Derived from ReadResult and gives specific access to Code39 and Code93 results. More...
Inherits ReadResult1D.
Properties | |
| full_ascii = property | |
| bool: Specifies the use of a full ASCII description of the code, only used with the Code 39 and the Code 93. | |
Properties inherited from ReadResult1D | |
| grade_result = property | |
| cvb.barcode.GradeResult1D: Barcode Read Result does not contain any valid grading results. | |
Properties inherited from ReadResult | |
| characters_read = property | |
| int: The return value contains the number of characters in the read barcode. | |
| decode_time = property | |
| int: The return value specifies the time consumed for decoding in units of ms. | |
| location = property | |
| List[cvb.Point2D]: Location of the barcode inside the image. | |
| num_words = property | |
| int: Contains the number of code words composing the read barcode. | |
| resolution = property | |
| float: The resolution specifies the smallest width unit in the code in multiples of a 10th of a pixel. | |
| int: Result of a read operation (note that read operations may partly succeed, which is not considered an error; see cvb.barcode.DecodeResult). | |
| text = property | |
| str: The text content of the barcode. | |
| type = property | |
| int: Symbology of the decoded result (see cvb.barcode.Symbology). More... | |
