CVBpy 15.1
BlobResult Class Reference
Container for a blob analysis result. More...
Properties
 bounding_box = property
 cvb.Rect: Bounding box of the blob.
 center = property
 cvb.Point2D: Position of the blob's center.
 maximum_moment = property
 float: Maximum inertial moment (smaller 2nd order moment translated into the blob's major/minor axis coordinate system) of the blob.
 minimum_moment = property
 float: Minimum inertial moment (smaller 2nd order moment translated into the blob's major/minor axis coordinate system) of the blob.
 minimum_moment_points = property
 List[cvb.Point2D]: Points where the major axis of the blob intersects with the blob's bounding box.
 moment_angle = property
 cvb.Angle: Angle between major moment axis and the x-axis.
 moment_ratio = property
 float: Ratio of the minimum moment and the maximum moment of this blob.
 size = property
 float: Size (area) of the blob in pixels.
 x = property
 float: Gets X-component of the blob center.
 y = property
 float: Gets Y-component of the blob center.
