_pixel_coordinates (self, cvb.Point2D point) |
| Convert a point from image to pixel coordinates. More... | |
| cvb.Area2D | image_to_pixel_coordinates (self, cvb.Area2D area) |
| Convert an area from image to pixel coordinates. More... | |
| cvb.Image | load (str file_name) |
| Loads an image with the given file name. More... | |
| cvb.Image | map (self, cvb.Rect source_rect, Optional[cvb.Size2D] target_size) |
| Creates a mapped image of the region of that image scaled to the size. More... | |
| cvb.Image | map_rotated (self, int rotation) |
| Creates a mapped image of this whole image rotated by the given rotation. More... | |
| cvb.Point2D | pixel_to_image_coordinates (self, cvb.Point2D point) |
| Convert a point from pixel to image coordinates. More... | |
| cvb.Point2D | pixel_to_image_coordinates (self, cvb.Point2D area) |
| Convert an area from pixel to image coordinates. More... | |
| None | raise_pixel_content_changed (self, cvb.Rect rect) |
| Inform clients listening to the pixel content changed event, that the image data has been updated in the given rectangle. More... | |
| cvb.EventCookie | register_event_pixel_content_changed (self, Callable[[cvb.Image, cvb.Rect], None] handler) |
| Register a listener to the pixel content changed event. More... | |
| None | save (self) |
| Write the current content of the image into a file. More... | |
| None | save (self, str file_name, float quality) |
| Write the current content of the image into a file with the given quality. More... | |
| None | unregister_event_pixel_content_changed (self, cvb.EventCookie event_cookie) |
| Manually unregister a listener from the pixel content changed event. More... | |
Additional Inherited Members | |
Properties inherited from Image | |
| bounds = property | |
| cvb.Rect: Bounding rectangle of the image in pixels. | |
| color_model = property | |
| int: Color model realized by this image (see cvb.ColorModel). | |
| coordinate_system = property | |
| cvb.AffineMatrix2D: Gets or sets the coordinate system of the image. | |
| height = property | |
| int: Height of the image in pixels. | |
| plane_data_types_identical = property | |
| bool: Check if all planes have the same data type. | |
| planes = property | |
| List[cvb.ImagePlane]: Access all planes for this image. | |
| size = property | |
| cvb.Size2D: Size of the image in pixels. | |
| width = property | |
| int: Width of the image in pixels. | |
This class is not intended for general use. Providing invalid values or not ensuring the validity of the associated buffer at all times will most likely lead to severe problems in your application.
| cvb.WrappedImage from_buffer | ( | Any | buffer, |
| int | layout = cvb.BufferLayout.HeightWidthPlane |
You need to take care of the buffers lifetime!
buffer : Any Python buffer that supports the buffer protocol.
layout : int The buffer layout (see cvb.BufferLayout).
cvb.WrappedImage The created image.
