CVBpy 15.1
AccessMode Class Reference
Access possibility of the node. More...
Static Public Attributes
int NotApplicable = 1
 Node is not available.
int NotAvailable = 1
int NotImplemented = 0
 Node is not implemented on this device.
int ReadOnly = 2
 Node can only be read.
int ReadWrite = 4
 Node can be read and written to.
int WriteOnly = 3
 Node can only be written to.
The access mode can change dependent on the device state.
Member Data Documentation
◆ NotApplicable
static
Node can become available when the state of the device changes.
Warnings
This enumerator will be deprecated in a future release. It is highly recommended to use cvb.AccessMode.NotAvaiable instead.
◆ NotAvailable
static
◆ NotImplemented
static
If the node is selected, it can be, that the node is only not implemented regarding the current selector(s) value(s)!
