CVBpy 14.1
All Classes Namespaces Functions Variables Enumerations Enumerator Properties Modules Pages
ReadResultCode39Code93 Class Reference
Derived from ReadResult and gives specific access to Code39 and Code93 results. More...
Inherits ReadResult1D.
Properties
 full_ascii = property
 bool: Specifies the use of a full ASCII description of the code, only used with the Code 39 and the Code 93.
- Properties inherited from ReadResult1D
 grade_result = property
 cvb.barcode.GradeResult1D: Barcode Read Result does not contain any valid grading results.
 characters_read = property
 int: The return value contains the number of characters in the read barcode.
 decode_time = property
 int: The return value specifies the time consumed for decoding in units of ms.
 location = property
 List[cvb.Point2D]: Location of the barcode inside the image.
 num_words = property
 int: Contains the number of code words composing the read barcode.
 resolution = property
 float: The resolution specifies the smallest width unit in the code in multiples of a 10th of a pixel.
 result = property
 int: Result of a read operation (note that read operations may partly succeed, which is not considered an error; see cvb.barcode.DecodeResult).
 text = property
 str: The text content of the barcode.
 type = property
 int: Symbology of the decoded result (see cvb.barcode.Symbology). More...
