CVBpy 14.0
All Classes Namespaces Functions Variables Properties Pages
cvb/QmlStreamDisplay
1import os, sys
2import cvb
3import cvb.ui
4
5
6from PySide2.QtCore import QObject, QUrl
7from PySide2.QtQml import qmlRegisterType
8from PySide2.QtWidgets import QApplication, QWidget
9from PySide2.QtQuick import QQuickView, QQuickPaintedItem
10from PySide2.QtGui import QIcon
11
12
13
14if __name__ == "__main__":
15
16 app = QApplication([])
17 app.setOrganizationName('STEMMER IMAGING')
18 app.setOrganizationDomain('https://www.stemmer-imaging.com/')
19 app.setApplicationName('Display Python tutorial')
20
21 # tell Windows the correct AppUserModelID for this process (shows icon in the taskbar)
22 if sys.platform == 'win32':
23 import ctypes
24 myappid = u'stemmerimaging.commonvisionblox.pystreamdisplay.0'
25 ctypes.windll.shell32.SetCurrentProcessExplicitAppUserModelID(myappid)
26
27 app.setWindowIcon(QIcon('Tutorial-Python_32x32.png'))
28
29 # load the device
31 os.path.join(cvb.install_path(), "drivers", "CVMock.vin"),
32 cvb.AcquisitionStack.Vin)
33
34 # use a single stream handler to setup an acquisition thread and acquire images
35
36 handler = cvb.SingleStreamHandler(device.stream())
37 # create an image controller to interact with the UI
38 image_controller = cvb.ui.ImageController()
39
40 # register the display component with QML
42
43 # setup the QML UI
44 view = QQuickView()
45 view.setResizeMode(QQuickView.SizeRootObjectToView)
46 context = view.rootContext()
47 context.setContextProperty("mainImage", image_controller)
48 filepath = os.path.dirname(os.path.realpath(__file__))
49 view.setSource(QUrl.fromLocalFile(os.path.join(filepath,"main.qml")))
50 view.resize(640, 480)
51 view.show()
52
53
54 # register the device image with UI controller to trigger automatic refreshes
55 image_controller.refresh(device.device_image, cvb.ui.AutoRefresh.On)
56
57 # start the acquisition thread
58 handler.run()
59
60 # start the UI event handler
61 app.exec_()
62
63 # stop the acquisition after UI exits
64 handler.try_finish()
65
Opens a device with the given provider and acquisition stack.
Definition: __init__.py:1327
Handler object for a single stream.
Definition: __init__.py:4380
Controller object for the QML image view item.
Definition: __init__.py:14
Convenience method to register this type or a derived type in QML.
Definition: __init__.py:193
Common Vision Blox UI module for Python.
Directory Common Vision Blox has been installed to.
Definition: __init__.py:7146
1import QtQuick 2.0
2import CvbQuick 1.0 as CvbQuick
3
4
5Rectangle {
6 id: page
7 width: 320; height: 480
8 color: "lightgray"
9
10
11
12 CvbQuick.ImageView
13 {
14 id: view
15 anchors.fill : parent
16 image : mainImage
17 }
18
19 Text {
20 id: helloText
21 text: String(view.hoverPixel)
22 y: 30
23 anchors.horizontalCenter: page.horizontalCenter
24 font.pointSize: 24; font.bold: true
25 }
26}
