Dimensions | 150 x 100 x 35.2 (w x l x h in mm) |
Power | 9 - 19 VDC |
Operating temperature | 0°C to +55°C |
Conformity | ROHS |
Module Support | NVIDIA Xavier NX NVIDIA TX2 NX NVIDIA Jetson Nano |
Accessories | heat sink, fan sink, power adapter |
Pin | Signal | Pin | Signal |
39 | GND | 40 | I2S0_SDOUT_LS |
37 | SPI1_MOSI_LS | 38 | I2S0_SDIN_LS |
35 | I2S0_LRCK_LS | 36 | UART1_CTS_LS |
33 | UART0_RTS | 34 | GND |
31 | GPIO11_LS | 32 | GPIO07_LS |
29 | not connected | 30 | GND |
27 | ID_I2C_SDA | 28 | ID_i2C_SCL |
25 | GND | 26 | SPI0_CS1_LS |
23 | SPI0_SCK_LS | 24 | SPI0_CS0_LS |
21 | SPI0_MISO_LS | 22 | SPI1_MISO_LS |
19 | SPI0_MOSI_LS | 20 | GND |
17 | 3V3 | 18 | SPI1_CS0_LS |
15 | GPIO12_LS | 16 | SPI1_CS1_LS |
13 | SPI1_SCK_LS | 14 | GND |
11 | UART1_RTS_LS | 12 | I2S0_SCLK_LS |
9 | GND | 10 | UART1_RXD_LS |
7 | GPIO09_LS | 8 | UART1_TXD_LS |
5 | I2C1_SCL | 6 | GND |
3 | I2C1_SDA | 4 | 5V0 |
1 | 3V3 | 2 | 5V0 |
On the back side of the Modular Embedded Carrier, 2x4 MIPI CSI lanes are available on a clip-on connector. To connect the MIPI CSI lanes to a camera through the usual ribbon cables you're going to need an adapter board. These can be ordered from STEMMER IMAGING (46021 AV AC CSI-2 NVIDIA JETSON TX2/XAVIER).
To avoid confusion: The adapter boards has originally been designed for Nvidia's development carrier for TX2 and the Xavier AGX systems (hence the product name...), but it will work out of the box with the STEMMER IMAGING Modular Embedded carrier.
