Setting up your system
<< Click to Display Table of Contents >>
Navigation:  Getting started with CVB tutorials >
This chapter describes, how to setup the tool chain under Windows as well as on Linux based systems.
The procedure is mostly similar, but differs in minor details as follows.
It was tested with
•Windows 10
•Ubuntu 16.04 LTS
•Ubuntu 18.04 LTS
CMake version (for details see Service):
•Minimal 3.5
Qt versions (for details see Service):
•Minimal 5.9.x
•Recommended 5.12.x or newer
Microsoft Visual Studio Compiler version (Windows only):
•Minimal Microsoft Visual Studio 15 VC14
Before you begin, install Common Vision Blox and ensure proper installation by starting one of the supplied sample applications.
On Windows system test your compiler environment by recompiling a source code of a supplied tutorials from %CVB%Tutorial directory.
